Topic: Fuel Filter Change Interval
richvi |
posted 10-09-2007 01:30 PM ET (US)
I drained the gasoline from the platic bowl [of a RACOR fuel filter], and I found only 100-percent clear gasoline. Do you folks always change the fuel filter every year?
fourdfish
posted 10-09-2007 06:01 PM ET (US)
If you have not found water I don't think it is a problem. I personnely change mine every other year. These filters have a big capacity. |
posted 10-09-2007 11:41 PM ET (US)
I do not change the fuel filter on an annual basis. |
sosmerc
posted 10-10-2007 11:12 PM ET (US)
Racor does make a vacuum guage that can be attached to your filter. (this is a measurement of restriction, if you see an increase in vacuum that is a good indicator that your filter is getting clogged and should be replaced). As long as you do not see an increase in vacuum, then your filter is performing fine and your fuel system is in good shape. But if you do not monitor restriction, then I would recommend changing the element prior to the beginning of each season to be on the safe side. |
BQUICK
posted 10-11-2007 11:59 AM ET (US)
If it is a 10 micron I would change twice a season or more, depending on how much use. The ethanol fuel will loosen up deposits in your fuel tank. If the filter cemes restricted a lean condition can result. I had that happen causing cylinder head overheat alarm. |
