posted 06-16-2015 08:31 AM ET (US)
In the circumstances described in the narrative above, I do not believe the aural alarm and warning lamp annunciators are trying to give an indication of an actual alarm condition in the engine In the OMC SystemCheck alarm indicator and aural alert, the aural alert horn is operated by the System Check gauge. Generally the aural alert sounds in the same manner for all types of alarm indications. It is not necessary to interpret the meaning of the aural alert horn by analysis of its cadence of sounding. The annunciator lamps of the SystemCheck gauge give the meaning of the alarm.
Based on your narrative describing the manner in which the aural alert sounded and the four warning lamps of the SystemCheck gauge came on and illuminated in a stepping sequence across the display, the more reasonable explanation for this behavior is a momentary interruption in the power being supplied to the SystemCheck gauge. The events you describe as occurring are the same events that occur when power is first applied to the SystemCheck gauge. On that basis, my inference is there is an intermittent connection to the SystemCheck gauge.
The SystemCheck gauge is typically connected to the Johnson or Evinrude engine using a multi-pin connector that is part of the MWS wiring harness. Check the connections of the MWS harness, both at the SystemCheck gauge and at the engine, under the cowling, where the harness connectors to the engine wiring harness.
To check the electrical connections of any multi-pin electrical connector, follow this procedure
--disconnect the two electrical connectors from each other;
--make a close visual inspection of the connectors, looking for any indications of ingress of water that may have cause corrosion, any mechanical problems such as a bent pin or an enlarged socket, or poor latching of the mechanical tabs that retain the connectors;
--do not, under any circumstances, apply any sort of grease to any of the actual electrical contacts, no matter how often you read advice on the internet to do this;
--if there are any indications of corrosion, dirt, oxidation, or other signs the electrical connectors have been compromised, spray the electrical contacts with WD-40. WD-40 is a special solvent that has been designed to restore electrical connections. After spraying, shake the connectors to dislodge any surplus WD-40 that may remain on them.
--re-connect the electrical connectors of the MWS wiring harness to the SystemCheck gauge and the engine wiring harness; apply a very light coating of grease only to the rubber bellows of the front seal of the Deutsch multi-pin connector; do not apply any grease to the actual electrical contact pins or sockets or to the connector body.
Please perform the procedure I recommended above and reply with any observations and results.
