posted 01-20-2006 04:22 PM ET (US)
Jim - I noticed that in your photos also. The Safe boat I saw being re-rigged with 250 Verados had Revolution 4 props installed. Quite frankly, I think the USCG has the wrong props on that particular boat. It too should be using Rev-4's.Here's the sum total of what I know about the Vensura prop (used to be called Offshore Performance). As you know JimG and Steve run these, on my recommendation, and I alternately use one on my classic 21 Outrage.
It is not known for flat-out top speed, but has excellent hole shot acceleration, strong mid-range speed (like all 4-blades), and tremendous bow lift, with pretty good offshore holding. That is why I recommended it to Steve and Jim, as both of their boats needed these attributes. And neither has enough power-to-weight ratio to make WOT top speed a major concern, nor to be able to turn a 17" Rev-4. On both boats, the improvements were DRAMATIC, I think, particularly in hull lift, and plane-off for Steve. They really like the prop, running medium sized vent plugs, and I think Jim gained top end over the conventional Yamaha SS prop.
Mercury recommends the prop for 135-175HP V-6's, and for single/dual Offshore use, 18-24' boats. Minimum pitch offered is 17", max 23". Compared to a same pitch Mercury 3 blade, in my case it holds RPM down about 100, but will turn about 300 RPM higher than same pitch Rev-4. Mercury says the Revolution-4 holds better offshore, and I can confirm that.
On my classic, it is about 1-1/2 to 2 MPH slower top end than a Laser II or Revoultion-4, but has rocket-like low and mid-range acceleration, and great mid-range cruising, at lower RPM. It did run 1 MPH faster, however, than a brand new Mercury aluminum Black Max (much to my surprise a quite good aluminum prop) I tried in same 19" pitch. In short, it is a solid performer, I like everything about it except top speed. Also, it offers MUCH better engine control for docking and reverse thrust operations.
I think on heavier hulls, relative to HP, that go less than 45 MPH, 135-175HP as Merc recommends, it could be a great propeller to use.
In my case, when I want to go fast, (and not suffer the humiliation of having other brand 150's go by me!) I install the Laser II on this lightweight classic hull. For load carrying and cruising, I use the Vensura. Incidentally, the Laser II holds better offshore, when run 1" elevated, than the Vensura, to my surprise.
Getting back to your rig, I think the Vensura might run quite well for you, inspite of Mercury not recommending it for 3.0 liter outboards. But the 17" minimum pitch could be a problem? I think the Revolution-4 is clearly a better propeller, using much newer technology and blade design, but the high weight of the prop causes some limitations with gearcases, on 2.5 liter engines, and other brands. They even rattle the clutches on my 200 EFI's at 600 RPM in gear, but it goes away as I approach 800 RPM.
From what I can tell, the Revolution-4 is the talk of the town these days in boating, except for the bass-flats crowd, which use the Tempest Plus. Everybody else wants them, all brands of engines, and I am seeing them used that way.
