  Anchor: Aluminum Fortress
Author Topic:   Anchor: Aluminum Fortress
jimh posted 05-23-2005 01:26 PM ET (US)   Profile for jimh   Send Email to jimh
We are in the market for a new anchor for our Boston Whaler REVENGE 22 W-T WD. The current anchor is a 13-pound Danforth type. We don't anchor much at all, and the current anchor would be fine except that it is quite a monster to handle. It is heavy. The only place to store it is in the bow anchor locker, and that is too much weight too far forward. (A Revenge with Whaler Drive is not a boat that has too much bow lift, in fact, just the opposite.) I would rather store it in the stern of the boat in the stern cockpit well. The weight would be better there, and for the few times we use an anchor it would not be a hassle digging it out of the deep well.
To save weight, I am considering going to an aluminum anchor. The Fortress model seems to be the preeminent example, both in reputation and price. Are there other options? The perfect anchor would fit easily into the stern live well, but still have enough holding for the rare occassion when we stop for lunch and throw an anchor over the side. Suggestions or comments are invited.
bsmotril posted 05-23-2005 01:53 PM ET (US)     Profile for bsmotril  Send Email to bsmotril
I bought one, and quit using it after the first outing. Even with 10 foot of chain, it was very difficult to get it to set with a current running. The water depth where this happened was in several locations, from 8 to 45 foot depths, with current from 1-3 knots, and a mud-shell bottom. My boat had a lot of windage with the high sides and hardtop, so I'm sure that aggravated the situation. On a lighter boat like an Outrage 21, or smaller, I'd certainly give it another try, and likley get better results. But with a bigger boat, and current, I don't think it is a good choice. Without current, it would also likley work a lot better. BillS
dgp posted 05-23-2005 02:02 PM ET (US)     Profile for dgp  Send Email to dgp
Jim, I use a 9 pound Delta plow-style anchor which is rated for powerboats up to 22 feet. It's small size gets lost in my Montauk's anchor locker. When other's Danforth style anchors drag bottom around me the Delta holds fast and on the first drop every time.
jimp posted 05-23-2005 02:48 PM ET (US)     Profile for jimp  Send Email to jimp
JimH -
I use a Fortress FX-11 (7 pounds) on my 1990 Revenge 22 WT. I use 20-ft of chain. I anchor primarily in light current and rocky bottom and can usually get the anchor to hold. I like its light weight, but 20'ft of chain weighs a ton! The Fortress came with the boat when I bought her in 1997 (the second anchor was a 22-lb Bruce!).
It's a good anchor. If you're not anchoring that often, look at the Guardian anchor, the little brother of the Fortress. 40% cheaper and will likely do the same job. The G-11 Guardian is 6 pounds. Or go smaller still and look at the G-7 at 4 pounds or the FX-7 at 4 pounds also (both rated for boats to 22-ft).
The Fortress Anchor website has a lot of info. West Marine carries a line of both and has prices.
Is the Fortress or Guardian the right answer? Don't know, but my FX-11 works for me.
JimP
JohnJ80 posted 05-23-2005 03:13 PM ET (US)     Profile for JohnJ80  Send Email to JohnJ80
I have the fortress too and have no problems with it. We anchor on a primarily a sand bottom which is ideal for a danforth style anchor.
The trick with them is that you need to allow time for them to get to the bottom. They don't drop as fast as a steel one. Jim - I know you are a sailor, you will get this as far as anchoring goes - head into the wind, drop the anchor while holdin position, then pay out line as the boat drifts back. You won't have any problems.
If you have to anchor in rocky bottoms or very hard bottoms, then I think a Bruce style anchor is best since it can hook around rocks better and with less potential to bend parts of it.
J
andygere posted 05-23-2005 03:24 PM ET (US)     Profile for andygere  Send Email to andygere
jimh,
I use a Fortress FX-7 to anchor my Outrage 22 Cuddy. At just 4 pounds, it's easy to handle, and light weight was a big consideration for me. Like jimp, I use 20 feet of chain (3/16" proof coil, spliced directly to the line) which really seems to be the key to getting good performance from these anchors, at least according to the membership here. The reason I wanted a light weight anchor is that the Outrage Cuddy does not have an anchor locker, but it does have a rode locker in the bow, accessed via a rope deck pipe. Since I don't anchor very frequently, I keep the rode in the locker, with the chain end held to the rope pipe with a bungee and cordlock. To anchor, I usually bring the rode back to the cockpit to shackle the anchor to the chain, and deploy from the safety of the deck. It works well enough, and the lightweight anchor makes it that much easier. In very calm anchorages, I'll just walk the anchor up to the bow and shackle it on there. If I know I'll be anchoring during a trip, I'll stow the anchor in the forward Igloo cooler for convenience. Otherwise, it stays in the forward locker in the cuddy (what would probably be the anchor locker in a standard Outrage).
I don't know if the overall weight of anchor and chain would be any lower than what you are using now, but it wouldn't be that hard to calculate. You may also be able to use less chain with good results if you don't anchor where there is strong current. My understanding of the need for the long chain is in part to get the anchor down faster in order to hook up in moving water. Since I do take a few trips each year to an area with some swift water, this was a consideration for me, and I followed the suggestions of others here without any of my own experimentation. The way it's configured, I have never had difficulty getting a good set in a variety of bottom conditions. Also, the finish and construction of the Fortess is top notch, and is commensurate with the price in my opinion.
elaelap posted 05-23-2005 05:36 PM ET (US)     Profile for elaelap  Send Email to elaelap
I can't believe that twenty or thirty pounds up forward can make much of a difference on a boat the size of a Revenge 22 Whaler Drive, Jim, but what do I know? I'd sure hate to give up the convenience and safety of having an anchor right up there in the bow, no matter the weight saving. I suspect (no, I'm sure) that you're much more organized aboard than I, but consider the possibility of stuff and clutter ending up on top of the anchor, chain and rode in that easily-accessible aft locker, and the big nervous-making mess you might find just when you need to drop your hook in an emergency situation...and then there's the mad dash forward with an armful of anchor, chain and rode, maybe in lumpy windy conditions, and hurriedly making fast with the chain rattling around and the anchor gouging the deck. No, I sure think the anchor belongs in the bow.
As for chain, I've always been taught that it's more important than anchor type or weight. Andy's right when he says that chain helps a light anchor sink swiftly and set, but perhaps its most important function is as a shock absorber. Now that sounds really counter-intuitive--a rigid chain serving as a shock absorber--but the weight of the chain causes it to droop forming a 'catenary (sp?) curve' which absorbs much of the shock as the boat surges against the anchor. You can go to lighter chain with a lighter anchor, of course, but then you'll lose this shock absorbing benefit and make the anchor much more likely to break out when it shouldn't.
I've got an oversized Dansforth about the size of yours with I guess twelve or fifteen feet of chain in my bow locker plus a little collapsable lunch hook without chain up there in my Outrage 18...of course I want weight up forward to trim my boat the way I like (I also keep about 35 two and two-and-one-half pound lead weights in the cooler seat forward of my console).
Tony
Buckda posted 05-23-2005 05:56 PM ET (US)     Profile for Buckda  Send Email to Buckda
I too think that the weight shouldn't matter much on your boat, although I suspect that the addition of all your gear stowed in the forward cuddy is what starts to swing the balance to bow-heavy when you and Christine are on trips.
My respectful solution:
Twin E-Tec 200's on that Whaler Drive!
Seriously -
I really, really like my Bruce anchor. It's only 3 KG, and I know that it's not used by many folks up here in the Midwest, but the anchor holds in almost bottom, and it automatically resets when the wind shifts. I anchored just outside the "surf zone" in 3 foot waves regularly off Grand Mere state park on Lake Michigan numerous times last year, and each time, on my swim to shore and back out to the boat, I'd use the snorkel and go down to check the anchor: No dragging, solid as a rock, and buried in the sand.
Use a roller on the bow pulpit to deploy it just like you would a danforth or fortress.
Just my opinion.
Dave
CHRISWEIGHT posted 05-23-2005 06:02 PM ET (US)     Profile for CHRISWEIGHT  Send Email to CHRISWEIGHT
Jimh
saw these at the London boat show and the video appeared to suggest that they would punch well above thier weight so to speak, they are also self righting.
I think they were quite expensive about £100 pounds for a twenty foot boat as I remember but worth a look.
regards chris.
www.anchorright.com.au/docs/sarca_brochure.pdf
Buckda posted 05-23-2005 06:03 PM ET (US)     Profile for Buckda  Send Email to Buckda
correction to my above post:
It holds in "almost ANY bottom".
Dave
Backlash posted 05-23-2005 11:05 PM ET (US)     Profile for Backlash  Send Email to Backlash
Jim,
When considering truly lightweight anchors, I believe Fortress is the only choice.
Like Andy, I have the Fortress FX-7 (4 lbs.)with 20' of chain. I have had it for over 10 years now and couldn't be happier. It has tenacious holding in a soft bottom and usually must be "powered" out to retreive. The longer chain will reduce the tendency to "sail" in a strong current.
The Fortress is clearly the Whaler of anchors!
Steve
hauptjm posted 05-24-2005 12:41 AM ET (US)     Profile for hauptjm
jimh,
Whatever anchor you decide on (I'm a galvanized steel man myself), DO NOT "hide" that anchor away somewhere as a convenience. You may not "plan" on anchoring much and that's fine, but the anchor is a major line of defense in an emergency. Loosing power coming in a channel bordered by rocks with a current can be horrifing if you can't stop the drift with your anchor.
Check the regulations where you typically boat. There may even be a requirement to have it at the ready. Just a thought!
Jim
jimh posted 05-24-2005 07:56 AM ET (US)     Profile for jimh  Send Email to jimh
Re the weight in the bow: If I rigged the anchor on the bow pulpit I would have about 13-lbs of anchor, 5-lbs of chain, and 7-lbs of anchor roller sitting on the extreme front of the boat. That weight is about 27-feet from the propeller, which is where the force trying to lift the bow is coming from. If I remove all of that weight from the bow, I remove 25 x 27 = 675 ft-lbs of moment trying to hold the bow down. Or, you could say I increase the lift on the bow by 675-ft-lbs of moment.
Beaner posted 05-24-2005 08:15 AM ET (US)     Profile for Beaner  Send Email to Beaner
I have a FX-7 with 6 feet of 5/16 chain for my 170 Montauk. I have never had a problem setting this anchor in a fast moving current in approx 20 feet of water (sand/mud bottom). I now use a Danforth high tensile that is 1 pound heaver, also with excellent results. I switched only becuase the Fortress is too big to fit comfortably in the anchor locker. The Fortress is now stored broken down in the console in a Fortress storage bag.
Backlash posted 05-24-2005 08:23 AM ET (US)     Profile for Backlash  Send Email to Backlash
Jim,
I agree 100% with Jim on this. I'm a firm believer that an anchor should be mounted on a bow roller, of some type, with a chain tensioner for instant deployment.
7 pounds of bow roller? Are you kidding? I doubt if my bow roller and chain tensioner together weigh over a pound!
The bow roller that came with your Revenge is one of the largest I have ever seen and belongs on a much larger boat.
Get an FX-7 (4#), 10 or 20 feet of chain (5#), and an appropriately sized anchor roller and chain tensioner (2#), and you're all set. This would reduce your ft-lbs of moment to 297 (44%), if that really matters.
Steve
handn posted 05-24-2005 10:37 AM ET (US)     Profile for handn  Send Email to handn
The Fortress can be carried broken down which is even more of a space saver. It re-assembles quickly. The light weight is also nice. I now carry my little fortress as a backup.
I agree that the anchor is the boat's emergency brake. When I had a single engined boat, I used mine several times for that purpose. When I needed it, I needed it fast.
elaelap posted 05-24-2005 02:52 PM ET (US)     Profile for elaelap  Send Email to elaelap
Because I so strongly believe that the safety and convenience factors of having an anchor in the bow trump any other consideration, I shouldn't even get involved in discussions of trim and 'moment' forces. I can't resist the following thoughts, however, and I know Jim and you others will consider my vast lack of knowledge of physics if the following makes no sense at all:
It seems that jimh is concerned about every last pound of weight out there on the bow because his boat is slow to come up on plane (or has difficulty maintaining plane at reasonably low speeds), right? Jimh has apparently made a calculation that places the 'fulcrum' of the forces way, way aft, right back at his motors, which--and again forgive my ignorance of such things--doesn't make any sense to me at all. Seems to me, intuitively, that the 'fulcrum' is more at the midships of his boat as she begins to accellerate, and moves further aft as the boat climbs up onto plane. I sure don't think that this point EVER reaches all the way back to the motors themselves, unless we're talking about a radical speedboat blasting along totally out of the water planing on her cavitation plates. If I'm right about this concept, then the negative effect of having the anchor's weight way up there in the eyes of the craft is substantially minimized, though its effect does increase as the boat's speed increases on plane and what I'm calling the 'fulcrum' moves further back.
Tony (And please don't laugh too loudly...I was an English major at UC Berkeley, not one of those engineering guys walking around with a slide rule in a leather scabbard strapped to their belts.)
elaelap posted 05-24-2005 03:01 PM ET (US)     Profile for elaelap  Send Email to elaelap
accelerate...just one 'l'! See, they didn't even teach us to spell words pertaining to the physical universe back then in the arty farty world of English literature.
Plotman posted 05-24-2005 05:37 PM ET (US)     Profile for Plotman  Send Email to Plotman
Count me as a big fan of the bruce anchor - I have to check to see if mine is an 8 or 11. It sets quickly, even in marginal bottoms, and is significantly more compact that a danforth or fortress. IMHO, the fortress makes sense when you want to be able to use a 30 lb anchor instead of a 50, but the weight difference between aluminum and steel in the size needed for a 22 or even a 25 foot whaler is immaterial.
My bruce started out as my second anchor, however, it has taken over from the danforth that lives up in the bow locker (no pulpit on this boat.) It lives in the stern fishwell, and the rhode lives in a mesh bag. About 2 feet of the bitter end sticks out of the bottom of the bag and has an eye on it. I don't even have any chain on it. In a pinch you can put the eye on the end over a cleat and pitch the whole package overboard. The line will pay out of the bag and not foul the anchor.
Whatever anchor you chooose, I am a big fan of the rhode bags. Yes, it takes a minuter or two to stuff the line back into the bag after you use it, but it keeps things from getting tangled if you put other stuff in the locker with the anchor and rhode.
David
Knot at Work posted 05-24-2005 06:15 PM ET (US)     Profile for Knot at Work  Send Email to Knot at Work
Never, EVER, NEVER tie your anchor to your stern.
NEVER EVER NEVER
andiamo posted 05-24-2005 06:59 PM ET (US)     Profile for andiamo  Send Email to andiamo
Why not Knot? I can think of several anchorages where the wind and wave action are at 180 degrees and a stern anchor is the most comfortable way to ride as it allows the bow to ride into the wave action.
macfam posted 05-24-2005 08:57 PM ET (US)     Profile for macfam  Send Email to macfam
jimh,
On my 25 Revenge WT, I use the Fortress w/chain at the bow, and a regular Danforth w/chain as the stern/spare anchor.
I (and my wife)could not be more pleased with the Fortress performance.
With the Walk Thru feature, it's so easy to get to the bow, and that is usually my wifes duty(her choice, not mine.
She loves the light weight and the fast hold. We are generally in shallow water, less that 30 ft.
Just fantastic.
Compared to other anchors, it's so easy to handle and get out of the anchor locker, use, and then retrieve and store.
We often have several boats stop by and raft up for a while, and I have been shocked at the holding power of that anchor.
Worth the price. Even has a better garanteee than Boston Whalers!
I think you'd be pleased with it's performance.
elaelap posted 05-24-2005 08:58 PM ET (US)     Profile for elaelap  Send Email to elaelap
I've never experienced the situation described by andiamo, but I think he holds a 100 ton license and is an experienced sailor and fisherman, so I suppose he's correct in very limited circumstances. I think (no, I KNOW) that Knots is absolutely correct as a general rule. I've dropped a little lunch hook without chain and letting out only a very little scope off the sterns of sailboats and two Whalers when I've been in calm, shallow water and have needed a brief break, but I've been taught that in ordinary circumstances one should always anchor off the bow. Even when using two anchors I make their rodes fast to the bow cleats (an exception--dropping a hook off the stern and walking another anchor or bow line to shore on a protected beach). One major problem that jumps to mind with anchoring off the stern, especially with one of the smaller Whalers, is the real possibility of wind waves breaking over their cutaway transoms; another similar problem would occur when trying to break out the anchor by backing up over it into the wind and the waves. With anchoring as with most other boating evolutions, keep your bow into the wind and waves...
So Knots, you're right as usual (at least when you stick to opinions concerning seamanship :-)!).
Tony
where2 posted 05-24-2005 10:50 PM ET (US)     Profile for where2  Send Email to where2
Where cost is a consideration over beauty, the Guardian series by the makers of Fortress are not anodized, while the Fortress anchors ARE anodized (thus they cost more).
On my 15' Sport, I have the smallest guardian ever made (in fact, I shortened the shank so it would stow in the anchor locker). Attached to it is roughly 8' of 5/16" stainless steel chain, followed by 200' of 3/8" double braid line. I generally anchor in sand and have not had much difficulty getting the previous 4lb galvanized danforth, or the guardian to stick. However, in anchoring my father's 30' Houseboat with an aluminum anchor and 10' of 3/8" chain, I have seen a tendancy to skim the surface rather than digging on on more than one anchoring occasion, with the same sand bottom. (I've been tossing anchors off their houseboat since I was big enough to lift an anchor).
One thing I will note about the Guardian: I have seen some electrolysis between the SS shackle and the bare aluminum anchor. I've noticed minor pitting where the chain has simply been in contact with the fluke while stowed in a damp locker after use in saltwater. The electrolysis is not to the point of being a threat to safety, it's simply cosmetic. However, I was surprised to see even cosmetic damage, since the anchors are so highly regarded. Maybe the anodizing on a Fortress resists contact with SS better than bare aluminum. My father's aluminum anchor is much older and shows far fewer signs of pitting and electrolysis. Although, he uses galvanized chain and the zinc is less noble than the aluminum in that case.
For a book with great detail on anchoring, I still recommend the book "The Complete Book of Anchoring and Mooring" by Earl R. Heinz which I have mentioned before. Some rainy day I'll finish reading it...
Chuck Tribolet posted 05-24-2005 11:19 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
4 pound Fortress, rated by mfg for 16-27' boat, $104.99
5 pound Danforth Hi-Tensile, rated by mfg for 18-25' boat, $87.99.
Your choice.
coralgater posted 05-24-2005 11:39 PM ET (US)     Profile for coralgater  Send Email to coralgater
Maybe someone can advise me the need for 20 ft of chain
on boats approx 20-23 ft. I use this style aluminum anchor
for many years and have had no problem in quick grabs in
sand,grass, shell bottoms with 4-6 ft chain. At present
using on 22 OF and enjoy the light wgt when having to
walk with it onto flats or manually set it in party raft-ups. In addition the anchor line is never scuffed up with
shorter length chain.
elaelap posted 05-25-2005 02:56 AM ET (US)     Profile for elaelap  Send Email to elaelap
coralgater,
A longer chain make a more effective catenary curve 'shock absorber' when the wind, tides and/or seas kick up (you might want to check out my post above concerning this). A longer chain offers more protection against the anchor line itself chaffing on rocks. A longer, heavier chain helps the anchor set, and its weight at the head of the anchor keeps the shank more parallel to the bottom, thus further preventing the anchor from accidentally breaking free.
All this is nothing but words and theory in your situation, obviously, since your setup has worked well for you over the years. On the northern California coast the bottom shelves swiftly and I find myself anchoring on occasion in up to 100 ft of water over a sandy bottom. Obviously the more scope the better, but my rode is less than 300 ft, and with a shorter scope more chain is necessary. I'm sure you know that many cruising sailboats rig their main hook with all-chain rode...very expensive but durable, coral-resistant, and bomb proof.*
Anyway, different strokes for different scopes, and a never-ending topic to BS about over a few cold ones in a waterfront dive.
Tony
*Ironically, with all chain rode you need to set up a kind of snubber between a loop of four or five feet of the chain, since when the wind, waves and/or tidal currents are strong enough to almost fully straighten that helpful catenary curve, all shock absorbing benefits are gone, and without the elasticity of non-chain anchor rode, the now bar-like chain could easily pull the cleats out of your boat as she surges against the set anchor.
jimh posted 05-25-2005 08:27 AM ET (US)     Profile for jimh  Send Email to jimh
Some comments:
Advice to keep the anchor at the ready is good advice. I don't like to stow the anchor on the bow pulpit because it becomes a battering ram. If you are in a tight docking situation with cross winds, I'd rather not have an anchor as the most forward part of the boat. I'll give some thought to keeping a lighter anchor in the bow locker.
As for not anchoring by the stern, we used to do just that all the time with our sailboat. A lot of other sailors thought we were nuts, too. But at anchor with the roller furled genoa on the bow, our boat would sail on its mooring. In a breeze it would relentlessly tack back and forth. Moving the anchor to the stern let the furled genoa act as a riding sail, and we could sit steady all afternoon in a breeze; no more sailing around the anchorage on our mooring.
Also I find handling the anchor to be much more easily accomplished from the cockpit than the foredeck. Once the anchor is over the side you can walk the line to the bow to make it fast if you need to keep the boat pointed into the wind and waves.
A Revenge with Whaler Drive is very easy to get on plane; it will probably plane at a lower speed than most other Boston Whaler boats. You can hold it on plane down to about 13-15 MPH. The problem on my boat is the lack of weight on the transom. With just a single engine, and a not very heavy single engine at that, there is no bow lift at static trim. The boat sits very level. Compared to a boat like WHALE LURE with a pair of engines on a bracket whose weight creates significant bow lift, our Revenge has none. If we want the bow to rise a little we have to try to lift it with the engine trim. In some sea states it is preferable to run the bow a little light. That is why I want to take the 25-pounds of anchor tackle off of the extreme forward end of the boat. An alternative solution is to buy two new engines and increase the weight on the transom; this is a possibility in the future but not this season.
HAPPYJIM posted 05-25-2005 08:38 AM ET (US)     Profile for HAPPYJIM  Send Email to HAPPYJIM
Don't just think of a anchor as a item used for occasional use at lunch time. I was fishing with a friend in a 3 mile wide river when the motor just quit. We just drifted while trying to work on it and figure out what was wrong. A series of showers/wind came through and started pushing us pretty good. We did some troubleshooting for a short time. Winds were whipping pretty good by now. I thought it prudent to set the anchor to hold us and to keep the bow into the wind. It was a 19 foot boat and only 2 months old. The anchor was a little small but what concerned me was the short 5 foot of chain. It would not set even with all 100 foot of rode out in about 6 feet of water. The anchor kept skipping and after many attempts to set failed, I was getting very concerned. We drifted better than 2 miles and the cypress stump lined shore were fast approaching. As a last resort, we franticly gathered every fishing sinker we had and tied them to the chain. It set this time and we both breathed a big sigh of relief. She tried the motor again and it started right up with no problem. This whole ordeal lasted about an hour. We had plenty of time to think it out. If the motor would have quit while fishing the surf in the ocean it would have been disastrous for her new boat and our safety with that anchor setup. After that learning experience, I don't think you can have too much chain or too heavy an anchor.
Moe posted 05-25-2005 09:26 AM ET (US)     Profile for Moe  Send Email to Moe
Because Barb will have anchor duty on our 26' sailboat, I recently bought a Guardian G-11, the largest aluminum anchor that will fit in our bow locker. The major difference between it and the Fortress is that it has a fixed 32 degree fluke angle, and can't be set to 45 degrees for soft mud. Fortress rates the smaller FX-7 as having more holding power at 32 degrees, but I don't buy that. I went with the larger G-11 and lower price.
I'm replacing the 26' of 1/4" chain with their recommended 3/16" for her. Fortress advises 6' of chain for every 25' of water depth, and that's about as deep as we'll anchor, but I started out with 18' and will cut back to maybe 12-13' if she needs less weight.
Because of the lighter anchor/chain, we're going to use Yale Cordage's "brait" rode (3/8" x 200') which is easy on the hands but has even more stretch than hard on the hands twisted nylon. The stretch of the smaller diameter AND the brait should help with the lighter anchor/chain set. It also flakes without twist better.
That being said, it's just a light Danforth, and not ideal for rocks, gravel, grass, and soft mud (Bruce, Claw, Delta, CQR territory), nor do I feel good about using it alone in storm conditions. For that, we're keeping the heavy chain and will be carrying it and a rode with either a Lewmar "claw" (Bruce clone) or a Bulwagga in a tub below decks. For storm conditions, both will be deployed, off the bow.
Here's one of several Powerboat Reports (Practical Sailor) anchor tests:
http://www.noteco.com/bulwagga/multimedia/powerboat_pdf_Jan_01.pdf
To address the sailing at anchor problem, try running a line from the rode to a stern cleat, making a bridle of sorts that will keep the boat at an angle to the rode.
Moe
newt posted 05-25-2005 10:44 AM ET (US)     Profile for newt  Send Email to newt
Regarding anchoring from the cockpit, I picked up a good tip from someone here (sorry, but I don't recall who it was) that I have implemented when anchoring in my V20 Revenge (which is not a walk-thru).
I now keep a bow line attached to the mooring bit and run it back to the cockpit outside of the rails to the mid-ship cleat. The bow line has a loop tied in the end. My anchor and rhode sit in a milk crate in the cockpit. Deployment is simple and safe. I toss the anchor over the side, pay out enough rode, tug on the anchor line until I know the anchor is set, and then quickly double up a section of rhode and tie it to the bow line with a sheet bend and let the boat drift back until the bow line comes tight. The slack remainder of the rhode continues from the sheet bend back to the cockpit and is used to pull the bow line and rhode back to the cockpit when its time to pull the anchor up.
So far, this technique has worked well and allows me to anchor without scrambling around the windsheild up to the bow.
home Aside posted 05-25-2005 11:53 AM ET (US)     Profile for home Aside  Send Email to home Aside
I agree with Knot regarding not ever anchoring from the stearn, at least in a river or other area with strong currents. I knew a Detroit Police Underwater Recovery Team member who drowned during a rescue, precipitated by a boat owner who anchored his small pleasure craft from the stearn in the Detroit River to watch the Grand Prix races. The anchor held tight, the boat started taking on water over the stearn, the anchor line was then pulling too tight to untie from the cleat, no knife to cut the line,and the boat went down. All the occupants were rescued from the water, the officer drowned when he lost the seal in his dry suit.
Pat
Knot at Work posted 05-25-2005 01:45 PM ET (US)     Profile for Knot at Work  Send Email to Knot at Work
Pat,
you gave a perfect example of why knot. We recently lost a small boater and his fiance recently off Pensacola Beach. The boat was found with Anchor line tied to stern Clean. His boat turned stern first into oncoming swells and drew water over the stern. Guess is he had trouble getting his anchor off and tied to stern to pull. As he pulled the boat swung into swell, took water and weighted down by the motor and sudden increase in water weight, boat went down.
They recovered one body and a diver found his boat on the bottom, in 90 feet of water with the Anchor attached to the stern.
foolish.
elaelap posted 05-25-2005 07:13 PM ET (US)     Profile for elaelap  Send Email to elaelap
Again, Pat and Knots are right as a 95% general rule, but there are exceptions as noted in several posts above. So much depends on weather and sea condition, type of bottom, type of craft, length of stay on anchor, etc, that like in most things related to boating there are no anchoring absolutes. Jimh's post reminded me how my dad and I used to anchor our old 32 ft wooden cutter. Sarah W was a double-ender and we'd anchor from the stern--at least when we weren't going to be away from our boat for long and when the weather was decent--and we'd break the anchor free if need be with our sheet winch. The boat's mast, stays'l clutter, and furling jib out on the bowspit would weathercock the boat so she faced almost directly stern on into the wind and seas, but since she was double-ended this posed absolutely no problem at all. We never had to anchor in a serious blow in that fine old cutter...if we had we would have anchored from the bow.
Tony
TRAFFICLAWYER posted 05-25-2005 09:21 PM ET (US)     Profile for TRAFFICLAWYER
HAD a fx11, traded it back to west for a danforth II, it is a POS, too light, floats by in a strong current, tough to set,etc.
Howard Wright posted 06-04-2005 04:37 PM ET (US)     Profile for Howard Wright  Send Email to Howard Wright
I use 2 Fortress anchors - a lunch hook in the back with a small fortress anchor and anchor bag in the stern bilge locker, and the main anchor is a bigger Fortress that I keep on anchor chocks on the bow with the chain and rode going down thru the hawsepipe into the anchor locker. I have a '79 Revenge 22. Since most of my anchoring is done in different places on the west coast, I find that these anchors provide great holding with little weight. I also own a small Bruce, but found that stowing them is problematic. If I had a bow roller on the bow, that would be no problem, but I have yet to find a bow roller that would fit the limited space available on the Revenge, other than having something custom-made. As anyone made a bow-roller set-up for an old Revenge 22?
Howard
LHG posted 06-04-2005 05:31 PM ET (US)     Profile for LHG
For my money and uses, the best anchor is the Danforth Hi-Tensile. These are MUCH better, and easier to handle, and less weight, than the standard Danforth's, which I don't like at all.
The compact and 5# weight 5H is all that's needed for a 22. I use the 12# 12H on my 25, and it's overkill, and would also work fine on a 27-30' boat. These are expensive, but you get what you pay for. Since mine are carried on a pulpit, I keep them spray painted chrome. They look pretty good.
Bass Pro, at least the Ft Lauderdale location, is now selling highly polished (like an SS prop) danforth style SS anchors. For an anchor continuously carried on a pulpit, these are beautiful, real class, just like the mega yachts and big sprortfishers use. Maybe one of these days.....
Mumbo Jumbo posted 06-04-2005 09:17 PM ET (US)     Profile for Mumbo Jumbo  Send Email to Mumbo Jumbo
I have a Fortress -it sails in current and I don't trust it. My advice is to get a Danforth Hi-tensile or a Bruce that is a size larger that what is usually recommended. Nothing is more important than ground tackle does, and it must be more than just "sufficent."
Mumbo Jumbo posted 06-04-2005 09:19 PM ET (US)     Profile for Mumbo Jumbo  Send Email to Mumbo Jumbo
My bad. Let me restate: Nothing is more important than ground tackle.
Period.
