| Author | Topic: Hi-Range Repowering |
Continuing the listing I started with mid-range horsepower engines, I have just added a new REFERENCE article on Hi-Range Repowering. This lists engines in the 130-250 HP range which are available in model year 2002. See http://continuouswave.com/whaler/reference/hiRangeRepower.html . |
| John W |
You list the weight of the Honda 130 at 458 lbs...I thought that motor weighed 500+lbs. Have they changed the motor to reduce weight? |
| Bigshot |
25" shaft is 505lbs. OOOOOWEEEEE! |
I don't have a brochure for every engine, so I have relied on some third-party sources. If someone can cite a factory brochure weight or other statistic that is at odds with what I have listed I would appreciate notice of it; I'll be glad to emend the listing. Thanks! --jimh |
