Topic: Suzuki DF140 propeller options
itl |
posted 02-25-2007 01:53 PM ET (US)
Hi everybodyThis is my first post to this forum. Have been reading Continuouswave quite a long time and I would say, this is a great forum. I live in Northern Europe, in Finland and I am kind of motorboat enthusiastic and very interested about different outboards. I dont own a Boston Whaler at the moment, but hope that I will in some day. You guys dont believe how much new BWs cost here and used ones are quite rare and hard to find. For example a new Outrage 210 + 175 Optimax pricetag say: $78000. Way too much for me at the moment. My current boat is a Yamarin 59CC, it is a 19' center console, boat weight around 1490lbs and she has a 19 degree V-hull. Boat is rated for 80-150 horsepower. She is my fishingplattform when trolling atlantic salmon on Baltic Sea area. Probably you dont know the boat, it is well known brand in Northern Europe, but I believe it is not available in USA. I used to have a Yamaha F100DETL engine (guess you know this motor as F90, funny that is rated as F100 in Europe), but I choose to trade it to Suzuki DF140 -07 model. Used to own a DF70 and I absolutely love the engine, very very smooth and mileage was excellent. Anyway, want more speed and hope the Zuki can offer what I want. Did have a hard time to decide should I go DF140 or DF150. Finally DF140 win, because it is lighter, more fuel efficient in trolling speeds and it has been on the market already 4 or 5 years (old model, no new engine problems). I know that DF150 is a powerplant compared to DF140, which is known as a weak 140hp, but I think that DF140 will be enough for my relatively light and efficient hull (Crouch's hull factor is around 205-210) and trolling speed mileage is a big factor also. I troll about 70% my boating time. Gas is pretty expensive here, around $6,75/gallon. Now I am looking good propeller for DF140, top speed is most important factor to me. I dont know yet how she will run with DF140, engine is not installed yet and there is too much ice on the sea at the moment. My calculations based on the performance with F100 indicates that she should run with Zuki around 40knots (46mph), also my friend can hit 39knots with almost similar boat and DF115 engine. 2007 model DF140 Gear ratio is 2.59 (used to be 2.38 but Suzuki change it as 2.59 this year, at least with european models). I will also install a CMC 5.5" jackplate/manual lift and going to raise the engine as high as possible. So what propeller you recommend? I am planning to by a good 3 blade stainless steel prop, maybe a Laser II, Michigan wheel Ballistic or something from Power Tech. I guess that correct pitch is around 23-25". Also appriciate if you can recommend a good place to buy a prop, notice that prop needs to be delivered to Europe. Local Mercury stealer want around $1000 from Laser II. Sorry for the long post. Hope you can understand me. English is not my native language.
Tom W Clark
posted 02-25-2007 03:15 PM ET (US)
Ile,Welcome. Your english is better than many of the natives of my country. Because the Suzuki has such a low gear ratio, many of the normally recommended propellers may not be quite as suitable for your boat/motor combination. I am not sure I would recommend a Mercury Laser II for your boat but if I did, you would want the 22" pitch model. If speed is your top consideration, then try a Stiletto Advantage I in the 14" x 22" size. Turbo makes a Turbo I model in a 13-1/4" x 22" that may work well too but its diameter is not much more than a small tube Mercury Laser II and I do not think it will offer enough blade area for a 140 HP motor on a 1500 pound boat. It would be best to wait until you have the boat and have broken in the motor and gotten some test data with a borrowed propeller before making any expensive decisions about what may be best for your needs. If you do decide you want to try a Stiletto or Turbo propeller, I can get you one for a very reasonable price. Precision Propeller (the manufacturer of the Stiletto and Turbo brands) does not like to ship out of the country, but they can send it to me and I can mail it to you. The shipping will not be inexpensive. I sold a couple props to some guys in England last year and it cost over $100 to send them there. It took a while too. |
itl
posted 02-26-2007 03:15 AM ET (US)
Thanks TomI really appriciate if you can send a propeller to me. In my point of view, $100 wreight cost or a bit more is quite reasonable. As funny as it might sound, propellers are so much cheaper in USA than Europe that it actually makes sense to order one from there. Yep, it is better to broke the engine first and run baseline with the orginal propeller. My performance estimations are only educational guesses. Tom, I will contact you via email later in this spring. |
The Judge
posted 02-27-2007 12:48 AM ET (US)
I have a 1600lb Revenge with a DF115 and run a 14x20 stilletto from Tom Clark and run 40mph @ 6k on a good day. My bud runs twins with Tom's 14x22 and he runs 39-40knots @ 6k. The 140 will run a little higher rpms so I would say the 22" would be great. |
itl
posted 06-18-2007 06:26 AM ET (US)
Update to this topic.Yesterday my engine reach the end of 10 hour break-in period and I was able to push Suzi a bit. Propeller was 21" aluminium standard propeller, which came with the engine. CMC ML65 lift installed also, but engine was not lifted very high (about half an inch above the keel), because I wanted to make sure that engine does not loose water pressure during break-in. Result of my short test run: Holeshot: great almost WOT rpm: engine revs very easily 6000rpm. Didn't want to push the engine too hard yet. I think that it probably overrev in WOT. Top speed: 37,5kn@6000rpm, that is about 43mph, engine was trimmed about to zero degree. Quite impressed about the performance, but I definetily need propeller with more pitch. This engine really kick ass compared to F100 Yammie, but off course it was expected result. After the 20hour service/maintenance is done, I will try what happens in 100% Full Throttle. |
Tohsgib
posted 06-18-2007 10:47 AM ET (US)
Keep me posted...my bud has a used Stilletto 22" prop that he is selling. Read my post above when I used "The Judge" as my name. |
itl
posted 08-21-2007 03:34 PM ET (US)
Update to topic. Now I have run about 60 hours on the engine and I think it is well broke in. With std aluminum 14x21" Suzuki prop the performance is as following when engine is trimmed as high as possible without loosing prop grip: Boat will run 39.2knots@6350rpm WOT on a good day and lightly loaded. It burn about 43liter/hour in that speed and best mileage is 18,3kn@3500rpm when it burn 11.6liter/hour. In other words. WOT is 45.4mph@6300rpm. On that speed engine burn 10gph and that makes 4.5mpg. Best mileage is 21.2mph@3500rpm when gas consumption is 2.9gph and that makes 7.3mpg, that is not a bad figure at all I think. Performance is not bad, but one big disappointment is prop's bow lifting capability, want more bow lift near top speed. Now, what do you think about propellers. If I go to Stiletto, should I choose 20 or 22 pitch prop? I like to get bit more speed but don't want to loose good hole shot. I guess the 20" Stiletto is quite close to std prop and maybe a bit too short, but the 22" might be a bit too heavy for me, or is it? With good sst prop I believe I can lift the engine at least half an inch more and gain a bit WOT rpm. Engine's recommended WOT speed is 5600-6200rpm. |
Tohsgib
posted 08-22-2007 12:19 PM ET (US)
I am probably going to buy one of his 22" stilettos for mine. The 22 runs like a 23 alum but about 100rpm higher. I would say the 22" would be right for you and a SS will give you more bow lift because it won't flex. I also have a 20" Stiletto as well. They are both like new. $199 ea plus shipping if interested. |
itl
posted 10-27-2007 09:04 AM ET (US)
Well, now the Stiletto Advantage 22" is installed to my engine and I just made very short test run with it. Here are my quick observations about Stiletto:It revs like 14 X 21" Suzuki standard aluminum pro. Top speed with dirty hull was about the same as with std prop: 39kn@6150-6200. So I didn't reach my goal (yet), but I am sure that I will hit 40knot when boat and engine are fine tuned for stiletto prop. In general, I am very happy with the Stiletto propeller. Acceleration and hole shot was better compared the std prop. I was also very pleased because engine doesn't make big "klunk" noise when engaging gear. That is quite odd, Stiletto weight about 11.7lbs (5.25kg) and std aluminum prop weight around (2.65kg)5.9lbs. So the Stiletto is twice as heavy as std aluminum prop is. Both of my previous engines (Mercury and Yamaha) made very noticeable "klunk" sound with heavy SST propellers. It is mystery to me why Suzuki does not make that sound when engaging gear? Well, that is not a bad feature at all and I am very happy without the "klunk" sound. What comes to Stiletto trimming and slipping characteristics, it can be trimmed very high, was not able to make it slip, hit the high end of my trim meter and still the prop was performing really good. Std prop start to slip when trim meter was around half of the scale. Next thing is to raise the engine and figure out optimum high of it. I guess I can lift the engine with Stiletto prop at least 3/4". However, that and other tweaks are going to happen during next spring. Winter is coming here and soon I need to hibernate my boat:( And finally I want to thank Tom and Brian. Your help with my propeller selection/purchasing process is really appreciated. |
Tohsgib
posted 10-29-2007 10:21 AM ET (US)
The reason why your lower unit does not clunk is because it was designed properly. |
