| Author | Topic: 1982 SPORT 15: 46-MPH |
| zotcha |
Finally, last Thursday had opportunity to run [my 1982 SPORT 15] out at ideal conditions. Video taken from second boat running Garmin GPS. Unfortunately, chinewalking is very difficult to observe from video. But it is present! Details: 1982 SPORT 15, 2005 Yamaha F60 EFI, factory 10.25 X 15 SS prop and a Bob's Machine 5-inch jack plate. Single operator 155 pounds, 7 gallons of fuel in 15 gallon tank, and a full 48-quart cooler forward of the forward thwart. Conditions: Winds 10-MPH out of the north and mid-outgoing tide running approximately 4 knots. Fairly flat, protected creek. Both videos filmed heading directly into the wind and tide, and running 45-MPH. Not taped, running opposite direction of videos, hit 46-MPH running with wind and tide. I don't have the ability to display the video but can e-mail if anyone is interested. zot. |
| runpasthefence |
Zot, What kind of RPMs were you turning? |
| Sal DiMercurio |
I don't think so. First, if there's only 1 mph difference [ 46 mph ] running "with" a 4 kt current, vs running 45 mph "Against" a 4 kt current, something isn't adding up [ about 4 mph off ] . Next, unless your engine [ 60 hp 4 stroke ] is twisting close to 7000 rpms with "ONLY" a "15p" prop, your not even close to 45 - 46 mph. Try 38 mph maximum. You have to understand that many of us are running 70 hp engines [ 10 more hp than you ] with 19p props [ 4" more inches of pitch than you ] & were getting 43 - 44 mph. at 6000 rpms. Thats a sweet rig [ I own one just like it with 70 horses on the same jack plate ] but I think your gps is off. Sal |
| Sal DiMercurio |
I forgot to add. You wont get your best speeds on glass smooth water. Optimum water for best top speed is 1' to 18" chop very close together. The reason for that is, "LOTS & LOTS" of air under the boat, equals far less drag. This also allows your prop to cavitate in between some of the waves, resulting in bursts of over rev & when the prop grabs again it launches the boat in faster short bursts. That is ideal racing water. Sal |
| Binkie |
I don`t think 18" chop is race water for a 15` boat, maybe an offshore tunnel hull, I would think 6" would be ideal. Cavitation means lost speed, not increased speed. Zot has quite a bit of experience in fast boats, and it sounds like he has it dialed in. I would like to know what rpms he`s running. BTW Zot, is the cracker box coming to mt. Dora? Rich |
| Binkie |
Zot, I would like to see the video. Rich |
| zotcha |
Cool! Some feedback! First, RPTF, per my Yamaha mechanic, I am always bouncing off the rev. limiter (6300 w/current), with this set-up. And I know this is not good. He recommends a nosecone and high water pickup if trying to get anything else out of this set-up. Second, Sal, I knew this would not add up for current directions. This is only an estimate. Tide swing is a very big factor here. I've been told that a 6.5 to 8.5 tide swing in 6.25 hours is approximately 9 knots, usually the first and last thirds of that period, the middle being less. My Jersey Speed Skiff has no transmission (direct drive from crankshaft coupler to propshaft coupler). Docking and trailering is Nuts! I thoroughly understand 1" to 18" chop to air the hull and prop but I'm not sure if I've got the nuts to air this hull! My past posts have tried to research other prop configurations for this rig, and I am not trying to achieve the unattainable. I have never been sure of what I've been running. April I am planning to purchase the new Garmin 5 Series to swap back and forth from BW to SeaCraft. Just was impressed to run side by side with a boat I was previously running 41 mph an hour earlier with my girlfriend and Golden Retriever (w/current). I replaced a 1982 Johnson 70, without the jack plate, and the boat seemed similarly fast with the same chinewalking characteristics. But the A/V plate was significantly lower and the prop was not near 19. Ultimate demise of that engine was a severely clogged water jacket, discovered after powerhead was disconnected from midsection. Already agreed price of $400 and presently powering a 16' Carolina Skiff quite nicely. If calculations say 38 mph, I'll take it but I'm striving for more and filming boat never left the whaler. I want to ride in a 15 Sport that can "power through the chinewalking", settle in, and power back through while decellerating, if this is possible. My point, the video with the 90 hp at 51 mph, shows no sign of chinewalking. Now I undersatnd why. zot. |
| Sal DiMercurio |
Even at 6200 rpms with a 15p prop @ a 2:3 gear ratio it's -20% slip [ minus 20% slip ] and that isn't possible. Binky, 1' chop "very close together" "IS" optimum race water even for a 15' hull. The waves "CAN'T" be 20' apart. My 20' outrage likes 18" at approx 12 - 15' apart traveling over 45 mph. The boat rides from wave top, to wave top, & is perfectly steady with no ups or downs as long as you continue at high speed. You have to be moving at a good rate of speed, [ 45 mph+ ] or you will pound if to slow. This is best done in a following sea. In order to get 46 mph in a 15' sport, it's got to ride on lots & lots of air, not flat or trimmed in, & the more air under her, the faster she runs. Sal |
| Teak Oil |
Not to mention that the prop is only 10.25" diameter. Thats VERY small diameter, usually 30hp motors use tiny diameter props like that. Something is off because it is just not possible for that tiny prop to push that boat to 46mph. I am not saying anyone is a liar, just that something is way off. Does your GPS also have a paddlewheel for speed? |
| zotcha |
I agree about the prop diameter. That was my point this time last season when she went in for 20 hour service and a bent SS steering tube. 05 and 06 this was the larger of the two props available for this engine. Local dealer is selling with bigger diameters but have not had a chance to try one. The filming boat is a 2007 Key West 196 Bay Reef with a Suzuki 150 FS, a monster prop, and a dealer mounted Garmin 178C. Always learning. zot. |
| zotcha |
Bink, you have mail. Let me know if it works. Only sent two of four vids. Mike. Good Night All. |
| Binkie |
1 ft. chop sounds rough to me. Guess I`m just used to going fast in a boat with a padded bottom. It doesn`t need rough water to air out. I like to go slow in fishing boats. Rich |
| Sal DiMercurio |
Rich, your only going to find 1' chop real close together in shallow water, because in deep water the waves are far apart & impossible to run at wot. In shallow water such as bays [ 4' to 8' deep ], the waves are very close together, & that allows the boat to reach out for the next wave while still on top of this wave. The ride is very soft if you keep the speed up. Try it in a following sea. Thats where Whalers really shine compared to other boats. Just remember to run those waves at "maximum trim" or the boat will want to ride to flat, or stuff itself,.... keeping lots of air under her is the key. Don't be afraid to do it, just put the hammer down, trim her out to maximum & keep saying to yourself,...Damn that Sal, Damn that Sal, why did I listen to him, now how in the hell do I stop this thing. Sal |
| Teak Oil |
I can run my Montauk wide open in a 1' chop, but thats about it. Try it in a 18" chop and someone is flying off the boat, lol. I hit my best speeds in a 6" to 1' chop. Any inland lake in MI will produce perfect conditions for top speed. Getting conditions like that on the ocean is probably almost impossible |
| Lil Whaler Lover |
Sal, We have this discussion before on a 15" Center console of mine with a 15" Solas prop. The Yamaha F-60 has a 1.85 gear ratio NOT a 2.30 which you are using in your calculations. The Yamaha F-60 gear ratio is 19.6% percent closer to direct drive than the OMC 70's. Said the other way the OMC 70 is 24.3% longer in the tooth than the Yamaha f-60. In basically still water (less than one mile per hour current and flat calm), my rig consistently achieves 42.8 miles per hour whether I am running it north, south, east or west. This is read on a Garmin. Using the prop calculator, this means the theoretical top speed at 6100 RPM (my rev limiter) is 46.934185 miles per hour for this rig. The best I have seen is 43.8 miles per hour at 6100 rpm, giving a 93.3% efficiency. Also note I do not have a jack plate and my motor is mounted one bolt hole lower than Tarbaby who attains similar speeds. The bottom of my boat in unpainted and in very good shape. Tarbaby's boat is painted. All this said, ZOTCHA will likely be closer to 100 % because of the higher engine mounting. Now if he is hitting a 6300 rpm rev limiter his theoretical top speed will be 48.47 mph. 45 mph will give him an efficiency factor of 92.8%. Ironically this is slightly less efficient than my boats factor. A possible explanaion could be that chinewalking reduces the efficiency slightly. All of my speeds are taken without chinewalking, possible to do with the F-60. With my previous 70 hp Mercury chinewalking was a major safety problem. The design speed of this hull seems to be 42 to 44 miles per hour. Anything over that gets into handling problems. |
| Teak Oil |
What is the diameter of your 15" prop? |
| Lil Whaler Lover |
My 15" Solas SS prop has an 11" diameter. Now please explain any relavence this has to the discussion. The best I can figure is that the 11" diameter will rev much more freely than the 13" or 13.25" diameter that the OMC 70's run. Otherwise the diameter has nothing to do with the top end performance. Dave |
| BOB KEMMLER JR |
I still can't see how these 15's with jackplates are having chine walking problems?I still have my 15 Mischief/Merc 90 motor mounted right on the transom(as high as it will go)and have gone over 50 mph with no chine walking problems at all.The higher the motor goes,the less likely you'll have chine walking prblems,to a certain extent of course.The 15 Whaler hull definately isn't a high performance hull,but on good water it should be possible to go 45-55 mph without being ejected from the boat IMO.I'm getting ready to put on my 4" jackplate and dual cable steering.Hopefully this will allow me to raise it enough to run a 26/27p prop and of course i'll bore you guys with the report when i do. I know of one guy(Ancarrera86) here who moved his seating position forward and he says that allowed the boat to run at high speeds with less problems.So maybe the key to the 15 sport hulls is to move the weight forward some and allow the hull to make use of those 2 strakes on the bottom.I believe they act like training wheels and help stabalize the hull at higher speeds.Move the weight too far back and you may be balancing on a point past these strakes which will be the round portion of the hull.I have run my boat for miles at 47/48 mph(per gps)with not even a hint of any chine walking. |
| Binkie |
Bob is right. One of the major causes of chinewalking is running the motor two low. You can overcome chinewalking by walking the steering wheel back and forth very slighty, you can`t have any play in the teering wheel to do this, and you can power through the chinewalking phase, by puting the boat in a slow left hand bank and adding more throttle, although this might not work on a non padded hull like a 15 ft. Whaler as its not a high performance boat. Rich |
| The Judge |
All of my 15's with 60-70hp chinewalked when running full tilt boogie. Bob's does not probably because it is a mischief with a LOT more forward weight and you sit forward as well. Best I ever got was 48.6 with a 15 CC, Johnson 70 and a 13x20 at 6k w/bottom paint. She was jacked so high you could almost change the PTnT pump from inside the boat. When you nailed it she would run 5500 then slide down to about 5k and go from there...not ideal for everyday use but was like running a 4k stall converter on a car. What a fun rig. |
| Teak Oil |
Dave if you think diameter has nothing to do with top end you are completely ignorant of propeller dynamics. As diameter increases thrust increases and drag increases. Thus an increase in hp is needed. A 15" prop with a 15" diameter is going to have completely different characteristics than a 15" prop with an 11" diameter. The prop with the bigger diameter is going to push a lot more water. Too often diameter is ignored and a propeller is judged by pitch only. |
| Lil Whaler Lover |
Kudos to The Judge for his comment about forward weight distribution. This is a good explanation of why there may be some variance in chinewalking between 15' hulls styles. One other comment on chinewalking, when I had a 1988 Mercury 70 (based on the ninety) on the boat, I had a horrendous chinewalking problem which started at 40 to 41 mph. The boat was so hard to steer that I had to use the power trom to turn the boat. That motor had a 2.33 lower unit and turned a 13.5" diameter by 22" pitch Laser 2 prop. With the 11" diameter Solas on the Yamaha F-60, on a proportionally smaller lower unit I get essentially the same top speed, no chinewalking and can steer it with 1 finger at any speed without playing with the trim. It seems rather obvious that the hydrodynamics of the smaller lower unit just work much better on the very light Classic 15' Whaler hull. Now Teak Oil, an increase in diameter will give more thrust in the viscous state we run our boats in. It will also create much more drag, therefore giving a slower top speed for a given horsepower than a smaller diameter prop on a smaller lower unit. An increase in diameter will lower the maximum rpm of the motor as more energy is used to move more water. By any reasonable theory, the smaller the diameter of the prop, the higher the potential apeed is. (Gee, I hate answering my own rhetorical question.) Sal DiMercurio, please give us some more feedback about your theories now that you have the correct gear ratios available to you for the Yamaha F-60 and the OMC 70. I really respect your insight on propellers, but I have to continue to respectfully disagree with you on your assessment of the performance of the Yamaha F-60. Dave |
| an86carrera |
I have a fifteen foot Whaler with a 1987 70 Hp Merc. I am running a 13" dia. 22" pitch Laser II. I have moved alot of weight forward, battery, 20 gal fuel tank in a standup center console. This boat will chinewalk mildly at 43-44 mph. It has improved alot since the weight move foward. I have also noticed that the chinewalking is better the higher i raise the engine with the 6" jackplate. I started to get low water pressure though so now I am putting on a low water pickup. I also hope raising the engine a few more inches will get some more rpms without trim, which hurts the chinewalk problem. The boat is better with two people in it, more weight and lower bow height. I hope to have it back together by the weekend I'll let you know what happens. Len |
| BOB KEMMLER JR |
lil whaler lover-I have the 2.3 lower unit on my 90 and I think at these speeds the size or shape of the lower unit doesn't really comes into play.Just my opinion on that subject. |
| Peter |
My 15 SuperSport with the 70 Yamaha (max speed is about 42 MPH) and its large 2.33:1 gearcase will chine walk at anything over 39 MPH. Never had any chine walking with the 48 Johnson which was good for 36.5 MPH. The owner's manual for the 15 Super Sport has a cautionary statement about powering the boat with a 70 HP motor. |
| Sal DiMercurio |
Little one, I dissagree that the smaller dia prop will move through the water free'r than a 13" dia. RPMs are rpms, be it 11" dia or 13" dia, the 13" dia turning at the same rpm will eat the 11" dia in a second The 13" dia "will" give more umph than the 11". Personally I don't agree that 60 hp is getting 46 mph. Dia is power & pitch is thrust & pitch rules. Your saying the gear ratio on the 60 hp w/15" pitch over powers the 4" difference in pitch on the omc w/19" of pitch because of the difference in the gear ratio? I just don't agree the gear ratio on the 60 hp at 1:86 [ same as the 6 cylinder johnson - evinrude ], passes the the 3 cylinder omc 70 hp with either the 2:0 or the 2:50 gears twisting 4" more pitch. How many more revs will the 60 hp w/15p prop & 1:86 gear ratio turn "at the prop," [ not the tach ] than the omc 70 hp with a 19p prop & 2:0 or 2:45 gear ratio at the same engine speed [ rpms ]. As far as chine walking, my 15 sport w/70 hp never did chine walk at 43 - 44 mph because I also have an 18 gallon tank under the front seat. I would question the callibration on the gps. For instance, I was out today on my "V"20 & at 5900 rpms with a 19p prop on the 200 hp engine [ down on the second set of holes, not the third ] , my gps read 29 kts while my speedo read 55 mph & my ff read 56 mph. My gps is a garmin 160 but it reads 29 - 32 kts at 4000 rpms or 5900 rpms. Trust me, I know what 29 kts is [ 33.35 mph ], & 55 mph. I would still have to see with my own eyes to confirm 46 mph with a 60 hp on a 15' sport. Sal |
| BOB KEMMLER JR |
Time to set up those video cameras focused in on the gps and have ourselves a 15 shootout ;o) |
| Lil Whaler Lover |
Sal, do the math to get theoretical top speeds. I have just looked up the gear ratios for both motors so they are accurate. OMC 70, 19" pitch, 12/29 gear ratio (2.42), 6,000 rpm, yields a top speed of 44.67 mph with no slip. Yamaha F-60, 15" pitch, 13/24 gear ratio (1.85), 6,000 rpm, yields a top speed of 46.16 mph with no slip. I will absolutely guarantee that I have hit the rev limiter (6100) on multiple occasions on my F-60. There is nothing wrong with my GPS reading either. It is used daily in my truck and moved to my boat when I want it there. It has also been used on a snowmobile, where it reached the highest speed I ever saw on it (95mph). Keep in mind, I have never claimed over 43.8 mph on mine, but my set up is very conservative as to engine height. Dave |
| zotcha |
Realizing that encountering the smallest wake at these speeds would probably send this hull into violent reactions, niether rapid decelleration nor the quickest trimming in seems to safely prevent it. However, if the water conditions were not to change, I think I have gotten the hull past the point of chinewalking (at least the violent side to side reactions). The word I would use to describe the performance at this point would be "oscillate", and feels a little more predictable and safer. Has anyone experienced this? Does this word describe it? Or should we all just agree that its just "chinewalking"? Unfortunately the video is kind of poor but I think everyone in this discussion could easily recognize it. I'm biased but Great Discussion! zot. |
| BOB KEMMLER JR |
Zotcha the "oscillate" motion you describe sounds like the hull balancing itself side to side on those strakes.I think if those had been extended to the transom instead of stopping a few feet ahead of it,the weight balance wouldn't be so critical.Since the hull has a round bottom,it uses those strakes like training wheels. |
| Sal DiMercurio |
Little, you gauranty that your engine has hit the rev limiter on many occasions??? Any engine will reach it's rev limiter, if they put on a prop as you have, that is obviously to small in pitch. Hell, if I put a 15p on my 70 johnson it would twist 64 - 6500 rpms. Why haven't you gone to a 17p from the 15p, as your tach is screaming at you to do so? You would drop your over rev situation down to 5900 rpms from 6300 & atain more speed. Lots of rpms dosen't mean more speed, because if the prop is to small, your just spinning your wheels....[ prop ]. There aren't many boats running around today, with zero slip factor on their prop,especially if the prop isn't the right size, [ to low of pitch ]. Sal |
| The Judge |
I will look it up later but I do not think the 70 OMC has a 2.42 ratio. |
| Teak Oil |
Sorry Dave but you are flat out wrong. Increasing diameter does not slow a boat down simply because of increased drag. On many occasions in the past I have kept the same pitch prop and increased diameter by 3/8 - 1/2 inch and seen significant increases in speed. I will admit some of the increase was probably due to a more efficient prop design. Increasing diameter can bring the rpms down, but the only way you will lose speed is if you drop the rpms out of the motors peak range. If you have the horse power a 14x19 prop will always be faster than a 13x19 prop. |
| where2 |
From page 7 of the 1985 Johnson 70hp/75Hp Owner's - Operator's Manual. Gear Ratio - Long 70, 75: 0.414 (12:39) Gear Ratio - Standard 75: 0.536 (15:28) I get a solid 44mph with the 1985 70Hp mounted all the way down on the transom (Nick has seen it, told me to raise it 2"), turning a 13-1/4"x19" OMC stainless prop from 1985. (nothing high tech about it, although I have had it re-cupped once). Nick will note that I weigh somewhere slightly more than one keg of beer, so I have a definite weight advantage over you two keg guys. I want to borrow Len's prop... That 22" should be interesting... |
| an86carrera |
You are welcome to try at some RNDVU. But, if like to ski the you should try my 20" HighFive. They are both flo torque hubs. Len Ps. the High Five is for sale $250 |
| zotcha |
This time last year Yamaha was still only making two props for this engine. I believe it was the 10.25 X 13, and the 10.25 X 15, which is what I'm currently running. In theory, would the next move be to try finding a 10.25 X 17? Increase pitch 2" reduces rpm around 200, correct? Though barely glancing, I know I have seen 63 going with the tide. zot. |
| zotcha |
I stand corrected. The black painted model now comes in a 10.25 X 16 per the Yamaha home page. Also available for the F60 is a highly polished steel performance prop size 13 X 19. Not sure if local dealer has a few to try. zot. |
| Lil Whaler Lover |
I am going to try to clarify some of this thread in this entry. OMC built 2 different blocks for the three cylinder 70 hp engines. The following information is directly from Johnson brochures from 1968 through 2001. The first generation engines were 49.7 cubic inches. These motors were introduced in 1968 as 55 hp engines. The first 70 hp engines were introduced in 1974. These engines had a rpm max of 5500 rpm and came with a 12-29 gear ratio (2.42). A typical prop for this engine was a 13 1/4 inch diameter. This engine was built with very few changes through model year 1985. This block was also used for a 75 hp engine with a rpm max of 5800 rpm. It was introduced in 1975. From 1975 to 1984 it was available in a long shaft with the same gear ratio as the 70 hp engine. It was also built as a 15 inch shaft from 1975 through 1988 with a smaller gear housing and a 15-28 (1.87) gear ratio lower unit. This model was built to comply with the 50 cubic inch racing class. The brochure talked about Sprint Drive", a low drag lower unit. This lower unit would swing a 11 3/4 inch diameter prop (for low drag). This engine was built for racing and high performance applications. In 1986 model year OMC introduced a new 70 hp engine with 56.1 cubic inches, and a rpm max of 6000 rpm. It still kept the same lower unit with the 12-29 ratio. This engine remained in production through the 2001 model year. Now back to the way my boat runs with the F-60 Yamaha. I do not continually hit the rev limiter but I could at maximum trim if I chose to. The 15" prop accelerates strongly and any additional pitch would negatively the performance when the boat is loaded. Sal, pay some attention to gear ratio in the Yamaha F-60 in comparison to the OMC. (2.42 minus 1.85) divided by 2.42 = 23.55% My prop revs are 23.55% faster at the same engine rpm. The OMC triples are were great engines but the Yamaha F-60 is also an outstanding engine. |
| Sal DiMercurio |
Little, I know the gear ratio on the Yamaha is lower [ 1:86 vs 2:42 ] & allows for a 23% faster rev than the 2.42 on the omc. But,...the distance the 15p prop travels with each revolution of the prop is, 15" optimum with no slip, where the 19p prop travels 19" with each revolution which is approx 20% farther travel with each rev than the 15p, so now were not looking at a 23% difference , were looking at only a 3% difference with each rev, & 3% isn't measured in inches, it's measured in fraction of inches. If in fact both props were the same pitch, than the 1:86 gear ratio would make a world of difference, but when there's 4 inches of pitch difference in props, [ 15p vs 19p ] the 15p with the 1:86 gears no longer has the advantage. Sal |
| Lil Whaler Lover |
Sal, thanks for replying. All we have been talking about is a calculated, theoretical 3 % speed advantage for the F-60 over the OMC 70. Your calculations have helped to support this theory. 3% on 45 mph is only 1.35 mph. This certainly a reasonable difference for a low drag lower unit. Ironically the Yamaha F-60 lower unit almost mirrors the lower unit OMC used on the short shaft 75 hp engines built for racing, in gear ratio, prop diameter and gearcase housing size. |
| Binkie |
Lil Whaler` I believe the triple that was ther performance motor was called the Johnson Stinger, I don`t remember what the Evinrude version was called. They were sought after motors. Rich |
| Teak Oil |
The Evinrude 3 cyl race motor was called the Sprint. Has anyone ran the "high thrust" Yamaha lower unit on a 15 Sport? I am interested to see the difference in speed on the "high thrust" lower unit vs the standard lower. The same goes for the Mercury Bigfoot vs standard lower. |
| zotcha |
Have not had a chance to check price on the Yamaha 10.25 X 16, but sounds like it may be headed in the right direction. Have reputable prop shop in Savannah, can this 15" be worked? Jumping to 13 X 19 sounds extreme. Any thoughts? Thanks. zot. |
| Teak Oil |
Thats way too big. No way you can swing that prop with that gear ratio. |
| zotcha |
OK, I've got all the numbers for the factory 10.25 X 15 Yamaha SS black powdercoated prop per a handheld Garmin GPS and factory digital tach. I used Tom W Clark's performance data sheet, though I can not factor fuel consumption. Date: March 28, 2007 Air Temp.: 82* Fuel: 5 gallons Water/Wind: Flat, Calm 1-2 RPM: MPH: 1000 3.9 This was observed 30 minutes after low tide, with a .5 mph current, and all data collected while running with the tide. My girlfriend, guessing 135 lbs., was with me, and no cooler aboard. She could not handle WOT, so my brother, 205 lbs., joined me two hours later. Tide was running 1.5 mph, and again running with tide. With him aboard, 10 knot wind, I had a very difficult time bringing engine up to 6100 revs.. Numerous attempts, top speed was 44.6 mph and chinewalking. Now I am certain that this rig had hit 45 mph during original post, while running alone. Returned to the garage, replaced prop with a Turbo Hot Shot 10.5 X 16, purchased and received from Tom W Clark and ready to run this weekend, after this coldfront moves through. Thank you Tom! zotcha.
| edwardschnog |
These are some calculations made in Excel with details found on the internet. It is told that a slip between 6-10% is normal at top speed if the engine is running at the factory advised max rpm range. A gear ratio of most mid range engines is 1:2
Pitch Revelotions/min Gear reduction Slip % Mph |
| edwardschnog |
For got to use the tab key Pitch Revelotions/min Gear reduction Slip % Mph Pitch Revelotions/min Gear reduction Slip % Mph |
| Sal DiMercurio |
Huh ?????? Both charts are the same, only difference is slip & speed with the same size prop & reduction. What are you saying? Sal |
| edwardschnog |
depending on the pitch, slip and rpm at top speed you can find the top speed in MPH. So if your boat/engine is in top balance regarding performance, you'll be looking at the 6% slip chart. I wonder what pitch seize those with a 90HP-2stroke Yamaha engine are using and what the rpm is at top speed...... Has anyone ever used the original Yamaha 13 inch diameter Pro Series™ Propellers? What seize pitch did you use from this series. 19, 21 or 23 inch pitch? What is the rpm at top speed? What is the top speed? |
| edwardschnog |
This chart shows that most of you are way of with the said top speed..... It's impossible to go faster than the theoretical top speed unless you are going down stream on a 6mph water current.... 0% slip does not exist! So depending on the pitch, rpm, gear ratio and slip you can determine your top speed. However there are many ways to lower the amount of slip and to optimize boat drag, by choosing the correct propeller. see website: |
| zotcha |
Mr. Schnog, I can assure you of the accuracy of the information posted so far. I do not however understand half of the information you have posted, and have missed the entire point of your reply. I have not had the water conditions to test and collect the data with the new prop. But I will tell you this: If you weigh less than 205 pounds, and lived in South Carolina, I would welcome you to ride and take GPS figures, while I'm trying to navigate, read the digital tach, and keep us both from being ejected from this freaking rocket! Have a nice day! zot. |
| Tom W Clark |
Sal, I believe what Edward was trying to do was provide a chart showing what the calculated speed is with a given gear ratio, RPM and propeller slip. The reason he posted this chart twice is because he thought he could u=insert extra space between characters in his post but as we know, you cannot do that with this software; once you pst your reply, spaces are condensed to a single space. [ Aside: Edward, next time try inserting some characters to take up space, like a hyphen --- ] There is really to reason to go to the trouble to make a chart like this because Jim Hebert has nicely provided a Propeller Calculator which will crunch all the numbers and solve for any parameter be it RPM, gear ratio, pitch, slip or speed. You will find the CW Propeller Calculator here: http://continuouswave.com/cgi-bin/propcalc.pl As to slip: While in theory there can be no zero slip, in reality many propellers will calculate to zero slip or even negative slip. Stiletto and Turbo propellers are famous for this. It is as if they are underrated for pitch. When calculating performance I generally add two inches of pitch to any Stiletto or Turbo prop to get more realistic predictions. If I do not they will often yield negative slip numbers. This is but one example of why it is more or less useless to talk abut propellers in general terms like pitch, diameter and number of blades. One really needs to say exactly WHICH model of propeller one is contemplating. They are not all the same. I should also point that while 6-10 percent slip is a nice goal for an efficient propeller, it is not necessarily bad to have slip of 15 percent or even higher. It depends on the prop and its application. If a prop is faster with more calculated slip, so be it. |
| edwardschnog |
I am still wondering who can give me some advice on which prop to use, to get the highest possible top end speed. Boat: 15 classic sport. Pls let me know more about the siletto and the turbo props available for the 90Hp Yamaha engine..... Thanks, |
| Mardav |
I just bought a 1987 15' SS Ltd (from Troutman a CW member) and saw this thread so I have a question for the prop experts. The boat has a 1987 Merc 90hp Classic which according to the specs is a 2.33:1 ratio. The prop is an unknown brand 3 blade SS stamped with a 19 pitch. It is hard to tell the exact prop diameter but it is either a 13 or 13.25. I don't have a gps mounted yet and according to the prop calculator mentioned above, I should not be getting more than 40 mph at the 5250 rpm which the engine turns now. The motor is mounted one hole up on the transom. Based on the way I was flying by my buds when I took it out the first time though, it seems much faster than that. I overtook pretty easily an 18' Regal PC that allegedly was running low 40's according to their Garmin. I don't need to monkey with this if that sounds like the right prop setup to you guys. I can't get out for a couple of weeks but I thought maybe I would try the 21" pitch 3 blade aluminum Mercury spare that came with the boat to see if there is any difference. So here are my questions: 1. Am I wasting my time trying the aluminum prop? 2. Does the SS prop sound like the right one assuming I am getting around 40 mph? 3. Doesn't 40 sound low for a 90 hp on this boat? |
| Tom W Clark |
Let's not hijack Mike's thread. Edward, Start a thread with your question and I will offer some advice. Mardav, Start a thread with your questions and I will try to answer them. |
| zotcha |
Thank you Tom. Hoping to get new numbers to report by Tuesday. Steady 15 knot wind through Saturday. Mike. |
| Mardav |
Oh, sure, sorry Zotcha.. |
| zotcha |
As they say around here, "Thank you now, ya hear". |
| lastmango |
Edward, I have a 1991 sport that just had a 90HP Yamaha,6" jackplate with the cavitation plate running about 2" out of the water while on plane and a 19 pitch pro series prop. With the Yamaha digtal tach,I am running 48 mph at 4850 rpm's,full 12gal. tank of fuel, with a mounted gps. The range for the rpm for this motor is 4500-5500,gear ratio 2.00. This prop is the lowest pitch in the pro series and the extra cupping and rake that this one has makes it run like it is one pitch higher according to the Yamaha web page. From past experience with Yamaha/engineering dept. about a 250 hp that I owned, the peak hp when they test the motors,is not always at the top of the rpm range,like it is on the johnson's that I owned. The 250 had the same range that my 90 has but the peak hp was at 5300rpm. After testing a couple of different brands of props and reaching 5500 rpm's, Yamaha/eng.told me a different pitch and prop type to match the peak hp and picked up 7mph at 5300rpm's with more bow lifting. That being said, the prop calculators, are at best, a good starting point but not always an exact science for an imperfect situation. The hull bottom shape,prop rake-cup and progressive pitch thruout the prop, makes each prop,even with the same said pitch and size, run out differently. I will be finding out my peak hp/rpm range befor trying to increase my speed and rpm's with the next prop. Lenco trim tabs are also being installed to hold the bow from lifting to much while the motor is being tilted back. I am experiencing no chine walking at this speed. |
| Perry |
mango, if the gear ratio is 2:1 and your prop is 19 pitch and top speed is 48 MPH at 4850 RPM, the slip on that prop is minus 10% That prop would have to have 22" of pitch to generate a more normal slip of 5% while going 48 MPH at 4850 RPM. |
| lastmango |
perry, the 90hp gear ratio is 2.00, and where the talk was about the pro series props,I should have said that yamaha says this prop runs out like a 21 pitch prop because of it's extra cupping for lift.There are a couple of other brand props that also do this. Usually when you go to a performance prop they also have a progressive pitch,19 at the beginning of the blade then 20 to 21 pitch at the end of the blade for top end speed and lift. |
| zotcha |
Mango, are you saying that you are not experiencing any chinewalking, at any speed, or that you've powered through it at say 42 to 46, then it seems to settle back down? Hoping to prop test tomorrow with the new Turbo Hot Shot. zot. |
| an86carrera |
Weight distribution has alot to do with chine walk on the 15' but engine height has almost ompletely rid me of it. My 70 Merc is 8" above and 6" back from the transom. 46-47mph 22" Laser II 5300 rpm 5' x 30' rooster tail trimmed just before loss of bite. With low water pickup of course. Len |
| lastmango |
Zot, as Len has said,the weight distribution and the jackplate is what stopped the chine walking for me. On my gls model the whole console/seating unit was moved forward about 8" along with the gas tank. This keeps the boat from getting so airborn and allows me to tilt the motor back. As I said earlier,lenco trim tabs wiil be installed by the next time I run the boat,this will allow me to keep the boat under control and the motor can be tilted back even more to hopefully get the rpm's higher with the 19 pro series prop befor I start trying more props. Alot of the weight setup ideas I got from looking at Flipper's 15' with 90 Merc and watching his video while running without chine walking. It looked like the front of his driver's seat was about 5' from the back corner, to give you some idea of how much forward. |
| zotcha |
Very interesting. Len, are you running a water pressure guage, as well? And Lastmango, are you running the LWP and pressure guage? I'm finding that I can't even look down long enough to check my rev's via a digital Yamaha guage face mounted on the dash while WOT, let alone hang on to and read a handheld Garmin. It's almost to the point that a minor change of wind speed or direction, and I'm not going to get the foot down or the throttle backed off in time to save it. I do not intend to move my interior forward, cannot fit battery under console, will not add more holes in the deck to move the rotting fiberglass fuel cell forward, and do not have any plans for the LWP, or water pressure guage... so I guess I'm out of the race. However, today looks PERFECT for running the numbers with new prop. Have a great day. Mike. |
| an86carrera |
Zotcha, Yes, I have a pressure guage 0-30 need to change that to a 0-15. With the pump that far above the water line the pressure at idle does not register. At WOT the pressure gets to about 12 psi. There is a stream at idle but no pressure discernable on the high range guage. Standing up while driving must make it easier to handle, to me it is not unmanageable at all except for the eye tearing. I do however have a pretty heavy duty hydraulic steering system on the boat and brand new binnacle and control cables. One of my fishing buddies has named it 'White Knuckle' but he keeps coming along for the ride. Are you coming to the rndvu to try it out? Len |
| Sal DiMercurio |
Lastmango, putting trim tabs on that boat is only going to slow you down, even if you do get more rpms out of the engine. The reason is, the whole bottom of the boat will be wet instead of allowing air under her. You "MIGHT" get more rpms, but I think it will be false rpms as in slip, not traction. I'm sorry, but I don't buy 48 mph with a 15 pitch prop on a 60 hp engine even if it has a 2.0 gear ratio. I think your gps is not telling you the truth, just like mine says 32 mph at 6000 rpms & a 19-pitch prop. Again, the trim tabs are going to slow you down, not speed you up, because the only increase in rpms is going to be slip, which equates to less speed. Sal |
| lastmango |
Zot, I am not running a lwp,the cavitation plate is only about 2" above the water line while running and the water gauge stays at about 14 psi while running wot. Sal, the lenco's are mainly for keep the bow down while being able to tilt the motor back so less stress will be put on the motor wihile going thru waves/chop which is most of my boating time arround barrier islands. I do agree that they will slow me down the more they are applied.I was hoping that they could be used a little to stablize the lifting of the hull a little while running in clean water while tilting the motor back some.I,ll let you know how it works out. The motor is a 90hp,4850rpm,48mph,gear 2.00,19 pitch pro series. The Gps/mapping is a fix mount garmin,have never had bad reading with on while using it on another pedistal on searay 27' on long trips,I guess anything is possible to malfuntion. |
| Sal DiMercurio |
Last, sorry, I had Zots 15-pitch in my head. I really think your going to loose rpms with the tabs down even the slightest bit, because they force the bow down causing way to much water friction on the bottom. Your engine will work harder trying to push the boat "THROUGH" the water, instead of "OVER" the water. You can trim the engine all you want, but if the tabs are down, the bow wont come up. Thats just the nature of the beast. Sal |
What does "lwp" mean? |
| Sal DiMercurio |
Jim, LWP,.... means..........."low water pickup". Sal |
| an86carrera |
Here are some pics: http://s4.photobucket.com/albums/y104/an86carrera/boats/?action=view& current=2db3bd02.jpg http://s4.photobucket.com/albums/y104/an86carrera/boats/?action=view& current=79f0a2d8.jpg http://s4.photobucket.com/albums/y104/an86carrera/boats/?action=view& current=81288cf1.jpg Yes I know it's dirty Len |
| zotcha |
WOW! This is getting Nuts! I did not get a chance to get out today. And tomorrow isn't looking great either, but maybe. Len, I will not be able to make the rendevous, however am looking for a rentable place for four (guys weekend), May 20th or so, Thurs. thru Mon. morn.. Mostly drinking and some hard core fishing, tarpon, redfish and snook...let me know. So where are we? You're standing, and offering me a chance to run a comparable rig that I can't manage sitting 7 or 8" off the deck?!? My Costa Del Mar Ex-Frames seem to keep me dry at 70 in the Jersey Skiff, and 80+ on my Harley, but Standing? Gotta get down there. lastmango, I did not know that a water pressure guage was necessary without a lwp. And I didn't know that you could run the standard foot that high out of the water and still pick up, with a factory foot. I have NO idea how far out of the water my A/V plate is on plane. My 1999 Johnson 175 sets off an alarm (probably temp.) long before I think I would need a pressure guage. Live and learn. Len, I can't see where the pickup filter is located on your foot other than the half inch line feeding the water pump. Yes it is dirty...and yes, I do want to go for a ride! What's the weekend of the 20th looking like? Coming down with a bay boat, but 15 and trailer are READY! Mike. |
| an86carrera |
Z, No filter it is a problem...a little problem with alarms if take my 300lb neighbor out at low tide after some drinks... shut down and drink more till the alarm goes away then, just run to 24" of water and WOT till it clears. I won't clear at idle. Being able to run in 14" is not cheap. Backing up cost more! Len Let me know where your going. |
