posted 06-10-2004 09:53 AM ET (US)
I don't think anyone can really say and it really depends on the wind speed. If you are heading into a strong wind at high speed, you should be careful. I would think in normal hull to water attitude you are probably ok, but if you were to hit a wave and get most of the hull airborne at the same time a high velocity wind gust hit, it could be a problem. Remember that the force of the wind increases with the square of the wind speed. For example, the force of the wind against your surface area at 20mph of windspeed is 4X more than at 10mph. So, if you are going 20mph and you get hit by a 60mph gust (from 0 0mph wind speed before), you are travelling in a 'wind' of 80mph. That is 4X the wind speed of before and 16X the force from your boat just going 20mph in calm winds.
I would think that if you are flat to the water, you would be ok but if you had hit a wave, then you would have a problem. The problem is going to come if you are going really fast in flat water, you hit a boat wake or something at the same time that a very high speed gust hits.
All that being said, if you are able to go 20mph in those kinds of conditions, you have a stronger constitution than I. It is highly unlikely sea conditions would permit it. You also have all sort of other visual clues on the weather and approaching winds (plus you should seek out local knowledge). So, you should operate your boat cautiously in those conditions.
I have a Daunteless 15 and I have operated it in 50mph winds with no problems. However, the sea state on my body of water precluded the application of much throttle at all. Certainly not planing in wind driven chop at 50mph. If I had been hit by a 70mph gust I am sure that I would have been ok.
So, I wouldn't worry about it too much but you should operate your boat carefully anytime you anticpate sudden extreme weather events. Mother Nature has a nasty way of surprising you.
J
