Topic: 13' whaler speed question...
blag |
posted 08-24-2002 07:42 PM ET (US)
I have a 13' GLS with a 30 hp mecury motor on it, but it just crawls with 3 people in it. The RPM reading is only 3100 though the motor is rated to 5500. Sorry I must confess to being a newbie. Is this a problem with the motor not getting enough gas, a bad tachometer reading, or the prop which has a few dings in it.
JBCornwell
posted 08-24-2002 07:59 PM ET (US)
Howdy, Blag.It could be any of the problems you listed or a combination of two or more of them. Most likely is your engine has dropped a cylinder. How does it perform with one person? Red sky at night. . . JB :) |
blag
posted 08-24-2002 08:06 PM ET (US)
It actually seemed to perform great even with one person, but with 3 - 4 people it barely creates a wake. I didn't take it out again by myself to see if it was the load, or if something had gone wrong since I was last out. I imagine the load of 3 was roughly 500 lbs. |
Jerry Townsend
posted 08-24-2002 10:40 PM ET (US)
Blag - I had a 13 with a 25 on it and with 2-3 good sized people, it would plane, albeit it might be a tad slow in getting up on plane. I suspect that your prop may be the wrong size/pitch or your trim is not set properly. You might consider experimenting with the engine trim. It might also help getting on plane if one or more adults move aft a bit until it comes up on plane. ----- Jerry/Idaho |
Clark Roberts
posted 08-25-2002 08:04 AM ET (US)
B, check out the prop first! Sounds like severe "overpropping" (pitch too high)!!?? If so, this lugging can damage engine! Happy Whalin'/// Clark... Spruce Creek Navy |
skred
posted 08-26-2002 09:31 AM ET (US)
I owned a 1989 13 sport bought new with a 30 Yamaha. With myself (210 lbs) passenger (125 lbs), I could pull a 165 lb skier up and tow him around effectively It sounds like either a motor problem, or prop. The difference is so dramatic with light and heavy loads, I suspect something's awry with the engine itself. |
