ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Propeller: Changing to Four-Blade
Author | Topic: Propeller: Changing to Four-Blade |
prm1177 |
posted 04-18-2005 04:11 PM ET (US)
I'm considering using four-blade propellers instead of three-blade propellers on my twin 135-HP outboards. The current three-blade propellers perform very well, but in snotty water they are exhibiting a tendency to blow our at 3000-RPM or so. When moving to four-blade propellers from three-blade propellers, does one keep the pitch and propeller diameter the same or reduce the pitch to compensate for the added mass and resistance? |
posted 04-18-2005 06:08 PM ET (US)
I do not believe the "added mass" of a four-blade propeller as compared to a three-blade propeller of similar diameter and pitch has any effect on the ability of the engine to turn the propeller. The additional weight of the propeller (to use the common term instead of the scientific term "mass") is really insignificant in terms of a load on the engine when compared to the load of moving the boat forward. The extra weight of four-blade propellers can affect how the outboard motor shifts. A heavier propeller has more momentum when turning and more inertia when not turning, so it often causes the shift from neutral to forward (or vice versa) to have more gear clash. (Techically I guess you should say the clash is in the clutch dog. Let's just say more "clunk" in and out of gear.) As for "resistance" here I assume you mean drag. Yes, dragging the propeller itself through the water becomes one of the major loads on the engine as boat speed increases. This is one of the reasons why most people will generally describe a four-blade propeller as having lower speed potential compared to a three blade propeller--there is just more drag from having more propeller to pull through the water. But I don't think that either "mass" (weight) or "resistance" (drag) are the real factors which will affect how a four-blade propeller will behave compared to a three-blade propeller. From what very little I know about propeller science, the four-blade propeller will have greater blade area, and this should cause it to have a better "bite" (for lack of a more technical descriptor) than a three blade. As a result, it may be more difficult to turn a four-blade propeller than a three-blade propeller of the same diameter and pitch. Again, this is not due to an increase in "mass" (weight) or "resistance" (drag) but from a better grip on the water (for lack of a better explanation). Mercury describes their REVOLUTION4 propellers in term that suggest using the same pitch as a three blade propeller from the MIRAGE PLUS series if the WOT engine speed is near the maximum of the recommended range. From this I infer that they mean the engine will slow down slightly with the four-blade, but not so much as to necessitate a change in pitch. They also say to change to a lower pitch if the engine is operating near the lower end of the recommended range. And again, this seems to mean you can anticipate that a four-blade propeller of same diamter, pitch, and blade design as a three-blade will be more difficult to turn and affect the engine by increasing the load. This will probably be seen as a reduction in Wide-Open Throttle (WOT) engine speed, and in turn dictate a decrease in propeller pitch (or diameter) when going to a four-blade. If you mix and match diameters and blade designs, there is no sure fire way to determine how the four-blade will play compared to a different design in a three-blade. You just have to try it. One thing I have observed is that at slow speeds there is a different vibration from a four-blade, and in some situations this may be more resonant with other vibrations in the boat. Of course, changing to a four-blade could reduce sympathetic vibrations, too. So the short answer to your question: you'll may need to decrease pitch one size (2-inches). |
rtk |
posted 04-18-2005 09:34 PM ET (US)
As Jim points out it is really hard to give a definite answer, it isn't just pitch, diameter and number of blades that determines performance. There are so many different designs and manufacturers. I asked a propeller manufacturer the same question. They make a propeller of the same diameter in a three blade and a four blade. Very similar blade design. I was told the four blade would run 100 to 200 rpms less, or around one inch of pitch. According to Mercury the REV4 will run 200-300 rpms less, one to two inches of pitch, than a similar pitch Mirage Plus propeller, which is a large diameter three blade prop. (Over 15 inch, depending on pitch) The REV4 diameter for a 17 pitch propeller is 14 5/8 inches. The Mirage Plus 17 pitch propeller is a 15 1/2 inch diameter. Very different blade designs and diameter. My Mirage Plus 19 pitch/15 1/4 diameter three blade propeller runs 200 rpms less than my LaserII 19 pitch/14 diameter three blade. One to two inches of pitch difference (less for the four blade) would be a good starting point. It will depend on how the props you are running compare to the design of the four blades you are considering. Rich
posted 04-19-2005 08:01 AM ET (US)
You can see some results of trying various three-blade and four-blade propellers in my article: http://continuouswave.com/whaler/reference/propellerWDSingle.html I test four three-blade and four four-blade propellers on the same boat. These results may give you some indication of the trends you are asking about. |
prm1177 |
posted 04-19-2005 02:56 PM ET (US)
This is where it gets confusing. Bill S. confirms that the current 3 blades on the boat are 17 pitch Mirage props. These can take the boat to about 45 mph at 5400 rpm. By this calculation, I should move to a 15 pitch 4 blade. The Mercury prop calculator (I plugged in weight rather than length) recommends a Revolution 4, but with a 21 pitch; an 6 inch pitch difference and an estimated top speed of 49 mph. I can't see these engines pulling that pitch given their current props and performance. Anyone out there running dual engine 4 blades on a Conquest 23 with a recommendation? |
bsmotril |
posted 04-19-2005 04:11 PM ET (US)
When you look at the RPM range where you are having ventilation problems (3000), it is right at slow plane speed where the blade and motor load is greatest as the boat climbs over the hump. In calm water, you can maintain a plane at that speed/rpm with good trim and use of tabs. But in slop, I just don't think that boat will plane that slow unless you really go down on the prop pitch to put the motors up at their peak torque RPM of around 3500, and use a prop with a bunch of lift. Do that, and your top end goes to hell though. But, if slop is what you typically boat in, then you won't ever use the top end much anyway, so it could be a fair tradeoff. If it were me, I would start with another pair of 17" four blades, then even try some 15 inchers to see if it will plane even slower. Another option might be longer trim tabs, or whale tales on the motor cav plates. BillS |
posted 04-20-2005 09:42 AM ET (US)
I find that the Mercury Propeller calculator seems to be very optimistic about the horsepower/torque available to turn a propeller. It always seems to recommend too much pitch in my experience with it. However, since the on-line version of the Mercury Propeller calculator seems to think it should only perform calculations for people who use a particular brand of computer software, I can't really make any use of it. As a result, I think Mercury has effectively marginalized the value of their Propeller Calculator, and for my own case, I find it of no value at all. Using the method I describe in my article on propellers, I find that you can quite accurately predict what propeller pitch will work well with just a few simple calculations. The results of those predictions have been more accurate than those supplied by the Mercury Propeller calculator. |
prm1177 |
posted 04-20-2005 10:49 AM ET (US)
Jim, The prop calculator on the Merc site, as inaccurate as it is, is a JAVA applet. The logo appears to be Sun flavored Java. Have you tried a different browser? I'm going to live with the 3 blades for a bit and see if the aeration issue is really a problem. As Bill points out, it occurs during the maximum load on the boat. It doesn't do to make too many changes to a new boat until you actually get used to it. |
posted 04-20-2005 12:12 PM ET (US)
The JAVA available for the Macintosh is absolutely flawless. It is just some idiot at Mercury decided to prevent the application from being used unless you have Windows. Actually just for fun we captured the entire JAVA application and tested it on Macintosh. It works perfectly. It is just some stupidity on the part of whoever designed that web page that prevents it from being useful. However, even with the application available, I still find that it reports overly optimistic propeller recommendations. |
rtk |
posted 04-20-2005 12:27 PM ET (US)
I was experiencing alot of ventilation at slower speeds in choppy conditions. (1997 21 Outrage/250 Mercury EFI) It happened with two four blade propellers and one three blade. They were 17 pitch propellers that ran just a bit over on the maximum rpms, maybe by 100 rpms. I switched to a 19 pitch Mirage, no more ventilation. The 17 pitch Mirage ventilated like crazy, it was the worst of all the propellers I tested. My 19 pitch LaserII will not ventilate either. With the 19 pitch Mirage, I am now running smack in the middle of the recommended wide open throttle rpm range. All the propellers I tested were brand new out of the box, so I really can't contribute the ventilation to a "worn" or out of spec propeller. Increased propeller pitch solved my problem. When I described the ventilation problem to manufacturers and propeller shops, they suggested adding a little bit of cup to the tip or edge of the propeller blades. I was told sometimes propellers will lose a bit of that cup after a while or there just is not enough there. Might be worth looking into. I had a propeller shop add a bit of cup to one of my four blades, but did not run it on the boat to see if that resolved the problem. The pitch is just too low for my boat. I think they charged me about fifty dollars, not very expensive to do. Rich |
LHG |
posted 04-20-2005 03:21 PM ET (US)
Quoting Mercury's propeller catalog: "4-Bade propeller facts: If you're upgrading (a telling term) from a three blade to a four blade propeller, remember that a 4 blade propeller generally truns 50 to 100 RPM less than a three blade with same pitch. 4-blade props: * plane the boat faster than 3 blade props Mercury does say that that the Revolution-4 is usually as fast as the Mirage Plus, however. In my own experience, on my own Whaler, the Rev-4's are 4 mph faster than the Mirage Plus, and hang on like glue at elevated mounting heights. I think they are an amazing propeller. If one or 2 mph off top end is not important, the Offshore/Vensura prop is also great for hull lift and holding with 135-175HP engines. |
prm1177 |
posted 04-20-2005 05:08 PM ET (US)
Let's hope Mercury isn't running the web site on an IIS server as well. LHG's recommendation of the Revolution 4's are good enough for me. I intend to try a pair and report back to everyone. Since the Mirage props push the boat to 5400 rpm at WOT (no trim applied), I feel the same pitch should be fine on the 4 blades. |
LHG |
posted 04-20-2005 06:16 PM ET (US)
I appreciate your response, but have you checked with BW as to what they have found? Since Conquests are sent out with both Mirage Pluss and Rev-4 props, they may have some testing information of value to you. The best pricing I have found on new Mercury props is on Buddy's Wholesale Boat Props, an E-bay store. Use the Buy-it-Now price, non-PayPal. |
prm1177 |
posted 04-20-2005 07:19 PM ET (US)
BW is non-committal as they are not offering the current CQ23 with twins. All they are delivering now are singles and the larger boats with twins. My marina is willing to get the props in and let me try them, so I may go that route. |
bigjohn1 |
posted 04-20-2005 08:05 PM ET (US)
LHG, do you have to be a registered member of e-bay to access their stores? I have tried to find Buddy's a few times but with no success. I am e-bay illiterate though so be gentle please:-) |
bsmotril |
For your prop testing, here is some baseline information from my log for that boat with the stock 17inch Mirage Plus props and 25 hrs use on the motors/boat. The motors and tabs were trimmed to achieve the best speed at each RPM. Two people aboard, full fuel, and calm water, no wind. Speed measured with GPS, fuel burn measured with a portable 6 gallon tank. Fill, run 15 min, refill, and measure quantity used. I only checked fuel at cruising rpms of 3200, 3400, and 3600, and they were so close as to be within a few tenths of an mpg that I just took the best number at 3200 for a data point. 2500 rpm = 13.5mph with motors tucked in and tabs down, not fully on plane BillS |
LHG |
posted 04-21-2005 05:35 PM ET (US)
John - Go to Ebay.com and do a search for Mercury propellers, and he should come up. |
Backlash |
posted 04-23-2005 12:44 PM ET (US)
prm1177, I think the Offshore/VenSura props would be a better match for your 135HP engines than the Revolution 4. The Revolution's are substantially heavier with much thicker blades than the Offshore and I believe they are generally recommended for 200HP + engines. The Revolutions, due to their greater mass, may produce unwelcome clunking when shifting gears as jimh noted above. Steve |
prm1177 |
posted 04-24-2005 12:56 PM ET (US)
Thanks. That's good to know. I'll be waiting a bit before I go ahead with a major prop change. I want to get to know the boat better before embarking on this. We'll see if the ventilation issue I had becomes a regular occurence. How come no one is talking about the 5 bladed props like the Highfive? |
posted 04-24-2005 01:46 PM ET (US)
Five-blade propellers and ones with even more blades seems to be popular on nuclear-powered attack submarines where the shaft horsepower is tremendous and any blade cavitation is a no-no (due to the noise it creates), but I don't think they are particularly popular on small outboard powered boats.
posted 04-24-2005 01:49 PM ET (US)
I am with Steve on the weight of the Revolution4 propeller. I really think they designed that thing for 500-HP racing outdrives. The propeller is very heavy, and it looks very substantial on an outboard motor. When shifting it was making the kind of noise that says to me: whatever is making this clunk is not happy nor is it going to last long with this load on it! |
LHG |
posted 04-24-2005 04:03 PM ET (US)
JimH - I guess those OMC gearcases just can't stand up to a prop like a Rev-4!! As you know, they run super on my 200 EFI's with no "clunking". I don't think they clunk on Yamaha's either. I wonder how Peter found them to shift on his 225 Fichts? Steve - The Merc High-Fives are not made for CR twin application (no left hand version available), and now the prop is pretty much recommended for waterskiing & flats purposes. Mercury does happen to have a hot new 5 blade out, however, called a "Maximus" that they say is for high performance applications, with great top speed and elevated running capabilities. So far, it is not made below 30" pitch, I believe! Another hot 4-blade is the Bravo I, for high ht twin - quadruple outboards and stern drives, but not made below 22" pitch. |
Peter |
posted 04-24-2005 09:27 PM ET (US)
Except for a bad lot towards the end of OMC's existence, the OMC gearcases have no problem handling 4 blade propellers. The 225 Fichts I have are equipped with the "Magnum" gearcase which is, let's say, overbuilt relative to the prior generation V6 gearcase that Jim has. I understand these were designed to handle the torque of the Ficht/DI's 3.3L displacement. All the Mercury propellers I've run on the 225s are "clunkier" (not terribly so) when shifting than an OMC/BRP or other brand propeller. I believe the reason for this is that the change-in-direction "clunks" are not cushioned by a rubber hub between the propeller shaft and the propeller hub as is found on the OMC/BRP or other brand propellers. Rather, the changes-in-direction "clunks" are directly transmitted through a semi-rigid plastic Flo-Torq sleeve positioned between the propeller shaft and the propeller hub. In some respects, the Flo-Torq propellers act more like solid hub propellers. The reason this is noticible to Jim on an OMC V6 outboard is because the OMC/BRP V6 design gearcase is much, much smoother/quieter when shifting than either Yamaha or Mercury. In other words, on an OMC (or BRP) gearcase there is typically no gearcase "clunk" like there is on a Merc or Yamaha (almost a trademark if you ask me) to mask any propeller related "clunks". Last year the quietness of the OMC/BRP V6 gearcase design came in quite handy for me the first time out with a pair of Mirages. I had just put the Mirages on and took the boat out for a run to see how they performed. When backing into the slip I heard an unusual Mercury/Yamaha like shifting "clunk" when shifting into reverse. Upon examination I found that the Mirage on the port motor was a little loose even though I had torqued it down just as much as the Starboard prop. It turns out that after I ran the propeller that first time, the Flo-Torq decided to seat a little further into the propeller hub (perhaps with some water lubrication) and that caused a little axial play on the propeller shaft and a noticible "clunk" which I'm not sure would have been noticed on a Mercury or Yamaha gearcase. I have found that there are some dimensional variations in Flo-Torq sleeves. Some seem to "drop fit" into the propeller hub much deeper than others. This is probably just normal manufacturing variation for this plastic insert. Accordingly, I recommend that anybody using a new Flo-Torq sleeve for the first time recheck their propeller nut for proper tightness after the first forward run. |
rves |
posted 04-27-2005 10:08 PM ET (US)
I just tested 4 blade merc props tonight on my 88 22' wtwd revenge with twin yamaha 150s , I am very disapointed with the 4 blade props in all conditions and at all speeds my base line props are 13.750 x17 yamaha ss giving me superb acceleration and fair top speed of 45mph @ 52-5300 these are my do everything props and I like them ! The 4 blade units were 14.5 x 18 , they vibrated at low speed , they had poor acceration , they slipped in high speed turns , they lost me 5 mph and would only give 40 mph @ 5600 Plane and simple, I would not use these things if they were free! there is just nothing about them that I would call acceptable let alone good ! they are going back to the prop shop ASAP. thanks T |
Backlash |
posted 04-28-2005 08:17 AM ET (US)
rves, I am surprised at your unfavorable conclusion on the 4-blade props. Were these Revolution 4's? Were you running them without vent plugs? I installed an Offshore/VenSura 17 pitch last summer on my 21' Walkaround (200HP Yamaha) and it is, by far, the finest prop I have run on this boat. Acceleration and holding are amazing...it's like a new boat! I am running the medium sized vent plugs (available from your Mercury dealer for $.95/each) which allows the prop to bite quicker when it initally spools up (slips) than the non-vented prop. I am also running my engine elevated quite a bit on the transom with a 10" set-back bracket. IMO, the vent plugs are mandatory for this prop as well as proper engine heigth. Steve |
rves |
posted 04-28-2005 08:48 AM ET (US)
Backlash, I was shocked at the results ! I tried vented and closed ! I moved the "TOE" around , but I left the engines at the same height as we found to be perfect with all other props tested ! Kind of high but great handling with everything I tested so far except for these 4 blade units ! I checked the balance of the props at the shop and they are right on the money , but they vibrate at all low speeds ! Probably a low freq. harmonic situation playing off of the angle of the V block and the 90 degree blade spacing ! I really can not believe how much bite these things DO NOT HAVE ! My best 3 blade hand hammered props make this boat accelerate from 0 to 30 kts in 5.6 seconds and they will plane the boat singly with ease ! The 4 blade props were 15-20 seconds 0-30 kts and had alot of trouble getting the boat on plane singly! I guess if someone never experienced great props on this model boat with this power package, they might think these are good? Everyone told me that once I tried 4 blades I would never go back! I guess I herd them wrong , they must have said I would never get back ! thanks T |
Perry |
posted 04-28-2005 01:15 PM ET (US)
rves, I'm curious as to what brand and model of 4 blade props you tried on your boat? |
posted 04-28-2005 01:37 PM ET (US)
Yes, please, rves, let's have the model and dimensions of those propellers. It's not fair to paint with such a broad brush. |
bsmotril |
posted 04-28-2005 02:29 PM ET (US)
I'm going to guess and say Michigain Wheel. I had the same experience with their 3 blade I bought as a spare against a Mirage three blade on a Merc 175. Same pitch, Diameter within 1/2", drastically different performance in favor of the Mirage. BillS |
LHG |
posted 04-28-2005 03:30 PM ET (US)
For a starter, Mercury does NOT make 4-bladed SS props, Revolution 4's or Vensura/Offsore in EVEN number pitch, like "18" as stated. Only in ODD numbers. They DO make even number ALUMINUM 4-bladed props, 16, 18 & 20, and they are dogs, I believe. My boat is a lot faster than rves's, and my experiences with 4-blades is considerably different. It is generally accepted that a 4 blade will give up one MPH or so top end, but I did not even experience that, with the Rev-4's actually running faster (62 mph) than the Laser II's or Mirage Plus on my high powered, relatively light Whaler hull. |
rves |
posted 04-28-2005 03:48 PM ET (US)
Merc Quicksilver Diamond 4 p/n Qa2185x & Qa2184x 14 1/2" x 18" My dinged up michigan wheel 13 1/4 x 15s all bent and ugly spare props work alot better ! The next test will be a Pair of merc mirage 15x 19s Anyone have input on these props? thanks T |
LHG |
posted 04-28-2005 06:46 PM ET (US)
Come, on rves. You know way too much about props to be BS-ing us like this, and posting deceptive information. Those are what I call "bottom feeder" aluminum 4 blade props, similar to the Mercury Alpha 4 aluminum props. You told Backlash that you tried them with vents opened and closed? No way, since these props don't even have vents. As I have said, I agree those 4 blade aluminum's are a waste of money. JimH tried one in his prop report article, and came up with the same bad performance. So don't mislead the people here, and try a REAL 4 blade SS performance line of props. There is no way those elephant ear aluminum props could run at the high heights you are using. Next time, try the real thing, and I don't care who the manufacturer is, Yamaha or Mercury. You'll get better results, and be more creditable at the same time. |
posted 04-28-2005 07:54 PM ET (US)
I've never heard of an aluminum propeller with vents. The sure don't look like they have vents in this description: http://www.propline.com/Select-Boat-Props-By-Brand/Quicksilver/Diamond-4/Diamond_4.htm |
rves |
posted 04-28-2005 09:29 PM ET (US)
Jim take the description that you sent me and add milled slots on trailing edge of each blade retangular approx 8 mm x 20 mm then add a inner ring ported and slotted and that is what I have Lhg, how does one agree with my findings "bottom feeders" and then call me not creditable? I said these props were bad , I didn't say your props were bad ! These came from the prop shop , they pickup and deliver here at my shop every wensday ! I get to try what ever they have in stock or what they get on trade whenever I like ! Cause of this I get to try more props then most I have also become fair at pitch changes ( thats fair not great) I am not an expert On props by any means (ask me an engine question) The owner of the prop shop told me that these 4 blade props are the biggest seller he has by far and they recomend them highly ! He said if some one comes in looking for props 7 out of 10 times they leave with these! I thought what I wrote would be a warning for other forum members! even if jim tested these before he did not test them on twins and there so bad anyways that I don't think it hurts to remind anyone of that ! I still don't understand the vibration? And as far as the vents , that is probably the shop with there own magic ( I will ask tomorrow) The bad here is beyond venting! By the way they (the shop) sez everyone loves these things but me Thanks T |
rves |
posted 05-04-2005 11:03 AM ET (US)
The prop guy just dropped of a pair of Quick silver mirage p# 48-13700-19 stainless and sharpened non vented props for me to test! The venting on the 4 blade was their own deal allowing you to "decrease bite" and adjust for low torque "smaller engines" Any comments on these (MIRAGE) props before I splash them? T |
LHG |
posted 05-04-2005 01:57 PM ET (US)
If your teflon SS Yamaha 17's are only giving you 52-5300 RPM, you may find the 19" Mirage too much pitch. With the large diameter, they are tougher to turn up. It would seem that 15" Mirage is what you need to get up to 5500, as even 17" Mirage should only give you 5000-5200 RPM, although better speed. But give them a try, and see how she does. With your gear ratios, a 19" Mirage is a 51-52 MPH prop, so the question is whether you can go that fast. |
bsmotril |
posted 05-04-2005 04:44 PM ET (US)
The mirage is a pretty tenacious gripping prop. It can run a lot of trim, and run fairly close to the surface and still stay hooked up. If they look like they will work for you, there might still be a couple of MPHs for you by raising the motors up a notch. BillS |
rves |
posted 05-04-2005 08:43 PM ET (US)
Would you belive that these mirages slip in turns much more than the yams! The baseline props never slip nota!(spin out) Top speed was 45+ - 1 @ 5000rpm (just about the same as the base line props 13.75x17 just 300 rpm lower Acceleration was better than the 4 blade but not even close to the base line props I do not recomend these props for this application ! they have way too much bow lift , and I think the whaler drive begs for stern lift(based on my success with cleavers ! I was able to trim to 5700 rpm but the pourposing was so bad I could not take it & there was very little gain in MPH! Overall handling was ok not great , they slip in high speed turns ! I think I am on to something with the small diameter wheels They feel so much better and stay so connected it feels like I am on gears with them! The prop shop thinks I am nuts and they can't belive the small wheels even work at all! Fuel consumption was bad real bad , I did not record it though ! There was also a delay in transition to plane , kind of what you would expect from a single engine ! Any questions ? T |
BlackMax |
posted 05-04-2005 09:23 PM ET (US)
I think your problem is the engines, which aren't going to give you any more than that 45. Pretty lousy for a pair of 150's on that hull. Forget trying to run Merc performance props on those dogs. The engines can't handle them. Almost any pair of 150's will move a much larger and heavier Revenge 25 faster than you're getting. You need a pair of 60 degree inheritently balanced OMC or Merc 2.5 liter V-6's instead. Then you can run 50+. The Yamaha's won't cut it. The Mercury Mirage Plus is probably the best and most widely used High HP offshore prop in the world. 1000's of users can't be wrong, both outboards and sterndrives. Stay with those teflon props if you're going to keep those engines. Then people here won't waste their time anymore with your Merc prop trolls.
rves |
posted 05-05-2005 08:42 AM ET (US)
Well blackmax I here what you are saying but this boat has already gone 53+-1 mph on cleavers ! The yamahas are real good on low end and mid range power but poor on top end ! I would bet not too many people tried the small diameter wheels on this setup and if that is true then they are missing out on alot ! Now is it that your forced to read the post by some strange force and that is what is wasting your time ? I just don't click on things that I don't want to read ! Ok that being said, Yes I think I will piss off the prop shop that delivers free props to my door every week for me to try ! These guys have been real good with our high powered Arneson drive stuff, There hard workers and that is good enough for me! I am just trying to have funn playing around here and giving info back , If this was a race boat and we were attacking it with a open check book I can assure you we would find Utopia quickly ! thanks T
posted 05-05-2005 11:05 AM ET (US)
rves--I think you are onto something with your comment: "the whaler drive begs for stern lift" Any recommendation for a particular brand/style of propeller that would accomplish this? |
LHG |
posted 05-05-2005 08:08 PM ET (US)
Jim - One of the best overall hull lifting props made is the Merc Offshore/Vensura that both JimG and Backlash are now using on their Yamahas, with excellent results. As you have probably noticed, their boats really ride high now, with greatly improved ride and holding. The improvement over the Yamaha teflon props was staggering. These would do well on "rves" twin 150's, but not add much speed, except what is gained by the hull lift. For you, the problem is that Mercury does not recommend the prop for more than a 2.5 liter block, for some reason unknown to me. But I would still give one a try, since your engine has similar performance to the Mercury 200 2.5's. A 17" pitch is lowest offering. And people here with 225 Mercury 3.0 Optimax/EFI's have said they didn't like the performance. Robert Moore said he didn't recommend them for me either, as they are not known for top end speed. Cleaver props are your true stern lifting props, but are generally not offered in less than 26" pitch for high speed tunnel type hulls, where the bow lift is produced aeordynamically and do not need the propeller to assist in this function. I can't imagine one of those would run well for you. They are wide-open all out props, not for cruising. The smallest diameter performance props that Merc makes are the Laser II's, but not offered below 19" pitch and with 14" diameter. These are a prop design dating from the late 80's, and Mercury's really first recreational performance prop other than the go-fast Choppers. As you know I have run them for years, with good top end results above 5000 RPM, where they really come alive. But now they are not recommending them above 175HP and for more than 18' light and fast, high HP, boats. |
rves |
posted 05-06-2005 09:09 AM ET (US)
Jim , I think the smaller wheels have less dig reguardless of style ! I think bow lift with a whaler drive makes the trailing edge of the bracket catch and drop the bow and recycle ! I Hate that ! Most props like mirages are diggers not climbers and bow lift is usually what the masses are looking for ! I am trying to get my hands on cleavers of the 17-19" range They use these on high powered Cats to keep the nose and prevent blow over . But everytime I get a set they are 32"-36"and my home hammered ones are ok but what a pain in -- to keep even ! SO the prop shop is looking for low pitch climbers around 13" dia. there are other types that climb but I do not know about them yet ! I have cured this porpousing before in other boats that had tabs or stablization plates that acted just like the whaler drive (With cleavers) , but never with the HP to LBS. being so poor as the 22wtwd twin 150 whaler. So although I am hopeful and sure I can do it with enough HP ,I don't know if I can with my existing H power! Do you know of any props that are climbers that are not too big and don't cost thousands of $$$$$ My opinion is there is a better prop out there for the whaler drive boats and I think the performance that people are getting with the whaler drive speed wise is a compromise caused by convenience! Bow lift seems to be a whaler drives enemy! In the mid 1980s I took a factory 20' kevlar checkmate race hull That had the same problem , and develoved cleavers and plates That allowed me 93mph certified with a single Evenrude V6, when back then the rage for this type of hull was Mercs.& "chopper props" causing bow lift (lots)and 72mph this boat had a different balance point than conventional checkmates & did require a slight chop for top speed but she would run mid 80s on flat water! I have the same seat of the pants feeling with the whaler "tail dragger" that the checkmate had Before I tuned it ! Thanks T |
ivansfo |
posted 08-21-2006 09:12 PM ET (US)
prm1177, In researching to improve performance on my 23 Conquest with twin 135s, I came up upon this post. Can you provide an update on your 4 blade prop test? Thanks, Ivan |
oroseiwhaler |
posted 08-27-2006 05:19 AM ET (US)
Ivan, 4 blade props usualy improve handling and bite in rough water and mostly they provide in some (3-5mph) lower top end speed. I swapped this may motors and propellers: Before: 2 Yamaha 150 HPDI Now: 2 Yamaha 150 4-Stroke Gains: manoverability at low speeds Losses: Max 5300 rpm instead of 6000 I think that 4 blade props will perform even better on carbed outboards due to their higher low end torque, but i'm still happy with them. Before switching to 4 blade props, consider that usualy you have to use at least 2'' less pitch to have the same rpm's at wot. Find a good prop shop and test different 4-blade props on your boat and notify the difference between them. best regards Chris |
prm1177 |
posted 08-28-2006 02:39 PM ET (US)
Ivansfo, When I originally created this thread, I was new to my Conquest and twins. I had experienced occasional ventilation in the choppy waters of SF Bay. At that time, I was more familiar with handling my Outrage 17 and its single engine performance and behavior, than dealing with twins. Twins can be more susceptible to ventilation as the props are placed asymmetrically relative to the hull bottom (the outboard side more likely to be at or near the surface on plane). Since that time, I have learned to: a) re-trim the engines fully down after stop and Attention to both have made my ventilation issue much less problematic. While I'd like to get a bit more thrust for slow speed maneuvering and hole-shot, I'm not keen on the loss of top end and on the $800+ cost of a pair of new props (given the compromises they would entail). My current Mirage 17s do a pretty good job with the boat with my top speed being 43-45 mph. If the local shops had loaner 4 blades or a pair of 19 pitch Enertias, I might consider trying them out and budgeting for replacements. |
ivansfo |
posted 09-06-2006 12:51 AM ET (US)
Thanks Chris. Yep, I agree with your comments on a 4-blade prop and I'm going to give it a try if I can find a good deal. prm1177, your method of dealing with your 23 Conquest is exactly what I do too. For the most part it is not a big deal with the two adjustments mentioned but I still haven't found a way to deal with falling off plane when running in snotty seas. You want to go fast enough to keep on plane but slow enough so it doesn't pound. I just received my LH 4-blade Merc Revolution and the prop is HUGE! It's way beefier than my current Mirage Plus. Total shipping weight of the prop and hub kit is 24 lbs. I think I'll sell this and just want for the Vensura. I think that's the better prop to get. Ivan |
pineapplepig |
posted 09-06-2006 08:23 AM ET (US)
The Vensura is the right prop for your boat-the Rev 4 is a great prop but just too much for a 135 HP IMO. |
