posted 08-22-2015 12:27 PM ET (US) [In a prior discussion about a 1957 Johnson 3-HP outboard engine model JW12] the peak cylinder pressure was mentioned as being 60-PSI, and higher was ok. I have the same motor and the peak cylinder pressure is 50-PSI for each cylinder. Is that sufficient to warrant a full engine tune up?
Also, when I dismantled the lower unit, the drive shaft stayed in the power head rather than coming out with the gear case. Is that normal?
posted 08-22-2015 02:41 PM ET (US)
I would not worry too much about the reading your are getting for peak cylinder pressure in a test. The difference between a reading of 50-PSI and 60-PSI is not too great, and it could be due to factors such as the calibration of your gauge or the method of testing. You are asking about an outboard engine that is 58-years-old and only produces perhaps 2-HP by today's rating method. Take a chance with it. How many cylinders does that 3-HP engine have?
forest813
posted 08-23-2015 11:14 AM ET (US)
Thanks for your reply. It is 2 cylinder.
posted 08-23-2015 02:32 PM ET (US)
Rather than look for a particular absolute peak cylinder pressure reading, look for the match between the two cylinders. If the peak pressure measured in tests is similar between the two cylinders, typically not more than 10-PSI difference, then the engine is probably in good condition.
forest813
posted 08-24-2015 08:56 AM ET (US)
Thanks for your help.
forest813
posted 09-17-2015 10:23 PM ET (US)
I need to inspect and possibly change the impeller but I cannot separate the upper from the lower gear case after removing the 4 gear case bolts. Am I missing anything? What do you suggest I do? Usually the drive shaft just slides away from the power head.
posted 09-18-2015 09:40 AM ET (US)
Metal components that have been fastened together for 58-years may require some persuasion to become unattached. I suggest use of a solvent formulated to release stuck metal parts.
