Topic: Conquest 280, Yamaha 250-HP Four-cycle
AflredoS |
posted 01-16-2008 11:57 PM ET (US)
Recently I changed to 250-HP four-cycle engines from Yamaha from my old Mercury 225-HP OptiMax motors. It has been a disaster. Initially the [CONQUEST 280] didn´t plane unless it was half empty and no load. They raised the engines and installed a fin in each motor. This helped and the boat planes, but when fully loaded it takes forever. Last time I went to the sea I was carrying 10 diving tanks and 5 people on board, and we have to move to the bow, even myself, who was driving. Also when in open ocean it is more dificult to plane. With rough seas it is difficult to mantain RPM. As [the boat] climbs the wave the RPM goes down and the boat almost looses the planing state. In general the boat has turned out to be unreliable and dificult to handle. Can someone advice me where to start checking? I live in Guatemala City and the boat is in Rio Dulce, there is no good mechanics and tech support people in the country for this matter. I also bought the boat second hand in Florida and navigated to Guatemala, the Boston Whaler dealer doesn´t want to get involved. I need to address the problem myself. Sorry for my English. Please advice
Tom W Clark
posted 01-17-2008 12:46 AM ET (US)
Alfredo,It sounds as though your boat is not propped correctly. Please give us the following information: - Your best top speed with the F250s - The engine speed at Wide Open Throttle (WOT RPMs) at this speed - Make, model, part number, diameter and pitch of the propellers on the F250s |
Brian7son
posted 01-17-2008 03:31 PM ET (US)
Alfredo,What year is the boat? Brian |
AflredoS
posted 01-17-2008 05:41 PM ET (US)
Thank you guys for your interest. The Boat is a conquest 280 model 2000. equipped with the generator option The boat max´s at 34-36 knots at 6000 rpm´s when properly trimmed The propellers are the Yamaha standard coded 19M and I believe they are 14 1/2" x 17". When they installed the engine they had to install a metal "shim" or wedge to change the angle of the engine. they also raised the engine height and now there is a space of about 2 inches between the clamp of the motor and the firewall? this two things made it better but now it cavitates a little in rough seas. What do you think |
Peter
posted 01-17-2008 05:52 PM ET (US)
19M means its a 19 inch pitch, M series hub Yamaha propeller. The M series hub is used on the V6 gearcases. I believe your hull does not have a keel that runs to the transom. The full hull stops about 2 to 3 feet short of the transom. As such, the boat will be sensitive to where the weight is loaded because the weight of the motors is not supported well. Your boat may benefit from a stern lifting propeller such as the Mercury Revolution 4. I suggest that you give a pair of 14 5/8 x 17 Rev 4 propellers a try and see how it goes. |
AflredoS
posted 01-17-2008 10:29 PM ET (US)
Thank you for the feedback, Sorry about the prop its a 14 1/2 x 19. I read in another forum the same solution. This guy also mentioned the ventilation system this propellers has. The system is called PVS (performance venting system) and has plasic plugs in the hub of the propeller. They sell the plugs solid, with small and large holes. He used the large hole plug and said that the performance increased a lot. By the way, the engines where 225 and the props where Revolution 4 with 17" pitch. Do you feel the plugs are going to make the diference?
Tom W Clark
posted 01-17-2008 10:58 PM ET (US)
Alfredo,Based on what you are reporting I am assuming you have Yamaha 14-1/2" x 19" Painted Stainless Steel propellers, part numbers 61A-45974-00-98 & 61B-45974-00-98. These propellers do not use any vent holes. The PVS system is a vent hole system found on Mercury propellers. At any rate, you do not want to have vented propellers at all. If you try any Mercury propellers with the PVS vent holes, be sure to use solid plugs. I agree with Peter's advice, try a pair of Mercury Revolution 4 propellers in the 14-5/8" x 17" size (with solid vent plugs.) A large boat like yours is going to need as much blade area as it can get. The 14-1/2" x 19" Yamaha Painted Stainless Steel propellers are good props in their own right, but they are not going to be enough for your boat. Other propellers to try would be the Yamaha Saltwater Series II 15-1/4" x 19" or the Mercury MIRAGEplus 15-1/4" x 19" or maybe the 15-1/2" x 17" size. The Yamaha Saltwater Series II is very good imitations of the MIRAGEplus. |
Tom W Clark
posted 01-17-2008 11:01 PM ET (US)
The Mercury Revolution 4 will tolerate a relatively high outboard mounting height because it grips so well. It sounds as your motors are set rather high now. If you use another type of prop you may benefit from lowering the motors a set of bolt holes to improve the grip of the propellers.What you are experiencing in the ocean is most likely ventilation, not cavitation. High mounting heights will exacerbate ventilation problems and lead to a loss of grip. |
posted 01-18-2008 01:13 AM ET (US)
I am somewhat surprised that with 500-HP of Yamaha four-cycle motors on the transom the performance is so marginal. I hope you can correct it with different propellers. Even though the four-cycle motors weigh more than the two-cycle OptiMax motors they replaced, they are rated at more horsepower (50-HP more). You'd think that would make up for the extra weight they bring. |
Peter
posted 01-18-2008 07:25 AM ET (US)
Although rated at 250 HP at WOT, I doubt that the F250s have as generous a mid-band powercurve as the Optimax 225. But I don't think power is the problem. I think Alfredo's problem is getting enough traction to launch the boat onto plane. I had a similar problem with my 27 Whaler WD with all the three blade propellers I tried. The 4-blade propellers cured that. I currently run the 14 5/8 x 17 Rev 4 propellers with the vents plugged. If Alfredo switches to the 4 blade propellers, he may also notice that the venting while underway, sometimes called "blowout", typically caused when the boat rolls about the keel from port to starboard or vice versa causing one of the engines to be lifted high in the water, is greatly reduced if not eliminated. |
Brian7son
posted 01-18-2008 09:31 AM ET (US)
Alfredo,Tom Clark knows far more than I do regarding these things. However, I can tell you that I am "in the same boat" as you are. I have a 1998 285 Conquest. It has 2004 Merc. 225 4-strokes. The prior owner had installed them before I bought the boat. When he took me on a sea trial, the boat had less than 1/2 tank of gas, so it planed fine. After owning the boat for a while and loading it up for long trips: 298 Gallons of gas, full water holding tank, full live well, loaded with gear and passengers, etc. I began to experience the planing problems that you have. Peter hit the nail on the head. On our boat, the hull is notched and stops about 3 feet shy of the transom. I believe that our boat was designed with 2-stroke motors in mind. They are lighter and have a more powerful hole shot to get you up on plane. Check the specs on the weight of the engines that you had vs. the weight of the new ones. If your Mercury was a 2000 225 2 stroke, it weighed between 482 to 500 lbs. If your Yamaha is an 07 4-stroke, it weighs between 592 to 608lbs. With twin motors, you have a minimum of 184 additional pounds and a max of 248! additional pounds hanging off the transom of your boat. That's a HUGE difference. Picture a 248lb man laying across the top of your outboards while you are trying to get your boat on plane. That's what you've got going on. I agree with all of the guys regarding the Merc. Rev 4 17 props. I have tried 3 blades and there's no comparison. The Rev 4's are the best props for the setup that you have. I disagree with Tom regarding the solid plugs. I originally had the solid plugs on my Rev 4's and switched to vented plugs. My boat planes faster with the vented plugs. On Merc's website the PVS system vented plugs are used when your boat has difficulty planing (which is your problem). Speaking from personal experience, they worked better on my boat than the solid plugs did. They give the exhaust ventilation which allows the props to spin faster when you are trying to get on plane. The difference with the vented plugs over the solid plugs was certainly not dramatic, but it was noticeably better. Although your boat will perform better with the Rev 4's, you're not going to get back the hole shot that you were accustomed to with the 2-stroke opti's that you had. However, it will be queiter, less exhaust and much better fuel economy. When getting on plane with that rig and the Rev 4's try this. Trim engines all the way down and hit WOT, after about 6-8 seconds, tilt the motors up slightly while remaining at WOT. This should kick you up on plane. After trying lots of diffrent things over the past 2 years, this method has worked the best for my setup. Also, make sure that your trim tabs are all the way up (flat against the hull) when you are trying to get on plane. At low speeds, they will just create more drag on the stern of the boat and prevent you from getting up on plane. Something that you may want to consider, our boat has a very large gas tank with a 298 gallon capacity. It was designed for 2-stroke motors. With your 4-strokes, you will not burn nearly as much fuel. I dont know how far you are going on these diving trips, but you may want to consider starting off with 3/4 of a tank of fuel. By doing so, your boat would be 487 lbs. lighter. You will still have about 223 gallons of gas, which will carry you very far with a pair of 4-strokes. Best wishes, Brian |
Peter
posted 01-18-2008 10:49 AM ET (US)
Most of the boat manufacturers that made boats with integrated bracket, such as what the Conquest 280 has, filled in the hull "void" on their newer equivalent models about the time the large, heavier 4-strokes came onto the market. They seemingly did this to provide buoyant support for the extra weight and make it easier to get over the bow wave with lower mid-range torque. I can't imagine that there would be any fuel savings switching from 225 Optimax to F250s. The Optimaxes burn no more fuel than a 4-stroke, and in some cases, less.
Brian7son
posted 01-18-2008 01:54 PM ET (US)
"I can't imagine that there would be any fuel savings switching from 225 Optimax to F250s. The Optimaxes burn no more fuel than a 4-stroke, and in some cases, less."I would defer to Peter on that. I stand corrected. I was basing my statement on my impression that the average older model 2-strokes were less fuel efficient than the newer model 4-strokes. My point is that the boat has a large fuel tank and a great range. Unless taking very long trips, you may not want to top off the tank. It's silly that not topping off the tank has to even be a consideration and it shouldnt be. But on that boat with 4-strokes, loaded with fuel, passengers, dive tanks, etc. etc. Sometimes it's not a bad idea to drop some wieght where you can. Even by filling up less 1/6 of a tank (50 gallons) is taking 325lbs. out of the equation when trying to get on plane. Dont get me wrong, when I leave on a long trip or if I am trying to make a crossing to the Bahamas, I am loaded to the top with fuel, in the event anything goes wrong. However, for short offshore trips I'll go out with 3/4 tank 223 gallons. |
AflredoS
posted 01-18-2008 02:20 PM ET (US)
THANK YOU EVERYBODY!!! It´s been really gratifiyng for me to find so much support. I agree with you, Brian7son, and will follow your advice on the handling. Did you install any kind of shim or wedge to change the angle of the firewall (I don´t know if this is the correct term, but I´m refering to the vertical plate where you bolt the motor) The people who installed the engines put one of this??? Also can you tell me what is the distance between lower part of the bracket and the cavitation fin of the engine? this will help a lot to see where I am. I really will love to see this shim removed and the engines lowered because they don´t look right to me. Another problem that I´m experiencing is that turning has become hard on the wheel.(my wife can´t drive the boat!!!, for example) I been insisting with the people who installed the engines and they even made me change the hdraulic pump in the helm and did almost nothing. I bet there is something wrong with the installation. Any suggestions?Since I live in guatemala Central America I already ordered the propellers from MC Marine in Miami, They are sending the Rev4 14 5/8" x 17" with the closed plugs. Since I used to have a pair of the 225 Mercury Optimax I have several set of plugs that I can play with. Regarding the use of the boat we usually travel to Belize´s Atoll´s to dive and fish. I usally take my family (5 persons including me) and spend some days there. We stay in those small hotels out in the cays. We carry diving equipment, 2 big ice chests with ice, full water, full gas, sodas,beer and luggage etc... When I mean fully loaded is fully loaded. The problem in Belize is that there is no gas in the atoll´s so it´s vital to be able to plane in full load. From where we stay we have to travel almost 50 nautical miles to the closest gas station. We even sometimes take gas in drums, which I particularl don´t like. I agree with Peter. the 225 optimax where more fuel eficient that these Yamaha´s I used to run the boat at 4600-4800 rpm at 30 knots burning 30 gph now I can´t obtain 1 knot per gallon, Hope this will get better with the new propellers. The yamahas are nice and for me was the natural choice as it turns that is the only brand more less well supported. the mercury dealer don´t know anything about the injection engines and I could´nt even get the sprark plugs for the engine. Its a shame because I believe that the Mercury engines are really nice but as they say a brand is as good as the support you can get. I´ll be waiting your comments again thanks a million |
Tohsgib
posted 01-18-2008 02:32 PM ET (US)
It is not a firewall it is the transom. The reason for the wedges is the engines might have hit the transom without them in place. When you lower the engine all the way down, how close is it to the transom, should be within an inch or so. If not you might not be tucked in all the way and that will hurt holeshot as well. I think the main thing was the props. If all looks good as far as the shims, wait till you try the props and gve us a shout back.Was in Belize a couple years ago. Stayed on Ambergris Cay, can't remember the name(next to North pier) but the owner was Woody and he has a 17 Whaler w/50 Yamaha. Took a day trip to Caulker Cay as well. |
Brian7son
posted 01-18-2008 05:04 PM ET (US)
Alfredo,Tohsgib is correct on this. The upper part of the motors, shouuld only be an inch or 2 above the transom on your boat. That's how mine is. If they raised it up too high, it's a big problem because of the notched hull. Your props will be spiining in "wash water" created in the notch area and not be able to "bite" into the water and get you up on plane. On my particular rig, the engines are mounted as low as they car be. A simple way to explain it is this. Stand on inside the stern of your boat and lean down and look at the engine covers. The top of the engine covers will hang a little over the inside of the transom. If someone were to sit at the helm while you were there (with motors off!) and turned the wheel back and forth, you should not be able to put your full fist between the transom and the bottom of the engin cover. If it's raised up much more than that, it's too high. I dont have any shim on my rig. It's mounted to the boat at attatched at the lowest setting. I understand what you're saying about needing to load up with gas and gear. I just dont think that your rig, full of gas with a real heavy load will plane very well. On a fishing trip in the keys, I had full gas tank, full live well, then an addtional 60 gallon live well on the deck (about 480 lbs), 4 adults, 2 coolers and fishing gear. It was VERY hard to get the boat on plane. It got there, but it was hard. |
Peter
posted 01-18-2008 06:39 PM ET (US)
One other thought concerning setup. Did they have to redrill the holes to mount the 4-strokes farther apart than the Optimaxes were mounted? I think the minimum separation spacing is in the 29 inch range versus 26 for the 2-strokes. If they did, its possible that the toe-in or toe-out setting is not correct which will lead to performance problems. Even if they did not re-drill, it may be that if they reused the tie-bar, it may not be set at the correct length for the Yamahas and so the toe-in or toe-out specification may be off. While you are checking height, you might as well check to make sure that the toe-in or toe-out is set to factory specifications. |
Tom W Clark
posted 01-19-2008 01:08 AM ET (US)
Brian,Thanks for the first hand experience input on the vent plugs. Because Alfredo had been experiencing ventilation in the ocean, I would not thought the vent plugs being open would be advisable, but given the need for the four strokes to spool up and get to a point on their torque curve where the propellers can really be spun, it appears some controlled ventilation may be desired. Experimentation will be the key for Alfredo here. |
AflredoS
posted 01-19-2008 01:15 AM ET (US)
Since the boat is 180 mi from where I live I will need a few days to get all the measurements. I will get them and send them to you. I will check the separation between the engines and find out if they redrilled, I am not sure. What I´m sure is that the engines are not at its lowest. Is there a way to send a picture in this forum?
Brian7son
posted 01-21-2008 09:39 AM ET (US)
Alfredo,I'm thinking about your payload. You said that you carry 10 scuba tanks. I would estimate that they are at least 40 lbs. each when full, that's about 400 lbs.) You also said: "We carry diving equipment, 2 big ice chests with ice, full water, full gas, sodas,beer and luggage etc... When I mean fully loaded is fully loaded..... . We even sometimes take gas in drums," How many gallons are you talking about in these "gas drums"? This is quite a lot of weight. You may be carrying too much. Where are you carrying the scuba tanks? You may want to try to balance your load. Have you seen those racks that attatch to the side of bow rails for holding fenders(or boat bumpers)? You way want to try to rig up some type of rack system to hold 5 scuba tanks on either side of the bow, inside the rails. In doing so, you are now placing about 400 lbs of wieght forward and most importantly "off the stern". I wouldnt put them all the way forward as they would obstruct your vision. If I were to guess, you are probably storing the 10 scuba tanks on the aft deck of the boat, along with the coolers. Also, when loading your boat, try storing some of the heavier gear (for example weight belts for scuba diving) in the forward storage compartments in the cabin. Make sure the weights are wrapped in a towel, in case you encounter heavy seas. Anything that you can do to swap some of the weight from the stern of the boat towards the bow will help out a little in enabling the boat to get up on plane better. Obviously, I am not trying to tell you to overload the bow area so that you are "bow heavy". I am just suggesting that you attempt to shift some of your weight towards the bow. Brian |
Brian7son
posted 01-21-2008 12:57 PM ET (US)
Alfredo,I sent you and e-mail with photos showing how my outboards are mounted in my 285 Conquest. I hope that they help. Check your email. Brian |
AflredoS
posted 01-21-2008 08:41 PM ET (US)
I have the measurements: Between the two engines 31" (center of propellers) from the center of the propeller to the bottom part of the bracket 13" (the distance from the center of the propeller to the cavitation fin 8 1/2" in these engines) Due to the size of the engine covers from where they are installed right now they can only be lowered about 1" or one more hole (the transom has 4 holes, the engines are tied to the third from below to top) each hole is about 1" apart from each other. The problem is that the engine the direction bracket is almost hitting the edge of the transom. Hope this is clear.
SIM
posted 01-23-2008 01:13 PM ET (US)
Alfredo,You mention up there ^^^ that you are hitting 6000 rpms at WOT with a little engine up trim. Then you mention that you load the boat up with several people and dive gear. Is that 6000 rpms reading with the heavy load or with just(lighter)you in the boat? The reason I ask is that is a huge difference in weight. I can almost guarantee you that if the 6000rpms is loaded heavy, your boat would be way way under-propped when its light(no divers or gear). If your typical use is a "heavy condition" then you need to prop it considering that. Not doubting what any other posters have mentioned, but I would lean towards the Merc Rev 4 or the Powertech OFS 4-bladed props. The Powertechs have a larger 15-1/2 diameter and may be better suited for your application. I would also stay away from porting the prop. In my experience, porting props on large heavy boats can lead to the boat basically stalling while coming onto plane........that is the point when the load on the propeller is the greatest. I could be wrong(wouldn't be the first time!) In my experience porting has worked well on smaller lighter rigs with a lot of horsepower. Bass boats are a good example of this. Or with aggressive style prop blades too. Its hard to recommend a pitch with out knowing how the boat was loaded at your 6000 rpm reading. Andy |
Tohsgib
posted 01-23-2008 01:27 PM ET (US)
Good point Andy...might be smart to run one set of smaller props to the islands, then your current set back when you have lightened the loads and fuel. |
AflredoS
posted 01-24-2008 04:22 PM ET (US)
thanks Guys: I already received the rev4 propellers (14 5/8" x 17" )I´m going to try them during the weekend and will bring you back data of the current situation and ofthe changes made. I´ll keep you posted, regards |
AflredoS
posted 01-28-2008 10:56 PM ET (US)
Here´s the data: With the actual propeller, three people on board,full gas and full water the boat planes in +/-15 seg, WOT 6000/6100rpm=37.4 knots, at 4800 rpm= 27 knots at 26 gphwith the rev4 prop, same characteristics +/-8-10 SEG, 6000/6100 RPM=38.4 KNOTS, AT 4800 RPM=28.8 KNOTS AT 25 GPH. AS YOU MAY NOTE IT DID IMPROVE SIGNIFICANTLY, I will try lowering one hole the engines to see if it mantains the actual conditions and be able to solve the ventilation issue. I took some pictures of the actual rig, Is someone interested in comment them, send me your mails |
Brian7son
posted 01-29-2008 08:26 AM ET (US)
Alfredo,That's great news. Ain't it great when the guys on C.W. can come together and solve a problem. I have the same set up that you have(except I have 225 4-strokes, not 250's) and I do feel that the Rev 4's that you switched to are the best props for your(our)particular rig. Brian |
Tom W Clark
posted 01-29-2008 11:25 AM ET (US)
It is impressive what a simple change of propellers can do.While you only gained 1 MPH in top speed, the much more significant improvement was your time to plane which has improved about 40 percent. But what really caught my eye was the fuel economy. You have gone form 1.19 MPG at 31 MPH to 1.32 MPG at 33 MPH. My concern now is that if the boat really was as fully loaded as you indicate and you are hitting the redline then the props may not be enough pitch when the boat is loaded more lightly. |
