| Author | Topic: E-TEC 90-HP First Impressions |
| Clark Roberts |
Yesterday I piloted a friend's 17 Outrage with his new 90 E-TEC. The engine was mounted as low as possible (anti-cav plate about 1 1/2" above keel) and swinging a Solas stainless 15" pitch prop; no water in live well and fuel tank almost empty. Starting the new engine was instant with just a key turn and idle was smooth and very, very quiet (as quiet as my 115 Merc four-stroke) and acceleration was fierce. Owner said that it was quicker out of the hole than the 115 V4 Evinrude it replaced. Top speed, with just me aboard (190-lbs.), at 5500-RPM trimmed out was 35-MPH (per GPS). I haven't figured out the theoretical top speed yet because I don't know the weight of that hull. Bottom line: I'm very impressed with the engine's fit and finish, size, quietness (quieter at top speed also than my four-stroke), and low end power. Happy Whalin'...Clark...Spruce Creek Navy |
| JayR |
That is a great first hand report. I am hoping to purchase an E-TEC in the 135 to 150 HP range when they are made available. Good thing I passed on that Suzuki 140-HP four-stroke last fall. This E-TEC really has me excited. Can't wait! |
Given Clark's extensive experience with outboard motors, this is an excellent endorsement for the E-TEC. |
| David Jenkins |
Clark, thanks for the report! Two questions: Do you mean the engine was mounted as high as possible, or do you really mean as low as possibe? I would have thought that engine would take a 17" pitch prop on a 17' Outrage. When you hit 5500 RPM, were you dead rack or were you just reluctant to push the new engine more than that? |
| Clark Roberts |
David, the engine was mounted as LOW on transom as possible (C brackets resting on transom)...it could be raised a couple of inches but not lowered any. This is a very deep V hull and V carries all the way to stern. The previous engine was a 115 cross flow/90degree that bit the bullet for some reason and seized. The 115 twisted a 17" pitch SS prop (I don't know the make/model) and my buddy said it ran 44mph top speed (measured on same GPS). He may be able to get better top end somehow but I was flat out and trimmed to optimum. Also note that gas tank was virtually empty! This engine does not require any break-in but I suspect that after a few hours it will crank and idle better (if that's possible!) and may pick up a little speed. The Solas prop is a thick, wide blade design and from the looks of it would be more suited to a workboat. A Mercury Laser II 15" or 17" might light a fire under that rig but I haven't stuck my nose into the prop selection (imagine that!) but will make some suggestions if asked. Also it was a hot 80+ degree day and most likely would be faster on a cooler day. It's great to have the opportunity to run a brand new engine and wish you had all been there! Happy Whalin'...Clark |
| LHG |
Clark - Merc Laser II props for the 4-1/4" gearcase begin at 20" pitch. In 17" pitch, the 4 bladed Trophy is the only performance model available. Incidentally, for GREAT prices on brand new Merc props, search out "Buddy's Wholesale Props" on Ebay. These are the best I've ever seen. As the world's expert on getting a Merc 2 stroke 90 to run, how would compare these same weight engines, in both performance and sound? |
| ratherwhalering |
Clark, I have a 15-inch Stiletto on my Montauk/E-TEC 90 rig. 5500 RPM produces a steady 42MPH. I tried the 17-inch Stiletto first, but was a bit over-propped. The 15-inch seems to be a great match. I have had the E-TEC for about 10 months now (I bought #7 off the assembly line) and it has settled in wonderfully. I believe it is getting quieter, and objectively, it is running alot smoother than when I first got it. Overall I am very pleased with its performance and fuel consumption. |
| Clark Roberts |
Larry, maybe a Stiletto 15" or 17", like rather on his Montauk, would be a better match for this rig. I tried a Solas 15" on my 21 Revenge ... it was a dog and I finally setteled on a Stiletto 15". You are the prop expert and know more than most about how critical the prop choice is to performance and economy. I expect that with a few more hours and a different prop that the 17 Outrage may hit high 30's and maybe break the 40mph barrier. Will let you know! As to comparing the 90 E-TEK to the 90 Merc 2s I can say that the E-TEC starts easier, idles smoother and is quieter but on performance it would be close. Based on my many hours with many 90 (71 and 84 cubic models) hp Mercs I would say that the Merc would have an edge especially in top speed. However, the jury is out on E-TEC and it may equal or surpass the Merc's performance. I will let you all know how it goes when I get my hands on it again! happy Whalin'... clark... Spruce Creek Navy |
| JohnJ80 |
Clark, I think if the E-TEC engines are like the FICHT ones, after the first 10 hours, the computer cuts down on oil and changes some of the engine timing. I noticed on mine, a lot more torque and a lot less oil usage after that time. I would bet they did something similar in the E-TEC. My FICHT also says that there is no breakin after the first hour or so other than they asked you to vary the engine speed. But there really is a breakin and it is controlled by the computer. J |
| PeteB |
I just had my new E-TEC installed on the Montauk late November and took it to Florida over Christmas. It had about 2 hrs on it before the trip. I had it re-mapped to the XD-100 oil from the beginning. The first 2 hrs of use there was a rough idle that other people have noticed @1500-2000 rpm's. I'm guessing there is break-in oil even though the manual doesn't say. After 15-20 hrs of use in Florida, it operates really smoothly. It's no way as quiet as a 4 stroke at idle though at WOT its very smooth and I believe it to be quieter. Throttle response and gas economy is unbelievable and as others have said, it starts faster than a car. I'm running a 17" alum prop and topped out at 5200 rpm's w/3 men and choppy seas. The winterizing procedure is so easy, its a joke. It's a geat match for my boat. |
| fourdfish |
Clark Thanks for the observations. Good to see others checking out the E-TEC. I bought my 200hp E-TEC in Oct. My observations are the same as yours(impressive). My mechanic uped the oil output for the first 20hrs. He said the computer holds down the rpms during the breakin period and gradually opens up to a top of 6200rpms. It doesn't have the hrs yet so I'll wait and report after 25hrs or so. Till then good boating. Fourdfish |
| rehenderson |
Clark: The local E-TEC dealer is telling me I would get great perfomance on my 22' Revenge from a pair of the E-TEC 90's. Any thoughts after your first hand observations? |
| Clark Roberts |
Henderson, horsepower is horsepower and it doesn't matter what the source. However different engine designs produce different characteristics in how it's delivered ie. the E-tec seems to deliver tremendous torque at low rpm while some other engines have more torque higher up the scale...etc, etc. Figure the gross weight of your 22 Revenge including engines, fuel, passengers, gear etc, and use the formula for theoretical top speed in the reference section of this forum and this will give you a good idea of max top speed with 180hp (I suggest using a hull constant of 180 as 200 may be optimistic). Others may have actual experience with a 22 Revenge with approx 180 total hp. Happy Whalin'... Clark... Spruce Creek Navy PS> I noticed in the brochure that the 90 E-TEC 20" shaft comes with a 2:1 gear ratio and the 25" shaft has a 2.35:1 (I think it's 2.35 but can't remember exactly)...interesting! |
| seahorse |
Hi Clark, The 25" shaft 90 E-TEC comes with a V6 gearcase. It is possible to bolt a counter-rotation g'case on it for twin applications, plus all the advantages of a larger diameter prop for heavier boats. |
| Peter |
Specifications show the 25 inch model turns the propeller through a 2.25:1 gear ratio. I think the Outrage 17 uses a 25 inch shaft and would explain why the observed speed of 35 MPH with a 15 inch pitch propeller in your test report is less than the 42-43 MPH reported for the E-TEC 90 equipped Montauk (20 inch shaft length) achieved with a 15 inch pitch propeller. REH: Having had a Revenge 22 for several years and talking 2-strokes only here, I think a properly powered Revenge is one with a minimum of 200 HP coming from a minimum of 3.0L of displacement. This will ensure that the RPM of the motor(s) falls right into the middle of the efficient zone (usually 3000 to 4000 RPM) at the comfortable cruise speed (25 to 30 MPH). As much as I like what I see in and read about the E-TEC 90, I think a pair of E-TEC 90s on a Revenge 22 will probably be a little light on power for it. The combined displacement of these is the same as BRP's 60 degree V6 135, 150 and 175 HP motors. While I think a 175 is also on the light side for Revenge 22 power, you'd probably be better off with the single 175 rather than the two 90s because there would be less gearcase drag to overcome with essentially the same horsepower pushing the transom. Also, you'd be getting 175 HP from 425 lbs on the transom instead 180 HP from approximately 650 lbs on the transom. It looks like the E-TEC 90 could easily be a top engine choice for a classic Montauk repower. |
| LHG |
At the Evinrude test center in Waukegan IL, I recently observed, out of the water, an ORANGE hulled 22 Outrage/Guardian, which appears to be company owned, with a pair of blue 20" E-TEC 90's on it. |
| rumrunner |
Just returned from the local Evinrude dealer. I'm sold on the E-TEC, but am having difficulty deciding between the 75hp or 90 hp (for a Montauk). With a difference of "only" $600, I'm leaning towards the 90hp. But I'm wondering if that 15 hp differential is all that noticable. I currently have a 1986 Evinrude 90hp. Any feedback appreciated. |
| seahorse |
Rumrunner, Get the 90hp E-TEC. You will not be sorry. No boater ever complained of having too much power. |
| LHG |
I've got to tell you, seahorse, with an 18' Boston Whaler Outrage, powered 18 years ago (when I was a lot younger), with twin in-line 6 Merc 115's, I'm just about at that threshold!!! |
| seahorse |
LHG, Now that had to be a RIDE !!!!!! |
| crabby |
Having recently repowered my Montauk with a 90 E-TEC hoping for a good increase in speed over my old three cylinder 70hp, I would strongly recommend spending the extra bucks. The 90 E-TEC is not significantly faster than the old 70 but it does have lots of low end power. And go with a 15 inch Stiletto prop (what I am currently running) or a 17 inch SST from Evinrude. |
| Joe Kriz |
rumrunner, I agree with crabby. The weight of the E-TEC 75 Hp and the 90 Hp are the same. 320 lbs. Why not get more HP for the same weight. Here is the ratio on lbs to HP.. E-Tec 75 = 4.26 lb/HP E-Tec 90 = 3.55 lb/HP Also, in the 90 Hp model, you have a choice of two colors.. Dark Blue or White. In the 75 Hp model, you can only get Dark Blue. (If this matters to you). Also, when you go to the E-TEC 90-HP page, you need to click on the E90DSL model to view the 20 inch shaft version. http://www.evinrude.com/en-US/E-Tec/2005/SALTWATER/90.IN-LINE.3/ The other model, E90DPX is the 25 inch shaft model and weighs 6 pounds more at 326 lbs. |
| rehenderson |
Thanks for the various responses. I agree that 200-HP is the base for a Revenge- but with the 10% variance in horsepower ratings I read about, I thought the two 90's might actually be cranking closer to 200. |
| fairdeal2u |
Hello Crabby. I also have a Montauk with a original (1987) 70 Johnson and am considering the E-TEC 90. You said that the new motor is no signicantly faster. Hmmm
At 5,000 rpms on a perfectly flat greasy day I would say I get around an honest 30 mph. Also, what do you think your gas mileage is on average? Do you think that the E-TEC has twice as much gas mileage? They advertise around 8-MPG. Thanks, |
| newport jack |
Joe, sounds like the 90-HP Saltwater is the way to go, weighs the same as the 75-HP but comes in white with stainless, steering arm, shafts and tubes. The E-TEC's are the way I'm leaning for my next repower, I have twin 70-HP Yammies right now, and might as well go to the twin 90's if there is no weight penanlty and to get the salty version. My engines are running strong and I think it would be areal tough sell, but maybe my motors are worth a buck or two for resale....thanx for the posting, 320 lbs. doesn't sound too bad for the weight!!....Jack |
[Administrative post] |
| jimbob28 |
Hi Fairdeal2u, I also have a 90 E-TEC on a 1977 Montauk replacing a 1977 70 Hp. Johnson. With my old 70, the boat would run about 30 mph at wot. I only have about 25 hours on the new engine and have not had smooth conditions to see really how fast it will go but I have had it up to 38 mph in a short burst on water too rough to really get it trimmed out. (These are gps measurements) Fuel milage is good but not twice as good as the old 70. It is probably about a 30% improvement. You have to remember that you are also increasing the horsepower considerably since the old engine was rated at the power head. The E-TEC is everything that Evenrude claims. It is very quiet even at cruising speeds and it has incredible acceleration. You better be holding on to something when you push the throttle in. Living in California, I had to get a CARB approved engine. The weight of the 4 strokes really concerned me. Then I learned about the E-TEC’s. In addition to their lighter weight, I really liked the feature that it can be rope started and run even if the battery is dead. The facts that it doesn’t require oil changes, valve adjustments, and belt replacements are also big pluses. I am concerned about the cutting edge technology and the strength of Bombardier and if I could have held off a couple of years before making the purchase, I would have. |
| fairdeal2u |
hello jimbob Thanks for the info. Did you mount the motor yourself/ What brand and size prop did you decide on? Do you have any idea of the hours that you put on the old 70? Thanks again. |
| Peter |
When comparing to the tried and true 3 cylinder 70 Johnson/Evinrude, keep in mind that the 70 displaced something like 49 cubic inches and the 90 E-TEC displaces 79 cubic inches. Thus, the 90 E-TEC is a much bigger motor and should have a lot more push. Evinrude's E-TEC website has a couple of peformance reports for the E-TEC 90. The reports suggest a maximum fuel consumption rate less than 8.5 GPH at WOT. At 42 MPH, as has been reported here for a 90 E-TEC powered Montauk, that works out to almost 5 MPG at WOT! At slow trolling speeds, Evinrude's data is showing mileage greater than 13 MPG! This is where a direct injected motor really shines compared to the conventional 2-stroke. Based on the Evinrude data given for a boat heavier than the Montauk, I think you can expect a cruise efficiency in the neighborhood of at least 6 MPG for the Montauk. With 20 gallons on board, that motor should give the classic Montauk a range of better than 90 miles without exhausting all the fuel in the tank. As I've said before, on technical merits, I think this might be the top candidate for a Montauk repower. |
| fairdeal2u |
Thanks for the info. 5mpg at WOT isn't much better than what the old 70does already. Doesnt sound right. When trolling for tuna at around 6 -7 mph what will the etec get? Maybe that is where the extra power will really come in on the gas savings. |
| jimbob28 |
Hello fairdeal2u, I purchased my engine from a local dealer and he did the installation. It was mounted directly on the transom using the same holes that the old 70 had used. The dealer had thought that the blind holes were still provided but he was mistaken, so he had them drilled out and used that spiral stainless steel material that is used to improvise threads and lag bolts. The prop is a SS, 3-bladed Evenrude Viper 13.?? dia. X 17" pitch. The prop was chosen using a comparable sized aluminum prop and making sure that at wot that it ran within the operating rpm range. I am not overly concerned with maximum possible speed as I seldom operate in water where I can run that fast and I don’t need to win races. I wanted more power for the large Pacific Ocean swells and for a few years from now when my grand kids want to water ski. The 70 was somewhat under powered for both. I figure that the 70 had over 3000 hours on it and was still running strong but it was seeping a lot of salt out of the edges of gaskets and I was worried about its reliability for running off shore. As far as your last comment, I would say that it gets at least 8 mph more speed at wot and maybe more. The other thing is the physics that says that speed increases proportional to the square of the increase in horsepower. |
| fairdeal2u |
Thanks Jimbob You must have taken care of your motor well to get 3000 hours out of it. I was guessing that right around 2000 hours would be the average life of the motors. Good to hear that since I only have 900 hours on my 70. Even though I fish a lot we don't put many hours in per day when mooching for salmon or fishing for rockcod. The few days that weather allows for tuna and for tuna to be close enough to get to are rather limited. Guess I will have to wait a bit to justify the need to repower. At this point I am leaning more toward trading up to the 18 foot outrage. After going through the evinrude site and reading their test reports, it seems like the best average mileage for the 90 on a 1000 pound boat is between 6 and 7 mpg while cruising at 3500 to 4000 rpms at a speed around 25 mph. For my old 70 it would be more like somewhere between 4 and 5 I will have to go a see if there is a boat test for the honda 90 to compare the mileage. |
| ratherwhalering |
I installed a E-TEC 90, saltwater edition, in March(ish) of last year. Jimbob is correct, it does not come with blind hole mounts. I installed CMC set back brackets, using the 1987 17-Montauk's blind holes. It replaced a Johnson 90. Frankly, the fuel consumption is so good, I just don't bother to record useage. With a 27 gallon tank, I'd have to be a knuckelhead to run out of gas. The engine was fairly easy to install, although I did mount the set back brackets, replace the control box, key switch, wiring harness, instruments, and cables prior to receiving the engine. Connecting the instruments and the engine to the wiring harness was pretty darn simple. I figured that installing the engine myself paid for these. Before turning the key, I had my local dealer check the install, adjust the linkage, and change the oil setting to XD100. All in all it took about 18 hours to install everything, including a couple of attempts at wiring the tachometer, and eventually re-replacing all the new Faria gauges with OMC instruments. (I was getting sporatic RPM readings.) |
| fairdeal2u |
Thanks, Great info. How much did it cost for the controls and wiring? What motor did you replace? How many hours did you get out of the old motor? What was the total costs to replace everything plus the charges to do the settings? Thanks again for all of the info. |
| ratherwhalering |
I got most of the components off e-bay. I'm estimating around $500.00 for everything in my last post. In addition, the Set Back Brackets were $155.00 (Wests) The old engine was a 1987 Johnson 90, that came used with the boat, so I don't know how many hours it had on it. The install check, linkage adjustment, and EMC upgrade was $127.00 |
| fairdeal2u |
hello So, the total costs would be around 7500.00 Start to finish |
| crabby |
Fairdeal2u: I had a 1986 Evinrude 70 on the Montauk; this motor was rated at the prop and ran to 6000rpm's (it has more displacement than older three cylinder motors and a lower gear ratio). Swinging a 17inch SST prop I used to get up to 38 mph in favorable conditions (that was by gps when the motor was still running strong). With the new 90 I have had it up to 42 mph with a 19 inch SST prop, 41 with a 17 inch SST, and 41 with a 15 inch Stiletto. The 19 has a lot of bite but I did notice some "sootiness" in the hub when I swapped it out for the 15. The 19 would only rev to 5200 or so rpm's, while the 15 will go to max rated. The 17 would also max out but I traded for the 19 hoping to get a few more MPH but it didn't work out that way and I got a great deal on the 15 so that is what I am running right now. As for fuel consumption, well, due to some initial problems I had with the 90 e-tec I never got to do a lot of my regular fishing runs this past fall so it's a little hard to say but I would estimate that where I used to need 9 gallons of gas to make a run to the inlet and back, I would guess that I was using about 6 or 7 at the most. This is a 40 minute run in both directions, actually a little less than 40 minutes with the new motor. Nowadays I have just been running around the bay out to the marshes or over to the ocean beaches mostly at WOT so I know I am burning more fuel than I would if I were trying to be thrifty and backing down on the revs. If you search the various threads on these forums you will see some of my posts detailing my setup but in simple terms the motor is mounted directly on the transom two holes up. Total cost including NYS taxes, SST prop, no extra warrantee, no controls, and dealer installation was about $9200 (I purchased this motor at the end of the summer when I was panicking that my 70 was giving up the ghost; I know I really paid a premium but I could not stand the thought of missing the looming fall season...). I could have handled rigging the motor myself but was a bit put off by the computer setup stuff and figured it was better to establish a full relationship with a good service shop/dealer rather than walking in cold to someone and saying "hey can you help me with my new motor I just bought elsewhere...". (When I put the '86 70 on my boat I did all the rigging and never really had any problems with it that I needed a dealer for throughout most of it's life, and it is still going to go on something else this summer, maybe my old houseboat!) In this particular set of circumstances I did the right thing for once in my life as I did need warrantee work. The 90 E-TEC seems like a good motor. I wish it was faster but I think I did the right thing by not dropping a leftover 115 on the boat even though I would have had a rocket ship then. Good luck to you. |
| crabby |
I forgot that I needed a new system-check tach and key switch when I replaced the motor, that is incuded in the price I gave above. A breakdown of prices that I paid would be about $7250 for motor, $1153 parts and labor, $735 tax. You could likely save at least $1000 on motor alone and if you shop hard for parts you could do better than I did. I heard rumours that there was going to be another factory warrantee of 6 years offered this winter like ratherwhaling has on his motor, I only got three and will need to spend another $600 to get three more. |
| fairdeal2u |
Thanks for all of the honest numbers. Developing a rapoire with the service people can payoff in the long run as in your case. Something to definetyly consider. Your early efforts are also paying off in helping lots of folks on this forum.. Thanks again. |
| PeteB |
I paid $8K which includes alum prop, controls, key switch, system check tach, installation, 6% sales tax. |
| hauptjm |
How nice it is to read a thread regarding E-TEC and the possibility it may be a fine engine. With E-TECs and Verados coming onto to the scene, we may have some great choices in our future. This sure beats reading about failed Optimax, Ficht and HPDI technologies. And it sure as hell beats reading about dumping. |
| The Judge |
I am in love with the e-tec 225 for my boat(one day). What a beast and 8gph at cruise is about a 40% improvement over my 94 225 Johnson(13+). When it comes time to repower I will certainly buy either the E-tec or the Johnson 4 stroke and it really would depend on price difference because like Clark said...Hp is Hp just depends on how fast you need to get going. Now I think the 90 e-tec is a great engine and an awesome choice for the 17'...might be a tad shy on hp for an outrage 17 though being they weigh about 400lbs more. The 320lbs is awesome. The only question I have with all this is the performance you guys are posting. My 86 Newtauk(heavier than a montauk by almost 100lbs) has a 70hp Suzuki/Evinrude 4 stroke on a 6" manual jackplate that is up pretty high. Engine weighs roughly 350lbs plus another 30 or so for the jackplate. I swing a 18" Suzuki ss prop(2.33:1?) and WOT I get about 39mph on the GPS. I cruise at roughly 26mph at around 3800rpm and burn about 2-2.5gph which gives me about 10-13mpg @ cruise. At 1000 rpm(troll) I burn less than a qt/hr which is about 25mpg. Now being you can get one rigged for about $6k, why did you chose the e-tec. If you do a lot of skiing the extra 20 ponies is needed. The winterizing feature and LACK of any maintenence for 3 years is also a major plus but I "personally" could not justify the extra $2k for only gaining 2-3mph and less fuel mileage? I am NOT trolling here, just wondering why you all chose to go the route you did for the extra $$$, please advise. |
| ratherwhalering |
Nick, the truth is that I was on the fence between the Johnson 70HP 4-stroke and the 90HP E-TEC. (I'm not familiar with any Suzuki dealers in this area) If you look at the on-line prices, Eds has the 70 for $6,000.00 and the 90HP E-TEC for $6,299.00. I got a "saltwater" edition for $6,215.00 from Custom Marine, in Georgia. As I remember, the price difference between the two, when I purchased the E-TEC in 2004, was about $600.00. Evinrude was offering a $340.00 cash rebate, or 7 year warranty. In my mind, that made the price difference about $250.00. I always planned on a self-install, so the 3 year, no-maintainance was very attractive. I figured $250.00 for 20 HP was a deal, so why not? I didn't even consider the 70HP E-TEC. Finally, the E-TEC is/was lighter (2004 model weight was originally listed as 305 lbs.) I was intent on replacing all the gauges, controls, and linkage, so my install cost would be the same for either engine. Plus it looks sweet, and I can go 3MPH faster than you...nah nah! ;-) |
| The Judge |
For that price hell ya! I see the 70's going for about $5k(w/prop) if ya shop. Last year a dealer posted that he had a few leftovers for $4700. Most here are paying like $7k for the 90 and that was what raised the question. Maybe Suzuki was really dumping? I love the 70 but I really love the looks of that E-tec and the extra 20 ponies can't hurt. |
| ratherwhalering |
If those Suzukis were still available for that price, I would think long and hard about them. To look at it another way if the Suzuki is $4,700.00 and the E-TEC is $6,300 (lets forget tax, shipping, and rigging) then: Suzuki 70HP costs $67.00 per horsie. Of course this leaves the maximum 70HP vs. 90HP (and the fuel consumption) question open but at least the bang for the buck is somewhat proportional. (or is it?...heh, heh, heh.) |
| LewByrd |
I am by no means well qualified to talk props, but I bought a 1989 17’ Super Sport recently that had been repowered with a 90 Etec with the 25” shaft (V6 lower unit). The previous owner apparently got a deal on the engine and to compensate for the 25” shaft installed a fixed jack plate which sets the engine back about 5”, the engine is mounted as high up as possible which puts the anti-cavitation plate about an inch above the bottom / keel. It had a Stiletto 14.25d 17p and would only turn up about 4500 rpm, the local prop guy suggested I try a 14.25d 15p which I did and it performed exactly the same as with the 17. I can get about 200 more rpm by really trimming it up, but the boat starts to porpose. It also pulls really hard to the right at any speed. What prop should I try next? |
