Topic: Yamaha Saltwater Series II vs Mercury Mirage Props
TransAm |
posted 07-07-2008 09:43 PM ET (US)
I had a friend tell me that the Yamaha Saltwater Series II Props were very similar if not identical to the Mercury Mirage Plus props. I was wondering if there is any truth to this. I got to thinking that Yamaha came out with the Saltwater Series II prop design (from pervious Saltwater Series) about the same time Mercury went from Mirage to Mirage Plus design. I am thinking of purchasing a pair of Mirage Plus, but currently have a set of Saltwater Series II and wont bother if they are in fact identical, or virtually so.Also, if I were to adjust pitch on a prop, would it be better to adjust a 23 pitch DOWN to a 22, or adjust a 21 pitch UP to a 22.
Peter
posted 07-07-2008 10:43 PM ET (US)
I've heard that before. I've had both propellers and a quick glance at both side by side will reveal to even the casual observer that there is absolutely no truth to it. By the way, the SWS II propellers are very good propellers and I think you would be wasting your money buying Mirage Plus propellers to replace them. |
Tom W Clark
posted 07-07-2008 11:51 PM ET (US)
The Yamaha Saltwater Series II was Yamaha's answer to the Mercury MIRAGEplus. I believe Yamaha developed it as good imitation of the MIRAGE propellers. They are NOT identical.Both the Saltwater Series II and the MIRAGEplus is certainly worth trying on your boat. You'll never know how a propeller performs until you try it. |
Peter
posted 07-08-2008 07:32 AM ET (US)
I don't believe Yamaha developed the SWS series as as an imitation of the MIRAGE propellers. To my eye, it looks like a variation of the typical Yamaha cleaver shape, with the variation intended to provide more blade surface area by enlarging the diameter and changing increasing the blade surface at the outer half of the swept area (a little more soup spoon profiled versus teaspoon profiled). |
TransAm
posted 07-08-2008 10:29 AM ET (US)
Anyone have on opinion on part 2 of my original post? Is it easier/better to add pitch to a given prop, or take it away? |
timing
posted 07-09-2008 11:28 PM ET (US)
I have no personal experience, but have consistently read this position from a rock solid source (Premier marine surveyor Dunk in NJ)."You can always have more pitch bent into an outboard prop, but you can't take pitch out without ruining it." Ref within this link's thread - http://www.thebassbarn.com/forum/showthread.php?t=145795 |
