posted 05-18-2007 12:34 PM ET (US)
Thanks for the interesting facts on the outboard. It really is a nice motor-not too loud! I've never seen another. And thanks for the tip on the ratio for the calculator... once I predicted 168mph I figured I needed to use the reciprocal ; )If anyone cares to continue this... in regards to estimating a slip factor I am interested in what you would expect to see. I am running a 13" pitch OEM aluminum prop with some cupping on a 1968 16'7" hull with all the railing, and an aftermarket stand-up center "consul" (sorry-could help but inject a little humor here), 2x12 gallon Tempo gas tanks in the stern, and a 15hp kicker on the transom. Add a small drag for transom mounted bait pump (I angled its mounting back, but I should probably angle it back a little more).
Using a range of 13.75"-14" for pitch, and a max speed of 29.8mph(gps), I get a range of slip from 7.7%-9.3% (ref: 6000rpm, 2.42 ratio)
Any similar data (for a slightly underpowered 16') would be interesting. Thanks again-G
Slow boat, I know, but she performs well this way for "offshore" with live bait tank and heavy crew. I have a 15" too that couldn't handle the heavy loading. One of these days I'll put that one back on and go for a solo speed run for more data!
