posted 10-31-2007 03:02 PM ET (US)
hoppinJohn - you mention the engine was rebuilt - was the rebuilder knowlegable and experienced in rebuilding two cycle engines? Were any parts replaced - if so, was everything balanced?Who is the individual you refer to in your "... I have the utmost trust in the gentleman's business and all my dealings with him, but when I cannot focus on my mapping gps due to the vibration, it has me wondering. ..."? Is he the rebuilder?
Now, regarding the vibration. All engines will vibrate to some extent. That is the reason for balancing means (weights or drilling holes) are used to balance the entire engine assembly. Your engine was other than 60 degrees (Johnson/Evinrude only made their 115 and 90 in a 60 degree block - and those two block were virtually identical) - but that does not make all that much difference.
With your entire boat vibrating, what is happening is that the source of the vibration (obviously the engine/prop) - at idle or slow wpeeds - is producing a driving frequency that is at or close to one of the "natural" frequencies of the boat and components. As the engine speed increases, the vibration ceases - because the driving frequency increases to that above the natural frequency of the boat and components.
Jimh's mentioning an unbalanced prop or a misfiring cylinder(s) are possibilities - but you can learn which by running a simple test - with the engine in neutral, increase the speed of the engine to 1000 - 2000 rpm. If the vibration is not there, the problem is the prop. If the vibration is still there - the problem is in the engine.
A misfiring engine is typically caused by one or more bad spark-plug wires. A seemingly small "break" may still conduct electricity - but will "throw" an engine out of balance, resulting in significant vibration. At higher speeds, the ignition voltage is higher, eliminating the problem. Now - I am not sure of your ignition system type.
The engine mounts are, in part, intended to isolate the engine vibration. If those mounts are bad - there is little or no isolation, allowing any vibration from the engine to be "more directly" transmitted to the boat.
Regarding your gps - isolate your mount by putting as soft as possible rubber between your boat surface (top of console et.al.) and the gps mount. The "soft" rubber will than prevent higher frequency vibration from being transmitted through the mount - and your gps will be "rock steady". --------- Jerry/Idaho
