ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance 2009 Suzuki DF70/80/90 series
Author | Topic: 2009 Suzuki DF70/80/90 series |
rbulwa |
posted 09-06-2008 02:14 AM ET (US)
I am curious whether anyone has seen the new Suzuki 4-strokes announced for 2009. I am considering buying and re-powering an '85 Montauk 17, and while I was very happy with the 1998 Johnson/Suzuki DF70 on the Whaler I sold last year, these new engines are lighter and the DF80 or 90 might be even better. A dealer told me he has no information on the engines, but the Suzuki website has information about them in the section directed toward the media, which is easily accessible by anyone. Anyone out there know anything about availability? Thanks. Bob |
Perry |
posted 09-06-2008 02:45 AM ET (US)
Looks like a good repower choice for a classic Montauk. 348 lbs. http://media.suzuki.com/marine/product09/dloads/df70_80_90_productinfo. pdf |
Tom W Clark |
posted 09-06-2008 01:46 PM ET (US)
I do not see the weight listed anywhere in the specifications section of the .pdf linked to above. |
cyclops |
posted 09-06-2008 02:09 PM ET (US)
Tom It's there, the sixth line down on the specs. It took me a minute to find it when I looked at it also. |
Tom W Clark |
posted 09-06-2008 02:17 PM ET (US)
There it is. #41 pounds for the 20" shaft length. Note weight is with the battery cable but without the engine oil or propeller. How many quarts does it hold? |
Tom W Clark |
posted 09-06-2008 02:20 PM ET (US)
341 pounds without oil. It holds four quarts. How silly is it to list a motor's weight without the oil? It's not as if you are going to use the motor without oil in it, or as if different oils have different weights. So why don't we just cal it 350 pounds for comparison's sake. That's pretty darn good for a 90 HO four stroke. How much does Mercury's Fourstroke 90 weigh? |
Casco Bay Outrage |
posted 09-06-2008 03:46 PM ET (US)
Mercury's FourStroke 90 hp's dry weigh is 399 lbs, :~) |
sraab928 |
posted 09-06-2008 05:47 PM ET (US)
So for 4 stroke 90HP motors its... Suzuki 350 pounds - Fuel Injected ** Honda's new EFI 90 lists 365 as the weight for the 25 inch shaft - they only list 20 inch shaft as a tiller model - 359 pounds
For 2 stroke 90HP DFI you have Evinrude E-TEC - 320 Pounds
