| Author | Topic: Fasteners |
| sail16 |
I'm looking to purchase #10 x 1–1/2-inch oval head Phillips stainless wood screws. I have tried my usual sources (Hamilton, Jamestown, West Marine, McMaster) without success. Any leads would be appreciated. |
| acseatsri |
Stainless sheet metal screws are readily available just about any decent hardware store and should work fine instead of wood screws. |
| frontier |
Excellent fastener house on EBAY. Very good pricing and free shipping. Albanycountyfasteners. Current EBAY item number for your # 10 X 1 1/2 oval head SS is: 170990225325. |
| contender |
Fastenal.com |
| Etchase |
Had good luck here: https://www.boltdepot.com/Default.aspx |
| crabby |
fastenal |
Please give the fellow a direct link to the resource you are recommending. |
| ConB |
Check your local hardware store. Mine would have those. Con |
| sail16 |
Thanks for all the tips. Unfortunately, I'm no closer to finding exactly what I need. Is it possible that stainless #10 x 1-1/2" wood screws with oval phillips heads are no longer made? |
| kwik_wurk |
They exist, in fact I have a small jar of #10's at home; all bought from: All SS Oval Phillips, wood screws
| acseatsri |
I believe sail16 is looking for actual wood screws and NOT self-tapping or sheet metal screws. Wood screws are generally not threaded all the way to the head, hence my first comment that sheet metal screws (aka self-tapping screws) will work just fine as a replacement. |
| Binkster |
The screws described above are nothing more than sheet metal screws. If you are using a screw to screw something to a fiberglass hull, that is what you use. Wood screws are not used in fiberglass work. rich |
| padrefigure |
<https://www.fastenal.com/products/details/72836?r=~|categoryl1:"600000 Fasteners"|~ ~|categoryl2:"600051 Screws"|~ ~|categoryl3:"600071 Wood Screws"|~ ~|sattr02:^"Stainless Steel"$|~ ~|sattr03:^Oval$|~> I think this is what you are looking for. If the screw passes through the fiberglass skin into wood backing, use wood screws. Either use a tapered drill bit or use a larger bit through the skin and smaller in the backing. This will keep the fiberglass from cracking. Countersink the skin so all of the sealant does not get squeezed out. |
| sail16 |
Thanks for all the leads. From what I have seen, I can get most any combination of three of my four criteria, but not all four: 1 stainless Clearly all four criteria could be met in the past as I have an old fastener of that type in my hand, but none of us seem successful in finding a current fastener that fits those criteria. |
I tried several searches for your target fasteners. I could never get the OVAL HEAD criterion. If you could accept FLAT HEAD there are many sources. |
Here is a hyperlink that PADREFIGURE was trying to point to: |
