posted 07-27-2007 09:08 PM ET (US)
Henry,This is interesting. I just mounted a prop on my own Mercury 90 using a Flo-Torq III hub kit that I have. My results are the same as yours. Lots of wobble and slop.
At first I tried to mount my 20" Laser II but the aft adapter would NOT fit fully into the hub of the prop. The hole in the prop was too small. That surprised me very much. This was the first of dozens of Mercury props that I have ever seen this problem on.
I then fitted a 20" QuickSilver Lightspeed (Quicksilver branded version of the Laser II) and it fit fine, but for the slop.
I am now rather confused about the Flo-Torq III and IV kits and I will explain why:
I believe the intent of the Flo-Torq III and IV designers is the have the aft adapter actually come into contact with the thrust washer and allow the prop nut to form a compression fit between the aft adapter and the thrust washer bypassing the propeller casting itself thus allowing it to float free radially so that the spring action of the hub kit can work.
Unfortunately, this means the tightness of fit of the propeller is dependent upon both the fit of the drive sleeve within the propeller casting (it is usually very tight) and the fit between the aft adapter and the drive sleeve (usually some slop there.)
With a Flo-Torq II kit, the aft adapter is about half the length of the propeller hub. It acts as a washer on the back of the propeller. The prop nut compresses the prop forward onto the thrust washer. Thus a compressed and solid sandwich is formed between the thrust washer, propeller, aft adapter and propeller nut. This is also why 60 ft./lbs. is specified for these hub kits; you want the whole assembly on there good and solid so as to avoid any slop and imbalance.
I now realize that if you did this with the Flo-Torq III or IV, the propeller would be fixed radially vis-a-vis the propeller shaft via the aft adapter. But what you want to have happen if for half of the drive sleeve to fixed vis-a-vis the prop and the other half of the drive sleeve fixed vis-a-vis the propeller shaft. The radial connection is the springing titanium rods within the two part drive sleeve.
Hmmm. This leads me to be a bit chagrined and I will have to wait until later to tell you as I need to go now...
