| Author | Topic: Outrage 22: Evinrude 235 V6 Cross Flow |
We (Buckda and I aboard Dave's GAMBLER) were out for a boat ride last Saturday on a blustery day--one that will probably prove to be the last boat ride of the season up here for me, at least the last one in the Great Lakes. The weather was a bit cold (42°F or 5°C) and there were very few other recreational boats on the water. We took a run up the St. Clair River, under the twin spans of the Blue Water Bridge, and out into Lake Huron. With our course due north and the breeze light from the south, the waves on the big lake were negligible. We were loping along, until I finally said, "We better turn back or we could go like this all the way to Port Austin (about 75-miles north on the tip of the "thumb" of Michigan). Jeffs22Outrage was cruising along with us. Dave shot this short video of the classic OUTRAGE hull running at a moderate plane. It just has a great look to it. The boat really seems to have some authority as it comes up from behind you. Jeff and his Dad were braving the cold without any weather canvas. I thought it was worth showing this little movie--sorry no sound to go with it. You will have to imagine the sound of an old Evinrude V6 235-HP Cross Flow. By the way, the motor is the same vintage as the boat, which I think are both early 1980's. Jeff--jump in here with the details. As someone mentioned recently (Binkie?) having a motor of the same vintage on your classic Whaler hull is akin to having an old Corvette with all the serial numbers matching. It does seem to add a bit to the restoration value and admiration. The old Evinrude V6 motor was just rebuilt this spring by the equally old Evinrude hands at Lockeman's Boat and Hardware in Detroit, and she is running quite sweetly. Later, on the way back in after we ran a couple of miles out into the lake, Jeff went by us going like blazes. He said it was 46-MPH on the GPS. Not bad. OK--enough rambling. Just a simple short movie showing a very nicely restored classic Whaler with a vintage engine--both still running just like the day they were delivered. You can see why they sold so many like this: http://continuouswave.com/whaler/movies/outrage22BlueWaterBridge.MOV Also, couldn't resist showing this nice view of the Outrage. Here we're heading south into some two-footer rolling up against the river current. Jeff's Dad is waving to a crew member who came out on the bridge wing of the SAGINAW to take a better look at a couple of classic Boston Whalers:
I'm out of control here, now. I want to show you another view of the classic OUTRAGE 22 hull. We're just getting underway after lunch at the town of St. Clair. By the way, you can see how low the water level on the Great Lake gets late in the season. It was a tough climb for me to get out of the other boat and quite a jump down from the seawall to get back in. Remember, the boat I'm on has lower gunwales to begin with, there are twin engines, and because of all the canvas you can only get on or off from the stern. It was quite a climb for an old, out-of-shape guy like me. From this next shot you can get a sense of the classic Boston Whaler OUTRAGE 22's proportions. It shows the space in the stern for fishing or gear in this classic. Yea, there aren't any storage compartments or bait preparation tables, but there is a heck of a lot of room for whatever you want to put back there. When I saw the boat at this angle I had to find my camera, take off my gloves and snap this picture:
By the way, that old carburetor 235 lit right up after lunch and was running very smoothly for an old motor on a darn cold afternoon. This image was shot at 1/86-second and the motor is in sharp focus--that means she wasn't vibrating and dancing around from a rough idle. |
| jeffs22outrage |
Jim, Yes the motor is of the same vintage as the boat. Both were built back in 1985. When faced with the blown head gasket and a scuffed cylinder wall last year I knew I was going to keep the motor on the boat. Being a designer I wanted it on there more for aesthetic value than any other reason. I got lucky with the overhaul of the motor. After Dave and Ben of Lockemans Hardware and Boats looked at the motor when it was all torn down they and I all agreed that there was no reason to overbore the cylinder walls. Also the one cylinder that overheated could just have a heavy honing done to remove the scuffs. So all cylinders were rehoned, all pistons, rings, and wrist pins, and all bearings were replaced, all gaskets were replaced, new thremos, and all of the Carbs were rebuilt. The VRO was the only thing I did not replace only because the newest version will be out in Dec 06 or Jan 07. Dave at Lockemans tells me that the newest version will be built to with stand all the heavy ethanol uses in todays Gasoline. BTW the boat has ALWAYS run the VRO system in it's 20+ years of service without issue. If you use and care for the system there should never be a reason to remove it. The motor has been working great this year (though it has always run great). It fires up on the first try 99% of the time. It runs so smooth and for a motor of its age it is VERY quite. It does burn through the fuel but no more than the carbed Mercs I have run. The 46mph was hit for the first time ever since I have owned the boat. I think that speed was do to the motor finally breaking in a finding its groove, the rebuilt carbs, and some work I have done to the prop. I run the standard 14.5 X 19 OMC stainless painted prop. The fact that it is painted stainless has been driving me crazy for some time. So, wanting the prop to look like it should I have been wet sanding the black finish off the prop. I started with 200 grit and have worked my way up to 800. I still need some work at the 800 level than I will hit it with 1000 and move to a polishing wheel for a shinny finish. Also I have taken a good flat file and worked the trailing edge of the blade to a sharp 90 angle to the blade face to help the water to release better for the blade. The thing is, since I have been doing this work I have been seeing a slight but steady raise in top end. So in the end I can see both sides of the fence on the new motor craze. Being However, I still feel for me there is no reason to get rid of an old motor just because of its age. So long as you care for it the way you should it will keep you happy for a long time. Well that is with freshwater usage. Salt can be a different story I now. I do have to take a minute and thank Dave, Ben, and Doug at Lockemans.com for their service on this motor. It is easy to see why they are the oldest continuously operating OMC / BRP sales and service dealer in the country if not the world. Not only are they the best when it comes to the actually rebuilding of the mechanics of the motor but they are by far the best at building a relationship between them and the customer. They have given me by far the best customer service I have ever received for any item or service has been with them. Stories like Buckda's where we travels at times up to 8 hours just to have them service his motors speaks volumes. If you are ever in the Great Lakes area you should take the time and head over to there shop and say hi. They love people from the wave and welcome is everyone no matter what you have hanging on the stern. The continuouswave GLBWCC has kind of adopted their store as our club house. Here are all of the images from our run last weekend These are the images of the motor as I was tearing it down for rebuild. |
| Teak Oil |
Looks good Jeff. As an owner of a 1985 Montauk and a 1985 Evinrude V4 I can appreciate the aesthetics of having a vintage motor on a nice boat. It would be nice to have a nice E-TEC but I am proud of what's on there. If there comes a time when I have the cowl off more than its on I will have to rethink the old girl, but for now she is in her prime. |
| tonyt |
Motor looks great! [Changed the topic of discussion to his boat and his motor. Replies to this new topic have been deleted from this thread about Jeff's boat and motor and mailed to Tony.--jimh] |
| Jeff |
Nothing is ever 100% bulletproof. The motor in this thread had it's own failure but, after Lockemans and I put some love into it, the motor was great. It started nearly every time on the first turn of the key, idled and ran so smooth, and with the XD50 oil produced almost no smoke. I still speak with the new owners of my 22 Outrage (shown in this thread). They have the boat at their weekend house on the Chesapeake in Maryland and love using it with their 5 kids. They had all the intentions to repower the boat after they bought it but said, "That old motor runs so well we can not justify replacing it." Jeff Rohlfing "Jeffs22outrage" |
| Grogadile225 |
Gentlemen, I had a Crossflow 235 for quite some time years ago on my 18" John Haines Signature 1550LE and it was the best power to weight for its class. 30" off the heads, squared intake and exhaust ports, exhaust deflectors releived to match, releived crankcase and the intake side of the piston scalloped with a 1" diameter hole in the skirt (intake side), flex flywheel and Boyessen reeds. Ran wonderful on 95 RON Unleaded MOGAS (Petrol in Aus). It ran 6900 RPM with a 21" Mercury Laser for a radar proven 73 MPH. Prior to mods it ran 63 MPH with an OMC 21"- at 6600 RPM. Eventually put a 225, 2.7L Looper on and what a disapointment. Heavy, lethargic, slack on acceleration and torque but made up in gas mileage. The 235 after mods used to do 30 L/Hr sking, the 225 did less than 20L/hr. Still the cross flows are a great engine, idled at 500 RPM and never suffered the OMC Loop V sneeze. As my current 3.0L 225 does. Annoying idle quality on the loopers but the 2.7's seem the best for idle quality. Sneeze, cough burp. Whish they would just idle. New engine and gaskets in carburettors and it is the most annoying thing on the water. The 2.7 after adding quikstart wou;d just run. The 1993 well Mmmmmm. I've looked at it, an OMC trained technician has looked at it and we all throw our hands in the air. Perhaps a Rochester 4MV Quadrajet or Bosch LE Jetronic. |
| brisboats |
Cross flows just idle better than loopers, especially in the OMC lineup. Something I have been saying for some time. Brian |
| Peter |
I agree. It always seemed to me that the cross-flows had a less "peaky" power curve. In other words, the cross-flows would be active right from idle whereas the loopers wouldn't wake up until about 2000 to 2500 RPM. |
| Tohsgib |
They don't call them "2-Thirsty-5's" for nothing! |
