ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance 1971 Outrage 21: Suzuki DF150
Author | Topic: 1971 Outrage 21: Suzuki DF150 |
John W |
posted 02-25-2007 09:15 AM ET (US)
This past week I re-powered my 1971 Outrage 21 with a new Suzuki DF150 four-stroke. Yesterday I spent two hours breaking in the motor. A few first impressions: This motor is as quiet and smooth as I had hoped for. At idle you can hardly tell it is running, and it is as smooth as a new car at any throttle setting. You can feel the additional 100-lbs of weight back there, versus the 370-lb Johnson 150 two-stroke this motor replaced. The boat handles it fine, but at "mushing" speeds the stern sits a little deeper and throws a slightly larger wake. It sits about 2-inches lower in the stern at rest, as I thought it would. But overall the weight is not a problem. The motor is big, much bigger than the two-stroke, but I'm getting used to how that looks on the boat. I'll try to post pics at some point. After two hours of running no faster than 3,000-RPM, on a very windy, cold day on the water, I was able to make one WOT run with the wind. I didn't measure GPS speed yet, but the boat is significantly faster than with the Johnson. That may be the motor, the 2.50:1 gearing, or the propeller, but it was screaming fast. I am running a Suzuki stainless 15-1/2 X 19-inch pitch prop, and with full tanks, two adults and two kids on the boat, the motor hit its 6,000-RPM redline, but did not go over, and the rev limiter did not come into play. I think I may need a bigger pitch propeller, since I may pick up a few RPM once it is broken in. The dealer who installed it took the boat out last Tuesday, idled it for 20 minutes, and did one speed run to determine what prop to use. He was using a 16 X 21.5-inch pitch prop, and the boat hit 5,600 to 5,800-RPM with empty tanks (running off of a small portable tank) and two people on board. He clocked 47.5-MPH with that propeller. We felt that prop might have been too much, given that tanks were empty, but perhaps I should go back to that, or perhaps a 21-inch pitch on a smaller diameter propeller? Any suggestions as to what prop to try? Overall I'm very pleased. This is more motor than the boat needs in my opinion, but I think it will be a great rig. John |
JayR |
posted 02-25-2007 09:27 AM ET (US)
I'm happy to hear you are pleased with it. Now get those pics up!!! |
posted 02-25-2007 09:51 AM ET (US)
I am certain that many readers will be interested to see more data on this boat and motor combination. I do not recall any other reports on the SUZUKI DF150. It looks like a fine motor and it should be a strong competitor with the other popular 150-HP motors available now. It sounds like you have a good propeller on the boat now. I am sure others will be interested in seeing more data, and, if possible, some data on fuel consumption rates. I bet the engine will be a fuel mizer. Most naturally aspirated four-stroke motors of moderate displacement seem to be very fuel efficient, and especially so when compared to an old classic two-stroke. |
John W |
posted 02-25-2007 10:33 AM ET (US)
Jim, If the weather cooperates, I hope to have more data on speeds, etc after next weekend. No fuel data yet, but I'm sure the fuel economy will be fantastic...after 2 hours' running time yesterday, the fuel guage on the 17.5 gallon starboard tank hasn't moved off of a full tank reading! My concern on the prop is as the motor gets broken in, I think I may turn up RPM's above the motor's redline with this prop, since I'm hitting 6000 right out of the box on a very brief trip to WOT. |
filthypit |
posted 02-25-2007 10:58 AM ET (US)
[T]thank you for this post. [S]ince we're shopping for motors right now for our [19]72 Outrage 21, [I] REALLY appreciate your feedback [and] comparison to a two-stroke! [P]lease keep us updated. |
posted 02-25-2007 02:08 PM ET (US)
John--Did you purchase any instruments or gauges with the motor? If you happened to get the new Suzuki NMEA-2000 instruments, please let us know with a posting about them to SMALL BOAT ELECTRICAL. I see recently that Suzuki has become compatible with NMEA-2000 and the LowranceNET wiring. |
John W |
posted 03-03-2007 03:53 PM ET (US)
jimh, I didn't get the expensive guage packages...just a basic Suzuki multi-function tach/alarm, and a volt meter. I got the boat out today for some speed tests. Getting accurate readings on my very old Garmin handheld GPS was difficult, as the readings jumped around some, but here is what I think the speeds looked like, based on averaged runs with & against the wind & current. FYI, there was a 10 kt wind and smooth conditions. Full tanks, average gear, with just me on the boat. Prop is a Suzuki SS 3x15.25x19 pitch. RPM MPH At 6000 rpm, I still had throttle left when the rev limiter tripped. I think I could get at least 100-200 more rpm if not for the rev limiter. Fastest speed with the wind was 45.2 @6000rpm, with throttle left to go. The motor seems to be mounted fairly high, as I get some ventilation in turns, and sometimes when jumping on plane, unless I trim the motor under slightly. Clearly I can use more prop on this rig. I can swap props from the dealer for free, but since the dealer I bought from is out of town, it involves shipping costs & hassle, so I probably won't try lots of props if I can help it. I would appreciate input on what prop to try. Note in my previous comments the results with a 3x16x21.5 prop. My suzuki prop choices that might work are: 3x15x21, 3x16x20, or 4x15x20. Or I could try the 3x16x21.5 again. Thanks, John |
John W |
posted 03-05-2007 07:54 PM ET (US)
Any advice out there as to props? |
Bowman9491 |
posted 03-21-2007 11:36 PM ET (US)
John W, We are getting the same motor on the same hull but it is a revenge, so it ways about 200 more pounds. Any info you get on which prop you go with would be greatly appreciated because we should be getting it back soon. I will also let you know if I find out anything of use to you. Thanks for all of the informative posts |
Tom W Clark |
posted 03-22-2007 11:19 AM ET (US)
John, If you are going to stay with a Suzuki prop, the obvious propeller to try next would be their three blade 15" x 21". I actually think a very good propeller outside the Suzuki line to try would be a Mercury Mirage Plus in the 15-1/4" x 21". While Suzuki's gearing generally means most other brands of propellers are not really applicable to Suzuki outboards, in this case, given the light weight of your boat and the apparent performance and speed it is capable of, I really think the Mirage Plus will be an excellent choice. It will fit using the Flo-Torq hub kit and the Suzuki thrust washer you already have. I would be happy to loan you one to try but unfortunately, I have five 19" Mirage Plus's, but not a single 21". |
John W |
posted 03-22-2007 08:07 PM ET (US)
I exchanged my prop for a Suzuki 4 blade, 4x15x20. I plan to try it this weekend for the first time; I'll post results here next week. |
John W |
posted 03-25-2007 12:26 PM ET (US)
I tried the 4x15x20 pitch prop yesterday. I much preferred this prop to the previous three blade...ventilation problems I was having were eliminated with the 4 blade, and it handled better at all speeds. RPM's were more stable, and I didn't have to adjust throttle or trim much at all when cruising. I much prefer this prop, but I'm worried as to whether it is too much prop for the boat...results as follows: Full fuel (35 gallons), just me in the boat, about 6 hours on the motor, bimini top was down. All values approx, based on averaged runs & an old, slow GPS: RPM MPH Later I averaged 46.1 mph with slightly less fuel, at 5600 (bimini top down). Later in the day, I ran with wife & 2 kids, full tanks, and bimini top up, and could only get 5300 rpm's. This morning I had me & my 7 year old boy, half a tank of fuel, bimini top up, and I hit 5600. Is this too much prop? I'm thinking I may pick up rpm's as the motor gets broken in, but I don't want to overload the engine & shorten its life due to too much prop. Operating range is 5000-6000 @ WOT, with light load, according to the owner's manual. Do I need to be getting in the upper hald of that range? Thanks. |
John W |
posted 03-27-2007 04:07 PM ET (US)
I uploaded some pic's of the boat after the repower. Hopefully these links will work. Here is the boat being repowered: http://s28.photobucket.com/albums/c210/JohnPW/repower/?action=view& current=DSC00091.jpg Here are pic's after repower: http://s28.photobucket.com/albums/c210/JohnPW/repower/?action=view& current=DSC00094.jpg As to the prop: I spoke with the dealer, and the 20" pitch is the smallest Suzuki makes in a 4 blade...so if this is too much prop, I would have to go back to a 3 blade, or have an inch of pitch taken out of this prop ($$$). The dealer said it was OK as long as I was getting 5000-6000 @ WOT, but I'm not convinced that is what I should keep this prop. Any prop help is appreciated. John |
JayR |
posted 03-27-2007 07:58 PM ET (US)
Wow John! She looks GREAT!!!!!!!!! That motor does not look big at all. Beautiful!!!!!!! |
Bowman9491 |
posted 03-27-2007 08:08 PM ET (US)
John W, That boat looks very well maintained. Have you repainted it? Anyway we went and ran our boat (21' revenge w/ 150 suzuki) and got some results and wanted to see how they compared to yours. At 4300 rpm's we ran at 30.5 mph, 4.15 mpg, and 6.25 gph. We are running with a 19 pitch prop and are maxing out at 5600 rpm's and 42 mph. Let me know what you think. |
The Judge |
posted 03-29-2007 10:47 AM ET (US)
I think you need to try another prop with a smaller diameter. The 16" is too much wheel. If my 19 revenge which weighs 100lbs less than your 21 revenge and same weight or lighter than John w's, is fetching 40 with a 115 suzuki at 6100(14x20stiletto) I believe the key to top end speed with 4 strokes is the RPM. Keep trying...it took me 6 props to get my 70 suzuki just right. |
John W |
posted 03-30-2007 07:46 AM ET (US)
Jay, thanks for the compliments! Bowman: yes, my boat has been painted; it was sprayed with 2 part linear polyurethane. I spent over a year restoring the boat, 2004-05. As to your prop, some more info would be helpful. you mentioned a 19" pitch prop, is this the 16" diameter prop, or the 15.25" diameter 19" pitch prop that I tried? Did you have a lot of gear on board? Were tanks full? What is your tank capacity? Do you have a bimini or a hardtop adding to wind resistance? I would expect your revenge to be a few mph slower than my outrage since your boat is heavier, so I don't think 42 mph is out of line...but if you're using the 15.25" diameter prop, I'm surprised you're not getting more rpm's. My motor seems to be turning more rpm's as it gets broken in...at the end of the weekend, WOT runs turned up higher than my first runs with the new motor. |
renegade |
posted 03-30-2007 08:37 AM ET (US)
John; I think the boat looks great! Love what you did with the console and I agree with others - I don't think the engine looks too big or out of line. Great job. Where did you get the leaning post? I'm reworking an early 70's Outrage and thinking about changine the dual seats for a leaning post like yours. |
John W |
posted 03-30-2007 10:07 AM ET (US)
Renegade, Thanks for the kind words on my boat. The seating arangement on mine is the original "Outrage I" seating arrangement that came on the 1970-72 Outrages. Another pic of this seat is shown on Cetacea p36 on this website: http://www.continuouswave.com/whaler/cetacea/cetaceaPage36.html The Outrage I seat consists of an insulated fiberglass cooler seat base, a hinged teak seat mount, and an odd, removeable teak "drop leaf" table/seat arrangementat the back edge of the seat base. On top of all of this is mounted a marine vinyl bench seat as shown in my pic's. The original vinyl was shot on mine, so I had a new seat made using the original as a template. The seat is very comfortable to sit on or as a leaning post. The base was painted with the rest of the boat, and I chose to varnish the teak parts, which origianlly were bare (oiled) teak. Finding a seat like this would usually be pretty much impossible, since so few were made, but as it happens, Larry Goltz aka "lhg" or "blackmax" on this site has had one of sale. He replaced his seat on his 1972 Outrage with a reversible "RPS" syle seat. I sent him an e-mail on your interest in the seat, he may respond here or e-mail you directly if he still has the seat for sale. John |
Bondbuyer |
posted 03-31-2007 06:22 AM ET (US)
Hi John, If you don't remember me - I'm the one you & JayR helped out a lot in my 1971 outrage restoration. I still have the prop from the old Suzuki 150 that I removed. I'm not sure if it would fit your new Suzuki? or how to tell what size, pitch, etc... email me if I can return the favor & help you out? jfarrenjr@yahoo.com |
John W |
posted 04-09-2007 01:32 PM ET (US)
bondbuyer, Thanks for the offer on the prop...but the new 4 stroke Suzuki motors have lower gearing & use larger diameter props than the old Suzuki 2 strokes, so the prop you have wouldn't work for me. I'm thinking that I will keep this prop, and if I need to I'll have an inch of pitch taken out. Best speed was with the 16" 3 blade prop, but I much prefer the handling of this 4 blade propeller. Thanks again, Jhon |
Bowman9491 |
posted 04-10-2007 08:40 PM ET (US)
John W, I was wondering if you have come across any new problems trailering your boat, if you trailer it at all. Ever since we put the 150 suzuki on ours you cant travel over 60 mph with at the trailer going all over the road. Our trailer is slightly adjustable so we are gonna try to move the boat up as far as we can to try to give back some tongue weight, but wanted to know if you came across the same problem. Thanks, Bowman |
John W |
posted 04-10-2007 09:08 PM ET (US)
bowman, There's been no change in how mine trailers with the new motor. I wouldn't think an extra 100lb would make much difference...you probably had marginal tongue weight to begin with. Moving the boat forward on the trailer should help. If you pull your boat with a high-bumper truck, then another way to improve balance & increase tongue weight is to get one of those drop-down trailer hitch recievers, so the trailer ball is lower to the road. Good luck with it, I'm sure you'll get it figured out. John |
JayR |
posted 04-10-2007 10:08 PM ET (US)
Bowman, can you move the axle back? Sometimes that is easier to do. |
John W |
posted 04-23-2007 09:18 PM ET (US)
An update if anyone is interested: This weekend I had my big 4 bow bimini top up, me and two kids, and full tanks, and the motor turned 5550 into a 10 knot wind, and 5600 going with the wind. I'm still using the 4x15x20 pitch prop. Speed was 44.8 MPH with the wind but against a slight current...I felt that was pretty fast given the wind drag of the big bimini. I did not try again with the top down, but the motor seems to have gained RPM's over my early speed runs. |
