ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance 1995 OUTRAGE 19: Best Engine for Re-Power
Author | Topic: 1995 OUTRAGE 19: Best Engine for Re-Power |
tlabaugh |
posted 04-23-2008 11:43 AM ET (US)
I just had our 1995 Outrage 19 rebuilt. You know the typical, cut out the floor, remove the tank, take out all the wet foam, add three layer of glass inside the hull, epoxy the inside of the hull, replace the foam, install a new tank, and do an epoxy bottom job. And, yes, we have picture to prove it. Our 1995 Ocean Runner has been a great motor, but I was thinking about a re-power. Any thoughts on what would work? I was thinking Evenrude, but the Mrs would like a quite power plant. What is the best option: Suzuki, Yamaha, Honda? Are there other choices? Thanks - |
an86carrera |
posted 04-23-2008 01:31 PM ET (US)
I just purchased a 2008 90-HP E-TEC and it is very quiet by my standards. I can listen to the radio at full throttle and have conversation. Others will think different I'm sure. Len |
ratherwhalering |
posted 04-23-2008 01:37 PM ET (US)
The Evinrude E-TEC 150 is whisper quiet, smooth as silk, and fuel efficient. |
Don88outrage |
posted 04-23-2008 06:08 PM ET (US)
I'd have to give a vote for the E-TEC, but the way fuel prices are going the conversation may evolve to how do you rig a mast and sail on your Whaler. |
Buckda |
posted 04-23-2008 06:50 PM ET (US)
The quietest motor available is probably a Verado. . . But it is both spendy to install with all the bells and whistles and heavy to boot. The E-TEC and Optimax will be your best performers and quiet, but not as quiet as the Yamaha, Suzuki, Honda and Verado. Personally, I would buy within my budget with the best dealer in your area and buy based on available service for the brand in the area where you frequently boat. When considering Verado, consider also that not all Mercury dealerships can repair or service the engine without voiding your warranty. This is the single biggest prohibitive factor in my opinion for the most people. Weight should not be a problem on your hull as it might be on others. Good luck |
posted 04-23-2008 08:18 PM ET (US)
Do you have a preference for only Japanese-made outboards? |
an86carrera |
posted 04-23-2008 09:55 PM ET (US)
I think we have an E-TEC problem on this site, can we have an E-TEC only forum;) Len |
tlabaugh |
posted 04-24-2008 09:14 PM ET (US)
I was thinking E-Tec but have heard they are loud @ speed. Who has the experience with the Honda BF 150? I have heard it is quite and stays quite at RPM. Weight wise the Honda is 485 vs the Evinrude's 427. Has anyone heard the Evinrude? Any experience with hole shots? What is the difference between the 150 and 150 HO? |
tlabaugh |
posted 04-25-2008 09:37 AM ET (US)
FYI, the old ocean runner weighs 375. |
Casco Bay Outrage |
posted 04-25-2008 09:45 AM ET (US)
tia... - I think you need to get a ride from someone (regardless of boat brand) who has an E-Tec. Buckda published a video of Gambler's repower with twin E-Tec's. Couldn't hear the engines over the sound of the water and wind. No offense intended but you are going to exclude one option in a 13,000 purchase based on "heard they were loud"? While I have had two Yamaha's, when I repower, I will look at every brand/model appropriate for the boat. CBO |
Perry |
posted 04-25-2008 12:43 PM ET (US)
tlabaugh, I have been on a boat with a 150 ETEC and I own a boat with a BF135 (same as BF150). The Honda is definately more quiet than the ETEC. The ETEC is a fine motor amd quieter than the old carbed 2 stroke but not as quiet as a 4 stroke. I believe the BF150 was the quietest 150 HP motor in Trailer Boat Magazine's 150 HP shootout. |
Peter |
posted 04-25-2008 01:49 PM ET (US)
I've been on an Everglades 240 cc powered by a pair of Honda 150s. At idle speed they are quiet like all 4-stroke outboard except that one of the two motors on this boat had an annoying shake and rattle at no-wake speeds that took away from the otherwise expected quiet 4-stroke attribute. I'm not sure whether that was the so called "4-stroke prop rattle" or not. At cruising speeds I would not characterize the Honda 150 as being any quieter than my 2003 Johnson 150 2-stroke. One reason is that the Honda 150 has to turn higher RPM to go the same speed. Another reason is that the sound characteristic of the Honda 150, like all 4 cylinder 4-strokes, is simply different than a V6 2-stroke. The best way I would characterize the sound the Honda (or other 4-cylinder 4-strokes) at cruising speed (above 4000 RPM) is a white noise (multiple competing frequencies -- a sort of valve train versus pistons, crankshaft and exhaust) rather than a more specific "tuned" sound you get from the 2-stroke. The E-TEC is definitely not loud. While not as quiet at idle as a 4-stroke, it is in the category of outboards where you can noticibly hear the water from the water pump telltale hitting the water. It's that quiet. Determination of noise levels and sound preferences is, of course, very subjective. |
Tohsgib |
posted 04-25-2008 02:14 PM ET (US)
I will say the smaller e-tecs are pretty darn quiet. I was recently on a 150 e-tec 18 Outrage and although pretty quiet it is much louder than a 4 stroke at slower speeds. I did not go out of a slow zone with it. My Suzuki is barely noticeable at idle except for the water stream hitting the water. Len(above) who has an E-tec was with us in Homosassa on my friend Frank's boat with 225 Yama/Merc 4 stroke. We were putting in the keg and doing stuff for about 10+ Minutes. Frank then stuck it in gear and Len was like "Wow...I never knew it was even running!" Again if she wants quiet, get her a 4 stroke and go with best dealer and price by you. They are ALL reliable and have about the same resale. Weight is not an issue being that boat was designed to handle twins which would be 500+lbs. |
Tohsgib |
posted 04-25-2008 02:15 PM ET (US)
PS...Buckda has almost 700lbs on his transom with twin e-tec 90's, jackplates, etc and he is very happy. |
Peter |
posted 04-25-2008 02:22 PM ET (US)
The 1995 Outrage 19 was NOT designed for twins. It has the extra liner with the narrow notch in the transom and stern quarter seats. The extra liner adds something like 600 lb to the dry weight of the boat. |
mjf19 |
posted 04-25-2008 04:13 PM ET (US)
i have the same boat but a 94 and need to replace the tank and get some wet foam out, would love to see some pictures and may try some of the work myself, did you self perform this project? regardless can you give me a ball park estiamte on the costs and what was exaactly done thanks |
tlabaugh |
posted 04-27-2008 08:01 AM ET (US)
I will post the photos on the reconstruction job on the web or you can PM me. The restoration was a huge job and we had Metan Marine in Boston do it. This vintage of Outrage had some real [problems] that unfortunately surfaced 3 years ago and we were finally able to address it versus getting a new one. Regarding the engine noise being a key factor, the Admiral is the one who had to rubber seal the deal and her criteria is quite and fuel efficient. |
fourdfish |
posted 04-27-2008 12:12 PM ET (US)
OK- So I have the experience of being next to both a Verado and E-TEC and being able to compare the sound levels of both. It is very hard to tell with the naked ear which is quieter. Both engines are very quiet. My dealer ran both the Honda and E-TEC in the shop and said they were both very quiet. My 200hp is so quiet at idle (450-RPM) that you cannot hear it at the helm. |
tlabaugh |
posted 04-28-2008 11:11 AM ET (US)
Here are the rebuild photos. It was about $14,000 for all the work including the epoxy bottom job. http://tinypic.com/userstuff.php?u=gM4x3vnTYxiJFAqR9ViSlA%3D%3D If we add a new motor, it will be just under $28,000 for the complete refit, (including a new gauge, steering the throttle pack vs. $48K for a new 19 Outrage and trailer. Prior to the rebuild I also purchased a new trailer which made this rebuild decision easier. I'm very psyched to go 50 MPH again vs. the 32 MPH top end with the water logged boat. |
Tohsgib |
posted 04-28-2008 02:49 PM ET (US)
My bad I was thinking the earlier 19's. A 150 Suzuki can be had for around $8,000 engine only. I think you could repower for about $10,000 out the door or maybe less. |
tlabaugh |
posted 04-28-2008 06:22 PM ET (US)
Please forward any dealer info where I can pick up a DF150 for $8K. That would really do the trick! Thanks.... |
rush |
posted 04-28-2008 09:46 PM ET (US)
If you've set your sights on a DF, boattrader.com has a couple of dealers who will sell you a 2008 DF150 or a 2007 DF140 for about $8,000: The Boat Store has the DF150 for $7,900 I believe and Diamond Suzuki has them for $8,200. The catch is they don't ship; you have to have them rigged there, so the advice to find a dealer near you that is within your budget is key. Since you have Evinrude/OMC controls, add about $1,500 to $1,700 or so, depending on riggers (I agree with TOHSGIB) and then another $300 to $400 or so for a Suzuki prop (on Ebay). I have a 1995 [unrecognize acronym, possibly OUTRAGE] II as well, I am on the thread next to you. And I have just gone through this very decision process. My criteria are somewhat different in that I am additionally fiscally constrained to about $9,000. I, too, wanted a quiet, fuel efficient, and a weight (about 419 lbs) as close to or less than my 1995 Merc Black Max as possible . Oh yeah, I want to go as fast as possible, too! I must admit I had predetermined that I was going to get an E-TEC (if I could find one I could afford), but I studied the E-TEC, Opti, Suzuki DF and Yamaha four cycle anyway; I didn't look at the Honda BF150 due to weight and cost up front. I also ruled out the Verado due to its 510 heft and the requirement for rigging with the new Smartcraft guages and DTS (required) that would have exceeded my budgetm although I did find an [invented model year designator] 150 Verado for $8,000! The Yamaha, while only 467 pounds, was also beyond my budget ("spendy" as my wife would say.) I couldn't find anyone who would deal with me on a four-cycle motor and I didn't want the HPDI. That left the Suzuki, the E-TEC and the Opti. Still committed to the E-TEC, I found that there were few leftovers and fewer deals on the 150 (the HO is the high-output model, usually identified by the patriotic cowling, and not available in the saltwater edition). The Suzuki looked more attractive than before at a svelte 464 pounds (I could stomach the extra 45 pounds since I'm doffing an oil tank) and an $8,000 price tag. The deal breaker was not being able to take advantage of the price by having it shipped from FL to SC and rigging it myself and thus, bumping up the "drive away" cost to $10,500 or so. In every case, the dealer required it to be rigged by them and water tested by them. I did just return from a Whaler rendezvous on the Waccamaw where another CW member had a DF140 on his 1974 Outrage and it was quiet, smooth, and powerful. His boat was significantly lighter than ours at 1,900 pounds, but it was a really nice performer! Finally, I looked at the Opti. You'll find some pretty polarized groups and opinions in the E-TEC and Opti camps on CW. I read as much as I could on both (CW (Thanks, Jim!) and Google are awesome tools) and decided they were pretty neck-and-neck with the Opti edging the E-TEC out in most (if not all) the head-to-head comparisons I read. I'll be happy to share the literature I did download. The deal maker for me was availability of GEN II Opti leftovers for $8,700-9,000, the willingness of Mercury to ship to me and let me rig it (with a 5 year warranty through June), and the ability to rig it with my current controls (I can upgrade the guage set/monitoring system to Smartcraft at a later date). If money/rigging weren't an option, I'd really be hard-pressed not to go with the Suzuki (the new DF150); quiet, strong, fuel efficient, not too heavy for our boat. It really impressed me this weekend. I really think weight is an issue for the [OUTRAGE] II, particularly in trailering. Wet weight must be around 2,900-3,000 pounds. What kind of trailer do you have under your boat? |
tlabaugh |
posted 04-29-2008 11:55 AM ET (US)
Rush, Thanks for the info. Very helpful. I was thinking E-Tec because I don't have to do much in the way of changing the boat w/controls ect. vs. the Honda. For me, I'm pretty sure I need the 25" so my weights are a little more. The Suzuki comes in @ 484, but that price sure seem right. Assuming I can get someone up here to give me the same base price and install it, I'm good to go. Best.... |
Tohsgib |
posted 04-29-2008 01:04 PM ET (US)
Go to Edsmarinesuperstore.com and take that around to your local suzuki dealers and get somebody to come close. As far as prop goes, I got mine from Tom Clark for cheap. The controls and tach I got on E-Bay, the wiring harness from the dealer(not cheap but still only $126). I bought and rigged mine myself. Suzuki does not have any problems with you doing so unlike Yamaha and E-tec. Problem is finding a dealer who will sell it to you in the crate. My dealer was going bust so no problem there. Best thing about the Suzukis over the rest besides weight and price is the timing CHAIN, not belt. |
tlabaugh |
posted 05-07-2008 04:30 PM ET (US)
Found a DF150 for $8700. Install, new steering system and gauge pack is $2200 more which I think is a good deal. Any comments? |
Buckda |
posted 05-07-2008 05:03 PM ET (US)
For the record - I'm not down on the VERADO - another member here recently reported his intention to repower with one. let me tell you about my experience with VERADO 200 on a 210 Outrage in 2006. I darn near cranked the engine and it was ON already - it was that quiet! I was very impressed. My 90 E-TEC is not in the same league on quiet operation. BUT Quiet operation was not my primary parameter when repowering the boat, and I AM happy with the reduced noise of TWO 90 HP motors vs the single 150 Merc Black Max, carburated 2-stroke that was back there before. Regarding the WEIGHT of the VERADO (and similarly, my twin 90 HP E-TECs)...you will need to plug your splashwell. This is a LOT of weight for the classic 18' transom. Were I a major fisherman, I'd consider re-building my transom to enclose it like the optional version of this hull. I'm still considering that as a future project for my 18 once I get a little fiberglass and gelcoat experience under my belt. Yes...I'm serious, although it will add even more weight to the transom area. I'm still working on this idea. Good luck in your decision - I hardly think it is an easy one! My advice is always similar: find a dealership that you trust and you can work with...then make sure you are buying a product that can be easily serviced at other dealerships in the areas where you often boat. In Michigan, that rules certain brands out almost completely. Good luck. Dave |
L H G |
posted 05-07-2008 05:05 PM ET (US)
Why would you want to spend 11K on a Suzuki or Etec, with old fashioned standard controls and old fashioned gauges, when you can get a Supercharged Verado 150, with DTS AND Smartcraft for the same price (and no sales tax) installed? It's a no brainer, and the Verado is clearly a superior machine in acceleration, top speed and fuel economy. That Outrage II hull will easily handle the weight. Install engine in middle set of bolt holes and use an Enertia prop. CLick on the right hand print ad, then See upper right corner for the Verado price: http://www.boatshopper.com/de/nb1147/index.asp?dealerid=nb1147 For 150 comparison information, see here: Note that the Suzuki and E-tec are gas hogs compared to the Yamaha and Verado. |
tlabaugh |
posted 05-07-2008 05:18 PM ET (US)
LHG .............. Now you have done it. I have to put on my thinking cap again. |
fourdfish |
posted 05-07-2008 06:20 PM ET (US)
Larry, You again forgot to add in your post "In my opinion" Again: Opinions and facts are not always the same! |
fourdfish |
posted 05-07-2008 06:27 PM ET (US)
BTW--You could not possibly back up the statement that: "The Suzuki and E-TEC are gas hogs compared to the Yamaha and Verado" with any reliable evidence what-so-ever! Dave--I have heard the 200hp engines at idle and they sound quieter than the 90hp engines. I am not sure how that could be. Maybe it is just my ears. |
Buckda |
posted 05-07-2008 06:51 PM ET (US)
If you are considering VERADO, before you select the DTS controls, be sure to drive a boat with them. They are really slick - and a great idea - but I'm not a huge fan. I guess it's similar to the Boeing vs Airbus debate for pilots (classic controls vs. fly by wire digital controls). I do think that it is the future of controls on boats - and the next generation, and perhaps even the current ones, will get used to them and accept them easily. I like the solid feel of my classic controls, which are easy to use and provide a reassuring sensory alert when I'm in moving through neutral into and out of gear. The DTS equipped boat I described above did not have this. Again, I almost threw passengers out by charging right through the gear selection and straight into gear. I can see this as being difficult to adjust in heavy seas on a smaller boat like the 19' Outrage. Again - don't get me wrong - go with what you want. This is a very slick system that the engineers at Mercury developed - but this is about your comfort, not someone else's idea of what will work for you, or what they wish they had, or are planning to get for their boat. Finally - to restate the advice early on and just above; confirm that you have a VERADO certified maintenance facility in your area and that you like that dealership...otherwise, it may be like owning a Lotus in Nebraska. Fun to drive, a dream to own and a pain in the behind to find service. Good luck. Dave |
Wasatch Whaler |
posted 05-07-2008 06:55 PM ET (US)
LHG, That seems like a "deal". I remember a thread a while back about the change to engines being produced without a model year designation. I also vaguely remember a thread about significant improvements to the Verado engines. Could these be leftover, earlier, non-current production engines? That is, it sounds like a deal because we're thinking brand spanking new from the production floor, when in fact the engines are technologically outdated compared to their new production Verado brothers? |
posted 05-07-2008 08:10 PM ET (US)
In my opinion (and let me explicitly say that), the advantage of DTS accrues mainly in twin engine installations or in dual control station installations. When you get right down to it, DTS still operates mechanical devices to control the engine. DTS uses electrical actuators to operate mechanical levers to control the engine. A non-DTS motor just operates those mechanical levers using mechanical controls directly. DTS adds considerable complexity to the installation. There is a control computer associated with the DTS controls. This computer interprets the input from the mechanical levers of the control surface, and turns them into digital signals to be sent to the electrical devices in the motor. To diagram what goes on in DTS you have: Mechanical controls -->Mechanical movement-->Electrical sensors--> Conversion to digital data--> Data processing--> Data communications--> Conversion to mechanical movement-->linkage to mechanical controls. Where DTS can really shine is when you have dual control stations. The second station can be easily integrated. Also, DTS can add value with twin engine or triple engine or quadruple engine installations. With DTS you can implement features in the data processing realm which will improve the operation of multiple engines. For example, you can automatically synchronize the engine speed among multiple engines. When you have a single engine boat, DTS does not add a great deal of value. The value added is limited to two areas: you can have really feather light touch controls, because they are just electrical sensors; and you can have some intelligence built into the control surface to help prevent really stupid control input from causing damage to the engine. An example of the latter is preventing a high speed shift from forward to reverse from occurring. (Actually, I don't really know for a fact that such intelligence has been built into DTS, I am just giving Mercury the benefit of my assumption that they had the intelligence to do that sort of thing. I have never seen any literature which explicitly states that such control supervision has been implemented by Mercury.) There is no argument that DTS provides a nice control for an engine, but in a single engine installation I do not think that DTS provides any huge advantage over conventional direct mechanical controls. After all, motors have been controlled by direct mechanical linkage for one hundred years, and there really has not been an enormous problem with that approach. If you were planning on a twin engine, triple engine, quadruple engine installation and wanted to have duplicate or triplicate control stations, it would be absolutely a no-brainer to prefer DTS. But with a single engine and a single control station, DTS is nice but it is not the killer-app that some try to make it out to be. |
Tohsgib |
posted 05-08-2008 12:21 PM ET (US)
I am still under the K.I.S.S. plan and all that electrical BS in Salt water spells disaster in my eyes. Time will tell. |
posted 05-08-2008 10:14 PM ET (US)
Verado users often observe that the shifting with DTS is very smooth. I don't question that observation at all, in fact, I agree with it. But it is not the electrically operated shift controlled by a digital data link that makes the shifting smooth; it is the newly designed gear case used in the Verado. The Verado gear case shifts much more smoothly than the old Mercury gear case, which was once described as shifting like a 1950's truck. If the Verado gear case were being operated by direct mechanical controls, it would shift just as smoothly. The electrical solenoid which actuates the shift does make a nice, crisp, rapid shifting. However, a human-operated control can make that same sort of shift with a little bit of training on how to properly shift. |
Tohsgib |
posted 05-09-2008 10:04 AM ET (US)
It is about time they redesigned that gearcase. Merc V6 gearcases have clunked/grinded since the beginning. I never understood why they did not "fix" that problem so they were quiet like OMC, etc. More puzzling is that Yamaha copied their gearcases and copied the noise they make as well. I drove a F150 and the otor was just as quiet as my Suzuki until she went in gear..my hair stood up. It is bad enough with a noisy 2 smoke, throw in a silent 4 stroke and it sounds like you just chunked a gear. |
tlabaugh |
posted 05-09-2008 06:08 PM ET (US)
The Verado is a deal, but it is a 2006, counter rotating prop. |
posted 05-10-2008 08:47 AM ET (US)
L H G opines: "Why would you want to spend 11K on a Suzuki or Etec, with old fashioned standard controls and old fashioned gauges, when you can get a Supercharged Verado 150, with DTS AND Smartcraft for the same price (and no sales tax) installed?" In terms of the instrumentation, we have been over this ground a million times. At issue here is Mercury SmartCraft compared to Evinrude I-Command. As far as I can tell, there is no advantage whatsoever to SmartCraft instrumentation, and, if one looks at this with an open mind, there is a distinct disadvantage to SmartCraft--it is proprietary to Mercury and has not been supported by other vendors. I-Command, on the other hand, is a certified NMEA-2000 system. NMEA-2000 is a very widely accepted vessel instrumentation network which has shown itself to be interoperable among dozens of vendors. E-TEC motors are certified NMEA-2000 devices and can be incorporated into vessel networks with other NMEA-2000 devices. It is impossible to make an argument in favor of SmartCraft compared to I-Command and use the term "old fashioned" with any validity. There is nothing "old fashioned" associated with I-Command and NMEA-2000. If anything, the proprietary nature of SmartCraft makes it more "old fashioned" than I-Command. |
