| Author | Topic: MONTAUK: Tohatsu 90 TLDI |
| Sonic |
The Montauk [was] in the water last weekend, and I decided to get some accurate performance numbers for it, as I am looking at getting a new prop to replace the one that came with the motor. Boat Specs: --1983 Montauk
The boat is used for running around Nantucket sound and [unrecognized acronym] Sound, going to the beach, and water skiing and tubing. I think a 15-inch pitch SS prop with a 5-inch setback jackplate to get the motor up a bit and out of the blind holes will get me much closer to the upper end of the [recommended wide open throttle engine speed] range, and better [acceleration]. --Chris |
| ratherwhalering |
Your performance numbers look good for a blind hole mount. If you add set back brackets/jackplate and raise the engine, you can expect a 300-400+ RPM increase, depending on how high you raise the brackets/plate. That being said, theoretically, a stainless prop will increase your WOT RPM, and slightly decrease holeshot. Stainless props are much heavier and stronger than aluminum, therefore, it will not spin as fast when accelerating, but will not flex as much at higher speeds. However I have noticed that stainless props (in general) tend to have greater cupping and less slip than conventional aluminum props, so you may not notice any decrease in hole shot, but you will see an increase in top speed. There is a rule of thumb which holds that every two-inch increase in propeller pitch will decrease engine speed by 450-RPM, and vice versa. Therefore, I think you should stick with the same size propeller, but in Stainless, or you may over-rev the engine. 5600 RPM out of a maximum RPM of 5850 is pretty darn close. If you really wanted to get to the maximum RPM, then perhaps try CMC 4-inch set-back brackets, with a Stainless Tohatsu 13.25 x 16 (NM889610160.) Otherwise you may want to look into: Tohatsu 13.25 x 17 (NM889610170) for about $350.00 Perhaps someone more familiar with Mercury propellers can suggest additional options from that manufacturer? |
| Teak Oil |
Be sure to get some mileage numbers once you get dialed in. I dont think there are any other Tohatsu TLDI's on this site |
| bsmotril |
Thanks for posting. I've been considering a Tohatsu or Nissan 90hp and this is the first good performance report I've seen for that motor on a Whaler hull. BillS |
| Sonic |
Thanks for the comments. I don't have any way to measure fuel economy, but I know one thing: it is FANTASTIC! It seems to burn close to 1/2 what the old Johnson 90 would burn. Going water skiing for a day used to burn up most of a tank of gas...now it uses less than 1/2, and at a 3500 rpm cruise it just sips gas like we're running out. I would estimate oil use at about 60:1 so far. Overall, I've been very happy with the motor, less happy with the quality of work from my dealer. I think a setback/jack plate is in my future. |
| goldstem |
Waquoit bay. I grew up there. in a house next to Kelly's clam shack on the seapit river. perhaps we should do a cape outing later this year? m. |
| Teak Oil |
If you have a GPS you can measure avg mpg. Next time you go on a 25 mile plus trip fill the tank and fill it again at the end. Whammo instsnt mpg |
| The Judge |
Old 90's burned about 6gph @ 4k. Yours is probably burning about 3-4. Easiest way for me to measure is using a 3 gallon tank and seeing how long she goes before running out. |
Thanks for the information on the TOHATSU motor. For the TLDI models TOHATSU have licensed the use of the same Orbital Combustion Process that Mercury licenses for use in their OptiMax models. Tohatsu is also the primary manufacturer of most of the smaller horsepower four-stroke motors sold by Mercury. They make the motors which are re-badged as Mercury motors in North America. Mercury and Tohatsu are also involved in some joint manufacturing operations in a new plant in Japan. I do note that Tohatsu seems to be promoting its own brand in North America in a more prominent way lately. There have been prominent Tohatsu brand advertisements in boating magazines which are oriented to smaller, trailerable boats. |
