ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance MONTAUK Re-power: 90-HP OptiMax
Author | Topic: MONTAUK Re-power: 90-HP OptiMax |
holtrph |
posted 06-02-2006 12:56 PM ET (US)
I am in the market for a new motor for my 1988 Montauk 17, and found a good deal on an unused 2004 Mercury 90-HP OptiMax. I have seen a few pictures on this website of others with this same setup, but my boat dealer/installer has some concerns about the increased weight. She has heard some instances of de-installations of Merucry 90 OptiMax on older Montauk's due to instability caused by increased weight. Have any of you heard of any problems with adding a Mercury 90 OptiMax to a 1988 Montauk 17? Do any of you have good experiences with this? I'd really appreciate any feedback. |
Perry |
posted 06-02-2006 01:16 PM ET (US)
According to Brunswick's Commercial Division, the maximum motor weight for a 17' Alert (Classic Montauk) is 330 lbs. I have seen Montauk's with heavier motors on them and they seem to handle it OK. |
Tom W Clark |
posted 06-02-2006 01:22 PM ET (US)
The classic Montauk had a maximum engine weight of 410 pounds. Just how much does an OptiMax 90 weight?! |
holtrph |
posted 06-02-2006 02:23 PM ET (US)
The Mercury 90-HP OptiMax weighs 375 lbs. According to some delaers I have spoken with, there are some concerns about not just weight but some hull vibrations throughout the hull at certain RPM with this engine. Anyone heard/experienced this? |
sosmerc |
posted 06-02-2006 03:36 PM ET (US)
I have rigged three Montauk's with 3-cylinder Optimax engines. There have been no complaints whatsoever. In fact, it appears to be a great combination. Be sure to run the Flo-Torq III hub in whatever prop you choose, aluminum or stainless. Mount the engine so that the cavitation plate is at least slightly above the bottom of the boat. |
Buckda |
posted 06-02-2006 05:03 PM ET (US)
I would think that this would be an ideal engine for the Montauk 17. Remember, though, that any 3-cylinder engine is going to have unique vibration signatures. Three cylinder aren't as smooth as 4- or 6-cylinders, which is why the old balanced V4 motors from OMC were great engines for this boat. I would not hesitate to put this motor on a Montauk, so long as you are getting a good deal and are comfortable with the battery requirements of the OptiMax. Dave |
dcritch |
posted 06-02-2006 07:03 PM ET (US)
holtrph I have been very happy with the 90 OptiMax on my 170. There is a small vibration between 1,200- and 1,800-RPM, but nothing to be concerned about. Instant starts and great acceleration. The only negative is the weight if you want to add a kicker. sosmerc |
posted 06-03-2006 08:33 AM ET (US)
You can find the weight and other dimension for the Mercury OptiMax 90-HP and several other low-emission 90-HP outboard motors listed in Low-Emission 90-HP Outboard Price Comparison |
sosmerc |
posted 06-03-2006 11:57 AM ET (US)
dcritch....I doubt it very much, since the FloTorque III was really created to solve some clutch chatter issues with the 4 strokes. But as I have said before, I use the "III" whenever possible because it seems to help in every application. |
