| Author | Topic: Does Ethanol Reduce Horsepower? |
| Ridge Runner |
[Nota Bene: the values for BTU/Gallon cited are in dispute. The calculation of percentage difference between them is not correct. See below for further discussion and perhaps more accurate values--jimh.] A 9:1 gasoline and ethanol mixure has 84.2k BTU/Gallon and regular gasoline 125k BTU/Gallon, a 3.4% difference. Does the horsepower of an engine see a 3.4% reduction? I've read that the 3.4% will effect MPG, but does a outboard have 3.4% less horsepower? |
| Peter |
Here is information taken from a Gasoline Gallon Equivalent (GGE) Table Fuel Type |
| Tohsgib |
In other words...yes. |
| TransAm |
Wow, I figured there was some insignificant effect, but 3-4%, that's significant. Other than introducing more fuel in the combustion chamber, can this loss of power be reasonably recovered? |
| Tohsgib |
Yes...fill up at a marina that does not have ethanol. My marina also has stabilizers and water absorber additives in it. It is only like $.30 more than the pump. |
| TransAm |
What if your marina is E-10? |
| Tohsgib |
Should not be...go to a different marina. I am 99% positive that [ValvTect] fuel is non-ethanol so look for it. |
| L H G |
So, I assume outboard engines are rated for HP on pure gasoline? I doubt the manufacturers would be so magnanimous to rate them on E-10. I guess that means if you buy a 300 HP engine, immediately you are only getting 290HP. Then add in the 10% allowable "fudge factor" up or down, and you could really be getting a lot less HP than you are paying for. A 300 could only be putting out 260HP. If we go to E-15, which we probably will, all of us will need to be buying more HP than we think we really need. If one is going to buy a 225, probably a 250 should be bought instead. A lower pitch prop might be needed on existing engines. Just another cost to consumers of "going green". I thought all internal combustion engines needed to be modified if more than 10% ethanal is used? |
| Buckda |
Isn't it "ValvTect"? http://www.valvtect.com There is no information on the site that indicates that they do not use the ValvTect additives in E-10 fuels. The company makes fuel additives and blend them in with the fuels. JimH likes to refer to this as a "witches brew" when individuals do this to their fuels, but I'm a fan of finding your own blend that makes you feel better. Many marinas sell fuel that is not "ethanol enhanced" - but not all. |
| Ridge Runner |
Down in Port Charlotte, FL I can fill up with [ValvTect] fuel which does not have ethanol, I have verified this. In NJ all fuel has ethanol, its state law. In Wisconsin they have ethanol in regular and mid-grade and premium is ethanol free. It’s interesting I have two carbureted Yamaha two-cycles a 90hp and a 50hp and I have run both fuels in each, I can tell the difference. When I pull skiers it “seems” to take longer to get someone up, also the mid-range to full throttle-up “seems” different. Now on my 25’ CC w/twin Yamaha F115’s and Conquest w/twin Mercury Optimax 225’s I don’t really notice any difference. I’m not sure if it’s because they are larger boats or because the EMM’s that control the fuel flow through the injectors are compensating. |
| Buckda |
Also - I'm no fan of ethanol - but there are some interesting companies that are investigating synthetic fuels. The US Air Force is investigating jet fuel from RenTech - a California company that has a proof-of-concept refinery manufacturing synthetic Jet and Diesel fuel for research purposes. This fuel has more energy per pound than petroleum -derived fuels and can be generated for a profit at about the equivalent of $70/barrel oil prices. Feedstock can be biomass, agricultural bagesse or oil/natural gas. They claim that there are no modifications needed for current motors and the fuel can be delivered via pipeline (not truck/train, as is required of ethanol for transport). Not cheap, but there are companies working on alternatives that don't rob the energy. Hopefully we'll at least have some other options in the next few years. |
| TransAm |
Maybe that guy with the Rib boat and 300 E-tec is burning straight ethanol? |
| Ridge Runner |
Can a supercharged engine that is operating by forced induction and compressing the air/fuel mixture compensate for the energy difference? |
| BQUICK |
Don't forget about the loss in MPG also...... |
| weekendwarrior |
No use of ethanol will not by definition reduce horsepower, but you will need to burn more of it to get the same horsepower. On an closed-loop FI engine the computer will handle this for you. On a carbed engine your jetting might not be optimal as-is so you've got a 50/50 shot. Consumer Reports compared a truck (Chevy Tahoe I think) on e10 and e85. For both fuels performance was virtually identical but the mileage on e85 was significantly worse. See the test at consumerreports.org. ASIDE: nitro methane is less energy dense than gasoline, BUT you can burn about eight times as much of it with the same amount of air (the nitro is already oxadized). The top fuel dragsters burn nitro because they can burn so much more of it than they could gas that it more than makes up for the difference in energy density. |
| weekendwarrior |
Just a follow up, here's a link to one of the articles about ethanol tests on consumer reports, and an excerpt from the article: http://www.consumerreports.org/cro/cu-press-room/pressroom/archive/2006/10/0610_eng0610e85_ov.htm?resultPageIndex=1&resultIndex=3&searchTerm=e85%20test
"Overall fuel economy on the Tahoe dropped from an already low 14 mpg overall to 10. In highway driving, gas mileage decreased from 21 to 15 mpg; in city driving, it dropped from 9 mpg to 7."
URL: Test results: E85 vs. gasoline
E85 GASOLINE* |
| Jerry Townsend |
Easy guys - There are a couple of issues being discussed - energy content, which is based on energy per pound - and mpg - which is based on energy per gallon. Talking of energy performance and milesage in the same sentence is akin to comparing apples and oranges. Talking about energy alone - gasoline has an average combustion energy of about 20,300 Btu/Lb while ethanol has an average combustion energy of about 12,800 Btu/Lb. Therefore, E10 has about 0.96 of the energy content of gasoline and E15 has about 0.94 the energy content of gasoline. Since the fuel flow rates are about the same, the horsepower ratios are as given above. Now, when talking about mpg - or some other measure involving volume such as gallons or ... - the density of each fluid becomes a factor. The density of ethanol is about 49 Lb/CuFt while the average density of gasoline is about 44 Lb/CuFt. So - E10 will give about 0.97 the mileage of gasoline. E15 will give about 0.96 the mileage of straight gasoline. Incidently - the governing relationship is: mpg And frankly, when one factors in the cost of all farming operations and refining - there is a marked energy expenditure in using any form of ethanol. The controlling factos - political, emissions, political, greed and political. ---- Jerry/Idaho |
quote: Something is wrong in the math here. E10 = 84,200 BTU/Gallon Difference = 40,800 BTU/Gallon Expressed as a percent of difference with respect to Gasoline, E10 is 40800/12500 = 0.3264 x 100 = 32.64 percent lower |
| seahorse |
Using EPA information, gasoline contains about 114,500 BTU per gallon, and ethanol contains about 76,100 BTU per gallon. So a gallon of E10 would contain about, 0.9 * 114,500 BTU + 0.1 * 76,100 BTU = 112,000 BTU of energy. This is 3.4% less energy than normal gasoline. |
| seahorse |
0.9 * 114,500 BTU + 0.1 * 76,100 BTU = 110,660 BTU |
It looks like the fundamental problem in the initial statement is that the values given for the BTU/Gallon are in error. ORIGINAL VALUES PROPOSED: E10 = 84,200 BTU/Gallon VALUES SUGGESTED BY seahorse: E10 = 110,660 BTU/Gallon Using the actual values we see a difference of 3,840-BTU/Gallon. Expressed as a percentage, this would be 3840/114500 = 0.0335 x 100 = 3.35 percent. So the initial values are wrong in regard to the energy content, but the suggested percentage difference is correct. I will append a note to that effect to the original article to make this clear. |
| Jerry Townsend |
The numbers I used are from established engineering handbooks as: Gasoline : 20300 Btu/Lb, 44 lb/cuft, => Ethanol: 12800 Btu/Lb, 49 lb/cuft => Then, the energy content of: gasoline: 119,403 Btu/Gal E10 : 19,550 Btu/Lb or 115,299 Btu/Gal I have no idea where those other numbers are coming from - not only the energy (heat of combustion) but the density - as as I mentioned above, when talking about performance in gallons - the density is involved. --- Jerry/Idaho |
| weekendwarrior |
All number crunching aside, I think the questions in laymans terms are (1) will ethanol reduce my hp, and (2) will ethanol reduce my mileage. The answer is, for closed loop fi your hp should not change but your mileage will decrease. For carbed and open loop fi your hp will likely be reduced and we have not yet seen any imperical data for mileage. |
Jerry--Thank you for the clarification on the source of your data. I am inclined to accept it as more accurate. |
| seahorse |
quote:
quote:
quote:
MIT Engineering even has a higher number, 138,500 BTU, as shown in the following link: http://engineering.mit.edu/ask/question.php?id=39
http://www.epa.gov/oms/rfgecon.htm
To clarify, I don't trust the EPA to tell us about ethanol. The credibility of our government in regard to accurate information about ethanol is not very good in my opinion. An engineering handbook written without a vested interest in ethanol being successful is probably more trustworthy. |
| seahorse |
I agree with you, Jim. Because there is such a wide variation in gasolines, for ICOMIA horsepower certifications and for emission testing, a reference fuel is used so that each test is repeatable and everyone has to use it for consistancy. To control the test process and keep all This fuel has known hydrogen-carbon contents and is reproduced in consistent known |
