posted 03-18-2002 10:28 PM ET (US)
NickI know, spending way too much effort to save a hundred bucks...
I'm 99.9% sure my helm is fine. Cables are probably corroded due to late fall saltwater use. Yes I rinsed but probably not enough. Bass Pro says no cables available to fit my old helm. (78 montauk, factory helm).
Looking through West catalog, the only helms I see that resemble mine are the Big-T Rotary and the Safe-T rotary (pages 379 and 369, respectively). Not sure which I have. I know mine has the plastic tube coming out of it on one side and is made of what my pop used to call "pot" metal.
On page 369, the book shows QCII cables which fit both of the helms mentioned above. West says that the cables fit "old style (ie threaded) Safe-T, Big T etc..." and includes an adapter to fit older teleflex rotary helms.
Do you have any idea if this is what I need based on the info I have been able to provide? The 18' cable runs 143.99. Figure if all they have to do is run it through the tunnel and screw it on, It shouldn't take more than an hour labor and I get to go to the water this weekend.
Chris.
