ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Whaler 31 Re-Power
Author | Topic: Whaler 31 Re-Power |
trophyfish1958 |
posted 02-23-2004 08:52 PM ET (US)
Re: re-powering a WHALER 31, made in the late eighties for a few years. I am thinking about purchasing one that had gas power and changing over to diesel. Any idea what kind of mileage the diesel-powered boat got? Thanks |
posted 02-24-2004 11:59 PM ET (US)
You ought to read what Pascoe has to say about diesel vs gasoline engines. |
phonejones |
posted 01-14-2006 01:33 PM ET (US)
I am currently repowering with two Marine Max diesels. They are based on the [AM General] Hummer block and are direct drop ins for replacing GM 350 or 454 gassers. They develop 275-HP with around 450-FT-LBS torque at low end. Currently I have 7.4-liter fuel injected Crusaders. I should improve performance at crusing with larger props, 20x23, as well as cut fuel consumption fifty perecent. |
posted 01-15-2006 11:10 AM ET (US)
Sounds like you have these engines: http://www.amgeneral.com/vehicles_gep_productinfo.php/amSid/ 53d85bcea5a8ae182d2ebb154f259a13 |
frostbite |
posted 01-22-2006 06:35 PM ET (US)
After reading Pascoe's myths about diesel engines, I must say that I disagree with him on all points. I find the information that Pascoe has provided is misleading, at best. |
nytugcapt |
posted 01-23-2006 12:09 PM ET (US)
Frostbite is right on. That article is full of misinformation. It would be a shame for anyone considering a repower to think that is an accurate comparison. |
The Judge |
posted 01-23-2006 01:54 PM ET (US)
My main question is this: If I buy a new Dodge pickup with a cummins diesel it is a $4500 option. Why does that SAME engine "marinized" cost $40,000 as an option? There CAN'T be $35,000 in upgrades. |
COINJAM |
posted 01-24-2006 08:26 AM ET (US)
The 89"s came with Cummins 250's - - not enough power..The 300's will give you all the speed you need and consumption of about 1.5 miles to the gallon @2250 rpm.. You'll cruise at 24 knots all day long.....a little noisy, but, you'll have a great boat..good luck |
crashq |
posted 01-28-2006 04:00 AM ET (US)
Could you guys elaborate a little on the specifics of why you disagree with the article? It would be enlightening. Thakns. |
frostbite |
posted 01-28-2006 09:39 AM ET (US)
crashq, Pascoe makes blanket statements and qualifies the statements with bits of fact that aren't always relevant. Myth #1-Diesel is safer than gas. Myth #2,4,5, Essentially the same Myth #3 Diesels are more economical. In real life I don't think you will find many people yanking their diesel engines to replace them with gasoline powered ones. Thats my slanted view chief, we welcome yours. |
