posted 07-15-2015 05:33 AM ET (US)
Butch,Seems that there are fewer and fewer who do their own trailer maintenance these days...
Last fall, I replaced an axle, brand new bearings in all six wheels and a new LED trailer light kit... This spring, I splurged and installed a new actuator and new disc brakes on my Venture trailer... The drum brakes were just about done...
Thought there was only a handful who use grease on lugs and nuts... Can't tell you how many times I've helped guys with frozen lug nuts on boat trailers and travel trailers on the side of the road because of frozen rusted lug nuts...
There are those that worry grease gremlins will magically loosen the lugs while running down the road...
I have always applied a small dab of grease to the studs... A properly tightened wheel with greased lugs will never give you grief when changing a rim and tire on the side of the road...
Norm
