| Author | Topic: Outboard Comparison: Longevity |
Outboard motors are expensive mechanical devices. Buyers of new outboard motors are anticipating a long life span for their new motors. How can the useful life of an outboard motor be estimated? Piston Travel Piston travel is calculated by taking the engine's stroke dimension, multiplying it by two. (One up/down travel of a piston is needed for each crankshaft revolution.) This is the piston travel per revolution. This figure is multiplied by the engine's rated maximum crankshaft speed in RPM. This gives the piston travel per minute at rated horsepower. Let us compute the piston travel per minute of operation at rated horsepower for several engines. In order to do this calculation, we need the stroke dimension of the engine's piston. These are usually give in millimeters, but we shall convert the final answer into feet (to help our American readers gain a better appreciation of the actual distances involved and the comparison between engines). We will look at four engines. All are very recent products and should represent the best engineering of their respective designers. The engines are: Evinrude E-TEC 150 From the published specifications we located the stroke (in MM) and the rated crankcase speed (in RPM) Evinrude E-TEC 150 = 66 MM; 5500 RPM Taking the stroke, multiplying by 2, multiplying by the rated RPM, and dividing by 12 and 25.4 gives the piston travel in feet per minute at the rated horsepower: Evinrude E-TEC 150 = 2,382 feet per minute On the basis of favoring lower total piston travel, the Evinrude E-TEC 150 engine should have the longer lifespan. ENGINE STRESS Evinrude E-TEC 150 = 2.589 liter All of these engines are rated at the same horsepower (150), so it is simple to figure the horsepower per liter of displacement: Evinrude E-TEC 150 = 57.9 HP/L If an engine's longevity is affected by its "stress", then lower horsepower per liter should indicated higher longevity. Another index of stress might be the horsepower per cylinder. This is a very simple calculation. All of the engines in our sample are four cylinder engines, except the E-TEC, which is a six cylinder engine: Thus: Evinrude E-TEC 150 = 25 HP/cylinder Again, using the concept that less "stress" means longer life, a lower value of horsepower per cylinder should correlate to longer life for that cylinder. Finally, it may be interesting to compare the number of power strokes needed to produce the horsepower per cylinder. This is again a simple calculation. In the four-stroke engines there is only one power stroke per two revolutions, while in the two stroke engines there is one power stroke for each revolution. This implies that the power delivered on each power stroke must be twice as powerful in the four-stroke engine as in the two-stroke engine. Thus we could calculate the power per power stroke per cylinder as follows: Evinrude E-TEC 150 = 12.5 HP/power stroke/cylinder RESULTS The several parameters analyzed above seem to point quite favorably in the direction of the dimensions of E-TEC engine as having the potential for long life span if one accepts these paradigms: --lower piston travel is better These results would appear to say that the E-TEC engine is well designed for reducing what is commonly believed (and advocated) as important parameters for obtaining long life from an engine. With mechanical devices it is of utmost importance that they be well constructed, too, so the actual longevity depends in the main on the actual realization of the device. Quality material and craftsmanship are a must for long life in a mechanical device. On the other hand, if one assumes a relatively equal quality, then a device which has inherent advantages in its design may prove to be more long lasting. |
| Peter |
I'm not sure how, but I think the analysis needs to factor in that in the case of the four-stroke, piston ring loading should vary between power strokes and non-power strokes with less loading on non-power strokes than power-strokes where the intake and exhaust valves are closed. In the case of the two-stroke, the piston ring loading is there on each and every up and down stroke as soon as the intake and exhaust ports are closed by the piston. |
| jimbob28 |
Hi Jim, I used to subscribe to the theories that you suggest and I am sure that they are probably true if applied to exactly identical engines or when applied to the same engine but at different operating conditions. For example the same 2 engines, one run at 50% output should out last one operated at near maximum output. But, when comparing different engine manufacturers, consider a Toyota vs. a Chevy. The Toyota will come out looking very poor using any of the criteria that you suggest but I would wager that on average that the Toyota will have twice the useful life of the Chevy engine. The difference has to be in the manufacturing tolerances and other engineering considerations. Probably the best indicator is past history but we all know that corporate goals and strategies can change. They are not going to tell us if they decide to reduce quality to improve profits. Also, from my investigations, it does not appear that any outboard manufacturer has held an edge in producing more reliable engines. That said, I don’t think that you are not going to be able to predict who’s outboard is going to have the longest life. The consuming public just doesn’t have enough information or expertise. Jim 17 ft. Montauk w/ 90 hp. E-TEC |
| bsmotril |
It has been my experience that outboards usually don't wear out, but instead die via catastrophic failures. Most often, they are overheated by running with an impaired cooling system, or they score cylinders and break rings from either carbon buildup, lube system failure, or carb blockage and lean running. The repair bills being pretty hefty, the owner decides to repower instead. All these are largely preventable problems with proper preventative maintenance. In this new age of technology, we also now have to worry about valves, cams, and the sytem that drives them. One would think with their higher top ends, that a four stroke would die before a two stroke. But, when you look at the reasons noted above which are primarily two stroke failures, you eliminate a lot of those with four strokes and modern fuel injection. The cooling system is still a common failure mode between two and four strokes, but the technology in the newer motors is much better at letting the operator know of a problem before damage occurs, and protecting the motor by shutting down, or reduced RPMs. So, even though the 4S rev higher, and have the added complexity of valves, my gut tells me they will do quite a bit better than the old 2S in lasting longer. BillS |
To assess the load on the piston rings, you might want to consider the diameter of the pistons. The implication would be that the larger the diameter of the piston, the more area available for the piston ring to have in contact with the cylinder walls. The more area available to spread the load, the lower the loading should be on a per-unit basis. The implication would be that a larger diameter would correspond to lower loading, or lower "stress." Here is a breakdown of that dimension: Evinrude E-TEC 150 = 91 MM Again it looks like the two-stroke E-TEC is a larger diameter piston than most. In the two-stroke engine there is always the view that there are twice as many power strokes, so that implies twice the duty-cycle. On the other hand, each power stroke is only about a third the load on an individual cylinder when compared to the four-strokes (with only four cylinders). Let's look at the power stroke on a cylinder-to-cylinder basis between the Verado and the E-TEC. The piston and rings of the E-TEC have to absorb about 12.5 HP on each power stroke, and spread this load across a piston ring that is (91 X 3.14) = 285.9 MM in circumference. This implies a loading of (12.5/285.9), or E-TEC = 0.044 HP/MM of piston ring On a VERADO we have each cylinder producing 37.5 HP per power stroke, and spreading this across a piston ring that is (82 X 3.14) = 257.6 MM in circumference. This implies a loading of (37.5/257.6) or VERADO = 0.146 HP/MM of piston ring If we compare these, we see that the loading on the VERADO piston ring is higher by a factor of 0.146/0.044 = 3.32 times. The piston and rings of the VERADO have to absorb about almost three and a half times greater load than the piston rings in an E-TEC during a power stroke. But the E-TEC has twice as many power strokes, so let's divide that difference in half 3.32/2 = 1.66 Thus we ought to be able to infer that the load on the piston rings in the Verado is 66-percent greater than the load on the piston rings in an E-TEC. The other engines fall somewhere in between. I recognize that these are rather simplistic assumptions, but the general basis for them comes from widely held notions about how engines work. I agree that the ultimate proof of a good design and its longevity is track record. But all of the engines in this sample are very new engines, just announced by their makers or only in production for a year at most. |
| elaelap |
Good God, jimh, what a lot of work. Still ice on the water back there? I suppose I should be concerned about these things, since I put 300+ hours per year on my motors(probably more this year), but hell, if I have to buy a new motor after seven or eight years rather than after nine or ten, what will it really matter in the broad scheme of things? I suppose these calculations are very important for a guide service or rental operation, but from what I've seen on this website most outboard motorboat owners don't get much more than a hundred or so hours of use out of their motors every season anyway. Tony |
| merc125 |
I would think that the sleeve bearings on the 4 stroke cranks would wear sooner than the roller bearings on the 2 stroke. A sleeve bearing by nature is sacrifical ,the sleeve being softer than the shaft. MartyD |
| Lil Whaler Lover |
Interesting subject presented here by jimh. Many years ago I copied down a formula from a boating magazine that was said to calculate a Wear Factor for outboard motors. The Wear Factor is equal to the horspower multiplied by 396,000 and them divided by the rpm required to produce the horsepower and divided by the cubic inch displacement of the engine. The lower result would represent an engine expected to last longer. E-Tec 150: 150 X 396,000 / 5500 X 158 = 68.35 This formula supports the Yamaha as the longest expected engine life by a small margin over the Honda and E-TEC The Verado falls somewhat further back primarily due to its lower displacement. Somewhere in my archives is the article which would explain what the basis is for the 396,000. As it is already packed for moving I can't even search for it now. At least some food for thought?!?!?! Dave |
| Peter |
I'm not sure that that formula can be equally applied for 2 and four-strokes and chances are that the article was written at a time when it was primarily a two-stroke outboard world. I believe that two-stroke outboards generally have a lower compression ratio than four-strokes. Lower compression should equal longer life, everything else being equal. |
| rves |
Number of rings, ring material, ring tension, subtract port area covered by rings, if any, stiction, gas porting, piston weight, location of wrist pin, offset for noise, cylinder pressure, ring thickness (a .043 ring lasts only twenty percent as long as .047 ring in a 4-inch bore). These are just a small number of things that need to be in the calculation. Welcome to my world. |
| bigjohn1 |
As a former builder of stock and race engines on cars and bikes, right or wrong, I have always agreed pretty much with the basic points Jim suggests in his original post. That said, I think the "wild card" so-to-speak in all of this comparison is proper maintenance--or lack of it. To put this in the real world, we have four fine engines in this comparison and it appears theoretically that the If you take this wild card out of the equation and give it a level playing field, looks like the owner of a 150 E-TEC who also takes good care of it is in for many, many years of trouble-free service--good on them. |
| kglinz |
There are so many variables in the materials used and the lube used that you can't say that any one design is going to out last another. I read a post a few months ago that told about E-TEC using a NASA developed material that would last with little oil. Is this more durable than a cast sleeve and a forged piston? All 2 strokes are not sleeved. A lot of 2 stroke failures are related to the ports cut into the block and pistons. I think lube is a major factor in longevity. A 2 stroke burning 10 gallons a hour, with a 100/1 fuel/oil ratio has about 13 OZS of oil, per hour, for lube and cooling. A Yamaha F225 has 2.3 Gallons per minute at 1000 rpm. This oil is used for cooling as well as lube. Most Diesels and a lot of Gas engines including Verado use cooling orifices spraying cooling oil on the bottom of the pistons an cylinder walls. I know some manufactures claim that their motors will last a long time, at low RPM, with no oil. Only time will tell. |
| rves |
I am in agreement with bigjohn and kglinz [when they say engine maintenance is an important factor in engine longevity], but, please, let us continue with the discussion. There is a lot to learn here! When comparing two-strokes to four-strokes in endurance, the valve train needs to be in the equation, The piston is the valve in most two-stroke engines. It is also accepted that fuel lubricity offsets piston wear in two-stroke engines compared with four-stroke engines. ("Detroit Diesel Allison" [perhaps an allusion to the two-stroke diesel engines made by that firm--jimh.]) Provided the air source is 100% clean. I bet the engine with the best, most-protected electronics is the winner of the real life endurance test! The lion's share of failures will be due to human error! Does anyone have the results of actual factory endurance testing? They all do it. The best I have seen has been from BMW motorcycles. |
| kglinz |
The valve train of four-stroke engines is frequently mentioned as an area of weakness. I watch three online boating forums. I have posted questions looking for valve train problems, or even people that just have needed valve adjustments. I have had no responses. |
| rves |
Some of the four-stroke testing going on right now is using a small two-stroke piston and cylinder as the valves on four-cycle engines in an effort to increase sustained high-speed high-load endurance. Desmodromics is still alive and well in testing/ [The word "desmodromic" is from Greek, desmos (controlled, linked) and dromos (course, track). This may be a reference to a particular implementation of valve control used in Ducati motorcycle engines--jimh.] Many people feel that a small two-stroke engine is more reliable as a valve then a conventional valve and spring for ultra high cycles. |
| rves |
I should have said some of these [possibly a reference to the two-stroke style valve mentioned above] are in use and being tested further with great results. |
| LHG |
I'm sure Mercury and Yamaha, the engine brands with the largest selection of conventional two-stroke, DFI and four-stroke, have all of the testing data to answer these questions. Mercury has said that they did well over 50,000 hours of testing on the 6-cylinder Verados. I'm sure the OptiMax engines have been through the same endurance testing, and the conventional two-stroke engines, too, over the last 40 years. The question is how do we get them to tell us? These seem to be well kept trade secrets, for obvious reasons. To state that a Verado will outlive an Optimax is to put the Optimax out of business. I'm sure Mercury knows the life expectancy of a 150 OptiMax or 150 Verado, and which will last longer under ideal conditions. Yamaha knows this stuff, too, on their engines. They all do. I think the general perception is that the four-stroke engine will last longer, in spite of its higher piston travel figures due to higher RPM and lower pitch prop useage. So far, with four-stroke engines on the market for some time now, the results are encouraging. People think well of their Hondas, on the market for the longest time. There is also some evidence (a lot of failures!) that DFI technology stresses the engine more than conventional two-stroke fuel induction systems. Today's conventional EFI four-stroke technology is pretty low stress, from what I can tell. It's too soon to know about supercharging. Within a given technology, I am strong believer that piston travel, along with the overall quality and tolerances of the design and manufacturing process, have a major effect on longevity. High horsepower which allows high prop pitch, definitely contributes to longevity and less internal engine wear. That has been my experience. Afterall, we drive our autos on the highway in overdrive, not 2nd gear, the equivalent of underpowering |
| rves |
Swept cylinder volume is what I think everyone means: RPM x Number of Cylinder. It is not the same as piston travel because it compensates for size differences automatically. The only way one can (in a fair manner) compare endurance based on this is in the same exact engine type but with different bore and stroke configurations. You can not figure it out on paper; it's fun to try. There is still a lot to learn. You should be able to obtain data from the companies to show the number of hours a particular engine will service its owner still passing emissions requirements. Even if the emissions are exempt on that engine, the testing has still been done and it is sitting somewhere available to the public if one knows who to ask and what to ask for. This is the best indication of service life, or as good as any I have found. The data might not reflect reality, but the difference between the test data usually tells the story. I have eight cylinder liners that cost $1400-each in one engine and their endurance (in clean air ) is much greater than that of lesser material at three times the piston speed, all else being equal. |
rves---interesting point about the cylinder walls of a two-stroke have some ports in them which could affect piston ring wear and be a source for potential damage. |
| Outrage22Cuddy |
I'm really impressed at the complex wear factor formulas posted here. But, what about initial quality? The piston going up and down causes wear, but the motor is not worn out until the motor is so out of spec that the wear is noticible. If the tolerances are tight from the factory, I would think that motor might last longer than a motor with less piston strokes that was poorly constructed in the first place. Which motor is the best constructed? Huh? You got me on that. Time will tell. |
| rves |
If the tolerances are to the tight side then break-in may cause reduced endurance. There is a flip side to all of it, that is, needle bearings usually do not last as long as plain bearings, but they will last longer in situations with poor lubrication. They won't last as long in dirty conditions. Plain bearings will live in water much longer, if the water is farily clean, unless the water is really hot. There is not much rhyme or reason to this stuff. The guy that uses the cleanest, least corrosive fuel with poor maintenance will usually win over the guy that does meticulous maintenance and uses poor fuel. The guy that parks his boat under a tree for long periods will have all kinds of trouble. |
The focus of this discussion is on simple dimensional analysis that might yield some insight into engine longevity. Whether or not the manufacturer tested their product to a zillion hours is really not under consideration--it doesn't change the dimensions of their engine. Whether or not the manufacturer has any data to keep hidden from the consumer is not important--it doesn't change the dimensions of the engine. What pitch propeller you use or how much you over-power the boat is not significant here--it does not change the dimensions of the engine. I am just looking at basic engine dimensions and trying to infer something from them, alone. An analysis like this cuts across any brand preference. You just look at the dimensions of the engine and see what they tell you. What I see: The piston in a 150-HP Verado, a Yamaha, or a Honda travels a lot more per minute at the rated horsepower than a piston in an E-TEC. The load on the cylinder in each power stroke is much higher in a 150-HP Verado, a Yamha, or a Honda than in an E-TEC. The difference is 3:1. Maybe factors like this are part of the reason that these other engines need to be continuously bathed in a stream of lubricating oil in order to run. That, or course, overlooks all the additional components they have in motion, such as the cam shafts, the valves, the balancing shafts, the super chargers, etc., which all need to be kept lubricated when running with a stream of oil. Let's look at another dimension: stroke. The longer the stroke, the more weight in the crankshaft. The longer the stroke the bigger the crankshaft has to be, and the more rotating mass and angular momentum there is. Let's compare stroke: Evinrude E-TEC 150 = 66 MM Wow--the Yamaha stroke is 50-percent greater than the E-TEC. This means the crankshaft on the Yamaha is going to be larger, and have more mass rotating farther off-center than the E-TEC. When the two of them are running at 6,000-RPM, the E-TEC is going to have less angular momentum, won't it? Any other inference from the stroke to be drawn? |
| Perry |
I have owned, ridden, and worked on two-stroke steet bikes for over twenty years. They were either Yamaha RD 350's or RD 400's and I maintained them in excellent working condition. In my experience, the life expectancy of an engine on a two-strokes street bike is about half that of a similar four-stroke. I was lucky to get 20,000 miles on a motor before having to replace the pistons and rebore the cylinders. One of the main reasons why they didn't last very long was because the intake and exhaust ports reduce the life span of the piston rings. I know these bikes were designed in the seventies and are different than outboards but I thought it has some relevence to this discussion. |
| rves |
Perry, [your motorcycle engine experience has] little to no relevance [to this discussion because the engine on the motorcycle was] air cooled, [and operated in] dirty air compared to a boat. I have a friend with a old Suzuki Water Buffalo [perhaps a brand and model of motorcycle] with over 200,000 miles on it. It has never been apart! Jim--Too many assumptions on the rotating assembly. Stroke has other effects, but to say the rotating inertia is greater with longer stroke is wrong! I have a 60-lb. crank in one engine with a 3.5-inch stroke and a 39-lb. crank in another with a 3.48-inch stroke, and the 60-pound crankshaft has less inertia but more mass because most of the weight is in the center. Now let us talk about crank dampening. It is accepted that the heavier the damper the better the endurance of the rotating assembly. A super light rotating assembly with a super light damper making high horsepower might win races, but endurance will suffer! However, longer rods that are usually heavier can add endurance. Do you have piston and connecting rod weights from any of these engines? Most outboard two-stroke engines have heavy pistons and pins compared to high horsepower four-strokes. I have 700-HP four-stroke engines running with 310 gram pistons. I have not seen enough mechanical information here--not even close--on any of these engines to even make a guess as to which will live the longest "by design." Many engine desgins are tested on a Spintron to get combustion out of the equation and just see how long things will go up and down and round and round. Does cylinder perssure have an affect on tangental load (stress), or is radial load added to the reciprocating weight? Rod length and how long it takes the piston to move through its first 70-degrees after top dead center will have a great effect on what you are trying to calculat. Jim, if you can figure out what each of these pistons weigh at 5000 RPM it would be a start. Don't forget to add pins, clips, small end bearings. You can add rods but it would be slightly incorrect. |
| bigjohn1 |
Total displacement being equal (bore x stroke), the longer the stroke, the lower in the RPM range an engine develops peak power. Since we're talking marine outboards, its sometimes not useful to introduce automotive parallels, but in this case, it is relevant. Always remember that displacement is bore (piston diameter) times stroke (crankshaft stroke length) Two engines - both 350 cubic inches (5.7L). Engine #1 had this displacement designed and built into it by using big bore and relatively short stroke. Engine #2 had this displacement designed and built into it by using smaller bore and longer stroke. What is the output difference? Engine #1 will develop peak power at a higher RPM value than engine #2. It will have less low-end power (torque) but great high-end power. Engine #2 will develop peak power at a lower RPM value than engine #1. It will have greater low-end power (torque) but not as much power in the upper RPM range. In general, engines built as #2's lasted longer but there are a whole host of factors other than bore/stroke that could explain this give. In general, #2's were pulling motors in trucks and large autos but not always. Due to these variables, this where we should stop comparing auto and outboard technology as there are too many differences. Still, for the sake of discussion regarding stroke, the above facts are of some value. |
| rves |
bigjohn please don't get mad at me. I agree that what you said is what was generally accepted. But, it can no longer be said that short stroke always means top end power and long stroke means low end power. We are finding that the big-bore short-stroke engines are quickly becoming the low end torque kings. This is made possible the techical advance in cam timing and fuel timing and how it is varied. The simple short of it. It is old technology. Being recycled and perfected, that is, Bultaco trials bikes of the 1970's, all low end power, huge bore, short, very short, stroke, no RPM. It now has to do with cylinder pressure and where in the power event of the cycle it is occuring and at what rate it is applied. For years it was easier (still is) to make low end torque with a long stroke because designers had much more time (the stroke ) to get it done. The stroke would mask poor design very well. I have too much information on this issue since I have spent much of last 5 years of my life persuing low end torque and along with high RPM with great success. I will step off here. If you would like to discuss further, let me know. I would love to hear input on this subject from others. It is cool stuff. |
| Jerry Townsend |
Wow - very interesting information and discussion going on here. Thanks Jimh and all participants. I don't have experience with two-cycle engines, but detailed and extensive experience on four-cycle engines, and, having been raised and working in the oil patch, I have seen the difference in wear and longivity caused by different lubricating oils and maintenance. Using cleaner oils and keeping the filters clean vastly extends the lifetime of an engine. For example, all lube oils are doing at least a good job of lubricating, but some oils are notably cleaner than others. And I suspect that the cleanliness is, at least, part of the difference in decreased lifetime noted of dirt bikes. Certainly the four-cycle engine and the two-cycle engine are different, but has anyone addressed the difference in oils used in the two-cycle engines? I apologize if this has been addressed above and I missed it. ----- Jerry/Idaho |
| Perry |
rves, I was comparing similar engines. I have had four-stroke air cooled motorcycles engines breathing the same dirty air last much longer than similar air cooled two-strokess. What gives? |
| LHG |
After reading this discussion, it seems as if the smaller, 2.5 liter 150 Optimax is the engine to buy. It is also built on a long time proven block, probably the best, and first, 60 degree V-6 ever built. |
| rves |
Perry, after being in the motorcycle industry for many years as a racer, mechanic, builder, designer, and teacher, I can say I have seen a lot of data on which motorcycle engines have the best endurance. It is a different ball of wax on water at constant load with the world's largest radiator and all the clean air one can use. Two-stroke engines love this kind of thing; four-stroke engines by design do not. They hate constant load. It equals EGT [possibly exhaust gas temperature--jimh.] My two-stroke engines are the most reliable, longest lasting things I own (except for my series 60 Detroit), and my four-cycle engines are only fair in the endurance category. Use plays a big role here. Let us get back to which outboard is the endurance king. I think that is the question, and I am willing to learn, if someone can come up with a scientific way of figuring this out. But so far for every heave there is a hoe, kinda like engine designing huh! Jerry, I almost missed [commenting on your discussion of the effect of oil lubrication quality on engine endurance]. Sorry. And "Amen." [The imposition of an oil rating schedule called] TCW was supposed to level the field here. Did you know that most motor oil is only filtered from the factory at 100-microns? That is BAD. Hydrostatic systems require 10-micron filtering on average! I have done extensive oil testing, and I continue to do so. One interesting tidbit I have learned is that oil filters usually filter better when dirty (a little), and they do not need to be changed as often as you might think. We cut and analyze oil filters in our race stuff as well as our shop equipment, and I have never found a full-to-capacity oil filter yet even through multiple oil changes, but the O-ring does get hard after too long. |
| rves |
How would a Wankel engine fare on paper? I think it would win hands down in this discussion. How would it work on water? |
I agree with LHG, these 150-HP engines built on a V-6 are quite strong on paper! |
| Jerry Townsend |
rves--I have often wondered why a Wankel is not used for an outboard. I think a Wankle would be of consideration in an application where weight and performance is important. But, I have not heard anything about recent/current improvements to the Wankel, but suspect that someone out there is working on them. What is the status of the seal problem? Wish I had one to play with and test. Thanks for the information on the filters. Is there information regarding the different mix oils for two-cycle engines? Is one brand noticeably cleaner than any others? Is one brand of engine noticeably having fewer problems with carbon buildup? ---- Jerry/Idaho |
| Peter |
Regarding Wankel outboards, see www.infoblvd.net/sah/Outboarder/1973/apr73-25.html |
| rves |
Jerry , On the dynamometer, would you believe, bean oil at ridiculous (very rich) ratios will still make lots of power compared to many of the synthetics. But I am sure not recomending it to use, it has lots and lots of other issues, I just cannot believe the power. The carbon [problems] have not been high on our list of oil concerns, so I don't think I have much for you there. I am aware that for most carbon is the main issue. just not us. Our stuff is apart often and run very hard. My bearing dynamometer likes Royal Purple [a brand of oil] best! Two-stroke and four-stroke. I am of the belief that I can make the most power with very hot oil (300-degree F) and cold water temperature in four-stroke engines. In two-stroke engines cold fuel and cold air with alcohol injection or NO2 [nitrous oxide] for detonation control. The wankel ; I had to learn about them because when I was a mechanic in the MC [possibly "motor cycle"] industry there was mucho money to be had if one could understand, tune, and repair them. It was pretty short lived, though, but man could they be smooooth, and what power. We were talking recently with a well-to-do customer about making a prototype outboard for his skater [perhaps a brand of boat?]. I don't even know if it is feasible. Money talks and it is quiet at this time. It has been years since I touched one. I would like to produce a two-stroke SB [possibly "small block"] Chevy, but I cannot figure out how to do it and still meet a reasonable amount of sanctioning rules. I would appreciate any ideas even if you think they are dumb. Oh yea what outboard will last longest? Well here is a very scientific answer for you guys. The one that runs the happiest. A happy engine will live the longest. I cannot tell you how to learn the feel or the sound but I know many of you can do it, even if you don't know it. When all the BS is over you will find this to be true. |
| Jerry Townsend |
Peter - thanks for the link. I don't recall ever hearing anything about commercial Wankels, and around that time (1973) I was thinking about boats. I am surprised that those problems were not worked out. Thanks again -- Jerry/Idaho |
| mikeyairtime |
I take exception with Merc 125's logic that the roller bearings make the two-stroke engines more durable. If a babbit sleeve bearing ever made metal to metal contact it would sieze instantly. The reason two-strokes engines run roller bearings is that crankshaft lurication is limited. The reason heavy industrial diesels run sleeve bearing is they can cary much more load. My experience with two-strokes engines is they've failed by destroying the big end rod bearing and four-stroke engines have failed by destroying the valve train. The trend I'm seeing on the West coast purse seine fleet is that four-stroke engines are replacing the two-strokes engines on their net skiffs for durability reasons, primarily Honda's. |
The dimensions of the Mercury V-6 OptiMax 150-HP engine are: Displacement = 2.507-liter These calculate to HP/Liter = 59.8 This two-stroke 60-degree V engine block has been around for many years and has proven to be a reliable and strong engine for Mercury. It has demonstrated longevity in conventional two-stroke engines. The problems that Mercury had with their OptiMax low-emission engines should not detract from this basic engine block design and its proven reliability. These dimension are very similar to the E-TEC. These seem to be good dimensions for a 150-HP two-stroke engine. Perhaps from this you could infer that the new E-TEC 150-HP will be similarly reliable. |
Re: four-stroke engines replacing two-stroke engines on commercial fishing skiffs. What horsepower range? |
| Peter |
Jerry--here is a link to a Yanmar rotary outboard www.infoblvd.net/sah/Outboarder/1973/apr73-35.html . The link suggests 1973 as well for this information and judging by the similarity in look between the Yanmar and a late '60s to early 70's Johnson, I'd say that the photos depict a Yanmar product of late '60s to early '70s vintage. I wonder if the application of direct fuel injection technology could breath new life into the rotary engine configuration for use as an outboard power head? |
| bigjohn1 |
rves, Not to worry, I am not mad. That's a fair point you make on changing technology and it affecting the "old rules" of bore, stroke, torque, and power. |
| rves |
It does not apply directly to this discussion, but it needs to be said: A sterndrive with a "car engine" four-stroke that will do 12,000 hours on the road has trouble doing 1,000 hours on water (run hard). On paper this "car engine" would look really good in this discussion. I also would bet that a two-stroke engine would have the opposite results (land vs water). This is based on design versus use and the marriage of design and use. I agree with mikeyairtime [perhaps on his commenst about roller bearings versus sleeve bearings]. These four-stroke outboards will probably have good endurance if used in moderation, but used in excess the two-strokes engines should shine. And I think vice-versa. Older Detroit Diesels are two-stroke but they use plain bearings. They are one of the most durable constant-load power sources available. They are all supercharged, and ,if you start one on air pressure, it will run with no rod caps installed. My point is regardless of piston travel and [the ratio of horsepower to displacement] and so on, a two-stroke engines will be tough to beat for continuous high-load high-RPM endurance, and a four-stroke engine will be tough to beat for intermittent light to medium load. Four-stroke engines lug better than two-stroke engines. Diesel engines do not lug well at all, two- or four-stroke. Gas four-stroke engines have much more low end torque than diesels. This is all due to design, and it has a lot to due with endurance. That is why I am mentioning it. |
| Buckda |
Great discussion guys. Thanks, and keep it up. I find it very interesting. |
| bullwinkle |
I have no real technical training in this area, but this topic has mind whirling with thoughts (it does that sometimes without thoughts). I remember seeing an old photo of a racing outboard with a radial engine for power. I know those have great longevity in seaplanes, etc. Anyone have any idea if or why not anyone has done more research on using these on outboards? Another thought ran along the lines of the weight of the crankshaft. If the weight is along the shaft or the throws makes a huge difference in acceleration or constant use at speed. My thought went to a flywheel that had centrifugal function that would expand at running speed and its circumference would be smaller at lower RPM allowing for easier acceleration. |
| LHG |
I consider the OMC 60 degree V-6 150 and 175 horse engines to be the best V-6 block they have ever made, so it should follow that the E-TEC technology on this block would also be great engines. It is also their most modern V-6 engine block, a completely new design, introduced in 1992, I think. Am I correct in assuming that the 3.3 liter 90 degree V-6 block of the 200-250 E-tecs, is just a displacement increase on the older V-block, that also provided the 2.0 liter V-4, the 3.0 liter V-6, 3.0 liter V-6 Ficht, and 4.0 liter V-8? Regarding DFI vs four-stroke longevity, it would seem hard to believe that companies like Mercury and Yamaha would bring out new four-stroke technology, Verado or F-series, at huge R & D cost, and not design them for longer life expectancy than their current, lower cost, DFI two-strokes. Otherwise, what reason at all to develop them? Only to compete with tiny market share Honda or Suzuki? I think it's much more than that. If BRP had the financial R & D resources, they would have had their own larger four-strokes on the market for some time now. They are presently too small to be able to compete in this four-stroke outboard market place with the others since being spun off from parent Bombardier, into a new company. Currently DFI two-strokes only have 15% of the total outboard marketplace. Conventional two-strokes, mostly by Mercury, Johnson and Yamaha, have 35%. The question is which way will the 35% go next year, and to whom. With Mercury having the lions share of this 35%, it would seem that those users would stay with Mercury, moving to Optimax or four-stroke EFI/Verado. Same with Yamaha, and actually, probably the same with the Johnson buyers moving to E-tec. So, in all probability, where the 35% two-stroke marketshare is now, is pretty much where it's going to end up next year, brand wise. Right now, unless your boat is badly underpowered (something you DEFINITELY do not want to do with conventional four-stroke due to acceleration problems), a four-stroke engine is already enhancing the re-sale value of your Whaler. If 60% of the current 35% go to four-stroke (making 20% of total share), and 40% go to DFI, then the final market share would end up 70% four-stroke, and 30% DFI. With Verado now on the scene in 7 hp ranges, I'll bet four-stroke total share could end up as high as 75-80% |
| rves |
LHG, I have no reason to doubt your numbers, but I feel market share has more to do with perception than reality when it comes to endurance of engines. If you knew the minimum hours that these companies feel they need their products to last to be salable you would be shocked. The average hours nationwide per year on outboards and pleasure boats in general was extremely low, last time I read something about this. These companies pay more attention to this minimum and what percentage of total cost warranty will eat up than what you might think. I have sat with manufacturer engineers that have recited (bitched about) manufacturing miscalculations that have caused certain engines to last way past their planned obsolessence. That is why you will notice at times old parts that are readily available will all of a sudden increase in price as much as 400% overnight. There is a useful life rating in word of mouth and customer satisfaction and this is also taken into consideration. All of the engine manufacturers can make a better, longer lasting engine, but will it sell? And can they profit by doing so? Many companies feel it is not endurance that sells. I am sick of hearing "SEXY SELLS," but that is what I hear is a major concern with high performance engines these days. Once again it is a balancing act. |
| Peter |
Larry, I think you must be forgetting that BRP has four-stroke technology in their stable (ROTAX). They use high power to displacement four-strokes in their PWC's. Some of these are even supercharged. So it would seem they must know something about four-strokes and I think they have the means to produce a large four-stroke outboard if they chose to do that. Given this, I do wonder whether they may not be jumping into the "four-stroke pool" for other reasons, namely, there is a very credible view that the long term future of four-strokes for use in outboard motors is now currently uncertain at best in light of probable tightening of exhaust emissions. Tighter emissions would likely require four-stroke's use of a catalytic converter or other performance detracting changes which reduce power to weight ratios even further than where the currently are by either lowering power output or increasing weight or a combination of both. It would seem that all of the investment made in developing four-strokes was done at a time when almost everyone, except a few, believed that the emissions regulations would drive two-strokes into extinction. That didn't happen and now, interestingly enough, it seems the table has turned and the two-stroke technology is putting pressure on the four-stroke technology on the emissions front. I have read somewhere recently that Suzuki is developing two-stroke outboards again. This whole longevity question between four-strokes and two-strokes could very well become a moot point in 10 years if the emissions regulations tighten. |
| LHG |
Peter, I think you're right in that the Japanese companies have been pushing the four-stroke technology on us, but they have been highly successful in doing so. The Honda owners are particularly pleased with their products. The Japanese have certainly forced Mercury to re-think outboards, witness the Verado. The fact that Suzuki might be working on DFI is also of interest, as they were essentially a non-player in the two-stroke market. Another indication that two-stroke DFI's may be here to stay will be whether Mercury and Yamaha bring the larger current 2 star models up to 3-star ratings. Mercury just introduced a 3 star 225 3.0 liter Pro Max I understand, which indicates it can be done if needed or wanted. We'll just have to see what shakes out. I have always leaned toward the two-stroke, but of late, the Verado has caugth my interest in 4 cylinder version. When you see them in action, they are impressive. None of the other four-strokes interest me at all. I had never thought the Rotax technology was convertible to outboard engine design, and that is was more of an "inboard" engine |
One comment I found particularly interesting was that from rves where be observes how four-stroke automotive-based engines used in stern drives (I/O) don't seem to have long life spans. The guy that gets 1,000 hours from an automotive four-stroke in a stern drive probably has bragging rights over everyone else. Yet 1,000 hours on a two-stroke outboard is probably considered normal. I am still waiting to see what people think of 150-250 HP four-stroke outboards when they are 10 years old. Right now they are all less than 1-3 years old, and everyone loves them. They have not needed any major work. All of those valves and cams are still working. All of those oil passages are still free from sludge and clogging. Let's wait a few years and see how the four-stroke guys feel when they need a $3,000 overhaul on the valve train. As for Bombardier, I was looking at some satellite photographs of their plant location and it sure looks like there is some room for expansion: I bet those guys are breaking ground right now for expansion of production capacity to fill the void left by dropping the Suzuki line of four-stroke outboards. |
| mikeyairtime |
jimh, the most recent one I saw was yesterday. It was a Honda 130 on a purse seine skiff in San Pedro. Two nights ago there was a show on Discovery about Alaskan salmon fishing and another siener had a big Honda on its skiff. I've seen others in fish harbor, Willmington and working the wet fish fishery offshore. The outfit I worked for when I ran boats for a living in San Pedro had a 19' aluminum work skiff with push knees. We got an Evinrude 175 (don't remember the year but it was the first year the garden hose screwed into the back of the motor) We pushed a big workfloat around and went through 3 power heads in 3 years and Evinrude was very good about replacing them but there was considerable down time.(Big end rod bearing failures) Then it calmed down and went another three years and destroyed itself again. The owner put a Honda 200 on it the minute Honda came out with them, again I don't remember the year and it's run everyday since with zero problems. My 22' aluminum lobster skiff destroyed two Yamaha 130 powerheads in 8 years of commercial fishing and then I sold the boat. When I bought my 170 my only choise was the 90 four-stroke. The best part about four-strokes is their longevity and reliability, and people are willing to sacrifice some performance for it. |
| mikeyairtime |
jimh, I just read your last post and have two comments. Comparing a four stroke outboard to a sterndrive is apples and oranges. What usually kills stern drives is not major engine failure, it's saltwater cooling an iron block. The exhaust and heads usually go. The west coast has a commercial sea urchin fishery and the boat of choise is a 26' Radon with a big block GM stern drive usually a Mercruiser. With fresh water cooling those guys get 10 years out of those motors. |
| rves |
mikeyairtime, I agree, salt is bad but I strongly disagree that is the main killer of stern drive powerplants. Reason is: we are in fresh water here and I was being generous saying 1000 hours, 500 hours tops is more like it for this area. Problems here are valve guides, valve seats, camshafts, head gaskets, etc. The blocks themselves stay good for the most part unless it's a freeze up. I would believe that salt water use could kill one before one of these other failures occur if that is what you meant. Also, I see no difference between fresh water cooled and raw water cooled engines in the endurance category. In this area they all are very poor endurance wise. I just worked on a 1976 Silverton with 426 hours on it. The marina said that guy uses his boat more than any of their other customers. So how much endurance is needed? In 1984 OMC factory engineers told me the Coast Guard was overhauling their V6 outboards at 4000 hours and continuing to run to 6000-8000 hours before they would re-power. This is what I was told, and I never had a reason to doubt this information. Can anyone dispute this? Thanks |
| mikeyairtime |
Sorry I don't know how to do a hyper-link. Look guys I just don't come up with this stuff out of the blue. The tide has turned and four-strokes are proving more reliable with commercial users. www.honda-outboard.com/rescue.htm |
| rves |
mikeyairtime, I am going to use a little Kentucky windage here and say that here we feel that there are two-stroke people and there are four-stroke people. Some people will not have good luck with a two-stroke engines no matter which one they have. They just don't run their engines in a range that behoves two-strokes. The other side of this: I purchased a Honda a few years ago for my tender and I returned it within two days. The owner of the dealership said he was suprised it took so long for me to hate it! He knows me and figured I would just hate the vibration (its a different frequency then a two-stroke) and the heavy intake drone. He said aside from making lots of coins from sail boat people, he felt the same way as me and thought the Honda was a much better anchor than outboard! It is personal preference for me; endurance is not so much an issue here. My personal stuff seems to last regardless of brand and design. They're all good when they run. I will be testing a 30-foot Spectre cat with Verados soon. I wonder if I will hate them? I love the 2.5-liter engines on the same. |
In the case of four-stroke engines replacing two-stroke engines in commercial use, I would offer these observations: The initial high-horsepower four-stroke engine was the 135-HP Honda outboard. This is a very heavy engine. It produces quite modest horsepower for its size and weight. I have seen it used in a number of commercial applications where the operating speed of the vessel was not going to be very high. For example, I have seen it pushing around large barge-like vessels at displacement speeds. In contrast, we now have four-stroke engines of similar size and weight but with the horsepower rating increased to the 225-250 range. These engines are now in use on much higher speed vessels, and are being run at 30-MPH or more for long, sustained runs. It will be interesting to see if the same qualities of the four-stroke are maintained when they are put to this use. If a motor is going to troll all day at idle speeds, there is no question that a four-stroke will perform better than an old two-stroke engine. Running at idle speed has always been a problem for a two-stroke. Running all day at 3500 RPM has never been a problem for a two-stroke. If I ran my automobile engine at 3500 RPM, I would be going about 85-MPH. After 4,000 hours of use, I would have traveled 340,000 miles. I have a lot of respect for the light weight aluminum four-stroke engine in my car, but I have to wonder how it would survive that sort of treatment. Also, I would have changed the oil 68 times (at a 5,000 mile interval) or perhaps as much as 113 times (at a 3,000 mile interval). Considering the high-speed application, the later is probably recommended for long life. Changing the oil 113 times is quite a bit of additional expense and down time for the four-stroke. On the other hand, the modern engine has electronic controls which record the usage pattern of the engine. These show remarkably little time spent at wide-open-throttle. Most of the time an outboard is at low speed operation for most users. This may be key to why the four-stroke engine has been received so well. |
| rves |
Jim , well said ! I would like to add that 4 strokes are less fussy about prop size ( by design ) Wihtout getting too technical A boat that may vary its weight frequently ( commercial fishing for instance ) would like a well designed 4 stroke as it would put up with lugging with ease if the potential preignition is addressed by the managment systems ! A 2 stroke would not like to lug (by design )even if preignition is out of the equation! Throttle mapping is a huge part of race engine design & MY boat vs race car application My outboard powered pleasurecraft spends much more time at or close to full throttle then Our circle track race cars (modifieds)! T |
| hauptjm |
Jim - just chiming in here, but could we add to your equation for durability the number of moving parts? I believe everyone would agree, durability is a lot easier to design into a engine if it has fewer parts to move, lube, calibrate, etc. On this topic the two-stroke has a huge upper hand. |
| mikeyairtime |
Gentlemen, you make many valid points. Jim's observations about the 135 Honda are I believe correct. I also believe the current crop of 225 4 strokes are proving extremely reliable as well, but they are still heavier than a 2 stroke. Mercury's Verado has to use supercharging to get high two stroke like output from a small four stroke at a similar weight but this I suspect will be it's achilles heel. Time will tell. Rves is also correct when he stated there are 2 stroke guys and 4 stroke guys. I get the feeling though that we are trying to prove why 2 strokes (e-tec) are better and not comparing reliability. We haven't even talked about fuel contamination effects on a high pressure fuel injection system. |
| LHG |
But, just assume for a positive moment, that it's (small supercharged displacement) not Verado's Achilles heel. Then what? You've got a real mean runnin' 4-stroke machine, that the others will copy. |
| Peter |
Huh? I don't think anybody, well almost anybody, would be thinking that the Verado is "mean" at its current power to weight ratio. It's got a long, long way to go before its in the lean 'n mean category. Even if they were able to get the weight down, the Verado consumes far too much fuel at WOT to ever be considered much of a "contender". |
| Perry |
jim, I assume you are referring to the old Honda 130 hp motor. The BF 135 is an all new motor. It is lighter than the 130 and essentially a BF 150 without the VTECH. |
Perry--Yes, I was thinking of the older Honda, and I got the horsepower mixed up. The older four-stroke 130-HP was quite a beast in terms of size and weight for the modest horsepower rating it was given. As I said, I believe it was the first four-stroke engine in such a high horsepower rating. Honda probably went very conservatively with its design and rating, so as not to spoil the market with an unreliable product. Again, there are plenty of 10- to 15-year-old two-stroke engines in the 200-HP or higher range still running, but there are no four-stroke outboard engines of that age or horsepower. It will be at least 6-8 years before we can see if a 200-HP four-stroke will carry on into old age in outboard marine service. rves--I find your comment about the difference between the ability of two-stroke and four-stroke engines to tolerate "lugging" to be quite interesting. Perhaps the addition of more modern electronic engine controls (to both types of engines) will help expand their power bands over a wider RPM range, and particularly for the two-stroke engine. |
| rves |
Jim , That comment was based on current mechanical designs of 2 strokes ( there may be existing designs that I am not aware of ) a 2 stroke can be tuned for low end power with ease, but its piston, bearing, rod, and cylinder arangment are the issues ! A needle bearing or roller bearing will not put up with lugging anywhere near as well as a plain bearing ( harmonics ) load distribution, the relationship of the cage to the roller to the races ! A supercharged 2 stroke can last longer in lug conditions (mechanicaly speeking ) as there is always positive pressure on the piston (always ) The rod cap or the bottom of the rod is only there for start up ! with this positive pressure there are less harmonics in the compelte reciporcating assembly! When ever I have made a super low end power 2 stroke, I always used a huge bore with a short stroke ( I never could get it done the other way ) You would think the opposite? I have been involved with engines that were 4 strokes ,using roller & needle bearings along with total loss oiling ( like a 2 stroke ) and they were not mechanicaly good luggers ! Some of my best engines indurance wise were supercharged ! if done correctly a super charger can remove strain from an engine and make it real happy But I feel in a boat (cause you have the worlds largest radiator ) Turbo charging can increase indurance a ton ! I will wait for questions( if any) before I continue cause I do not want to start a arguement here! T |
| mikeyairtime |
Turbocharging would work well for steady cruising where turbo lag is not an issue and would probably be more fuel efficient. I realize there are ways of eliminating lag but the added comlexity of sequetial turbos or variable vanes or anti lag would concern me. My comment about the Verado's superchargering being its achilles heel are also based on this complexity standpoint rather than on out and out supercharger reliability. Rves, these roller / needle bearing total loss oiling four strokes you speak of wouldn't be Jawa's would they. |
| rves |
mikeyairtime, No on JAWA. Let us just say it is a five-letter word. Many of the problems that apply to an ultra-high performance turbo system, such as lag, just do not apply to a design that is set up for endurance as a integral part of an engine's opperating system. Turbo lag in a boat pretty much does not exist on take off, and, in changing speed while on plane, it is negligable if there at all. You might feel a power surge after spool up, but not a lag. Lag comes from poor design. That is, a naturally asparated big block that has no lag to [plane] a boat will have no lag if a turbo is added, as long as it was in a mild state of tune to begin with and mechanical parameters have not been change to accomodate the turbo. As far as complicating things with multi's, NO2, air, water, air, air, and so on, that is a different story. When considering a turbo or supercharger in an endurance calculation you must add back the negative load on intake stroke. Some of the longest lasting reciprocating engines in the world are turbo charged. People assume that turbo's ands blowers kill endurance, but most of the time this has to do with an improper installation in an effort to increase performance beyond an engine's design capability. Turbocharging a gas engine is tough to get correct, but all that cold water a boat has available makes it possible. Supercharging is a little eaiser. It depends on what you are looking for. |
| AZdave |
I remember reading a statistical analysis (several years ago) showing that the Ford Mustang was one of the most dangerous cars in terms of survivorship in an accident. The Ford Fairmont wagon was among the safest. The problem was that the cars really were essentially the same in terms of floor pan and drive line components. The differences were mostly cosmetic, and led to radically different driver demographics. I still read statistical proof that Volvos are safe and Toyotas are reliable. Is it not possible that the way complex machines are used is often the overriding factor in safety or longevity? People who seek safety buy a Volvo and drive it soberly and prudently, while many Toyota owners are real bugs about maintainance. It will be interesting to see what we are saying about these outboards in five years. Dave |
| rves |
..it may take 10 years. Just think of it this way: anyone that has had fuel problems, bad gas, contaminated fuel systems, etc., with two-stroke engines can now add stuck valves, clogged oil passages, and worn guides to the list if they are changing to four-stroke and all else is equal with no improvements in maintenance. The frequency of failure of the items mentioned coincides with fuel problems at about a 3:1 ratio. Now I am sure we are going to have people that step up their maintenance due to the $20,000 they spent on their new four-stroke engine when their old two-stroke was lucky to get an impeller every 7 years. I think at some point a hybird engine will be the winner of this endurance thing. It is hard to beat a power stroke for every cycle, and it is hard to manage all events that need to take place in that one down stroke The mix of both two-stroke and four-stroke technologies looks great from where I am sitting. The mix of both two-stroke and four-stroke technologies will allow much more control than that of just great (two-stroke) fuel managment. And the mix of both two-stroke and four-stroke technologies will be almost as simple as a plain two-stroke if total loss oiling is used. The mix of both two-stroke and four-stroke technologies will weigh less than four-strokes and be more powerful than conventional two-strokes. |
[Administrative post.] |
| Peter J Morgan |
Talking about a mix of two-stroke and four-stroke technologies -- it's not to far away that engines will be able to switch from one to the other and back again at will! I'm referring to the development of camless engines -- please refer to the website: http://www.mrtruck.net/camlesslaneesc.htm One of the pioneers in this new technology is Eddie Sturman of Colorado who invented and developed digital valves used in the Appollo rocket program. He and his wife now run Sturman Industries and have big R&D contracts with very major auto companies. My pick is that within five years we'll see camless motors that will make the performance, fuel economy and emissions of today's four-strokes, both in outboards and cars, pale in comparison. Peter J. Morgan |
