ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Compression Testing
Author | Topic: Compression Testing |
lizard |
posted 10-16-2008 10:38 AM ET (US)
What tools are required to perform compression testing on a V6 Evinrude, circa 90's? Is this something the average individual with a hands on background to some auto maintenance can do? What are ideal readings for a motor like this? Thanks, in advance, for any input! |
Tohsgib |
posted 10-16-2008 11:09 AM ET (US)
Depends on the year but anywhere from 90-110 seems to be the norm. Guage accuracy varies as well. So my gauge might read 95lbs and yours might read 85lbs. Go to ANY autoparts store and for $25 you can buy a tester. Remove all the plugs, screw it in to a hole and have somebody turn it over a few seconds until needles stops going up. Write it down and move on to the next hole. All holes should be with 10% or so. Make sure you remove the safety lanyard so the wires do not spark. |
lizard |
posted 10-16-2008 09:14 PM ET (US)
From your response, it would appear that I do not need muffs on the boat, with water supply, to check the compression. I suspect that the motor might be a Ficht. Other than the known concerns with some Fichts, is there anything else I should look for besides the lower end oil? thanks. |
posted 10-16-2008 09:44 PM ET (US)
A procedure for performing a compression test is described in my article Assessing Used Outboard Motors |
posted 10-16-2008 09:45 PM ET (US)
To assess a used outboard, see the recommendations in my article Assessing Used Outboard Motors |
Peter |
posted 10-17-2008 07:32 AM ET (US)
Exactly what model Evinrude V6 are you looking at? You will not be running the engine when you are doing a compression check so there is no need for muffs. If it is a Ficht, then it would be wise to have a qualified technician take a look. The technician will be able to plug a laptop into the EMM and determine what trouble codes have been set, how many hours the motor has been run and how the engine has been run over those hours. |
Tohsgib |
posted 10-17-2008 12:36 PM ET (US)
If it is a ficht evinrude then 1999 or newer. So when you say circa 1990's are you sure it is a ficht? If it is a 1999 it better be darn cheap and if a 150-175 I would basically want it for free. |
Blackduck |
posted 10-17-2008 04:58 PM ET (US)
The engine should be warmed up to normal operating temperature before doing a compression test. |
posted 10-17-2008 05:29 PM ET (US)
Re engine temperature for compresssion testing--this is mentioned in the article I suggested above. |
lizard |
posted 10-17-2008 10:34 PM ET (US)
Many thanks for the responses. I got an email tonight that the boat went to another buyer. However, I will keep the links inserted above, as a reference for if/when the next opportunity arises. Thanks again. |
