posted 07-15-2001 09:51 AM ET (US)
With trailerable boats, there is a definite correlation between likelihood of using the boat and ease of launching and recovery from/to trailer.When the boat and trailer are well set up, you can launch and recover without hassles. Making this process as simple and easy as possible will greatly increase your tendency to "throw" the boat in the water and go for a spin.
Also, the more your set up is adaptable to different styles of ramps and different slopes and depths of water, the greater will be the opportunity to use your boat.
Although there is somewhat of a religious schism on this issue, I think that a keel roller trailer offers the best approach.
The trailer needs:
--plenty of rollers--two at each crossmemeber and at least four crossmembers;
--premium rollers (Stoltz) and well-greased axles (stainless steel preferred);
--side guides to help hold boat in position in a cross wind;
--winch with power and ratio suitable to haul boat. Two speed winches for heavier boats.
With this type of set up you can launch and recover at any type of ramp, from shallow to deep, you won't have to get your feet wet,
and you won't need to "power load" (which is a prohibited practice at most ramps in our area).
