| Author | Topic: OUTRAGE 22 Trim Tabs |
| whaler131 |
I would like to put trim tabs on my 1988 OUTRAGE 22 over the winter. What size would fit best? Looks to me that space is a problem with the swim platform and depth finder on the transom. Thanks |
| banff22 |
Lenco 12 X 12E's. It will take a little thought as to their exact positioning but they work great. Peter |
| kingfish |
Second that- John |
| whaler131 |
Thank you, Joe |
When installing trim tabs, is it important that the hinge of the trim tab be located close to the hull bottom? I saw an installation of trim tabs on an OUTRAGE 22 where the trim tabs were located several inches above the hull bottom, and I wondered if they would work more effectively if located in line with the hull bottom. Do any of the trim tab manufacturers have specific instructions for installation on Boston Whaler OUTRAGE series hulls? |
| rtk |
My Lenco trim tab instruction manual said the hinge should be mounted 3/8 of an inch above the bottom of the boat. www.lencomarine.com/Trim%20Tabs%20Pages/trimtabinstallat.html The Bennett tabs I removed were close to even with the bottom. I think this contradicts the Bennett instructions. Rich |
| kingfish |
I concur with rtk in regards the Lenco directions to install the hinge above the deadrise line, and that's what I did with my Lenco 12x12Es on my Outrage 22 and they have performed satisfactorily for me. Were I to do it again today, at least on an Outrage 22, I would install the hinges right on the deadrise line though, due to the loss of efficiency the tabs suffer as they cross the profile of the outboard "sponsons" of an Outrage 22 hull bottom. I have even toyed with the notion of fabricating "pads" for the bottoms of my tabs to match the profiles of the sponsons, but have hesitated due to the sideways force I think might be imposed on the hinges when turning. Jim, unless the recollection you cited is in reference to the sponson profile that is below the tab hinges that I just talked about, those tabs must have been useless. There isn't enough travel in trim tab actuators to accomodate a setting "several inches" above the deadrise line, and still have travel left to exert effect on the water coming under the hull. I notice the Lenco tabs that BW installs at the factory are installed right on the deadrise line. John |
| Peter |
My 22 Revenge had Bennett Sport Tabs (narrower and longer tabs each powered by twin hydraulic rams). These were mounted inboard of the sponsons, as I recall, perhaps just ever so slightly above the transom/bottom interface. |
I'll link to a picture later, but for now I'll try to describe. These tabs were in line with the central hull V-bottom, but were mounted outboard so that most of the tab was actually working over the sponson. This put the tab a couple of inches above the sponson. The advantage of this mounting was that it placed the actuator far enough outboard, too, so that it did not have the problem of fitting to the transom right where the thickness of the transom changes. As kingfish knows, if you put the tabs a little more inboard the actuator will end up landing right at the edge between the thick and thin areas of the transom on the 22-foot hull. |
| kingfish |
Jim- That is the condition that I tried to describe above on my Outrage 22. With a 12" wide tab mounted as far outboard as possible on or near and parallel with the deadrise line, (which I believe is the preferred location), but short of the reverse chine, the tab crosses the sponson as you and I have described. Recognizing the loss of efficiency caused by that condition is why I would now mount them right on the extended deadrise line. Mine work OK like they are, and I continue to be very pleased with them, but I think they would work even better by reducing the loss of efficiency caused by the sponsons. Tabs could theoretically be mounted far enough inboard on an Outrage 22 so as to be entirely over the uninterrupted deadrise portion of the hull bottom, and would be more efficient per se, but the tabs would then be in the way for the potential of mounting an auxiliary motor, and possibly in the way of transducers, etc., as well as no longer acting from as near as possible to the outside edges of the hull bottom. It is an interesting thing about the way my upper actuator brackets fell half way on and half way off the thickened transom area with the tabs located as I have described, because Jechura mounted the same tabs in the same place, or nearly so as far as I can tell, and his upper actuator brackets fall completely on the thinner transom section. I don't think there is any difference in hull or transom configurations from one year to another, but I'm thinking Jerry might have mounted his tabs just a little lower, and maybe just a little further outboard, perhaps crowding the reverse chine a little more than I did. And there is probably a little play in the joint of the lower actuator bracket that might allow a little fudging to avoid straddling the break line in the transom, when added to the other factors. John |
| rbruce |
Why not installing a Doel-fin in your motor. It allows better control with the trim of the motor of the attitude of the boat... |
| kingfish |
Trim tabs provide much more control, especially lateral control over "wind lean", prop torque and asymmetrical loading, than DoelFins. I have used, and recommend, DoelFins on smaller boats, and I used them on my Outrage 22 before I installed the tabs. If your motor is set to the correct height for optimum performance, with the AV plate above the lowest part of your hull bottom, then DoelFins really have no effect at all at mid to high planing speeds anyway, because they are above the water. They are helpful in getting onto plane more quickly and being able to hold plane at lower speeds. I have one friend with a 21 Walkaround whose technical expertise I rely on, and who really got me aimed towards trim tabs to begin with, who uses *both* trim tabs and DoelFins. John |
| Plotman |
rbruce- If a doel fin is touching the water when your boat is on plane, then your motor is mounted too low. These fins should be clear of the water when the boat is on plane if the engine is installed properly. I am convnced that the reason 95% of people who install these things is that they are trying to correct problems that would be better solved by moving the engine up a hole or three. Also, tabs give you the ability to correct a list induced by a crosswind or uneven loading of people/cargo in a boat. David |
| rtk |
I do think I would also mount them a little lower, 1/8 to 3/16 of an inch off the bottom. The tabs perform pretty good, but on windy days I get alot of "wind lean" that can be a bit tough to correct. I think I am going to put a 3/16 or so shim between the actuator and the trim tab so the tabs run a bit deeper when full down. Adding a "pad" to the bottom of the trim tab has crossed my mine too. The 12 x 12 would have been better for my boat, but with transducers and a kicker motor the 12 X 9 was a better fit. Advantage of the Lenco trim tabs is you do not have to run the wiring through the transom at the point of attachment of the actuator to the transom, you can run the wire over the transom, or through the transom anywhere you choose. The Bennett hydraulic line attachment is where the actuator is attached on the transom, no options. Rich |
| kingfish |
I chose to run the electric cables on my Lencos through the transom behind the actuator pad; I'm nervous about running cables or hoses over the transom, for fear of snagging them with something, or pinching them. I installed clamshells over the cables where they came through the transom in the motor well. Some other advantages electrics have over hydraulics (tabs) is less stuff to contend with on the install, less stuff to find room for (hydraulic pump and reservoir), and quicker and crisper response. John |
Here is an installation of Trim Tabs on a Boston Whaler OUTRAGE 22 transom. The tabs are mounted outboard so that the actuator does not have to be mounted in the region where the transom thickness changes. The tabs end up following the line of the central V-hull, but they are also above the sponsons by a couple of inches. This is the installation on Jerry's OUTRAGE <jechura>. It looks to me like a nice compromise between having the tabs mounted further inboard--which leads to difficulties mounting the actuators--and mounting the tabs a bit farther outboard. Perhaps Jerry can comment on how they work. |
I'll send Jerry an email to alert him about this thread. |
| jechura |
I was just looking for my pictures of the installation and Jimh pop them up. The only difference between John installation and mine was that he clipped the inside corner of the stainless at a 45 degree in order to try and maintain Lenco's preferred measurement from the chine. If you look at John's site in his technical, you will see that he had to drill a new mounting hole. That 1/2 inch clip brought the actuator over on the notch. I just rounded the corner. Both ways work with the same results. With Johns way gaining maybe a percentage or two of effectiveness. I do agree with John that the total effectiveness of the tab is maybe 50 to 60% which normally is fine, however on the Isle Royale trip My boat was extremely stern heavy with added gas, coolers equipment etc. The tabs were all way down for the and the engine trimmed all the way in to keep the bow down. In fact when we { Gambler } pulled the boats at Copper Harbor and kissing the old 235 for it's performance, I pointed out to David that the tabs were still all the way down. I think the pad idea will raise the effectiveness 20 to 30 % and it on my to do list this winter. Jerry |
John--If you have good pictures of your installation, post the link or email it to me. I don't think I have a good shot of your boat's tabs in my collection. |
| kingfish |
Will do Jim - I'll start snooping around my archives right now. John |
| banff22 |
I just happen to have some good pictures of both jechura's and kingfish's Lenco 12X12E trim tab installation. And I've been lucky to have face to face conversations with both of them about this. My 12X12E's are not installed yet. If you mount the tabs as low to the deadrise as possible, preferrably right on it, I think you will gain a little room where you will not have to move the tabs quite so far to the outside to have the actuator tabs fall flat on the transom. This is due to the angle of the thicker part of the transom as it travels to the deadrise. You'll still need to trim that inside corner of the mounting bracket to achieve this tightness though. This should achieve some better effiency than John and Jerry's initial install. How much is very hard to know. Regards, |
| LHG |
Someone should check with G&CP to see how they factory install trim tabs on a commercial 22' hull, and what they use. |
| RCS |
Just emailed you a couple of photos of tabs on a 20' Outrage I owned not too long ago. They are further inboard that most would recommend but they worked great on that boat. The previous owner had installed these and mounted them within the area of the transom where there is wood backing. |
No pictures in my email. |
| RCS |
Jim, I should have been more specific.... I sent photos to Whaler 131. I had 12" Lenco's on a 20' Outrage that were mounted at the outer edge of the area of the transom where there is plywood backer. Thought he might want to see how they worked with a swim platform and transducer mounted nearby. |
| andygere |
RCS, could you send the pictures to jimh so he can post them here? I'm considering trim tabs for my Outrage 22 Cuddy, and would love to see photos of another installation. Thanks! |
| RCS |
I'll send them to both of you. One of these days I'll get around to setting up an account at Photobucket. Actually, I think I had emailed Jim some photos about a year ago when he brought this topic up but I will send some out to you later today. I'm headed to a soccer game at the moment. |
| Backlash |
Jerry, From looking at the above photos of your trim tabs it appears they are mounted too high off the bottom of the boat to be really effective. I would think that when fully lowered (down) only the back half of the tab is actually contacting the water. In essence isn't this like having 12"x6" tabs on the boat? This may be why you had to keep them fully down on the Isle Royale trip. Steve |
| andygere |
One of the reasons I've been reluctant to install trim tabs to date is that I keep my boat in a saltwater slip. The idea of having additional equipment below the waterline to keep corrosion and fouling free has always worried me. Can anyone speak to what measures must be taken (zincs, antifouling paint, manual scrubbing) to protect trim tabs in this type of environment? The T-top on my boat really does tend to lean into the wind, and I know tabs would be just the thing to correct the problem, but I don't want to trade a minor headache for bigger one. |
| rtk |
I also keep the boat in the water in salt water. You do have to protect the trim tab from corrosion and fouling. Put a zinc on it to protect from corrosion just like any underwater metal. When you paint the bottom just paint the trim tabs. As I understand the primer you use on the trim tab is very important before applying the antifouling so the metals in the antifouling do not cause corrosion of the tab. The primer acts as a barrier coat to the antifouling paint. I primed my trim tabs with zinc chromate primer before applying the antifouling paint. When I haul out for the winter I'll see how that worked out. You should use the system that the antifouling paint manufacturer suggests for the paint and type of metal. Long story short, if you properly prep the trim tabs for paint, use a good antifouling paint and put a zinc on each tab you will not have any problems with the trim tabs in salt water. The benefit of having the trim tabs will far outway any minor maintenance you will have to do to protect the trim tabs in a salt water environment. The trim tabs are stainless steel so they are very resilient to adverse environmental conditions. The zincs and painting just become part of the spring pre-lauch ritual and require no more care than the bottom of the boat during the season. The 22 hull looks like it is tough to pick a location to mount the trim tabs. I do agree with Steve that they appear to be too far up to be effective. I am not familiar with the boat so I really do not have a suggestion, I would like to see how others have mounted them. Rich |
| jechura |
Steve. They are mounted correctly. The way Jimh took the picture gives you that optical illusion. On the Isle Royal trip I knew I should have loaded it more evenly. Jerry |
Jerry--The shot from below is a close-up. Figure the dimensions from the thickness of the bunk board, which I'd guess is about 2-3 inches. Looks like your tab is about 0.5 to 0.75 inch above the hull bottom on the central v-bottom, an inch or two higher on the outer sponson |
Trim tabs on the transom of an Outrage 20 with the tabs mounted inboard: |
The above picture via Rob Stephens (RCS). This mounting position has advantages: --puts the whole tab right at the bottom of the transom. The drawbacks seem to be: --tabs are farther inboard so less leverage I like the way Rob integrated the bonding ground electrode with the tab. What is the blue block on the starboard tab used for? |
The photographs above also illustrate the difference in the mounting of the actuator between the standard position and the edge position. Jerry has edge mounted actuators. They cut down on the vertical height need above the tab for the actuator to mount. Rob had the standard actuators. They need more room above them. |
Here is John's installation, which is a bit different than the previous two. John has the tab outboard of the center, thicker section of the transom, but mounted as close or as inboard as possible. I think he trimmed the hinge section slightly to move it in an extra inch or two. However, this put the actuator mounting right on the line of the transom where the thickness changes, so that required building up the transom thickness with the wood spacer block. I think John put the tabs in place before the auxiliary engine. The mounting position for the tabs worked out well--good planning, John!
John is also using the Edge Mount actuator. Hey--are all of these installations with LENCO tabs? |
| kingfish |
Jim- I just took 4 more detailed shots of my installation and sent them off to you. John |
| RCS |
Jim, The blue bracket is a mounting bracket for a bait well pump. RCS |
Some new pictures from kingfish: The Port tab installation. Notice how the hinge has been cut back to fit against the transom center section. The actuator is an Edge Mount style, which reduces the height needed to about 11-inches from 15-inches with the Standard Mount style. This position allows room on the transom for an auxiliary motor. As Jerry mentioned above, when the hinge is trimmed to fit like this, a new mounting hole has to be drilled at the inboard end: ---- The Starboard tab trimmed up. This shows the relationship between the tab, the central V-hull and the sponson. If you look closely you can see a pencil line which extends the line of the central V-hull onto the area above the sponson. |
[Thread was closed briefly for editing] John--Thanks for the pictures. I think I have been drinking as much coffee as you have this morning. Man, I am typing fast and getting these photographs tweaked and posted in record time! How many cups of Kona coffee before you trudged out to the pole barn and took those photos this morning? |
| kingfish |
Jim- Three cups, but it was a blend of Leelanau Sumatra and Kenya...(working on #4 now, and my typing is breaking a new speed record for me - probably about 9 wpm after I deduct the time needed for corrections). It's funny how the camera's eye shows *everything* - what is also clear on the photo showing from the underside of the tab is that I missed part of the hull the last time I cleaned it! John |
| kingfish |
One other possibility I have thought about to gain efficiencey with the challenges of the Outrage 22 hull bottom shape, besides attaching a "pad" in the shape of the sponson section to the bottom of the tab, is changing the angle of the tab so it no longer is parallel with the deadrise line, by pivoting the hinge location on the intersection of the deadrise and the sponson edge so the outboard edge of the hinge drops down into the area behind the sponson. I may experiment with that one day. John |
| banff22 |
Your second picture here is perfect John and I think illustrates why the "optical Illusion" in Jerry's pic. Plus it better shows the difficulty of answering, just how, or where do we mount tabs on our hulls to achieve max performance. Shoot, you are typing too fast this morning. As I'm typing you just answered my question. What would happen if we mounted the tab not exactly parallel to the deadrise? Peter |
| banff22 |
And in doing so it will change where the actuator falls on the transom. P |
| jechura |
Damm, got up early to go to my shop to take the some pictures with a tape measure to prove the Illusion, however John bailed us out. At least everyone will understand what we mean by adding tab pads. Oh well, had to clean the boat up anyway's if I decide to go the color tour. Jerry |
| kingfish |
Peter- Right you are- - pivoting the tab hinge as I described above would cause the upper actuator bracket to fall entirely on the thinner section of the transom. Jerry- I still think the best way to gain the most efficiency would be the pads - I am concerned though that if we followed the actual shape of the sponson section, the sharp nearly vertical surface (though short) of the pad could put some really considerable lateral strain on the hinge to transom connection on the inside tab in a tight turn with the tabs deployed. I wish you'd try it out... ;-) John |
| Plotman |
Volvo has come out with an entirely new design for trim tabs that has me intrigured. Instead of a hinged flap that comes off of the transom, they are more like a small guillitine blade that extends straight down. http://www.qlmarine.com/pdf/QLBTS4pEng.pdf It would seem to me that it would be much easier to mount these tabs in such a way as to avoid the sponsons, and perhaps they wouldn't interfere with a kicker at all, as they only look to be an inch thick. Only issue I can think about is how you would run the cables to tabs on a whaler. That is, assuming they work. Who wants to be the gunia pig? David |
It seems somewhat reasonable that the QL Trim System could produce the same amount of up-force on the hull as a conventional trim tab without producing any more drag on the hull, however I would like a little more proof of that than just promotional literature. The QL Trim System components look like they are rather substantial to manufacture. Also, it looks like the forces exerted on your transom would be greater. And they look more expensive than conventional tabs. |
After my third coffee this morning, I just got another idea for the tab mounting: Mount the tab hinge on the central or thicker portion of the transom, but extend or overlap it outboard so that if follows the deadrise line of the v-bottom out to the sponson! You would have to make a shim or filler (perhaps from teak) to bridge the 0.75-inch (or so) gap between the hinge and the transom on the outboard portion. This would be a length of about 4- to 5-inches (judging from the pictures of a 12X12 tab on John's installation). You could drill holes for the mounting screws to pass through the filler and fasten to the hull. You could also use adhesive to attach the filler to the transom. The advantages of this approach: --actuator mounting will be on wood-reinforced transom area; The disadvantage: --you have to fabricate the fillers or shims |
| kingfish |
That is a good solution, and if you don't have or aren't planning to have a kicker, I think it would be worth some consideration. Another potential con would be the possibility of interference with a preferable location for a transducer. John |
| andygere |
Great article, especially the detailed photos. Here's a question for the twin engine folks out there: Would a 22 foot Whaler with twin engines be capable of providing enough trim adjustment with the motors to more or less match that of a single engine boat with tabs. In other words, with twins, can you balance the boat to correct for wind lean, uneven load, etc? What about trim adjustment bow to stern for lower planing speed, handling in chop, etc.? The purpose of the question is related to pricing a repower with a single, kicker and trim tabs vs. twins. |
| Plotman |
Andy- I have twins, and you can definately adjust trim on the engines individually to correct leans. Twins will also plane at a lower speed than a single, but you don't get the same kind of bow-down from having the engines tucked all the way in that you get from having tabs down. It really depends on what your primary objective in having tabs. Twins give you part of it, but not all. David |
| Backlash |
Andy, The main benefit of trim tabs is to adjust the attitude of the boat - bow down, listing, etc., and trim your engine so that it's thrust is parallel to the hull bottom which is the most efficient for the engine. I normally do not adjust my engine trim at all once I have it trimmed properly (which is parallel to the hull bottom). I then use the trim tabs to adjust the boat's attitude depending on sea conditions. When you trim the engine in to lower the bow, the engine thrust is down (at an angle and not parallel to the hull) and much of the power is being used to push up on the transom rather than being used to push the boat forward. This results in inefficient use of the engine. As David mentions, with twins, one engine can be trimmed in to correct for a list, but again that would not be the most efficient way to run the boat. Steve |
| Plotman |
Steve- I've got to disagree with you on whether it matters if you push the bow down by changing the thrust vector (trimming the engines) or changing the effective hull shape (trim tabs). In either case you are essentially doing the same thing - namely lifting the stern using the power of the engine. I guess what I'm trying to say is using trim tabs isn't "free" from an energy usage perspective. On a boat with trim tabs, the force used to lift the stern when the tabs are deploted is subtracted from the total propulsive force provided by the engine, just the same as it is I do agree that trim tabs give more versatility that one gets simply with engine trim, but I don't believe it changes efficiency with a given motor and a given running attitude. David |
| kingfish |
Well, nobody asked, but I'm going to throw in my 2 cents worth - I think David is right, trim tab usage isn't "free". But I'm going to agree with Steve even more, in that, while I don't have the tools to prove it empirically, I am fully convinced (beyond all shadow of a doubt) that it is "more expensive" to raise or laterally trim the stern with the thrust of the motors than it is to do so with trim tabs, keeping the thrust of the motor(s) in line with the movement of the boat. John |
| Backlash |
David, I respectfully disagree with your statement that "On a boat with trim tabs, the force used to lift the stern when the tabs are deploted is subtracted from the total propulsive force provided by the engine, just the same as it is." Read the he following 2 paragraphs which were taken directly from Bennett's web site: TRIM TABS AND POWER TRIM To achieve maximum performance, first adjust the trim tabs to achieve the desired running attitude. Next, use the power trim to position the propeller thrust parallel to the water flow. If necessary, re-adjust the trim tabs to fine tune the attitude. By observing the boat’s speed and engine RPM's the best combination of trim tabs and power trim will be apparent. Trim tab angle indicators and a power trim angle indicator are particularly useful in duplicating effective settings. Steve |
| andygere |
I'll agree that trimming the boat's attitude with tabs is probably more efficient. That said, I've always felt that my outboard did a decent enough job of that. The real problem I want to correct is listing. I have a T-top and enclosure, and it has a tendency to lean into the wind. Also, when fishing with a few full sized buddies, I'm always having to move them around to get the boat on an even keel. It sounds like this can be done with twins or tabs, and it's a matter of efficiency. I don't think there's room on the back of a 22 hull for twins and tabs. |
| kingfish |
It would be crowded, but Andy, I'd be curious what the dimension might be from the "outside" (port side) of your port motor to the port hull side say at the chine. I'd wonder how that compares to the same measurement taken from my kicker to the chine. (I don't currently know my dimension, but I'll measure it tomorrow.) |
| Backlash |
Andy, Trim tabs do an excellent job of correcting a listing problem. My 21' Walkaround can seriously list with a cross wind, especially with the canvas up. The trim tabs correct this very nicely. IMO, the best thing since sliced bread! Steve |
| Tom W Clark |
I have to disagree with some of the things said above including the quote attributed to Bennett's web site. Power trim CAN correct listing on a boat with twins. Trimming the motor(s) can IMPROVE the performance of the boat. Trim tabs DO come at a cost to performance. They add a lot of drag which SLOWS the boat down. The notion that the motors should always be trimmed align the prop thrust parallel to the water flow is flawed. There are often times when you do not want this to be the case. The problem with the Bennett argument is that it assumes all you are ever trying to do is bring the bow down. That is all trim tabs can do. They can do nothing to lift the bow. Your outboard(s) can. I have Bennett trim tabs on my 1988 Revenge 25 Walk Through. They are mounted much as John Flook's are, outboard of the center transom area and well above the sponson on their outboard half but more or less flush with the V hull. I also have twin 150 outboards. The motors can be trimmed to correct list TO A POINT, but in any sort of a strong cross wind I MUST use (a) trim tab to correct the list. The Revenge models do not need any help bringing the bow down. Usually I trim the motor out a bit to help lift the bow and increase speed and efficiency. Any time I lower a trim tab to correct for list I increase the drag of the hull and slow it down a bit. The difference is perceptible. In general I use a combination of motor trim and tabs to correct list. I have yet to use both tabs to actively try to bring the bow down. Regarding tab installation, I think the advice to mount them 3/8" above the hull plane is good. My tabs were installed almost flush or maybe 1/8" above the V hull, but (like John's Outre) are an inch and a half above the sponsons. The trouble for me is that water rolling off the bottom of the hull catches the inboard edge of the trim tab and is sprayed up at the motors. Had the tabs been mounted 3/8" above the bottom I do not think this would happen. |
| LHG |
From this non-trim tab fan, the best way to adjust list, either from wind or weight distribution, is to move your passengers & gear around in the boat. This does not increase drag as a trim tab would do. Even with twin engines boat, I never use the engines to correct list, moving weight around in the boat instead. |
| andygere |
Larry, that's what I do right now, but in a stiff breeze when I'm by myself, there's not much to move. Also, when it's windy and cold, everyone wants to hide behind the T-top enclosure to stay warm. Yeah, yeah, the downside of T-tops.... |
| Peter |
I'm not a fan of trim tabs for an 18 Outrage and under but for the 22 foot hull and up, I think crew and cargo shifting imposes an inconvenience on the crew that isn't necessary. In some cases, as Andy points out, there isn't any crew or cargo to shift around to correct listing. In the case of a Revenge, it can be difficult for the captain to move much more than to the center of the boat. When the Revenge is listing to port, where is the captain supposed to go to offset the listing when the captain is as far to starboard as the captain can possibly go? The small increase in drag caused by the tabs is far outweighed by the increased ride comfort correct use of the tabs can provide. |
| Tom W Clark |
Andy and I were recently discussing this on the phone. You have to have trim tabs to keep a 25 on an even keel. No way moving gear around is going to counter an 18 knot cross wind, and why should you have to? This is made evident to me almost every time I cross Puget Sound as I did Sunday night. Traveling eastbound across Puget Sound from Bainbridge Island to Seattle the wind was stiffly blowing out of the south at 18 knots, thus the wind was coming from starboard where I am standing. The boat will always lean into the wind. Even when I moved into the companionway to steer with my right hand so I could see past one peeled back corner of the Mills windshield (it was dark and raining) the difference in weight distribution is negligible. Without trim tabs the hull would have been riding on one side of its V and slamming into each and every wave, big or small. A very punishing ride. So, as both Peter and Andy point out, if you're onboard by yourself, what are you going to do? I was never a fan of trim tabs and was actually a bit disappointed that the boat I recently bought had them because they seemed like a lot of extra complication I didn't need. It is now obvious to me that they are a necessity on the Revenge 25. The 25s do have the huge advantage of accommodating trim tabs without ANY visible clutter. Because of the stern storage compartments, one cannot tell from the inside of the boat that it is equipped with trim tabs. Everything is hidden and out of the way. Only the switch on the dash and the tabs themselves on the transom are visible. I have found the Bennetts to be simple, reliable and easy to use. |
| andygere |
I was looking at a photo of JimP's Revenge 22 and noticed that he is running trim tabs as well. Jim if you're out there, let us know what you think of them, and tell us about the brand, size and mounting details. |
| Sheila |
We have Bennett trim tabs on our Revenge 25 foot Hardtop Walkaround. I've been using them exclusively (instead of motor trim) to adjust her attitude bow to stern. Tom, can you say more about the Revenge models not needing help in keeping the bow down? I often use my tabs for this purpose. |
| Tom W Clark |
Sheila, That surprises me. I can only speculate that you are using your trim tabs when the boat is not fully on plane. Because your boat is underpowered the motor may be at what seems a normal cruising speed (3000-4000 RPM) but the boat is just sort of mushing along on a semi-plane. I have found the Revenge 25 to have a minimum planing speed of 20-22 mph. On my boat the motors just do not like to run at speeds less than that. Realistic minimum planing speed for me is motors turning 3150 RPM and the boat traveling through the water at 22 mph. Anything less than that and it on the backside of the power curve. That is it takes MORE power to maintain a SLOWER speed. Under these conditions the trim tabs can bring the bow down and make the hull travel through the water more efficiently. But a Whaler is not really a semi-displacement hull. It wants to get up and RUN. |
| Sheila |
Tom, Thank you for your thoughtful reply. I shall pay more attention next time I'm out to the speed at which I'm deploying the tabs to bring the bow down. I'm not proud--in fact, I'm beginning to think that poor Tohora Iti is suffering at the hands of new boaters. If any of you experts are ever in our area, and want to go out with us for a shakedown cruise to critique how we run her, I'd be happy to spring for dinner afterwards for your trouble. |
