ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Rigging Accessories
Author | Topic: Rigging Accessories |
montauk steve |
posted 09-28-2006 09:12 PM ET (US)
I am trying to price out [the rigging accessories] needed for my re-power. I know that a few of you have the DF70 on the back your Whalers. If anyone has part numbers for everything they have to re-power that would be great. I need the following: harness, binnacle, control cables, system check tach (Suzuki of course), hydraulic steering, gauges, key switch, etc, and all necessary harnesses. I have most of the part numbers for the E-TEC. Now need to compare prices of everything before pulling the trigger. It is replacing a 1983 Evinrude two-stroke with hydraulic steering right now. thanks steve |
The Judge |
posted 09-29-2006 12:10 PM ET (US)
All dealers will be the same most likely, they are down here. I got most of my parts on e-bay for 1/3 the dealer price...brand new. From what I remember this spring: wiring harness $118, control cables $39 ea, Tach $149 and side control with key was $225. The main harness does everything and just plugs into the tach, controls, key, etc. You steering will fit. I paid $25 for a new tach, $118 for harness at dealer, $125 for controls, and $39 for each cable. $39 for hour meter. Engine itself comes with a few parts and so does the controls. You can use ANY controls you want, do not need suzuki but you will need the suzuki key switch. Try Marine Surplus in Bradenton and Ft Myers FL as well. They carry a LOT of that stuff but I doubt wiring harness. They only had the old style which will not work. |
skeepyjack |
posted 10-02-2006 11:14 PM ET (US)
Steve, go to this website, they listed all the Suzuki parts and price (they are all same every where except e-bay): http://store.brownspoint.com/ Skeepyjack |
posted 10-03-2006 12:21 AM ET (US)
A Suzuki dealer should have information about the DF 70 rigging accessories. |
montauk steve |
posted 10-03-2006 01:28 AM ET (US)
jimh, I find it difficult for dealers to give me part numbers and prices on things that i am trying to budget for. yes maybe i will not shop there but, who knows. with one of the more popular topics being re-power i think it would be a good idea to have a list of was/is needed to repower in the reference section. i understand that this is not a message board for motors and parts but think most guys would like it when its their time to pull the trigger on a new power. my $.02 steve |
montauk steve |
thanks sleepyjack |
ratherwhalering |
posted 10-03-2006 01:52 AM ET (US)
Remote control outboard engines need several accompaniments to function and operate correctly. These accessories are commonly referred to as “rigging” and entail the following basic components: 1. Fuel supply line. Flexible tubing that supplies the engine with fuel, from a remote tank. It is available by the foot at most marine chandleries and is distinguished by its inner diameter. It must be USCG Type A1 to be alcohol and fire resistant. The fuel line is commonly secured to engine using the manufacturer’s “quick connect” fitting, or other in-line splice fitting, both of which are secured with circular crimps or clamps. Fuel filters and water separators may be added in-line with a primer ball down flow from the fuel filter/separator, and in a vertical position. For further reading, see: 2. Battery cables. Flexible wiring that supplies power from the battery to the engine for starting. The manufacturers commonly provide 4-6 feet of duplex (positive and negative) battery cable with the purchase of a new engine. It is also available by the foot at most marine chandleries and is distinguished by its thickness, referred to as “gauge”. Typically after the engine has started, these wires then supply power from the engine, back to the battery, for charging and powering accessories, such as instruments and running lights. 3. Wiring harness. If the engine is the heart of your whaler, this flexible, multi-functional bundle is your engine’s nervous system. It runs from the engine to the helm area. The wiring harness is specific to each engine manufacturer. It contains: 4. Remote oil tank, oil supply line, and wiring (most larger 2-stroke engines). Many 2-stroke engines have a remote oil tank. These tanks provide 2-stroke engines with oil, which is used to lubricate the engine. Four-stroke engines have an internal lubricating oil supply and do not need these accessories. The remote oil tank typically has an oil supply line and a small, independent wiring harness that runs from the oil tank to the engine. 5. Throttle and shift cables. These semi-rigid cables have a solid outer sheath and flexible core wire. These cables bridge the span between the operator’s remote control (“control box”) and the engine’s transmission (“shift”) and throttle control levers. (“throttle”.) Collectively, these are referred to as “linkage.” While linkage is specific to each engine manufacturer, some generic cable adapter kits are available for both the engine and the control box ends. 6. Control box. This unit(s) allows remote control of the engine’s shift and throttle cables. It should have a concealed neutral safety switch that only allows the engine to be started when the control box shift lever is in neutral. It may also contain the trim/tilt switch, which allows the operator to raise and lower the engine. A trim/tilt switch may also be mounted as a stand-alone switch on the console. Both the neutral safety switch and the trim/tilt switch are connected to the engine via the wiring harness. Modern single engine applications commonly use 1 dual-function control, while twin-engine applications commonly use 2 opposing dual-function controls. 7. Steering system. This system is used to turn the outboard engine form side to side, thus controlling the direction of the boat. There are three systems, cable/pulley, mechanical, and hydraulic. The cable/pulley system is not commonly used in modern applications, and will not be addressed herein. Mechanical steering consists of a steering wheel, helm box, push-pull cable(s), and hardware that allow you to connect your steering system to the outboard motor. A hydraulic system is used for large horsepower outboards, and gives the operator a greater mechanical advantage, and easier operation. It consists of a helm pump, which is connected to the engine-mounted cylinder, via flexible hydraulic hoses. The cylinder has hardware that allows connection to the outboard motor. The helm pumps hydraulic fluid through the hoses to control the cylinder. 8. Ignition switch. This is a remote, keyed switch that allows the operator to start and run the engine. It commonly has an integrated choke function, and is connected to the wiring harness. It can be found mounted in the control box or as a stand-alone unit on the console. 9. Warning horn. This is a remote alarm that signals the operator if there is a problem with the engine. It is typically located behind the instruments, and emits a loud, blaring signal. It is connected to the engine via the wiring harness, and can also be found in the control box. Two additional categories are not always required, but are necessary to promote safety and functionality: 10. Instruments. There is a multitude of choices, options, and variations regarding instruments, however there are two main instruments that are accommodated in all wiring harness; the tachometer provides the operator with information regarding the engine’s RPM, and the trim/tilt gauge provides information on the static trim of the engine in relation to the hull. Newer engines and instruments can contain a multitude of engine performance data, using the wiring harness as a conduit for information. Sonar transducers, speedometers, and temperature gauges often use separate wiring conduits not contained in the primary wiring harness. 11. Ignition kill switch, or “dead-man switch”. This is a remote ignition disconnect switch which is physically connected to the operator via a lanyard. If the operator leaves the helm area, the lanyard extends, ultimately triggering the switch, which shuts off the engine. In some applications, the switch must be reset before the engine will start again. This switch can be found mounted to the control box, integrated in the key switch, or as a stand-alone unit on the console |
posted 10-03-2006 01:39 PM ET (US)
Rob--That is a great list. I will turn it into a stand-alone article in the REFERENCE section. montauk steve--if you think it is too much to ask the dealer to give you prices and part numbers for the rigging accessories, why do you think it is not too much to ask someone else to provide that information for you? I'd think a dealer who is in the business of selling the stuff would be glad to give you some prices and a quotation of what is needed. |
montauk steve |
posted 10-04-2006 09:44 AM ET (US)
montauk steve--if you think it is too much to ask the dealer to give you prices and part numbers for the rigging accessories, why do you think it is not too much to ask someone else to provide that information for you? I'd think a dealer who is in the business of selling the stuff would be glad to give you some prices and a quotation of what is needed. It would be the same thing here with this message board. whaler owners could call the company, twin city marine, or whom ever, but why when you can come here and search for what parts and things have been done. Just thought it would better the community. |
andygere |
posted 10-04-2006 11:11 AM ET (US)
I was at my local Evinrude dealer this week, and picked up the 2007 catalog. In it were some very nice looking binnacle controls that are a completely new design. My dealer told me that at a recent BRP dealer meeting, he was told that BRP set out to design a control box that was as smooth operating and well made as Yamaha's, which are widely regarded to be the best in the industry. Be sure when you are collecting part numbers to get the number for the new control box, not the clunky, ugly old OMC designed units. |
The Judge |
posted 10-04-2006 12:02 PM ET (US)
First off if you guys do NOT own a Suzuki then why are you on this thread? Suzukis come with battery cables already installed. They also come with the steering arm and mounting bolts/nuts. They also come with a fuel line and bulb. They also come withcable fittings for the throttle and gas(not the cables though). They also come with an oil filter. The only things you need are the wiring harness, tach, controls, and cables. I think the 70 even comes with an alum prop but they might have stopped that, they did in 1999. What I did to get the part #'s out of dealers was I called and asked about the parts and price. Then I said OK how long does it take to get them in? Then I said I will stop down to pre-pay so what are the numbers so YOU do not have to look them up again because I am not sure just when I am coming down, might be next week. They gave me the part numbers and I scanned e-bay for a few weeks. Luckily I got what I needed except for the wiring harness which set me back like $126 @ dealer. Next friggin week there was one on E-Bay for BIN of $59...DOOF! Again I am not sure about the new 70's but the 115 I bought(2005) needed 2005-up wiring and controls. Any Sukuki tach with warning lights will work with newer harness though. |
andygere |
posted 10-04-2006 05:55 PM ET (US)
Judge, montauk steve said: quote: I think that makes my input on the BRP control box relevant to the thread. |
posted 10-04-2006 08:47 PM ET (US)
The way information becomes available is that someone collects it, organizes it, and publishes it. Maybe once montauk steve collects all these part numbers and prices for both the E-TEC and the Suzuki, he will organize them and present them for the benefit of others. |
montauk steve |
posted 10-04-2006 11:41 PM ET (US)
yes once i get all the part numbers i will post it. |
bamatenn |
posted 10-05-2006 10:52 AM ET (US)
I repowered with a DF 70 about six months ago. The E-tec 90 was on my short list. I've put about 120 hours on the Suzuki and I'm convinced I made the right decision. Top speed is 38.5 mph. I normally cruise around 20 mph (3,200-3,300 RPM) and burn just under 2.5 GPH of 87 octane. Everything was included in the price of the 2006 motor ($5,950) except for a stainless steel prop, binnacle controls w/ switch and $125 for rigging. All part numbers can be found here: http://www.suzukimarine.com/accessories/ |
bamatenn |
posted 10-05-2006 04:03 PM ET (US)
P.S. I also used a 4" Setback Plate (Cook Mfg. # 40012) and a Custom Washer Plate (#2000) engraved with "Boston Whaler". Both were ordered from Boat Owners World. Ken |
montauk steve |
posted 10-09-2006 12:48 AM ET (US)
ken, thanks for the reply. |
