posted 05-18-2009 08:18 PM ET (US)
The only real operational advantage for a boat owner in using a propeller with a plastic hub coupling is the notion that in the event of a failure of the hub it could be replaced in the field. Of course, this assumes you are carrying a spare hub plastic insert with you at all times, that the failure of the hub will be in a way that you can replace the failed component, and that the time and place of the failure will be convenient for you to perform the replacement.I have found that propellers with rubber hubs have smoother and quieter shifting. I have never had the occasion to need to replace a hub in the field. If the hub fails due to a propeller strike, there is a very good possibility the propeller will have damage to the blades, so whether or not the hub is replaceable becomes a moot point; you can't use that propeller anyway.
The most advantageous situation for a propeller with a plastic replacement hub is when the hub fails due to too much torque on the propeller shaft. This generally only happens on very high horsepower, high torque engines. You will not be twisting the hub on a propeller with just normal engines and normal use. If you have a very powerful engine, and you run the boat in unusual circumstances, such as running at high speeds in large waves where the propeller comes out of the water and re-enters the water at high speed, you might twist the hub. But in normal operation, most boaters never spin or twist a rubber propeller hub. It is not that common.
The plastic hub inserts are also prone to melting. If they melt in place you may not be able to easily replace them in the field. A melted plastic hub may need to be chiseled out of the propeller.
I carry a spare propeller with me. If I had a propeller strike or if I spun the hub on the main propeller, I would just change to the spare.
Many propellers are made only with a design that requires a plastic hub, so you may not have a choice if you want to use a particular propeller and that is the only way it is made.
I currently own four propellers. Three have rubber hubs and one has a plastic hub.
The other advantage to a boat owner with a plastic hub propeller that is available for many brands is at the time of sale. If you want to sell a propeller, and it can be fitted to almost any motor, it gives you more potential customers to sell it to. In this way, you have the same advantage the manufacturer had when he sold the propeller.
