ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance 1995 Mercury 100 hp, good motor?
Author | Topic: 1995 Mercury 100 hp, good motor? |
JMARTIN |
posted 12-31-2007 07:10 PM ET (US)
Found a 1995 Montauk 17 with a Mercury 100. I am assuming that the motor is a 1995 also. The problem is, I know nothing good or bad about this motor. The boat looks nice. John |
JMARTIN |
posted 12-31-2007 10:38 PM ET (US)
OK, it is a 1995 2+2 Mercury 100 hp on a 1995 Montauk. Everything is original right out of the dealer. It does have a "removable stern seat" which I have never heard of. Sooo, is it a desirable motor if maintained well? John |
JMARTIN |
posted 01-01-2008 02:48 PM ET (US)
Some more information on the motor I know nothing about. Boat and motor bought new at Hawleys in Bellingham in 1995. The motor has about 100 hours on it, seems low. Good, bad, just OK, rare, or indifferent, anybody got a comment on this motor? If the boat checks out, we are going to have a mechanic look at it. Other than a compression check, is there something to look for? John |
Buckda |
posted 01-01-2008 05:23 PM ET (US)
John - If it's maintained properly, it should be fine. There are a few mentions of this motor on the site that I can recall. The associated memory I have of those mentions is "a rough transition" at a certain RPM when going from 2 cylinder operation to 4 cylinder operation. Take it for a test drive to make sure you can deal with this rough transition. |
Buckda |
posted 01-01-2008 05:29 PM ET (US)
John – I take that back. Here’s what I found doing a search: This stern warning came from two astute MERCURY FANS!
quote: If Mercury supporters are this wary of the engine design, I'd be especially wary and certainly would test run the engine before making any promises to the seller. |
Tohsgib |
posted 01-02-2008 11:14 AM ET (US)
13 years and only 10 hours...boat better be mint. I would not stray from the deal if it is a good deal. With a 13 year old engine it may be time for a repower soon anyway...or it may last another 13 years. |
JMARTIN |
posted 01-02-2008 11:46 AM ET (US)
Jeepers, 2+4, I searched 2+2. Oh well, deal is done, my buddy bought it. He can back out if the mechanic has bad news. http://seattle.craigslist.org/kit/boa/524441391.html He said the boat was in great shape. They took it out for a run. It does stumble during the transistion, but you just power through and back off. Boat was kept under a tarp and not used much. I think he will be pleased. It gets to come up to my barn so we can play with it for electronics, fuel tank set up and other stuff. What fun, it has not and will not cost me a dime but I get to use it. He will be listing his 13 for sale soon. I will post it when I get the OK. Thanks for the replies, John |
DeeVee |
posted 01-02-2008 09:44 PM ET (US)
John, My brother in law had a 115 2+2 that he repowered his 1986 Montauk with. He liked it once he got use to the 2+2 idioscyncrasy. Doug |
L H G |
posted 01-02-2008 11:20 PM ET (US)
The 100 is a good 2 + 2 engine, but Mercury finally discontinued it because as a detuned 115/125, it had no more power than the 3 cylinder 90, which is also about a 100 HP. Merc's prop charts clearly showed this overlap. |
JMARTIN |
posted 01-03-2008 06:18 PM ET (US)
Thanks for the information. The motor checked out fine and my buddy has taken possession. This will be my first Mercury experience. I expect it to go very fast and I will get bugs in my teeth from grinning too much. John |
Tom W Clark |
posted 01-03-2008 06:25 PM ET (US)
Taylor has a Mercury 100 on his Montauk he keeps on Whidbey Island. It is a perfectly fine motor for a Montauk, cruising or trolling. |
