ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance is it possible to install jackplate on the 13'
Author | Topic: is it possible to install jackplate on the 13' |
willyjoe1 |
posted 02-15-2001 08:55 AM ET (US)
i have a 98 40 hp yamaha with p t/t "about 200lbs"on my 86 bw 13', but the motor is set lower in the water than my older motor,is it possible to install a cmc 5"vertical extension"14lbs" or manual jackplate with 5"set back "32lbs" so i can in shallow water, please give me some thoughts, thanks |
awares |
posted 02-15-2001 09:35 PM ET (US)
If that is possible that could help me resolve the issue about only using a 15" short shaft motor on my 1968 13'Whaler. I never thought about using a jack plate so that I could use a 20" shaft motor with power tilt and trim options. I'm sure somebody has done that we just need the feed back from the Whaler crowd. Great question. |
posted 02-15-2001 11:28 PM ET (US)
Larry Goltz and I have been working on a comprehensive article about jackplates, which will appear this weekend. I think you will find it interesting. Also, look at CETACEA Page 28. |
willyjoe1 |
posted 02-16-2001 02:12 AM ET (US)
jimh thank you, that pictures in the cetecea really open up my eyes, that mean is possitble to put the jackplate on the 13', but i wonder what kind of the jackplate mr. Roberts using, and how much the weight of it? because his motor is lighter weight than mine,he really did a good jobs on his boats,i can't wait to see your aticle, thanks again william |
hardensheetmetal |
posted 02-19-2001 12:05 AM ET (US)
Thought this may be of some interest under this topic http://images.traderonline.com/img/6/dealer/759036/6082920_3.jpg |
awares |
posted 02-19-2001 09:45 PM ET (US)
Hardensteel, Nice picture! Where can I get one of those jack plates? Thanks,awares |
hardensheetmetal |
posted 02-19-2001 10:53 PM ET (US)
Awares- Sorry, I only knew where the picture was, it is on a 13 sport that has been for sale on boattraderonline for quite some time. You might give the guy (I think it is a dealer) a call and see if he can get a manufacturers name off the bracket. Dan Harden |
MikeC |
posted 02-20-2001 06:40 AM ET (US)
Check out the new West Marine catalogue,They have a bracket made for installing a 20 ich motor on a 15in transom.I think it was 89.00 |
posted 02-25-2001 11:47 PM ET (US)
I think the engine mounting bracket you are seeing is one made by T&H Marine. It is not a "jackplate" in that there is no vertical adjustment. The setback is minimal, but it does look like just the solution for using a 20-inch shaft outboard on a boat with a 15-inch transom height. --jimh |
