ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Designer propellers: what gains?
Author | Topic: Designer propellers: what gains? |
cooper1958nc |
posted 09-05-2008 05:08 PM ET (US)
I took this to a new topic for grins. My thesis is that fancy-schmancy propellers are not much different, where it counts, from old tried-and-true propellers. Before everyone reaches for their keyboards, I am *not* talking about race boats or very high speed operation, where granted a very small change in "something" underwater can win or lose the race. I am talking about normal, everyday service. Like 20-35 mph, where almost everyone cruises. I am *not* talking about a comparison of propellers where one has a different "real" or "effective" pitch than another, so the test shows differences. That is easy to spot. I am stating that in the normal cruise range, efficiency (defined as miles per gallon) will not change more than 5% between equivalently pitched props. By "equivalently pitched" I mean resulting in the same speed on the same hull at the same RPM. Obviously, if the props are pitched differently, one will need a higher RPM to cruise at the same speed, and I will bet, further, that that one will most often use more fuel. So if we leave pitch out of the equation, I maintain no propeller design will produce much difference. I cite to the aviation experience for one, where the Wright Brothers propeller was almost as efficient as one you buy today. No one has, despite a lot of trying, come up with much better. I maintain, for example, the 2-blade Mercury bronze props of the 1960's will hold their own for efficiency with anything today. Any scientific hypothesis begs to be proven wrong, and I would be happy to declare it false on proper evidence. |
TransAm |
posted 09-05-2008 05:43 PM ET (US)
You seem to have declared it true without proper evidence. I'm not sure you will get many takers for your proposition as this exercise will require much work to accomplish and require access to many props with similar effective pitches, especially older, 2-blade props. Perhaps someone in the business with access to this type of inventory as well as proper hub kits and matching spline conficurations would be able. Lots of time. Are you buying gas to conduct this experiment professor, and what's the bet? |
contender |
posted 09-05-2008 06:10 PM ET (US)
Mr Cooper. In the early 70's(For the life of me I can not remember the correct year maybe 72) I had a 15 1/2 ft Rapier with a new 140 mercury (first year for power trim/tilt I believe). We tried every prop we could borrow, buy, steal you get my drift. Anyway the best prop we found was in fact a old two blade bronze prop from the 60's. It weighed a ton but it let that engine crank and we were running in the 70's mph, it was fun...good memories |
Tom W Clark |
posted 09-05-2008 08:12 PM ET (US)
Please define what a "Designer propeller" is. Please define what a "fancy-schmancy propeller" is. Please define what an "old tried-and-true propeller" is. We're not going to get anywhere talking in vague made-up terms. |
Perry |
posted 09-05-2008 10:40 PM ET (US)
Why not use evidence and report your findings instead of throwing out a thesis? Discussions of what you think to be true is a waste of time in my opinion. I'd like to see some first hand data to support a claim. |
an86carrera |
posted 09-06-2008 06:40 AM ET (US)
I suspect this person has never been out on a day of propeller testing. Len |
TransAm |
posted 09-06-2008 07:47 AM ET (US)
I would go further to suggest that two comparative test propellers fitting your narrow test criteria likley do not exist. Consider that when you change from a 3 blade prop to a 4 blade prop of the same basic pitch, RPM's drop, often significantly, because there is usually more surface area spinning 4 blades, although not necessarily proportional. This change represents a 33% increase in the number of blades, and a bit less than that percentage in increased surface area assuming 4 blades have smaller per blade surface area. Personally, I experienced a 300 RPM drop changing from a 23 pitch, 3 blade Mercury Mirage Plus to a 22P 4 blade Mercury Bravo I. Even though the pitch was less on the Bravo I's RPM still went down significantly primarily because of the increased surface area and perhaps influenced by some smaller factors as well. When going from 2 blades to 3, you are increasing the number of blades by a much higher percentage, 50%, and one would expect a much greater change in surface area, again not necessarily proportional. It would seem logical to assume changes in actual performance between these 2 propellers would be greater than that the example above, so to find 2 propellers (one 2 blade, one 3 blade) of equal pitch, that operate at similar speeds at similar RPM's would be, well, highly unlikly. |
cooper1958nc |
posted 09-06-2008 10:38 AM ET (US)
Increasing blade area generally decreases efficiency except when the smaller blade area propeller has so much load per unit area it cavitates, so I agree the decrease in RPM (WOT?) easily explained. Okay, let me simplify this: Today and tomorrow, with fuel and emissions and C02 issues on the rise, I believe that the name of the game will be fuel efficiency in mid range cruise. Small planing vessels will continue to exist, but they will be optimized for fuel efficiency, not top speed. Best efficiency, from the hull, occurs just over transition, at some mid range in the 20's (for small planing boats under 30' or so). I have said, despite being called a heretic, that the best mid range fuel efficiency occurs when the engine speed is kept as low as possible. That means as large propeller diameter as practical, and as much pitch as possible so that the engine can still plane the boat (or a multi gear transmission if necessary) but forget setting pitch to get to top RPM as that is inconsistent with low engine speed at mid range cruise. Now my argument is: what prop *design* will give peak efficiency at mid range cruise? This is *not* an idle question, if you believe what is going to happen to boating in the future. By "design" I do not mean merely what diameter and pitch. I mean what design elements other than those specifications improve economy. I challenged the propeller gurus here to explain how design affects this type of performance. I do believe that the propeller "tests" that I have seen on this forum and others support the proposition that the design, other than the diameter and pitch, as almost no effect on mid range fuel economy. Apparently I am right. |
Tom W Clark |
posted 09-06-2008 01:38 PM ET (US)
cooper1958nc, This has the potential to be an interesting conversation. Please do not side track it. Again, I am asking you to define what a "Designer propeller" is. Define what a "fancy-schmancy propeller" is. Define what an "old tried-and-true propeller" is. We are waiting for your answers.
quote: Apart from that sentence not making any sense, I do not believe anybody has ever called you a heretic. If I am wrong, please cite even a single instance of anybody calling you a heretic. Reviewing the thread, I see you are wavering about what your thesis is. Could you firm it up a bit so we all know what your point is? Since when is a five percent improvement in [ fill in: speed, fuel economy, acceleration, whatever your performance goal is. ] Insignificant? I would LOVE to see a five percent improvement in fuel economy on my boat for example. |
Perry |
posted 09-06-2008 05:59 PM ET (US)
This sentence makes no sense.
quote: If you have two props with the same pitch resulting in the same speed on the same hull at the same RPM, the props will be identical. They will have the same slip % and should have the same efficiency. Why would you want to compare identical props? |
cooper1958nc |
posted 09-06-2008 09:02 PM ET (US)
"If you have two props with the same pitch resulting in the same speed on the same hull at the same RPM, the props will be identical. They will have the same slip % and should have the same efficiency." Well, not exactly. It is a common misconception, however. Remember, except for WOT, having equivalent RPM and boat speed does not mean the propellers are identical at all. What you don't measure directly is manifold pressure or throttle setting, which relate to torque. It may take a different amount of torque to turn two different props the same speed, although the same boat speed is produced. The throttle setting does have a big effect on fuel flow, of course. Also remember, "slip %" is an amalgamation of hull and propeller factors. It is not an index of propeller efficiency. And there is no way to directly measure it anyway, because no one knows the "real" pitch of the propeller, only what is stamped on it by the manufacturer. I guess one could try to measure the speed of the water column ejected sternward, but I have never seen that done. Designer fancy schmancy propellers are in my opinion the various series of pretty looking propellers offered for sale by touting some design characteristic other than merely diameter and pitch. Some are said to have lift, some are said to be good on small boats, some good on big boats, some just good on everything. I looked at the Mercury website and found several series of very pretty propellers, although the exact differences in the design were not clarified. Perhaps our propeller gurus could clarify it, because I don't sell propellers and can't speak for the manufacturers. "I have said, despite being called a heretic, that the best mid range fuel efficiency occurs when the engine speed is kept as low as possible." What about that sentence does not make sense to you? I believe it scans well, is in acceptable if somewhat vernacular english, and is in proper grammar. One could question the term "mid range"; perhaps "midrange" or "mid-range" would be better. The dependent clause "despite being called a heretic" might in formal use be better rendered "despite *having been* called a heretic," although the use of present tense is, in the present context, possibly even better and less ponderous. A heretic is one who espouses heresy. Heresy is spoken or written words that are anathema to the established dogma. I have said, contrary to the established dogma, that the practice of propping for WOT RPM at the mid or high end of the manufacturer's specified range, results in less midrange fuel economy because of engine friction. Many have joined the chorus of denouncing this idea. Therefore, I accept the implied title of heretic. So, what does that have to do with the physics? And this issue is purely a matter of physics. |
glen e |
posted 09-06-2008 11:03 PM ET (US)
Well as usual coop, I have no idea what you are trying to prove except that I guess you think that all new the new props are fancy and it’s just some major marketing scam put out by the prop mfrs. I don’t have a physics degree and get by with just a lowly MBA. But here is what I do know from my own actual real world tests. Here are the five sets of props I own, all considered “designer” by you, I guess. The 5 sets of props I own: Enertia 19’s Now when I take all 5 sets to the beach and make the same run up and down the ocean, THEY DO DIFFERENT THINGS. Some are faster than others, some are smoother, some get better mpg at cruise or WOT than the others and some has a bit of each…One is clearly the winner on mph WOT by 3 mph..... So what’s you’re point? For me and everyone else I know, you must decide what you want and then find a prop that fits those requests. |
TransAm |
posted 09-07-2008 08:26 AM ET (US)
glen, Would you mind sharing which props do what of your set-up. I'm curious. I have tested some you listed and may test others. I would like to see how my results stack up against yours |
glen e |
posted 09-07-2008 09:29 AM ET (US)
Enertia 19’s - a good overall prop - a bit of blowout in ocean Tempest 19’s - the fastest of the bunch about 3 mph than any other prop - but feels "rough" around docks, ICW speeds Mirage Plus 19’s - overall good performanace but huge blowout in the ocean Rev 4 17’s - lower WOT mph but smooth prop with good cruise mpg - no blow out Rev 4 19’s - same as above but not enuf wot rpm I run the rev 4 17 as my everyday prop |
cooper1958nc |
posted 09-07-2008 10:16 AM ET (US)
The results would be interesting if combined with fuel flow readings and accurate speeds, if on comparable hulls. All the questions about the question remind me of my physics students. If they are having problems understanding the concept, they ask the question be repeated, hoping I will give them the answer in the question. " Yes, that is my hypothesis. Manufacturers are driven to produce "new models" for marketing reasons. Certainly. Is that surprising? So, is the hypothesis correct? Two different propellers, especially when they differ in diameter and pitch, certainly can differ in WOT speed, midrange economy, and other factors. I am interested in isolating the differences, if any, that result from design characteristics OTHER than diameter and pitch. So what design characteristics, if any, differentiate
2manyboats |
posted 09-07-2008 02:06 PM ET (US)
cooper1958nc what prop do you run on your whaler and how much lower are your RPMs than what your motor manufacturer recommends. |
fishgutz |
posted 09-07-2008 02:52 PM ET (US)
Coop, I think you are correct for the most part. I think the differences are minimal and will vary from boat to boat depending on weight, length, beam, drag, etc. The list goes on. After spending hours reading posts on this site and my own limited experimentation, I find most prop testing is really pretty much trial and error with somewhat predictable results. The manufacturers need to put out new products year after year to make you think you need a new and improved item. |
cooper1958nc |
posted 09-07-2008 07:44 PM ET (US)
I have a 21' Hunt-type V hull with a 150 Opti, among other boats. The prop is some kind of Mercury SS prop, 1999 vintage. The engine can barely make 5000. I have no ability to read fuel flow. Why? |
2manyboats |
posted 09-08-2008 01:38 PM ET (US)
sounds like you need a better prop |
cooper1958nc |
posted 09-08-2008 06:43 PM ET (US)
Why on earth? |
Murphy |
posted 09-08-2008 09:39 PM ET (US)
http://www.niu.edu/~jdye/method.html Socratic or Scientific? This discussion is intriguing since I have just started to look for a new prop. I was never good a physics, but it seems to me to boil down to an equation of variables- and I believe we have a lot of unknown variables here. Even if we take all of the variables you suggest out of the equation and declare them constant, how do you propose to quantify "design"? |
TransAm |
posted 09-09-2008 11:01 AM ET (US)
I think the simple response to this hypothesis is, well, it just doesn't really matter, unless of course, all boaters were relegated to simple cruising under the most ideal of conditions. In reality, most of us use our boats in a variety of conditions. We often compare propellers on boats to the tires on our automobiles. I do not suppose there are many automobiles or trucks in northern Michigan sporting mild weather touring radial tires you may find on south Florida automobiles, or SUV's with 160 MPH speed rated tires you might find on a corvette. Interchanging summer and winter rated tires, or tirs of other uses has become impractical. In that regard, I would not want to be pulling one or more water-skiiers with a boat full of passengers using a 2-bladed bronze prop barely able to make 5,000 RPM lightly loaded. There are a variety of "designer" props just as there are a variety of automobile tires, each designed for one or more such conditions. Choose the prop which best suits your needs, but there is no "catch all" prop just as there is no "catch all" tire. I suspect continually changing propellers based on the activity of the day would also be impractical, and often would have marginal, if any benefit. |
Tom W Clark |
posted 09-09-2008 11:04 AM ET (US)
I'm still wondering what a "Designer Propeller" is. Does anybody know? |
TransAm |
posted 09-09-2008 11:18 AM ET (US)
I went out on a limb and made an assumption is was anything but a 2-bladed bronze prop. |
Perry |
posted 09-09-2008 01:07 PM ET (US)
I think TransAm sums it up pretty good:
quote: |
cooper1958nc |
posted 09-09-2008 07:33 PM ET (US)
Mr. Clark, what are the design caracteristics of these propellers, other than their diameter and pitch? Enertia’s and probably a lot more than I can recall..
Says nothing whatever about whether you should have an "Enertia" or a "Mirage" or a "Rev." Thats my point. Not the diameter and pitch, but the "design" if it truly exists. Manufacturer's planned obsolescence, or actual value? You know, Cadillac convinced a lot of people they needed tail fins on the 1960 deVille. |
TransAm |
posted 09-09-2008 08:10 PM ET (US)
Mr. Cooper, I think the responses to your initial post are not meant to besmirch you personally, but simply to clarify what the purpose of this exercise might be in practical terms and what practical application it might have. As best I can tell, you are attempting to demonstrate that an old school propeller can be as efficient as a more recently designed propeller, or designer propeller as you call them under some undefined test circumstances. I would suggest that to accurately conduct this experiment would require a tremendous amount of resources not limited to multiple identical hulls, with identical set-ups, identical power, fuel flow meters calibrated similarly, etc., etc. in order to limit the influence of external factors such as wind, tide, altitude, temperature, etc. Because you have set only a 5% differential in comparative results, fuel flow would need to be computed to the nearest 1/100th. Instead of offering any direct evidence to support your hypothesis, you have asked the forum here to go out and conduct these experiments to refute a theory that has no data to support its basis. Reminds me of a professor dictating an assignment to his or her students. I enjoy learning, but I'm done with school. Given real world applications, the results of such an experiment would change nothing relative propeller selection for applications here, unless of course the results were so unexpected that a new wave of propeller design would be warranted. I suspect that would not be the case. |
Tom W Clark |
posted 09-09-2008 08:13 PM ET (US)
cooper1958nc, I will be happy to answer your questions to the best of my abilities once you have answered the questions I have already asked. |
an86carrera |
posted 09-09-2008 08:51 PM ET (US)
I personally have tried the Dolce and Gabana prop and it looks good on the boat every one asks where I got it...I like the attention. But, the Crocs propeller is such a smooth ride..I can't take it off. Len |
sosmerc |
posted 09-09-2008 08:53 PM ET (US)
When we discuss propellers, it really is alot like discussing tires. If you are a long-haul trucker you are pretty limited as to what is available and there really isn't a whole lot of difference in the "performance" from one to the next. On the other end, if you own a "performance car" and intend to drive it near its limits, there is quite a difference from one style and brand of tire. The faster a boat is capable of running, the more difference in performance one can expect from different propellers. You can push a non-planing barge with just about any type of propeller, as long as the engine can reach its peak recommended rpm range...as long as you are operating in that range I don't think there would be much noticeable performance difference between a 5 blade prop or a two blade prop. But if you have a planing hull I do believe there will be a very noticeable difference in performance between different styles (chopper, cleaver, round-ear, vented, non-vented, 2, 3, 4, 5 blade, etc)...assuming you reach the same WOT rpm....some will accelerate better, some will hold better in rough water, some will be smoother, some will manuever better in reverse. So, depending upon your personal goals, there is quite a difference from one prop style to the next. To find the very best prop for your needs requires alot of testing and trial and error. Merc offers alot of props that are "taylored" or "designed" for certain requirements and applications. I don't believe they are doing it strictly for marketing or the need for something new every year. The Enertia is a great example. They promised better top end performance pitch for pitch and my personal experience with that prop confirms that their predictions were VERY accurate. |
cooper1958nc |
posted 09-10-2008 10:19 AM ET (US)
"I do believe there will be a very noticeable difference in performance between different styles (chopper, cleaver, round-ear, vented, non-vented, 2, 3, 4, 5 blade, etc)...assuming you reach the same WOT rpm....some will accelerate better, some will hold better in rough water, some will be smoother, some will manuever better in reverse." Now we are getting somewhere. Which accelerate better and why? (Assuming in the comparison we are not just comparing different pitches.) Which "hold" better in rough water (I assume that means resistance to ventilation) and what design characteristics are involved? Is this subject to documentation or is it anecdotal? Smoother is usually associated with more blades. Easy to understand that one. Which maneuver better in reverse and why? And the original premise was: "I am talking about normal, everyday service. Like 20-35 mph, where almost everyone cruises." So, who has the slightest rational thought about the effects of a "chopper" versus a "cleaver" versus a "round-ear" (if that is really a "versus") versus other design characteristics? Well, why don't you believe that? Seems reasonable to me. |
sosmerc |
posted 09-10-2008 11:33 AM ET (US)
I has to cost Merc a great deal of money every time they develope a new propeller. And every time they add a new design it potentially takes away sales of their other designs which makes it even harder to recover their costs. So I have to think that they are seriously trying to improve and advance their prop technology for the benefit of their customers. I think Merc does an outstanding job with their propellers...even their aluminum props perform quite well. I will try and address some of the other questions when I have more time. Also, Merc offers a VERY good book about propellers and it explains alot about the different aspects of their prop designs and why certain props work better than others in specific applications. |
sosmerc |
posted 09-10-2008 04:27 PM ET (US)
Some good info here: http://sites.mercurymarine.com/portal/page?_pageid=126,48572,126_49291:126_49299&_dad=portal&_schema=PORTAL |
glen e |
posted 09-10-2008 05:18 PM ET (US)
Mercury's last new "designer" offshore prop was the "Enertia" in 2006. Their most recent inshore bass prop was in 2007 called the "Fury". It is 30% lighter than other bass props as it is made of X7 alloy like the Enertia. I consider that to be an advancement, not hype. I hardly see this a "marketing onslaught" with the satanic reason being to obsolete their existing ones and get you to buy a new prop. Leave that to Apple iPods.... |
cooper1958nc |
posted 09-10-2008 07:25 PM ET (US)
Ok, from the Mercury website, these claims: Revolution" Fury Enertia Mirage Laser Vengeance Tempest
How to separate the salesman's hype from reality? |
Tom W Clark |
posted 09-10-2008 07:44 PM ET (US)
quote: That's easy. Go run them. As I have been counseling folks to do for some time, you have to experiment and see for yourself. We can talk theory all day long, but in the end, the proof of the pudding is in the tasting. |
posted 09-11-2008 08:35 AM ET (US)
In the 20 to 35-MPH range, the biggest difference that likely will be noticed among propellers of different styles or families is the influence of the propeller efficiency on the boat's fuel economy. In this regard my suspicion is that the differences are due mainly to the speed being run compared to the speed for which the propeller was designed. For example, a high-rake three blade propeller with high pitch is probably designed to work best at higher speeds, higher than 35-MPH. If you cruise around at 25-MPH with this propeller it may not work at its optimum. On the other hand, a four-blade propeller of much less pitch might run very efficiently at 22-MPH on the same boat. The pitch designation is not very consistent. I can show you curves of boat speed as a function of engine speed which are almost identical, yet they are produced by propellers with pitch markings of plus or minus two inches. In some families, the "gain" is really just in having a propeller with more pitch than it has been designated compared to your existing propeller. To make an analogy to automobile tires, these propellers with their pitch understated are like buying a tire with slightly larger diameter. The bigger propeller or bigger tire will tend to improve fuel economy. |
cooper1958nc |
posted 09-11-2008 04:27 PM ET (US)
Ha ha. I have not heard one bit of theory. Nor any experimental results, at all. Jimh, I cannot imagine a lower pitch prop getting better fuel economy than a higher pitch prop at mid range cruise. If that has happened, I would like to see the fuel flows. As to "rake", well....it seems no one agrees what it does. Some say it lifts the bow (how?), some say it lifts the stern. Hmmmm. |
cooper1958nc |
posted 09-11-2008 04:31 PM ET (US)
"That's easy. Go run them" The "test-drive" is a salesman's dream. Hopefully, not everyone in the boat universe should have to test drive propeller. Science works by generating hypotheses, testing them, refining them, and using them to predict things. Now, I have a hypothesis, but it is not what the manufacturers say. There could be a lot of other hypotheses on these elements of propeller design. In addition, there is a great deal of testing in various sources, anecdotal and otherwise. Yet no one seems to have a clue. No synthesis of information. No theory of how it works. Just "go run it." O well. |
an86carrera |
posted 09-11-2008 06:00 PM ET (US)
I have driven many different props engines and gear ratio lower units mounted on the same boat and different boats. I CAN tell you this; THEY ALL FEEL DIFFERENT when rigged with any of the combinations listed above. Why don't you come up with some results from your testing? It seem's your the one who came here spouting your theories. Most of the scientific types I have known would have been testing different propellers in a well organized DOE. That way, your could prove to us that they are NOT DIFFERENT. Quit your nagging please. Len |
an86carrera |
posted 09-11-2008 06:09 PM ET (US)
And engine height as a heavily weighted variable. |
Perry |
posted 09-11-2008 06:33 PM ET (US)
Cooper throws his theories out and expects everyone else to prove him wrong. I think he should do some testing to try to substatiate his theories. Too much time in the classroom and not enough time out on the water. |
fishgutz |
posted 09-11-2008 08:21 PM ET (US)
"Go run them"? Where? Who's got the cash? There aren't too many dealers that Also, I think the differences will all result in some kind of compromise. If you get more top end you will lose hole shot. If you want a better hole shot you will lose top end. If you want better handling you will lose either top end, hole shot or both. If you want to have a lot of snacks in the boat and pull a 208 pound skier like me you're going to lose top end. If you want good economy you will lose hole shot and top end. Coop's post from the Mercury website about the different props is hilarious. All the props are best. They almost all claim the same things. The more choices there are the more people will think one is better than the other. I wish I could find it but jimh made a funny but true statement some time ago about the proportion of money spend to the percieved effect. I wish I could find it. Maybe he'll repeat it. Coop, as I said before I think you are right. |
Tom W Clark |
posted 09-11-2008 09:02 PM ET (US)
quote: No, there aren't. Who said anything about going to a dealer? In the last twenty years I have bought exactly one propeller from a dealer. It came on my brand new 1990 Johnson 150. Boy, some of you are dense. What do you think a discussion area like contiunuousWave is all about if not a place to share experiences and offer each other advice, maybe loan a prop for testing or sell a used one that is not longer being used. Where does this fear of trying something new come from? I just don't understand that. And for anybody who cannot afford a new propeller: powerboating is definitely NOT the hobby for you. As to Mercury's marketing being somewhat ridiculous, that is very true. I've made the same observation myself several times over the years; a lot of fluff that does not say much. There are some here who just regurgitate this stuff and offer it up as "advice" but if you want to know how a propeller will work for you, run it on your boat. The best advice about propellers comes from folks with similar boats and motors who have used the different propellers under consideration. Anecdotal personal experience is a powerful tool. No theories required. |
fishgutz |
posted 09-11-2008 10:24 PM ET (US)
TWC, So you agree. And where do you get your bushel basket of props if not a dealer? "A" new propeller? Coop is talking about dozens of props and their real differences. Also it isn't the fear of trying something new. Often it is the cost. There are probably 10 to 30 different props for my boat. Yeah, and Coop's point is what is the real difference? His point is that the differences are minimal in the same effective pitch. Like I said before it is mostly trial and error. Expensive trial and error. Lucky for me I ain't a tweeker. I have 3 props and use one 95% of the time. |
Marlin |
posted 09-11-2008 11:15 PM ET (US)
Well, for some performance data on two similarly-pitched props, I'll drag out my old post at http://continuouswave.com/ubb/Forum4/HTML/004868.html . Sorry, no fuel flow data. In this case the 16" Vengeance proved to have a greater actual pitch than the 17" Trophy Plus. Performance-wise, the vented 4-blade Trophy had much better acceleration, slightly less top speed, and a much smoother ride (can't really explain that one, but it was abundantly obvious in testing). Though as I said I don't have fuel flow data available, I can say that my average fuel consumption per hour or per mile has not changed significantly between the two props. -Bob |
Tom W Clark |
posted 09-11-2008 11:34 PM ET (US)
fishgutz, To be honest, I am not sure what cooper1958nc is talking about. For any given boat/motor there are not "dozens of props", there are a few good candidates. Here is how it goes. Somebody has a Boston Whaler with an outboard motor or two. They are curious if there is a better propeller than what they have now so they start a thread to discuss it. It there are hundreds of such threads of discussion here on CW. Owners of similar boat chime in with their experiences, much as Bob has just done. The advantages and disadvantages of the different props are discussed, performance data is shared and debated and sometimes a decision is made to try a different propeller. Sometimes that proves to be a good move and the results are shared as well. From all of this, a body of experience is built. A collection of experiences that anybody with the ability to search the archives can now access. It's a pretty good system. |
Marlin |
posted 09-12-2008 12:17 AM ET (US)
I might also add that, as others have said, the performance of a prop varies widely by the specifics of the boat. This summer I pulled the Trophy Plus off my 160 Dauntless and tried it out on Yiddil's 190 Nantucket with his 115 2-stroke. He generally runs an aluminum prop, but had done pretty well with a 16" Vengeance in the past, so I had high hopes for the Trophy. It was a disaster. With the larger, heavier boat, the Trophy ventilated wildly, produced very poor acceleration, and it seemed as if no throttle setting could produce a constant boat speed. I couldn't believe the difference in results as compared to my boat.
quote: I couldn't agree more. -Bob |
an86carrera |
posted 09-12-2008 10:53 AM ET (US)
I buy a lot of props. For the most part, they come from eBay and then go back on eBay. If you by them at the right time and sell at the right time they are near free or profitable. Two weeks ago I had 7-8 unused props at the house now I have 4-5 plus 2 on boats. Some of these will not be sold as they are spares or alternatives for different uses of the boats. I just don't get compromising on your source of drive force and connection to the water with all the other money that is tied up in your boat. Len |
Perry |
posted 09-12-2008 12:34 PM ET (US)
Len, I have done the same thing as well. I have purchased over 10 props on eBay {new and used} and ran them on my motor. If I don't like the way a prop performs. I put it back on eBay and sell it. It's a good way to test props and cost effective as well. |
TransAm |
posted 09-12-2008 12:43 PM ET (US)
Ditto. I have 5 sets of counter-rotating at present. The last 2 sets I sold on e-bay, I turned a profit based on what I paid for them. |
ratherwhalering |
posted 09-12-2008 02:05 PM ET (US)
I look at propeller dynamics the same way I look at beer. There's a basic formula that must be followed, and some predictable results, but the art is in the crafting. My preference depends on my goal...for speed, I'll drink microbrews, but when heavily loaded I'll drink Budweiser. |
cooper1958nc |
posted 09-12-2008 02:13 PM ET (US)
This is hilarious. The whole purpose of inductive reasoning is to understand basic principles. The "line" seems to be: there are no principles. Just go and endlessly test different propellers without having the slighest understanding of why any design is likely to help or hurt a given situation. In the middle ages, people lacked theores, by and large. Someone would put an apple in the window to see if anything happened. Maybe it did,maybe it did not. Anything was possible. The design of a propeller is part of the design of the package. The contribution of different design elements to performance goals is not a chance event. Or is it? Mr. Clark is, I think he will admit, in the business of selling propellers, so his bias should be clearly stated, and discounted, at the outset. Having said that, I am sure he has some knowledge of these things. So, lets start: 1. What are the variables in propeller design? I can think of several. The obvious: diameter and pitch. Rake. Blade area and blade count. Materials and thickness. Blade shape, including cupping. What are the others? 2. Now for these variables, how do they affect performance? pitch -- moves a smaller column water faster. Changes gearing. Etc. Rake -- Bow lift (?). Stern lift (?). Nice styling (?). Cupping -- increases effective pitch at higher RPM. May decrease tendency to cavitate. Blade area -- increasing decreases efficiency, but decreases cavitation tendency at high blade loadings The above is a start. Lets tap the knowledge base around here and see what is there. |
brisboats |
posted 09-12-2008 07:40 PM ET (US)
I too never pass on an opportunity to try a different wheel, guess I fall into the CroMagnon group. It must be my liberal arts background as I just could never compose a concise scientific test procedure. I rather just pick up there nearest rock and pound on a different prop and give it a whirl. If I am pleased with the props performance I have been known to pound my chest, stamp my feet and chant "prop good" while I scratch a line picture of it on the cave wall. Brian |
TransAm |
posted 09-12-2008 08:22 PM ET (US)
The theory behind a propeller design is perhaps very scientific. Since I am not a propeller guru, or a propulsion engineer, I will not attempt to explain it. However, in reality, the behavior of propellers is less so scientific. It has been stated here that the proof in the pudding, and the tasting-an accurate assessment. I have tested propellers that, in theory, should have behaved exceptionally on my boat, but did not, due to countless external influences which would be impossible to positively isolate. Theory, in terms of selecting precisely the correct propeller for your application, is somewhat unreliable, so why waste time harping on it. Theory is used in identifying a few reasonable candidates, and then testing them. If you don’t have the time, the money, or desire to see how different propellers actually behave are free to go buy some run of the mill propeller and be happy knowing you have the best propeller for your application. I see no benefit in attempting to prove a theory that, in practical terms, is impossible to prove. The theory presented here focused exclusively on efficiency, one of many components involved in propeller selection, and for many, given the small differences in comparative efficiencies, a less significant component of propeller selection. Any attempt in theorizing an absolute correct propeller absent going out and "running them" would be a waste of time. |
Perry |
posted 09-12-2008 10:54 PM ET (US)
Cooper, I'm glad you think this thread is funny.
quote: It appears that people here prefer to test propellers instead of discussing propeller design. If you want to learn about propeller principles, perhaps you should go read a book instead of looking for answers here. |
glen e |
posted 09-13-2008 08:56 AM ET (US)
I agree with Perry - this has all been for Coop's amusement. I'd be surprised if one of his physics students has not waited for him outside class and clocked him, as I'm sure he exhibits that condescening smirk in class that he exhibits here... |
posted 09-13-2008 11:06 AM ET (US)
quote: From page five of Screw Propellers and Estimation of Power for Propulsion of Ships. by Rear Admiral Charles W. Dyson, U.S.N. |
Tom W Clark |
posted 09-13-2008 11:29 AM ET (US)
cooper1958nc,
quote: No let's not. We are 59 posts into this thread and it is not going anywhere as you refuse to make your point. If you want to discuss the various design elements of propeller, that's great. I would enjoy a thread where that is the topic is discussion; I might learn something new. If you would like a discussion along those lines, then start a new thread with a title like: "What are the Different Design Elements of an Outboard Propeller and how to they Affect its Performance?" ...or perhaps a more concise topic of discussion such as: "Propeller Rake: What Does it Do for You?" Bt this thread was started by you and the title is: "Designer propellers: what gains?" If you have refuse to tell us what you mean by that. How can we have a discuss it? You have rambled on about this and that but the one consistent theme I pick up from you is: If something cannot be explained, it does not exist. That's not only illogical, it is silly. |
elaelap |
posted 09-13-2008 11:48 AM ET (US)
"My thesis is that fancy-schmancy propellers are not much different, where it counts, from old tried-and-true propellers...[a]ny scientific hypothesis begs to be proven wrong, and I would be happy to declare it false on proper evidence." Here's the real problem with this topic: Cooper proposes a thesis/hypothesis without any supporting facts and then challenges anyone to prove it wrong. This flies in the face of classical rhetoric as well as the scientific method, where the proponent of a thesis/hypothesis has the obligation of proving it up factually, in a manner which can be tested and confirmed by others. Cooper has it backwards. Here's an example of what I mean: My thesis is that fancy-schmancy astronomy has it all wrong, and the sun actually revolves around the earth (or that the world rests on the back of a huge turtle, etc)...now you prove me wrong. Nope, that's not the way it works, Cooper. Advance your hypothesis, support it with facts which can be verified by others, and let those who disagree state their position. It's impossible to deal with the other way around, and you should know better as a retired engineer. Tony |
Tom W Clark |
posted 09-13-2008 11:49 AM ET (US)
quote: Again, you are wrong. I am in the business of designing and building homes and improvements to homes. One of my recent hobbies, an offshoot of my love of boats and Boston Whalers in particular, is the study of propellers, particularly propellers for outboard powered boats like my own. This interest came about after purchasing my Revenge 25 Walk Around four years ago. Subsequent to the purchase of this boat, I never gave any great thought to the propellers on my boats apart from making sure they were stainless steel and appropriately pitched. With the purchase of the Revenge 25, fuel economy suddenly took a higher priority. Additionally, a new boat always brings a certain curiosity about speed and what the ultimate top speed of one's boat might be. At this point I really started to follow discussions of propellers more closely researching what had been written about different props here on the forum. Having never been a believer in aftermarket propellers being anything more than merely less expensive, I was surprised to consistently hear about these propellers called Stiletto. I decided I wanted to buy a pair for myself and see how great they are. To that end I contacted my find who had an account with Precision Propeller as he had offered them to me at a deep discount. In the end he suggested I just open my own account with Precision and contacted them on my behalf to set it up. So I opened my own account with Precision and can now offer a good deal on any Stiletto or Turbo prop to folks here on the forum. I have done so numerous times. My goal is to be helpful and perhaps learn something new from the feedback offered with each new trial. It has worked out well for everybody. If you would like to replace the fancy-schmancy Mercury propeller on your Optimax powered Bayliner with a run-of-the-mill Stiletto, I can help you out ;-) |
ratherwhalering |
posted 09-15-2008 05:19 PM ET (US)
quote: HA. Tom is hardly in the business. Tom owns a sucessful and productive construction business. For those of you that have bought Stiletto propellers from Tom, I can tell you with absolute certainty that you should be thanking him from the bottom of your pocketbook. |
