posted 06-01-2004 03:53 PM ET (US)
I am new to this propping so take my stats for what they are worth. This is just data not advice.I am propping my 2000 18 Dauntless which has a 125 Merc. I have two props I have narrowed it down to...both are a Michigan Wheel Rapture SS with vent holes. One is a 17 inch pitch and the other is a 19 inch pitch. The operating range on mine is 4750-5250 with a redline of 5500 rpm and max hp at 4900.
17 pitch 19 pitch
4000 rpm= 27 mph 4000 rpm=28.5 mph (gps)
WOT 5250-5400=38-40 mph WOT 4800-4950=40.6 mph
The economy cruise range is 4000-4300 per Mercury and the 17 hits 30 mph at 4300 and the 19 is going 33 at 4300. I want economy cruise and top end and it takes a lot of rpms to get the 17 to 38 mph and on a good day to 40. The 19 p has nearly as good of a holeshot, accelerates fine, cruises faster at lower rpms and snaps up to 40 quicker and quieter. My next test is to load 3 more people and 30 more gallons and retest both.
Many of us have found the Mercury prop guide to be way off. It recommended a 21 or 22p for mine. I really need and 18 but MW doesn't make one and I have bought through them and will be fine with either 17 or 19 I believe.
I am learning propping is a science but there are many opinions. Some camps advise me to use the 19 and the motor is not lugging and others say it is lugging and will rapidly destroy the motor. Seek Whaler factory rep advice, motor manufacturer and prop shop.
Good luck.
