posted 07-13-2005 09:43 AM ET (US)
Now that I have a NAVMAN 3100 fuel flow instrument, I have a more accurate record of my fuel consumption. Here are some data from a recent trip:Boat: REVENGE 22 W-T WD
Motor: Evinrude V6 225-HP two-stroke
Total Distance: 283.8 miles
Total Fuel: 151.3 gallons
Average MPG: 1.875
This is fairly close to my previous seat of the pants estimate of about 1.75-MPG based on coarse measurements of distance and fuel.
The 225-HP two-stroke is a 3.0-liter loop charged engine with carburetors. It has never been known as a fuel miser. The boat was loaded with gear, crew, and fuel, so it probably weighed 4400 pounds or more during most of this cruise.
On one long leg in nice seas we averaged about 1.9 MPG. Coming back over some of that water in rough, upwind conditions the mileage dropped to about 1.6 MPG.
According to the Navman, fuel economy at idle is not very good, about 1.4 to 1.6 MPG.
My impression of newer engines is they have much better fuel economy at idle speeds, often four times better. At cruising speeds the new engines probably only have a 50-percent improvement potential. Although you may spend considerable time at idle, most of the fuel gets burned at cruising speeds.
I would estimate (or guess, really) that if I had a newer engine I would probably get about 3-MPG tops at cruise, which is a 50-percent improvement over the current best cruise economy of about 2-MPG. I would get more like 6-MPG at idle and slow speeds. This could improve my fuel consumption to around, say, an average of 2.875 MPG, or about 1-MPG better than current.
Using this figure, I could have made the trip in 283/2.875=98.4 gallons, or a savings of 151.3 - 98.4 = 52.8 gallons.
Fuel prices were in region of $2.75/gallon on average, so I would have saved about $2.75 X 52.8 = $145 on fuel during the cruise.
Typically we only use the boat like this about 3-4 times a year. My potential from fuel savings would be roughly $145 X 4 = $580 per year.
A new engine would probably cost about $10,000 allowing for some trade-in value on the current engine. To recover the cost of the new engine via fuel savings, at the current rate of use and current fuel prices, would take about 10,000/580=17 years.
The current engine has some virtues: it is quite simple in its design and has relatively low maintenance. It is also paid for and has already undergone most of its depreciation in value. Once you get over the shock of some of those fuel mileage numbers, it still looks like an old friend that you might want to keep around for a while.
