| Author | Topic: Bombardier Publishes Torque Curves |
Many people have asked for torque curve information from outboard motor manufacturers. Bombardier has published some information in their new catalogue. This graph is from the 2007 Bombardier Evinrude catalogue:
http://continuouswave.com/whaler/reference/graphics/torqueGraphETEC.jpg Your dealer soon should have a copy available for you. |
Information source for data in graph: Ralph Evinrude Test Center / 2007 Evinrude 150-HP E-TEC, 2006 Yamaha 150-HP four-stroke. Testing done using dynometer. |
| bigjohn1 |
It looks like E-tec is clearly superior at all rpm levels. |
| Peter |
That tends to back up the results in the side-by-side test in the 2006 informercial. |
| BOB KEMMLER JR |
I don't see the big deal. They are running an E-TEC up against a four-stroke. Of course it's gonna wipe the floor with them. Let them run against a HPDI Yamaha or OptiMax Mercury and see what happens. That graph is like apples to oranges. Worthless. |
| Peter |
Going after the HPDI or OptiMax is inconsistent with the 2>4 marketing theme. |
As soon as Mercury or Yamaha publish torque curves for their Optimax and HPDI motors we can compare them. The "big deal" is that an outboard manufacturer has published a torque curve for their motor. People have been asking for this information. Bombardier has supplied it. Why react to discard the information as having no value? I find the information to have considerable value. It is far from worthless. In terms of marketing, it is much more effective than giving out baseball hats. |
| JayR |
Thanks Jim! That's great to see.... It is compared to the 4-Stroke as that is what this motor was designed to do. It is their answer to the 4-stroke. When the other manufacturers come out with 2-stroke motors that burn as clean, quiet, etc.... then request the comparison. Don't ask that they compare the motor to something that does not provide the same features. I am sure there are trade offs in getting the motor as clean and quiet as they have. I would not expect them to out perform older, dirtier and louder 2-strokes. Do you? If so, you are asking too much.... Bring an Opti that is as clean and quiet as the E-TEC to the test and then a comparison can be made. For now, the 4-stroke is what the E-TEC is competing against. |
| BOB KEMMLER JR |
I thought the Opti's were quieter at WOT than the etecs?If they are marketing it against 4 strokes,then let them test against a Verado.I don't think they'd fair as well against them as they do the naturally aspirated models.I'm not trying to take anything away from the etecs at all,but i just think this is more a case of the marketing and advertising guys using selective tests to make thier product look perfect. Why should merc,yam or anyone else provide torque curves?they aren't touting or trying to say anything about torque.Etec is the one trying to prove something,they can very easily put the torque curves up of every motor out there if they are in fact superior in that area. |
| andygere |
I agree with Jay; if you are shopping for a 150 h.p. motor, this may change your mind about buying a 4-stroke. Clearly, Evinrude thinks the competition in this power range is Yamaha, so that's who the data targets. By the way, good luck finding an HPDI motor at any Yamaha dealer. When I was motor shopping this winter, none of the Yamaha dealers in my area had a single HPDI in stock, loose or mounted on a boat. This includes a Grady White and a Scout dealership. None of the dealers would even talk about ordering one either. All of them tried to convince me that the Yamaha 4-stroke was the hottest motor on the planet, and that I'd be foolish to even consider a 2-stroke outboard. I'm glad I bought the E-TEC,so far, it's everything that Evinrude has advertised. |
| Peter |
Spending advertising dollars to compare against the Verado is a waste of money. It's not the market leader, as is Yamaha, in the 150 HP category and its doubtful it ever will be due to its excessive weight and heavy fuel consumption at the upper part of the operating range. Virtually none of the advertising dollars spent comparing the E-TEC to a Verado will be effective in prying a Verado 150 off of a Brunswick transom, which is where the majority of Verado 150s will be found. On the other hand, if the consuming public starts to demand E-TECs instead of Yamaha 4-strokes, many of the independent boat manufacturers might be forced to abandon their exclusive lock-out relationship with Yamaha. Thus, its much better for BRP to focus its attack and comparative advertising dollars on Yamaha, the market leader. |
| BOB KEMMLER JR |
I wasn't talking about just the 150 hp sized outboards,but across the whole board.As far as a dealer pushing you towards a 4 stroke,thats a easy case of trying to get more $$$$$$$ from you,both in initial cost and upcoming maintenance.All i know is if i in fact had a superior product,i would show the test results of ALL the competition to clearly show an advantage with my product.These tests also look to be done at the powerhead on a dyno.There's a lot of parasitic hp/tq loss through the driveline.I wonder what that torque curve looks like in a real world scenario,through the driveline and at the prop where it counts? |
| Peter |
(1) HP ratings are measured at the prop and have been been for about 20 years. (2) Evinrude has done a real world side-by-side comparison of the E-TEC 150 vs. the F150 on an Angler brand boat which takes into account all drive line losses. The F150 struggled to get the boat on plane by itself consistent with the common knowledge that naturally aspirated 4-strokes are light on low end torque as compared to 2-strokes. Yamaha has never challenged the test results because it can't. (3) Showing test results against all brands muddies up the message with respect to the target, which is with little doubt, YAMAHA. Perhaps some day it will be SUZUKI and we will see comparisons to SUZUKI but right now its YAMAHA because YAMAHA has the bulk of the new independent transoms. |
Bob Kemmer writes: quote: Extensive testing of sound levels of 150-HP motors showed the E-TEC to be THE QUIESTEST ENGINE OF ALL at cruise, quieter than the VERADO, which has been widely promoted as being "world-class quiet." I don't understand where people invent new test results as those mentioned above. If you have test data about the sound levels, perhaps you could introduce them into the extensive prior discussion about the sound levels, rather than throw this into a discussion on torque curves. See: Quietest 150-HP Outboard
quote: If people want to promote their engine they need to give customers some data, not just baseball caps. Some people make decisions about engines based on data and testing. |
| BOB KEMMLER JR |
Peter,they don't call them yamadogs for nothing.This test was done at the "crankshaft",so the ONLY thing it proves is that the 150 etec powerhead is stronger than the yam 150 4 stroke powerhead at the crankshaft.From the powerhead to the prop there could be a decent decrease in power and no two brands will have the same hp loss.Throw longer shaft lengths and larger gear cases and the actual power at the prop will be much different.
I thought the optimax got a new oil pump that lowered the decibel levels?I could be wrong on this and i'm not going to waste the time to look for the test i saw this on.maybe someone else will know what i am talking about in more detail?With that i am going to put my Boston Whaler baseball cap on,my mercury racing t shirt on,take my dodge truck key fob and run to home depot for more home improvement goodies. |
| bigjohn1 |
As in all industries, one would be well-advised to carefully consider manufacturing claims, whether from an infomercial, a company catalogue, or both. If this were Merc or Yamaha sponsored info, I'm quite certain it would show those brands to be superior. |
| prj |
But rest assured, bigjohn, the E-TEC cheerleaders would find fault in those tests. Can anyone decipher the top text on the left side of the graph, More trivial analysis would beg the question: |
| Teak Oil |
The word is "Greater" The chart sucks all right, but over 200 ft lbs of torque from a 150 is pretty darned impressive to me. It looks like the 2.6 liter E-tecs are going to have no problems moving out heavier boats. |
| VI Jamie 22 |
Hey, I've got the boat from the informercial on my dock. Come on down and I'll give you a ride.....The boats' fast, I clocked 51 mph on the Gps. If you have any questions I can answer, let me know. |
| Richard Quinlivan |
If you eyeball the torque curves you can calculate the HP. HP=Torque*RPM/5250 RPM 4000 4500 5000 6000 Yamaha The E-Tec clearly develops its power over a much wider rpm range then does the Yamaha. Dick |
| The Judge |
Crankshaft torque is key and hence why 4 strokes use gear ratios like 2.59:1 to level out the playing field. A 90 suzuki will swing a 22" prop on a Montauk and the e-tec will swing a 15" due to gear ratios. Sure the torque is greater at the crank but what about the prop, I say it is probably close. To find out for sure...anyone running a 115 E-Tec on a banana 19' Revenge? Now we can compare holeshot, rpm's, top end, etc. Anyone who has ridden in my whale can attest to the holeshot and top end. I can not attest to Yamahas torque being I have never driven one of their 4 strokes. Suzuki claims to be the only 4 stroke comparable to a 2 stroke and maybe that is why BRP did not use them in that comparo. I love the E-Tecs and one day will probably own one but not until they 1) actually start shipping the engines(115 & 130's) and 2) they come down in price some. They 115 E-Tec is pretty pricey compared to a 115 4 stroke of any brand(about $1000 more). Great info and a great marketing tool but the sides are not equal when talking about the crankshaft....hence why all outboards are now rated at the prop since 1986 or so. |
| gnr |
Some more "data" I came across recently. A pro bass tournament was held in my neck of the woods recently. I did not see all the boats in the tournament but of the dozen or so I did see all were running an E-tech. Now I know the bassers are barely a step above the pwc crowd to some of you but still... |
| Teak Oil |
Niick does have a good point, but gear ratio cannot make up for the broadness of the torque curve. The E-Tec will still have more balls at most usable rpm levels. IMO if you want the most performance from your boat, you still need to go Optimax or E-Tec |
| seahorse |
Bob Kemmler wrote: ...Peter,they don't call them yamadogs for nothing.This test was done at the "crankshaft",so the ONLY thing it proves is that the 150 etec powerhead is stronger than the yam 150 4 stroke powerhead at the crankshaft.From the powerhead to the prop there could be a decent decrease in power and no two brands will have the same hp loss.Throw longer shaft lengths and larger gear cases and the actual power at the prop will be much different.
Why do you say the testing was done "at the crankshaft"? All outboard companies use certified eddy current dynos according to ICOMIA standards so every test is repeatable, and that is using propshaft dynos. Several years ago BRP published the dyno comparison of their 225 with the Yamaha 225, again, propshaft rating per ICOMIA standards. Merc is #1 in overall sales, but Yamaha is the leader in 4-stroke sales, that is why E-TEC is targeted at them. |
| an86carrera |
Go E-Tecs! Rah Rah Rah |
Bob Kemmler writes:
quote: Bob--Sorry, but without some sort of citation of a test report, I am afraid that I consider your report of this information to be unreliable. You can go around insisting the OptiMax is quieter than the E-TEC, but until there is some reasonable basis to make that judgment, I wish you'd stop posting it to this discussion on torque curves. |
Bob Kemmler writes:
quote: As far as I can tell, there is no reasonable basis to make any inference about the test being performed at the crankshaft. There is no mention of it in the original source material I cited. Please explain how you came by the knowledge the test was performed at the crankshaft. My inference was that the test was performed at the propeller shaft. Engines with higher (numerical) gear ratios will have slower propeller shaft speed. Thus they will have to turn a propeller with more pitch, which in turn will place a greater load on the propeller shaft. If playing with a gear ratio were a way to get free torque or power, it would have been exploited long ago. |
| Perry |
seaorse, jimh, look at the far right of the chart. It says "crankshaft torque" in big white letters. |
| Perry |
Oops, I meant far left of the chart. |
| bigjohn1 |
OOPS! |
| seahorse |
Perry wrote: seaorse, jimh, look at the far right of the chart. It says "crankshaft torque" in big white letters.
I'll check with some factory folks and see what they say. |
| BlackMax |
Zzzzzzzzzzzzzzzzzzzzzzzzzzzzzz................... |
Well, I'll be switched! It does say that! My apologies. I wonder if they tore the power heads off the outboards to test them? That seems like a lot of work. Now we'll have to see if there is something sinister about the "crankshaft" method of comparison. |
| Tom W Clark |
Would somebody explain to me why we should care? I understand that measuring power at the crankshaft vs. the propeller shaft may yield different absolute measurements of power, but this comparison was made ceteris paribus. In other words they didn't measure one motor at the crankshaft and the other at the prop shaft, so who cares? Are you going to tell me that the Evinrude gearcase is somehow going to sap significantly more power than the Yamaha gearcase? Ha! |
| BOB KEMMLER JR |
Jimh-I was merely responding to Jayr about the quietness. I wasn't insisting,merely stating i "thought" i read somewhere about the pump change on the opti's and the reduction in noise because of it.I guess if someone were comparing torque figures on these two powerheads,then this information is worth it's weight in gold. |
| Peter |
There is nothing sinister about using the crankshaft method to show the 2 > 4 message, except to Mr. BlackMax. ;) But its pretty common knowledge that when it comes to low end torque, a 4-stroke of the same displacement as a 2-stroke won't be close. See Figure 1 in Mr. Dawson's 4-stroke outboard article at members.iinet.net.au/~pauldawson/gen/Iame24-4strokes.pdf . This latest BRP graph showing a sizable gap is consistent with the horsepower graph identified as Figure 1 in Mr. Dawson's article. There is a sizable gap there too. The F150 and the Evinrude E-TEC 150 have approximately the same displacement at 2.6L just as the 90s in Figure 1 of Mr. Dawson's article have approximately the same displacement 1.6 to 1.7L. Mr. Dawson goes on further in the article to show that it takes considerably more displacement in the 4-stroke to match the power curve of the 2-stroke. See Figure 2 in Mr. Dawson's article. The F150 uses a 2:1 gear ratio to turn the propeller shaft, and the E-TEC 150 uses a 1.86:1 ratio. (The lower ratio means that the prop shaft turns faster for the same crankshaft speed). The 2:1 gear ratio represents only a 7.5 percent greater mechanical advantage over the 1.86:1 ratio, yet the largest crankshaft torque gap appears to be about 33 percent. So it would seem that a 7.5 percent mechanical advantage is not enough to overcome a 33 percent deficit in crankshaft torque in the mid-range. The side-by-side test of the E-TEC 150 and the F150 on the Angler where the F150 struggles to push the boat would seem to confirm this. There are folks who have expressed skepticism about the side-by-side test saying that the testing was rigged, etc., etc., etc. The torque curves simply explain why the F150 did not perform well as a single when propped as a twin. It doesn't have the low end torque of a 2-stroke and its simply got bogged down by its overpropped condition (all motors are overpropped when run in an emergency as a single on a twin boat). If the HPDI or the Optimax 150 were substituted for the E-TEC 150, the result would have been the same but since Yamaha and Mercury sell 4-strokes, they are not going to put a spot light on the issue by doing a direct live comparison like BRP is doing. Again, they simply have a marketing message conflict that BRP doesn't currently have. |
| Buckda |
quote: Just thought that needed to be repeated. It's funny, but true - BRP has nothing to lose by attacking 4-strokes, so they have the freedom to do so, and do it quite freely! The others don't like it because they have trouble saying "Well Optimax..." or "Well, HPDI...". If they do, they have then emasculated the marketing for their 4-stroke models. Serving two masters is bad business....and people were long-ago warned about it. Matthew 6:24 |
| The Judge |
Again...that is probably why Suzuki uses a 2.59:1 ratio and why I have never seen a holeshot difference for the most part. My friend had twin 130 Yamahas and switched to 115 Suzukis, he lost 1 mph in top end and 1 mph at cruise but went from 15+gph to about 10 even though he gave up 30hp. This could also be why some call them Yamadogs, especially their 70 & 90hp 2 strokes compared to OMC's. |
I am the first to admit I am not an outboard engine designer, but my feeling is the gear ratio is chosen to optimize the propeller performance and to allow the engine to match up to existing propellers. |
| stefan |
actually, I like the free baseball caps I got from evinrude, but of course, I had to buy a new Etec to get them-LOL |
| JayR |
Free caps!!! How did I miss out on that? |
| stefan |
my dealer gave 'em to me- he had a box full of Etec caps and visors- give your dealer a hard time! |
| seahorse |
The following is the reason given to me about using crankshaft dyno readings for engine torque and propshaft dyno readings for horsepower charts in the Evinrude brochure. It makes sense now. The torque chart is CRANKSHAFT torque and the horsepower chart is PROPSHAFT horsepower. Here's why. Propshaft horsepower is the power available to the consumer after exhaust restrictions and power LOSS after going through right angle gearing. So, that's why the industry looks at propshaft hp. Torque, on the other hand, is something that can be misrepresented and can be misleading if taken at the prop. Let me explain. Torque can be dramatically misrepresented if a gear ratio reduction is involved. Typically, a standard gear ratio in an outboard today is somewhere around 2:1. If that ratio were a fixed standard for ALL motors in the industry, we'd probably go with it. But, ALL gear ratios are not equal, so propshaft torque is easily manipulated and is never a true measurement of the motors POWER. As you probably know, to derive the torque of a motor, simply multiply the hp by 5252 and divide by the RPM. What if tomorrow I decided it would be a good idea to change the gear ratio on the 115hp Evinrude E-TEC to 3:1. What would happen? · 2:1 Gear Ratio w/max hp at 5500 RPM o 115 X 5252 / 2750 (propshaft RPM) = 220 lb ft of propshaft torque
· 3:1 Gear Ratio w/max hp at 5500 RPM o 115 X 5252 / 1833 (propshaft RPM) = 330 lb ft of propshaft torque Question. Does the motor with the 3:1 gear ratio have more power? No, it's still 115hp. However, the torque has changed because we changed the gear ratio. You may ask, but wouldn't that give the customer more POWER to plane the boat, pull as skier, etc. Answer, yes and no. The only way the customer would get more power is if he didn't have to concern himself with top end RPM. The 3:1 gear ratio represents a 50% increase in required prop pitch to achieve the same top RPM of this boat and motor combination. A customer running a 21" prop would have to change to a 32" prop to keep the same RPM on top. If he wanted more "torque" he could achieve the same result by putting on a smaller pitch propeller. Of course, he would have the same problem with top end RPM. So, long explanation to a simple question and simple answer. We list crankshaft torque because it is the only way to see a true representation of the motor's available power. We list propshaft hp because it is the hp available to the customer.
| pglein |
I didn't look at the torque curves as I'm not in the market for a new motor at this time. I did, however notice a lot of people talking about whether it's a fair comparrison, and someone saying that if Yamaha and Mercury come out with a 2 strok that is as clean and quiet as the E-Tec, then they could compare. But to me, I don't care how clean or quiet an engine is. I care only about how much power it delivers to the propeller, how much it weighs, and how reliable it is. Everything else is window dressing. I want a powerful, lightweight, reliable engine. Nothing else means jack to me. I don't care if it's two stroke or 4 stroke. I don't care if it's loud. I don't care if it uses a lot of fuel. I just want it to never leave me stranded, and have the best power to weight ratio possible. |
| holmaldo |
My advice to pglein here is to find a well maintained 2-stroke Merc 90, look at my experience here with my 1998 model: http://continuouswave.com/ubb/Forum4/HTML/004480.html Thirsty and noisy yes, but a reliable, light weight engine with unbeatable, aggressive power in upper register. But where is your environment consciousness pglein.. |
I did not find any torque curves in the linked article. How does it relate to the discussion of torque curves? |
| fourdfish |
Bob Kemmler, How can you possibly say you are not bashing the ETEC?????? Are you loseing money because of ETEC success? |
| BOB KEMMLER JR |
Not bashing at all,the Etecs are a pretty slick outboard.I wouldn't want to own the smaller 50/60/75/90 hp's as they seem to have some tuning bugs they are working out but i'm sure that will eventually get fixed.I dislike thier BS advertising and marketing mumbo jumbo,but they all are guilty of that in one way or another.I think the pricing on them is a little high,but they are selling them so others must not feel that way.Just like cars and trucks,they all suck when they break down. |
