posted 08-07-2006 03:37 AM ET (US)
My BRP tachometer in my Evinrude E-TEC 90 2005 shows as much as 250 RPM less than real, according to my dealer who has tested my boat with his digital tachometer. Background is my earlier reported problems with too low RPM (4850) at WOT, correct RPM is then 5100. Solving that problem is another discussion.
The dealer says the difference is within margins for such an analogue type. Is he right?
My measurements:
a) At idling it shows precisely 500 RPM, I put it in gear and RPM rises slowly to showing 650-700. Both numbers are nearly exactly the numbers from the manual.
b) Tachometer shows less after som minutes. Idling RPM remains the same, but the difference increases with higher RPM and I have found it to be about 150 RPM at WOT, measured several times under same conditions:
Cold engine WOT: showing 5000 RPM, GPS speed 32,9 MPH
Warm engine WOT: showing 4850 RPM, GPS speed same, 32,9 MPH
Then my conclusion is that the tachometer shows 100 RPM too low when cold, rising to the dealer-measured 250 RPM when warm.
Anyone with similar experiences? Should I ask for a new tachometer according to the warranty?
