| Author | Topic: Changing Tire Size |
| floater88 |
I'm finding it difficult to find the same size tires and rims for my trailer. I currently have 215-75R14 Load Range C tires. I'm noticing squishing of the side walls when towing. Air pressure is set to just under maximum. I'd like to get some new tires as I am planning on some highway trips and these tires are from 1996. What other size |
| Jefecinco |
Tire Rack: Goodyear Marathons $85.58 for your exact replacement tire. Try a Bing search for several others. Butch |
While not an expert, I believe the tire size notation is as follows. For the example 215 75R14 the interpretation is 215 = width of tire 75 = profile of tire R = radial 14 = wheel size You can find fatter or thinner tires, such as 205 75R14 Or tires with a different profile, such as 205 70R14 Or tires with bias belts instead of radial belts 215 75D14 The size you presently have seems to be a very common size in boat trailer tires. My experience is that trailer tires are not kept in stock at local stores and often have to be ordered from a regional distributor by the local store. |
| contender |
jim is correct about the tire sizing, 215 width, 75 height, 14 rim size...If you want a taller tire try to fine something like a 225 80/85 R14...letters on the tires tell you that they aree a radial and look at the smaller letter for the load. I think trailer tires should be a c or d load.... |
| Marko888 |
I bought the Goodyear Marathons in 215/75 R14 C in 2013 and would suggest trying a different brand as I'm not that happy with them. They're made in China, run quite hot (in the PNW) and even when inflated to 50 psi there is a lot of sidewall flex and bounce. I've weighed my Outrage 18 and trailer and the total axle weight was 2750 pounds. They are cheap, but I got what I paid for. I will try a different brand next and will also go for load range D. |
| Jefecinco |
Due to their construction radial tires by design have more sidewall flex than do bias tires. Some think this is a good thing as it provides a softer ride to the load. I agree this can be a good thing as long as the tire rating is not exceeded. Goodyear Marathons tend to get mixed reviews. I personally change to radial LT (light truck) tires as soon as the first replacement set is due if my size requirement is available. My reasoning is that LT tires are superior in almost every respect to trailer tires. Butch |
| Ridge Runner |
I have had excellent results towing long distances (NJ to FL - 4 times a year) with Kumho Radial 875's. The are one of the only D load rated and 99 MHP speed rated tire. Kumho does not use the publish conventional profile sizing so you would have to measure the sidewall of your current tires. Here is the spec - The D load rating will have stiffer sidewalls. |
| floater88 |
Great info. I was thinking of going with truck tires as an upgrade because my trailer has only one axle and the Revenge 20 wt, with all my salmon tackle onboard including a 15 hp kicker and two batteies, adds up the weight. Thanks |
| EJO |
There are I think two good trailer parts and tire supply companies on the net that can fill your request from stock. An LT type will do fine. Radials have more side wall flex. Do you need the wall height and profile of 75? A lower profile height will automatically give you less flex. Most performance car tires don't have 75 profiles but more likely 60 or less. If you have not bought any tires, look at http://www.easternmarine.com/Heavy-Duty-LT-Truck-Trailer-Tires-Only/ or http://recstuff.com/14-Inch-Trailer-Tires.aspx Good luck. |
| deepwater |
What do you have on the trailer? |
I think my trailer has 14-inch radial tires. I can't recall the width and profile. |
| mb159 |
X 2 on the Goodyear Marathons.. just had to replace older tire that shredded a fender when it blew. Marathon is a steel belted tire that actually runs cooler than bias ply. VERY happy with them |
| Don SSDD |
215 is the width in MM 75 is the height of the rubber as a percentage of the width. 14 is the rim size in inches. Using those numbers, you can calculate the height of the tire by converting the 215 MM to inches= 8.46 x 0.75=6.345 inches (X2 for the tire height twice)= 12.69 inches + rim size 14= 26.69 inches. You can easily calculate the height of any tire using this math. You can set it up in excel and quickly calculate tire sizes for comparison purposes. Tire Height RIM Tread Width Aspect This is the excel formula where A is the solution, B rim, c tread width, and d the aspect ratio. =B2+(2*((C2*0.03937)*(D2*0.01))) I find 14 inch tires are getting very hard to find, you might be better going to a 15 inch rim and even raising the fenders a bit if you can do that. Since 14 inch tires are getting hard to find, you may also be buying a "new" tire that was made a couple of years ago. Buy from a high volume place, more likely to get a fresh tire. There is a date code on the sidewall of all tires, just google decoding those numbers. I would say more sidewall is good, more rubber to dissipate heat? More rubber to squirm when turning or cornering. Take a look at highway tractors and trailers, nice tall rubber and fairly narrow. With stiff sidewalls and high tire pressures, the LT tires would be good. I don't think the boat trailer tyre tires are very high quality. Don |
| n1ywb |
It's important for any pneumatic tire to flex somewhat so there is a "contact patch" between the road and the tire. If the tire didn't flex at all, then the only contact would be along an infinitely thin line and traction would be very low. Also shock absorption is one of the main reasons why pneumatic tries are so widely used. So it's normal to see a bit of a bulge |
| EJO |
Don made a point about buying new old tires. Read this article http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=11 and familiarize yourself with the code so you won't be taken. |
