posted 07-28-2007 07:07 PM ET (US)
Hello all. I have a 2000, 200hp Evinrude Ficht with low hours. The engine has new plugs, new fuel filters (x2), new batteries, and I just did the lower unit fluid. Also, full fuel and full oil. In addition, I recently did a compression test as part of the survey prior to purchasing the boat earlier this month.
My first time out on the boat resulted in a check engine light and the boat entering the S.L.O.W mode after about 2 hour of running at a wide range of speeds between idle and 3500 RPM. After about 10 seconds in SLOW, the light went off and the boat functioned as normal only to again 20 minutes later end up at this condition. I stopped and let the engine cool for about a hour and left for home -15 minutes after this cool down period and again the check engine light / SLOW is on and continues to frequently come on and then off again even at RPMs as low as 1500, resulting in having to idle all the way home. Note that the Check Engine light finally did come on and stay on which allowed me to get a code, this code being code 25, EMM Over temperature. Looking at past discussions, I assumed that I had a blockage in the EMM cooling line. However, by disconnecting the water output on the EMM, I can easily blow air through. In addition, by disconnecting at the water evaporator the water hose between the EMM and the water evaporator, I can easily blow air through the EMM and out this hose, however cannot blow air through the EMM with the water evaporator connected. I also using a long rod was able to poke down through the EMM water pipe and there appear to be no obstructions.
The water coming out back of the engine comes out very fast and in a continuous stream. The temperature of this water when the check engine comes warm to the touch, but not real hot.
With my little engine experience I’m stuck at this point. Should I be able to blow air through the emm and through the water evaporator with ease (as right now I cannot.) Perhaps the water evaporator is plugged up?
If the water is coming out of the back of the engine, would this indicate that I have good water flow through the EMM, or is irrelevant?
Could this be a sensor failure? I would not think so just based on the fact that the longer on the water, the more frequent the check engine comes on.
Overall this issue has kept me stuck at the dock and the summer is passing by quickly - any help would be greatly appreciated. Thanks.
