ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance 1999 OUTRAGE 20 with Yamaha 225-HP
Author | Topic: 1999 OUTRAGE 20 with Yamaha 225-HP |
onlyawhaler |
posted 08-30-2007 03:23 PM ET (US)
I have recently purchased a 1999 20 Outrage. I am pretty thrilled with it. It came with a nice low hour Yamaha 225 OS66 which is running a Mercury Mirage Plus 19 pitch prop Down at low (sea level) elevations the previous owner was experiencing top end speeds in the mid 50s with about 5300 rpm Up here where I boat at about 6000ft or higher I am seeing a top speed of 46 mph at 4900 rpms I am looking to drop a pitch to a 17. The current Mirage Plus prop has the model # of 48-13700-A45 in a 19 pitch. I think this is a 15 1/4 hub size. Any help or recommendations on props, pitch and hub size would really be appreciated that would work well with this Outrage and motor combination Thanks |
Sal DiMercurio |
posted 08-30-2007 08:37 PM ET (US)
First of all, the previous owner couldn't get mid 50s at 5300 rpms with a 19 pitch prop. In order for him to get 53 mph, [ not mid 50s ] he would have to put a 21 pitch prop on the engine. A 21 pitch prop is the only prop you can look at the tach & know your going real close to whatthe tach reads, in mph. Example, 4500 rpms would produce 45 mph with a 21 pitch prop if the rig is set up right. The true speed of the boat with a 19 pitch prop twisting at 5300 rpms, would be closer to 49 - 50 mph. Ok, now for the change in pitch for 6,000 ft of altitude. I believe that engine is rated for 5500 rpms maximum, so if your now getting 4800 rpms at wot at 6000 ft altitude with a 19 p prop, a 17p prop would still only allow you 5200 rpms. I would go with a 15p prop because that would allow the engine to al leaast reach or be very close to it's maximum rpm rating. At 6,000 ft, performance go's out the window real quick with a carbed engine, & even injected enguines struggle in that thin air. I would test a 15p before buying anything. If that engine is a carburated engine, you really should change the carb reeds to a leaner burn, just don't come back down to sea level & run the leaner reeds, because you could lean the engine out & fry it. Sal |
onlyawhaler |
posted 08-30-2007 09:42 PM ET (US)
Thanks Sal We have a 4 Winns dealers here that has test props one can rent for 15 dollars a day and apply that cost to the purchase price of a new prop. I will rent a 15 and a 17 and go out for a day with a handheld GPS and get all the stats down Onlyawhaler |
Tom W Clark |
posted 08-31-2007 09:53 AM ET (US)
Sterling, Sal is right about the sea level top speed. With a 19" MIRAGE plus that boat might be able to hit 50 MPH, and that is it. 48-13700 A45 is a 19" MIRAGE plus without vent holes. 15-1/4" is the overall diameter, not the hub size. This prop is an excellent propeller but you are right, at 6000 feet, you will need a lower pitch prop. The Yamaha OX66 are EFI and should do well at altitude. The EFI should be able to adjust the fuel mix to help compensate but there is no replacing the missing oxygen in the thinner air. Figure a HP reduction of about 4-5 percent for every 1000 feet of elevation gain and your 225 will effectively perform like a 175 at that height. You need to prop accordingly. Now having said that, I note that your data suggests the motor only lost 400 RPM at WOT going form sea level to 6000 feet. This is approximately the RPM change you will see with a two inch change in pitch with a MIRAGE plus so trying a 15-1/2" x 17" MIRAGE plus is logically the first prop to test. I would also recommend trying a 14" x 17" Mercury Offshore/VenSura and maybe a 14-5/8" x 15" Mercury Revolution 4. In aftermarket propellers, the Stiletto Advantage II in the 14-1/4" x 15" size is the obvious choice. |
onlyawhaler |
posted 08-31-2007 11:19 PM ET (US)
Thanks Tom You mention a few props with the hub size in the 14 inch range. When one goes down in hub size from say, a 15-15 1/2 I am renting a Mercury Mirage 15 and 17 pitch next week and I will post the results. They will be meaningless to most because of the altitude situation, but it will be interesting to see what can be done to improve the situation. Thanks for your advice I am taking pictures and posting them on my photobucket account. I am really liking this boat. Very exciting Thanks |
Tom W Clark |
posted 09-01-2007 10:18 AM ET (US)
Sterling, Whaler performance literature I have indicates the Outrage 20 with a Johnson 225 will do just a tad over 50 MPH at 5500 RPM with a 14-1/4" x 21" OMC SST. I believe the OMC and the Yamaha 225s use the same gear ratio or nearly so. Do not concern yourself with the propeller diameter. The diameter itself is not entirely indicative of how a propeller will perform, rather the diameter is just one part of each unique propeller model that is designed to achieve certain combinations of attributes. If propeller design were as simple as diameter and pitch, they would all look the same. The propellers I have recommended are all props that I have personally experimented with on Boston Whalers and know to be excellent performers. All boat/motor combinations are different, which is why I always encourage folks to experiment with as many props as they can get their hands on. It is the only way to really know how a prop will perform on your boat. All manufacturers produce literature that tries to explain how each of the propellers they make will perform and what kind of boat it is best suited for. These descriptions should only be used as a general starting point in the propeller selecion process. All too often I read here (and elsewhere) comments for people offering propeller advice that is nothing more than regurgitation of manufacturer's descriptions. Run the props yourself. Decide for yourself. |
Tom W Clark |
posted 09-01-2007 10:38 AM ET (US)
Looking at the Whaler performance literature again for the Outrage 20, I see that a Mercury 175 on this boat was able to push it to 46 MPH with a 15-1/2" x 17" MIRAGEplus. It will be interesting to hear how your boat performs with that same propeller and if my prediction of an effective 175 HP at your altitude is accurate. |
Wasatch Whaler |
posted 09-02-2007 10:19 AM ET (US)
Sterling, Congratulations on your new 'Whaler!!! Jay |
onlyawhaler |
posted 09-04-2007 12:35 AM ET (US)
Thanks Jay Tough to be without a Whaler for close to a year. Take care of that wonderful 18 OR and and I am glad you got her. It is a choice, rare boat. This 20 is not classic, but it will fill the gap and it will be alot of fun. Keep in touch and enjoy our fall boating Sterling |
Wiscbw |
posted 09-04-2007 08:24 AM ET (US)
Congratulations, I have a 96 Outrage which I think is the same boat with a 225EFI Yamaha. Fun but heavy boat, mine does 52 mph at 5500 rpm, half tank of fuel, 2 people with a Rapture 19” pitch prop. This may not be your problem, but last year my engine lost a few hundred rpm and some speed until I cleaned the O2 sensor and VST filter. Not sure what caused the problem, but after that, I stopped buying any fuel with ethanol. |
phatwhaler |
posted 09-04-2007 11:51 AM ET (US)
FWIW, I have the same boat powered by a 2.5L 150 EFI Merc. With a full fuel tank, T-top and 2 POB she tops out at 43/44mph. This is a result of turning a 17P Powertech 3 blade, 5500 RPMS on a hot summer day. http://i62.photobucket.com/albums/h109/whays/WhalerBlueWater.jpg pw out. |
onlyawhaler |
posted 09-22-2007 09:16 PM ET (US)
Well, Tom you were almost spot on on your estimate. I have had this 20 out 7 times in the last two weeks, testing three different props as they were available and taking the scout troop and a few dads fishing. Here is a link to some pictures. I am in the last few shots with the white hat http://s2.photobucket.com/albums/y40/onlyawhaler/1999%20Boston%20Whaler%20Outrage%2020/ Here is what I found out with peformance at altitude. Prop Testing for a 1999 Outrage 20
onlyawhaler |
onlyawhaler |
posted 09-22-2007 09:47 PM ET (US)
2500 20/on plane 19/not on plane 17/ Not on plane A few suprises for me on these tests. The 15 pitch held the boat on plane in the 20 mph range where the 17 and 19 would not The hole shot on the 15 was incredible, but a big loss of 10 mph or more on the top. It gives a renewed wish for an affordable, raliable two pitch adjustable prop. I tested the 15, then 19 and then last the 17. I was suprised that the boat would go 47 mph at 4800 rpms max on the 19 and was hoping the 17 would hit 50 even here at altitude when it would rev into the sweet spot of 5300 rpms. It did not. I got the desired rev by dropping a pitch, a good hole shot of 3 1/2 seconds, but dropped a few miles per hour over the 19 even when the 17 could rev high enough. It looks like the 17 is the best all around pitch in the mirage up here at this altitude and higher which I will do. Good hole shot with reasonable top end. Over all observations about the 20 Outrage of the 1996-1999 era now that I have one Great storage, love the fish boxs in the floor, quarter seats storage, bow and anchor locker storage. The center console is huge with doors on both sides. The lockable electronics boxs is nice too. It handles rough water and plans well, very well. It does have a tendency to porpoise a bit and a touch of the trim tabs ends it. Finish work is nice and it feels solid. I really like it. Comparison to my former 18 classic. Alot different. The 18 classic is imcomparable to anything. It planes at a lower speed and gets up on plane quick. It is more nimble and turns quicker. It is almost a full 1000 lbs lighter. That is a lot. Easier to tow and store. The classic wood and cast pieces are beautiful. In rough water- 20 outrage Onlyawhaler
posted 09-23-2007 09:38 AM ET (US)
Thanks for the nice report on the performance of your 1999 OUTRAGE 20 and for the excellent photo album showing the boat. I also enjoyed your comments in the comparison to the classic OUTRAGE 18. |
Swellmonster |
posted 09-26-2007 10:27 PM ET (US)
Great info. I also like your ss cup holder in your console. Where did you get them? Where is your fire extinguisher? |
Swellmonster |
posted 09-26-2007 10:38 PM ET (US)
My merc 225 efi ran great w/17 mirage plus. The 17 rev 4 I have is a totally different animal, simply awesome, my favorite. I also have the 15 rev 4, too small for me, it will limit out in less than 10 seconds, but it is 10 seconds of nitrous like excitement. "Like a cheatah on crack" Not a bad prop when you have several people aboard, you get on plane real quick w/6-8 people no problem......but I lost 5-7 mph off top end. |
skeepyjack |
posted 09-27-2007 04:45 PM ET (US)
Congratulation on the new boat Sterling, very nice boat. I have similar boat as your (Crosstackle)but rigged with 175hp oceanrunner, 17P four blades at WOT she flys to 42mph (GPS)with trimtab, on the light wind and flat calm ocean day (Santa Cruz,CA) mine lost a few top-end miles (due to 4 blades prop?) but great hole shot. IMHO this one is almost the best 19~20 feet BW for the near/off shore fishing( I've owned the classic Montaulk, 18 outrage). Only one I can find in a negative side is the water alway get into the under deck fish-holds (no matter modify I've tried) Swellmonster, Sharped eyes with SS cupholders. I replaced mine with the SS as well, and found those cups cheap on Craigslist thought those poker table access stores, there is two sizes, the larger one fits. |
Swellmonster |
posted 09-27-2007 11:30 PM ET (US)
Thanks for the input on the ss cup holders. Do they have a drain? |
onlyawhaler |
posted 10-01-2007 03:13 PM ET (US)
The stainlsss cupholders came on this outrage from the previous owner who is a CW member in Pa. Great guy and he kept this boat in top condition. I will email him to see where he got these. They are the best cup holders I have ever had on a boat. They are a lightly brushed stainless with a two cup fit. They will hold either a beverage can or a larger cup from a convience store due to the inside shape of the holder. They do not drain, but could be easily drilled. The only "if" I have with this boat is the scuppers. I am used to the 18 outrage classic with the bilge recessed area that you could wash the decks, slightly tilt the boat to starboard and drain the deck water instantly into that area and bilge it overboard cleanly. Washing the decks on the 20 doesn't drain through the scuppers fast enough and it overfills and spills into the fish boxs which I then pump overboard via the fishbox pumpout option. That works fine that way, but the slow scupper drain system eliminates the fish boxs for any dry storage. The 20 Outrage has a special set of plugs available only through Whaler that fit and plug the scuppers from the inside. It makes for a dry deck and impossible for scupper leakage through the outside to the inside with a heavy load of people on one side tipping the boat to the point where the scupper is under water, but to clean or wash down the decks out on the water, the plugs have to come out. Other than that, I really love the boat. Sterling |
phatwhaler |
posted 10-01-2007 11:12 PM ET (US)
The plugs that work great for keeping water off the deck are made by T-H Marine. The 1.5" plug with ring works great. It's actually what came OEM for my bait well. http://www.thmarine.com/product.cfm?PRID=66 pw out. |
