ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Effect of Oil Sump on Four-Cycle Engine Efficiency
Author | Topic: Effect of Oil Sump on Four-Cycle Engine Efficiency |
posted 12-18-2008 02:25 PM ET (US)
I am not a motor racing enthusiasts or a high-speed boat racer, and it never occurred to me that in four-cycle engines there might be some influence on the overall engine efficiency from the design of the engine oil sump and crankcase. The first time this came to my attention was when Mercury Marine explained some of the refinements to their Verado motor they introduced c.2007 in what has come to be known colloquially as the "Gen II" (or "second generation" of the product). In an interview with BoatTest.com published in July of 2007, Mark D. Schwabero, then the president of Mercury outboards, said that the improvements included: --Precision Machined Oil Dams in the Crankcase. By greatly reducing the clearance between the crankshaft and the “oil scrapers”, the amount of oil mass that the crankshaft had to push through and swirl around was also reduced, thus releasing more usable horsepower. --Eccentric Grooved Crankshaft Main Bearings. This slight change, too, reduced the amount of oil “sloshing” around in the crankcase--and thus robbing power.... Cf.: http://www.boattest.com/resources/view_news.aspx?NewsID=286 There is also a video in which a similar presentation is made by Steve Miller, Verado Platform Manager of Mercury Marine. Mr. Miller explains that the fundamental basis for the improved performance of the Verado was the simple reduction of friction in the engine itself. The power saved from those losses goes right to the propeller shaft output. Cf.: http://www.boattest.com/flash_video_player.aspx?vol=50&video=mercury/ verado_walkaround ) Is the increase in engine efficiency by these crankcase modification and oil sump designs related to what I often see mentioned as a "dry-sump" engine? I've seen that term used on more exotic racing engines. Do these refinements have more influence at higher crankcase speeds than lower? I notice that the Verado engines tend to be able to run at 6,400-RPM. Does that high speed create a situation in which the oil sump design is more important than it otherwise would be in an engine that only ran at 5,000-RPM? |
posted 12-18-2008 02:30 PM ET (US)
Also, in the case of the Mercury Marine Verado specifically, are these refinements in the crankcase design only in the 200-HP four-cylinder and 300-HP six-cylinder engines? Or were they added to the other models in the Verado line, too? Were they added to the non-Verado FOURSTROKE motors (the so-called Veradito or L4NA or "the non-supercharged FOURSTROKE motors based on the Verado block) as well? |
posted 12-18-2008 10:42 PM ET (US)
About four minutes into the video (link given above) Mr. Miller mentions that the reduced friction designs are applied in all of the Verado motors, not just the 200-HP and 300-HP top-of-the-line models, and thus that answers one of my questions. How do the "dry sump" racing motors handle lubrication? |
an86carrera |
posted 12-18-2008 11:05 PM ET (US)
Dry sump motors scavenge oil from the crankcase constantly and send it to a reservoir where it can be pumped through a cooler and back to the bearings and valve train. This saves the resistance of turing a crankshaft though the oil bath. Sort of like running your outboard higher to reduce resistance. All of the aircooled 6 cylinder Porsche engines have dry sumps. Len |
posted 12-19-2008 10:37 AM ET (US)
Based on Len's description, can you say that all two-cycle motors are dry sump motors? |
posted 12-19-2008 10:49 AM ET (US)
[To keep the discussion on the topic (four-cycle engine crankcase designs to reduce friction) I have removed several off-topic comments--jimh] |
glen e |
posted 12-19-2008 01:39 PM ET (US)
A 2 cycle would be a "NO sump", I think - are we having fun yet? |
SC Joe |
posted 12-19-2008 10:55 PM ET (US)
Actually, doesn't the latest model year E-TEC--notice the correct spelling--return unused oil to its reservoir? That would make it a type of dry sump engine wouldn't it? |
posted 12-19-2008 11:17 PM ET (US)
Joe--Are you saying that in order to improve the Verado to the Gen II level they emulated the E-TEC (and all other two-cycle engines)? |
Peter |
posted 12-20-2008 09:00 AM ET (US)
Mercury describes the lubrication system for its 4-stroke motors between 40 HP and 300 HP as "integrated dry sump". Below 40 HP, they are characterized as "wet sump". Yamaha, Honda and Suzuki describes their systems as "wet sump". I'm not sure what the difference is between an "integrated dry sump" and "wet sump". A sump is the place where used oil collects for reuse in a recirculation loop. 2-strokes do not recirculate lubricating oil use a sump although there is some recirculation of oil that collects through recirculation hoses. The E-TECs do not use a return oil line. The FICHTS use a return line. The FICHT's lubricating system using a return line is analogous to the fuel return line in a fuel recirculation loop of a modern automobile fuel injection system, not a lubrication oil recirculation loop of a 4-stroke outboard. In the case of an automobile fuel system, the fuel is flowed in a loop from the fuel tank to the fuel pump and then back to the fuel tank. A varying portion of that fuel is diverted to the fuel injectors based on demand. In the FICHT lubrication system, oil is flowed in a loop from the oil tank, to the oil lift pump, to the oil injector and then back to the oil tank. A varying portion of that oil is diverted to the oil injectors based on demand. The recirculation rate in an automobile fuel system is very high as compared to the oil system in a FICHT outboard. |
posted 12-20-2008 09:44 AM ET (US)
Because of the vertical orientation of the crankshaft, I would expect that the oil sump of a four-cycle outboard motor would exhibit different behavior than the oil sump of a similar motor when used in a vehicle with the normal horizontal orientation of the crankshaft. It seems to me that gravity would be an important influence in where the oil tended to go in the sump. I am assuming that when the Mercury engineers speak of oil "sloshing" in the sump, they aren't talking about a big pool of oil sitting at the bottom of the sump, but rather they are talking about oil distributed in the crankshaft area in general. I envision the crankshaft turning in a thick mist of oil. Then I envision the improvements made in the Verado crankcase design to contribute to directing this oil mist away from the sump or into a lower portion of the sump, or in some way cutting down of the amount of oil suspended in the region where the crankshaft is revolving, and in this way the friction of turning the crankshaft was reduced. |
Jefecinco |
posted 12-20-2008 11:10 AM ET (US)
Interesting. For the Verado perhaps the difference is that without some work to reduce the amount of oil "mist" in the way of the crankshaft throws there would be some resistance to turning and some power/performance loss. I'm thinking of an aircraft flying in a heavy rainstorm vs flying in dry air. It seems to me that for a given airspeed in rain more power would be required than in dry air. Is that a correct assumption? Butch |
glen e |
posted 12-20-2008 03:03 PM ET (US)
I am not technical enough to explain it in specifics but you are on track. At the tech session we had in July of 2007 with the powerhead designers and the person in the video, the "friction reduction" (their term) efforts of the Gen II were indeed made to knock down the "oil cloud" that hovered above the sump and restricted the performance at higher RPM. |
Peter |
posted 12-20-2008 07:13 PM ET (US)
How much actual HP is robbed by not having the oil dams and grooved crankshaft bearings of the GEN II? I bet its not that much. If its a large amount, say 15 HP, why not apply these techniques to the 75 to 115 HP FOUR STROKE (AKA Veradito or LN4A) line? That would enable the 115 to be bumped up to 130 HP and then allow Merc to get rid of the Verado 135 which has a horrible power to weight ratio and allow for a cheaper, much lighter motor in the 130/135 HP segment? |
glen e |
posted 12-20-2008 07:22 PM ET (US)
A fair question, but the gen II technology - if that what you want to call it - was not to renovate the performance of the verado. but to get the gph burn more in line with the competition, and to move the high burn of a supercharged engine to the extreme top end (>5500). They accomplished that, as the Gen II's now hang with their counterparts thru the 4000-5000 range re fuel burn. |
Peter |
posted 12-20-2008 07:58 PM ET (US)
"....was not to renovate the performance of the verado, but to get the gph burn more in line with the competition...." This is just another way to say they improved the efficiency. Improving the efficiency means that you get more HP for the same fuel consumption rate. So, for example, for a fuel burn of the GEN I 225 you now get 250 HP out of the GEN II, 300 out of a 250 etc. No matter how you look at it, they did "renovate" the performance of the GEN I. To get the improved performance, however, they did much more than just change the above mentioned lubrication structures. They made a significant metalurgical change from cast to forged pistons, changed the intake cam profile, changed the PCM programming. I suspect that all of this was done so they could lean out the fuel mixture above 5000 RPM without burning up pistons. |
SC Joe |
posted 12-21-2008 10:27 AM ET (US)
Jimh wrote: >>>Joe--Are you saying that in order to improve the Verado to the Gen II level they emulated the E-TEC (and all other two-cycle engines)?<<< Uh..hardly. The E-TEC isn;t like all other 2 stroke technology (as been preached on this forum ad nauseum). Do any other current 2 stoke engines do what the E-TEC does in regards to oil distribution? Dry sump oil systems have been used on 4 stroke engines to improve performance and serviceability probbaly since about 10 minutes after the four stroke was proven to be a viable engine. Racers, both road course and sraight line, have been using that 'technology' since racing began. Merc just borrowed the concept from the past to gain similar results. |
SC Joe |
posted 12-21-2008 10:30 AM ET (US)
Peter wrote: >>>The E-TECs do not use a return oil line. The FICHTS use a return line. The FICHT's lubricating system using a return line is analogous to the fuel return line in a fuel recirculation loop of a modern automobile fuel injection system, not a lubrication oil recirculation loop of a 4-stroke outboard. <<< Interesting. The Evinrude employee who explained the E-TEC lubrication system while touring the Evinrude factory on Ship Shape TV was wrong. |
Peter |
posted 12-21-2008 05:40 PM ET (US)
I didn't see the ShipShape TV show but if there are any doubts that the E-TEC doesn't have a FICHT's return oil line, I suggest reading this Evinrude publication www.evinrude.com/NR/rdonlyres/CD515371-3E86-4EE1-99D9-15C689486AF2/0/ ETEC_115__200_Backgrounder_42705.pdf . See page 4 where it says "There is no return line in the system". |
SC Joe |
posted 12-22-2008 09:28 AM ET (US)
Interesting. There seesm to be quite a bit of misinformation available regarding the E-TEC, on here and even from Evinrudes employees. [Moderator's note: In so far as possible, there is no known misinformation presented on CONTINUOUSWAVE about any topic, except perhaps in the course of discussions where the topic involves an exchange of theories and hypothesises. The allegation that CONTINUOUSWAVE contains misinformation about the E-TEC in particular is particularly silly. There is probably no better place to find information on the E-TEC than CONTINUOUSWAVE, as most of the information presented here comes from experts or from BRP publications. Introducing this specious discussion into the middle of another topic is typical of the intention to disrupt the current discussion, or to make an inference about the website's general credibility. This participant would find his remarks to be more acceptable if he stayed on the topic of discusison. Again, we are discussing the effect of design changes in the oil system and crankcase on the efficiency of four-cycle engines--jimh] I also find it interesting that this white paper states that V4 and V6 models support NMEA 2000, but does not mention the smaller models. I have read on other forums where these instruments have been placed in use with the those engines as well. [Moderator's note: Please let's not wander to NMEA-2000 as a topic. Move that inquiry to SMALL BOAT ELECTRICAL.] |
an86carrera |
posted 12-22-2008 09:55 AM ET (US)
An oil return line to the tank is not the subject here. The Fichts don't have one either, I own one of each of the DI Evinrudes, Ficht and E-TEC. There may still be a scavenging system in the crankcase, I am not sure but thought there was a methodology to use the extra oil the crankcase. It would seem logical to return it to the pump system for oil? Len |
SC Joe |
posted 12-22-2008 09:59 AM ET (US)
My thought as well, Len. |
posted 12-22-2008 10:33 AM ET (US)
It seems to me--perhaps an uninformed opinion--that by removing the surplus oil from the oil sump in a four-cycle engine the designers are moving it toward a environment that is inherent in a two-cycle engine, that is, a crankcase in which there is not a excess of oil. In this regard, this improvement in the four-cycle crankcase seems like something that is more or less inherent in the two-cycle design. I am also very confused by SC Joe's account that the improvement engendered in the Verado by the second generation ("Gen II") refinements is something that has "been used on 4 stroke engines to improve performance and serviceability probbaly since about 10 minutes after the four stroke was proven to be a viable engine." Again, to me this seems odd. If the technique has been known for so long and is in such wide use, why did it take two generations of Verado design to implement it? Clearly the people behind the Verado must have been aware of this. |
Peter |
posted 12-22-2008 11:47 AM ET (US)
Len -- Both of my 2002 Ficht 225s have an oil return line to the oil tank. SC Joe -- The referenced article is about 4 years old. The smaller model E-TECs were not NMEA 2000 compatible when they first came out. |
an86carrera |
posted 12-22-2008 12:24 PM ET (US)
whoops, Peter you are correct. So does my 2000 200hp. |
SC Joe |
posted 12-22-2008 01:16 PM ET (US)
Jimh, I can't answer why Merc didn't use dry sump oiling in their first Verado designs. Perhaps they didn't think the added complexity of such a systems was needed, or maybe, even more simply, they didn't think about it's use in their application. Maybe a marine application doesn't easily lend itself, for whatever reason, to it's use. Most factory built high performance automobiles don't use a dry sump oiling system, even though a few horsepower could be gained with it's use. Why not? Some don't even have the simpler to install and use crankshaft windage trays. Why not? They can add several horsepower just by keeping the oil from sloshing on the crankshaft. I would imagine cost for both was a big reason, and designing the necessary plumbing for a dry sump system would certainly add cost and complexity. |
jeffs22outrage |
posted 12-23-2008 10:16 AM ET (US)
Jim, The term for your loss of efficiency is referred to in the automotive world as PARASITIC LOSS. http://en.wikipedia.org/wiki/Parasitic_loss The all of the moving engine internals like the crank shaft and other bearings, valve train (which 2 strokes do not have), alternator and oil create smaller parasitic losses that add up however, the supercharger pulls a more bigger figure. Probably greater than all other losses combined. |
posted 12-26-2008 01:04 AM ET (US)
I wasn't the first person to ask the question about why the VERADO engine was not originally designed to use a dry sump technique and some other improvements that were made in the so-called Gen II models. In an interview with boattest.com, Steve Miller, Verado Platform Manager, was asked the same question. His reply:
From: http://www.boattest.com/Resources/view_news.aspx?NewsID=287 |
towboater |
posted 12-26-2008 03:36 PM ET (US)
great winter topic. Lil footnote here; My small engine mechanic Pete (40 years exp) is one of the nicest guys you could want to know. I just needed a diesel fuel filter for a gen set the other day, Pete was in the middle of rebuilding a 2 stroke weed eater and I started poking around...we started talking about 2 and 4 stroke engines, (Im still learning too Jim) he said, "the nice thing about 2 strokes, they always use FRESH OIL" With that, the comments on this topic have made a lot more sense to me. Thanks all.
posted 12-27-2008 04:15 PM ET (US)
The notion that the oil in a four-cycle is recycled in the motor while the oil in a two-cycle is fresh is incidental to the discussion. We're talking about the crankcase design and how it can affect efficiency, and not about the age of the oil in the crankcase. Based on what has been presented here by people who accord themselves as being really familiar with the topic, I have learned: --the dry sump or reduced oil sump design has been known to engine designers since the very earliest stages of the four-cycle internal combustion engine, or for about 100 years; --the dry sump or reduced oil sump design has been used in four-cycle internal combustion engines for about 100 years. However, in spite of that, --literally no production automobile high performance engines use the dry sump or reduced oil sump design, and this is believed to be because the added cost and added complexity of the design; --the initial Verado design did not employ a dry sump or reduced oil sump design because (according to the Mercury people involved) their priority was on "the utmost in reliability and durability." From these assertions (of which none are mine) I make the inference that using a dry sump or a reduced oil sump is perhaps moving away from the utmost in reliability and durability, that is, a lubrication system which bathed the crankcase in oil might lead to greater reliability and durability, but at the cost of some performance. This notion is similar to the one I have heard put forth about the inherent advantage of a four-cycle motor having a pumped oil system in which moving components were generously lubricated with oil. In opposition to this is the notion that in a two-cycle motor there is a minimum of oil, just a thin film of oil, covering the components, and that lubrication is not excessive. There is just enough lubrication to do the job, and no excess of oil. This seems to be to be the goal of the dry sump designs. I used to think of a four-cycle crankcase as being full of oil, oil everywhere, oil dripping and sloshing around--all those beautiful parts just drenched in lubricating oil, endlessly being pumped, filtered, cooled, and recirculated. After learning about this dry sump oil crankcase system, my image of a four-cycle motor has changed. I see it now just like a two-cycle direct injection engine, where in whose dry sump a small amount of oil is carefully distributed and pump to precise points that need lubrication. The crankshaft is not turning in a cloud of oil. I think we describe this: 2 = 4 |
SC Joe |
posted 12-27-2008 08:50 PM ET (US)
Those are interesting...'observations' that aren't exactly correct from what was written. I'm just waiting to see how JimH stuffs an E-TEC engine JimH in his perfect GM car. |
tmann45 |
posted 12-27-2008 11:17 PM ET (US)
quote: From the Mercury website: quote: And the 2004 Service Manual shows a sump seperated from the crankcase by the adapter plate in the 2005 Model Year engine. Don't know if they changed the sump design with the other improvements, but nothing is mentioned about changing the sump design. Oil Flow Diagram available that shows the sump in the Gen I engine. |
posted 12-28-2008 09:57 AM ET (US)
Thanks for cutting and pasting the text from Mercury about all the other changes in their product, and while that information is interesting, it is outside of the topic, which, again, is the oil sump and crankcase design in a four-cycle engine. All those changes, however, do give us a chance to see how much revision was made in the Verado to get to Gen II configuration. Boy--a lot of stuff was revised. Of all that text, the portion that bears most on our discussion is this: "Mercury developed an enhanced power train for the Verado line that gives consumers increased fuel efficiency and power without sacrificing reliability." (Emphasis added.) This is great news, really. It means that the old-fashioned four-cycle designs where the crankcase is bathed in oil are not really necessary. If you think about, two-cycle motors have been operating like this for decades, so it should not be a surprise that you can get reliability without drenching everything in oil. |
AlioopII |
posted 12-28-2008 11:22 AM ET (US)
Jim, You need to do some research before you write! The Chevrolet Corvette Z06,(which last time I checked was a production vehicle) uses a dry sump oil system. I know that if mercury added a dry sump system to a Verado it would add a lot of weight and a significant amount of hardware to package under a engine cowl. Mike |
SC Joe |
posted 12-28-2008 12:15 PM ET (US)
Alioop..I haven't been here that long, so I am still trying to make sense of the moderators seemingly relentless pursuit of arrogantly attempting to prove others incorrect, whether it be in concept, or just on simple syntax. I expect this to be edited or deleted in order to reflect that pursuit, so I hope you get to read it before hand. Jimh intentionally mistated that "literally no production automobile high performance engines use the dry sump or reduced oil sump design, and this is believed to be because the added cost and added complexity of the design", in response to something I typed above. I say he intentionally mistated what I said because he did...I stated: "Most factory built high performance automobiles don't use a dry sump oiling system, even though a few horsepower could be gained with it's use." The keyword I used there That JimH purposely ignored was 'most'. I think it had previously been mentioned that Porsche uses a dry sump system in some of their engoe designs. I would imagine other exotics like the Ferrari Enzo and probably a handful of other purpose built production performance cars do as well, but I can not confirm this. I do know that most production autombiles that are marketed to be performance oriented do not. |
tmann45 |
posted 12-28-2008 05:46 PM ET (US)
The purpose of the paste from the Mercury website on the changes to the Verado was to show that Mercury did not discuss any changes to the oil sump to increase efficiency in the improved motors. The oil dams are in the main block area around the crankshaft, as shown in the video link. It appears that Mercury did three things to reduce the power lost due to oil floating around the engine: 1)eliminated the piston cooling oil jets, 2)improved the oil dams, and 3)eccentric grooved crankshaft main bearings. These three things helped reduce the amount of oil suspended in the crankcase. I don't think any change to the sump design was made. |
posted 12-28-2008 09:41 PM ET (US)
As I pointed out, none of the four assertions I made above was mine, and if my restatement of one them altered its intended meaning, you have my apology. Let's examine exactly what has been alleged as a "seemingly relentless pursuit of arrogantly attempting to prove others incorrect." So far about all I have done that might have possibly caused SC JOE to become so upset is that I changed his observation that "most" cars don't use a dry-sump design. Now "most" can mean anything from 51-percent to 99-percent, and I don't think that "most" is really a good characterization of the ratio of wet sump to dry sump designs in production automobiles. It certainly is not 51:49. Out of maybe 500 models of cars, so far two have been proposed, and the production volume of those cars is so small it hardly would show up in terms of an overall percentage of production cars with dry-sump four-cycle engines. Thanks for the data point that a high-performance street race version of the Corvette uses a dry-sump engine. I don't think that really changes the mix of automobiles between dry-sump and conventional-sump by any large percentage. As I understand it, it can now be said that at least one production automobile uses a dry-sump design somewhat similar to the Mercury Verado, albeit a very expensive high-performance version of a production car that is sold in limited quantities. I have to disagree with the interpretation that the changes to the crankcase design (and here I am lumping this in with the "oil sump") were not intended to improve efficiency. Mercury spokesmen have said that these oiling changes improved efficiency. Perhaps the oil sump itself was not changed. That is not really of concern to me. Perhaps my initial topic should have included the word "crankcase," too. From my perspective, I see a lot of hair splitting here. I am just speaking in general terms. Mercury is using a oil sump or crankcase design that is not in wide spread use in automobiles, and so far the only examples cited have been in what I would characterize as exotic cars--Corvette and Porsche special edition cars are not exactly in high production. The dry-sump approach was not undertaken in the original design, which Mercury has said was focused on "reliability and durability." I think it is reasonable to make an inference that if a dry-sump was not used in the original design, and the goal of the original design to was maximize "reliability and durability," then it is hard to make a case that changing to a dry-sump design was done to improved "reliability and durability." Mercury does state that the new design did not reduce "reliability and durability," but that is hardly a surprise. Any spokesman for a company that made a public statement that their new product had reduced "reliability and durability" would be fired on the spot. However, my logic may be flawed, so I will leave it to the experts to pronounce that the move to a dry-sump design was done to improve reliability and durability. Please explain the mechanisms involved. The primary conclusion I have drawn from this discussion has been to discover that the evolution of the Verado to its second generation model seems to have followed an approach to the crankcase oiling that has been used in two-cycle motors, that is, a reduction in the amount of oil to the minimum necessary. The secondary conclusion that I have drawn from this discussion is that apparently there is some reticence to discuss it, or the discussion of it seems to upset some people. I note that almost immediately Glen asked, "Are we having fun yet?" As if somehow the notion that this would be discussed is already frivolous. Perhaps it is of no concern to Glen, but it is interesting to me. And that's why I initiated the discussion. The relentless pursuit of CONTINUOUSWAVE is to collect good information, and in that process I often use my own judgement about information that is presented. If someone says "the moon is made of green cheese," there should not be offense taken if that notion is called into question. That's how we separate "dock talk" from factual information. |
SC Joe |
posted 12-28-2008 11:05 PM ET (US)
A couple corrections JimH.. I'm not upset...and never have been. I find that description of anything I have typed or even my mood as odd, at best. And I'm not changing any observations on how many cars use/don't use dry oil sump designs. How could I? I copied and pasted my own comments as evidence that showed that! Again..not sure how you came to that specious conclusion. Regardless..I stand by "most cars" do not use a dry oil sump design. Simply, most cars don't. I do not have an exact count on how many that do, versus how many that don't, do you? Since I don't, and I think since it might be difficult (and really pointless in this example) to obtain that number, I think "most" summarizes that description pretty well. You seem to look to find an issue where there is none, and disagree..as typical. I often find your "relentless pursuit" of "collecting good information" seems to be the correction of trivial descriptions--your own "trivial pursuit", so to speak. In the past, you've needlessly corrected me on the syntax of "E-TEC", the correct use of the "HO" in the E-TEC "HO", and on Mercury engine model year designatons (regardless and in opposition of what my state gov't mandates). While these topics might be important (to someone, somehow..I suppose), they certainly can't be considered material or even important by almost anyone. In contrast, I've never seen you edit anyone on the correct use or elimination of "F" used in the description of the four stroke Yamaha "F150", or the "C" in a premix Yamaha "C115", or even the "DF" when used to describe a Suzuki four stroke engine. Is there a semantic difference that's not obvious to me? One person might say the problem is an Evinrude/Mercury bias, while someone else might say it's simply a personality clash that you seem to have. Were the latter the case, I'm certain it would be simple enough to ban me from posting. What is your opinion, JimH? |
posted 12-29-2008 08:08 AM ET (US)
Joe--My opinion is you have lost the argument about the oil sump and you now wish to change the subject to one which focuses on how I manage the website. If you want to have that discussion, please find a different place to conduct it. |
SC Joe |
posted 12-29-2008 09:04 AM ET (US)
LOL..But what was that argument again, Jim? Are you stating most cars DO have a dry sump oiling system? |
posted 12-29-2008 09:40 AM ET (US)
Based on the representations made by Joe and others, my assessment is that--speaking figuratively--just about no production cars use a dry-sump. So far only two models have been mentioned, and they're both limited-production exotic versions of limited-production sports cars. They're a tiny tiny fraction of production cars. Regarding my use of the term "sump" to refer to the general arrangement of lubrication and crankcase design, in this regard I follow the practice of Mercury. They use the term "integrated dry sump" to describe these engines. I don't think my use is significantly different or misleading. In the initial sentence of the article that begins this discussion I included the word crankcase: "... in four-cycle engines there might be some influence on the overall engine efficiency from the design of the engine oil sump and crankcase." While the precise nature of the oil sump itself may not have changed or may not have influenced the efficiency of the engine, the changes in the crankcase design and its lubrication have influenced the efficiency. Indeed, that is the whole focus of the discussion. |
bobgilsp |
posted 12-30-2008 01:32 PM ET (US)
I thought performance automobiles used dry-sump lubrication in order to avoid oil starvation during hard cornering. In a hard turn, the oil in the sump will be forced to the outside wall of the sump. If there is no oil pick-up tube at that site, the pick-up will suck up air instead of oil. There could be enough loss of lubrication to damage bearings and other friction points. The old air-cooled Porsche 6 cylinder engines used dry sump lubrication, but required 12 quarts of oil. The newer, water-cooled Porsche boxer 6 cylinder engines might have a different system & require fewer quarts of oil. But they are still designed to keep oil flowing during hard cornering.
Tohsgib |
posted 12-30-2008 01:37 PM ET (US)
That's a Porsche. I doubt a Kia Sephia is running a dry sump. Most just use baffles to slow down the sloshing. |
SC Joe |
posted 12-30-2008 10:32 PM ET (US)
Tohsgib posted : >>>That's a Porsche. I doubt a Kia Sephia is running a dry sump. Most just use baffles to slow down the sloshing. <<< Easy with "most". It's apparently not a good descriptor. What is probably the highest quantity produced transportation that uses a dry sump oil system? Harley Davidson. |
Tohsgib |
posted 12-31-2008 11:28 AM ET (US)
Whew!!! I thought you posted highest QUALITY....my bad! |
number9 |
posted 01-03-2009 09:59 AM ET (US)
It will be interesting if the Verado improvement actually do come "without sacrificing reliability". It appears the new crank bearings may not provide as much lubrication. |
95Outrage17 |
posted 01-03-2009 03:30 PM ET (US)
I wonder the same thing as number9. I don't like the sound of Mercury removing the Gen I Verado's piston oil coolers. They did change to forged pistons though. I've owned five Volvos cars now and my first two where 1991 740s which both had the nearly indistructable B230F engine. They also both had very noticable "piston slap" when cold which was common to those engines until the 1993 model year when Volvo added piston oil cooling jets. It's very uncommon for those later engines to have the piston slap problem. I must say though, it was more an annoying noise (sounded like a diesel at idle) then the signal of an engine's demise. I sold one of the 740s over three years ago working great with 411K km (260K mi) on the orignal engine. I've seen the car driving within the last two months. My point is that the oil cooling jets helped reduce the wear that caused the pistons to "slap" in their bores. I wonder if the Verados may be similar. It seems that sometimes efficiency has a negative effect on longevity. The other changes made to the Verado may have compensated for this though. Relating to the dry sump discussion; Aren't many Porsche engines known for their good combination of performance and longevity? Also, a good friend of mine owns a 2007 Yamaha Waverunner FX Cruiser HO that has a 1000cc dry sump lubricated motorcycle engine. That machine is light years ahead of the old 2-stroke jet skis (which I always found noisy). - Chris |
itl |
posted 01-05-2009 07:22 AM ET (US)
"I thought performance automobiles used dry-sump lubrication in order to avoid oil starvation during hard cornering. In a hard turn, the oil in the sump will be forced to the outside wall of the sump. If there is no oil pick-up tube at that site, the pick-up will suck up air instead of oil. There could be enough loss of lubrication to damage bearings and other friction points." I think this is the main reason why dry sump is used.
Well, water cooled 911 GT2/3 and Turbos are using dry sump, but other naturally aspirated M96/97-generation engines are using wet sump system what Porsche actually calls "integrated dry sump oiling". |
number9 |
posted 01-07-2009 12:37 AM ET (US)
A real dry sump engine? Look at the old school recip radial engines on DC3s and many other historic aircraft. One of the early French designed radials actually had the cylinders rotating around a fixed crank shaft. Just prior to the turboprop and jet age the premier radial was a four row of 7 cylinders each, 28 total. Obviously a wet sump was not an option. Any claims that Verado is some way a modified dry sump design is misstated. To my knowledge the is not a return or scavenge pump involved to return oil to sump and it uses gravity as the others. |
number9 |
posted 01-07-2009 06:36 AM ET (US)
FYI, checked the Merc site for unrelated reasons and decided to see their four stroke oil system descriptions. Currently 40hp up the term "integrated dry sump" is used. Possibly Merc believes since they lack a separate oil pan and use the drive shaft housing as their oil sump it's a catchy thing to call it. Same basic set up as the Yamahas I know of except they have a separate oil pan bolted through the adapter plate into the block rather than depending on the housing to block bolts to seal the sump. Upside is some increase in oil capacity. Downside seems to be the potential for gasket failure from drivetrain vibration or failure. The 30hp and below are referred to as wet sump, hopefully those are not just slinger lube systems and probably have a shallow oil pan. |
