Topic: Amsoil vs Evinrude XD50 vs Evinrude XD100
Smithsm |
posted 05-18-2009 02:00 PM ET (US)
I happen to sell a lot of Amsoil in our auto shop and can get the HP Injector oil at a good price. I like amsoil products and use them whenever I can. BUT....My evinrude dealer tells me the original FICHT oil is not what they call the XD50 - not the SD100 which is more for the E-Tec outboards. Both outboards are obviously DFI two cycles -but apparently use different oils. He tells me that when an E-Tec comes in they need to tell the onboard compute which of the two oils the owner will use because it will use 40% less if they tell it to use the XD100. Apperenly this all matters. What I don't know is if Amsoil HP Injecter Oil is more like the XD50 or is better or worse. All I want to do is use the best oil available. I have to believe you guys have an opinion. Thanks in advance.
Buckda
posted 05-18-2009 02:12 PM ET (US)
Hmm..interesting question. So, let me be sure I have it straight: your Evinrude dealer says that you should NOT use XD-50 in your FICHT engine? Does he recommend XD-100, or does BRP continue to market the FICHT-RAM injector oil? I would think that XD-100 would be serviceable in a FICHT or any motor. The XD-100 is expensive - you use very little in the E-TEC, but I'd hate to burn it at 50:1 or even 100:1 ratios, although I've done it in my 6 HP Evinrude and my brother's 50 HP Mercury. Regarding your core question, I do not know enough about amsoil's product to comment on "equivalencies" in relation to XD-50 or XD-100. |
Peter
posted 05-18-2009 02:28 PM ET (US)
XD-50 is the replacement for FICHT RAM OIL which was the recommended oil for the Fichts. You can use TCW3 XD-30, XD-50 or XD-100 in a Ficht although you'd be wasting money using XD-100 with a Ficht. I use XD-50 in my 225 HP Fichts. The regular TCW3 oils leave too much residue on the prop hubs. I don't know anything about the Amsoil injector oil but why take a chance to save a buck or two? |
Smithsm
posted 05-18-2009 03:26 PM ET (US)
My evinrude dealer says the XD50 is the replacement for the FICHT oil.He was not sure about where the Amsoil HP Injector fell into the range of oils - was it more like the XD50 or the XD100 - and since they dial in the E-Tecs for whatever oil will be used apparently it matters. |
Smithsm
posted 05-18-2009 03:31 PM ET (US)
PeterI agree that it is not worth risk here. The reason I am trying to figure it out is two fold: 1. the pure synthetic Amsoil products beat every other product in every other test I have seen and they have proven their worth in our auto shop with problem situations. they are so smooth they lower operating temps by 20 degrees. we have seen it many times. 2. I happen to have 4 gallons of the product. but - it is not worth the risk unless I am certain it is good for the engine. and right now I am anything but certain - except that the type of oil matters. thanks for you insights. also - what octain do you burn in your FICHT 225 and what year is it ? I don't have my engine manual but from what I know I should be burning perhaps an 89 octain even though it is supposed to only need 87. the dealer tells me I will have less carbon buildup at 89 or higher - and my head mechanic on the auto side says the dealer is right. |
Peter
posted 05-18-2009 06:00 PM ET (US)
I have model year 2002s. I burn whatever is available at the dock. I think its 89 octane these days. It used to be 93 until gas prices spiked. Makes no difference. Regarding oil, the manufacturer's oil has additives that they claim are formulated for their motors. For me, it's not worth saving a buck. You should consider doing a decarb procedure on your motor. Another easy thing to do. Just buy a can of Engine Tuner and follow the directions on the can. Make sure you have a way of killing the motor while spraying the Tuner into the engine because they have a tendency at the right RPM to run away (spike up in RPM) on you. |
deepwater
posted 05-19-2009 06:33 AM ET (US)
This sounds like dealer vs manufacturer,,The dealer wants to sell product that exceeds requirements by a lot,,contact the development area for that model and ask if the Amsoil is OK,,It seems on most of the gas powered things i have bought over the years that the instruction manuals say ,,recommend this or minimum that or meet SAE or API something,,so anything thats better but not excessive would be OK |
Smithsm
posted 05-19-2009 07:49 AM ET (US)
I appreciate the input just to be clear on one thing - since it has come up twice now.using Amsoil is NOT motivated by cost savings. If I wanted to save money I would use the cheaper Evinrude products. Amsoils is a premium, full cost product which happens to outperform every other manufacturer's product in other catagories and other applications. But - we all know the FFI technology is a bit different. So the question is - can a use a product that exceeds the XD50 oil. My concern is that the XD100 also is more expensive but DIFFERENT. so this just isn't that simple my dealer can't even get it straight and consistent between their senior peopple on how to index the spark plugs so they are no help. thanks again folk. right now I plan on using the SD50 - and it costs less than the Amsoil. but I am not doing it to save a buck - I am doing it to play it safe. |
seahorse
posted 05-19-2009 08:00 AM ET (US)
The XD-50 is slightly different than the original Evinrude FICHT Ram oil from 2001. When Bombardier become the owner of Evinrude, they had different suppliers and specifications. The XD-50 is better than the old Ram oil. Read your owners manual. It specifies a TC-W3 certified oil. Unless it just happened, Amsoil is not certified by the National Marine Manufacturer's Association, NMMA.
Amsoil "says" their oil meets TC-W3 specs, but that is marketing, it is not on the approved list by NMMA. Go to NMMA.org for the list of TC-W3 oils. In their defense, Amsoil makes good products and thier synthetic 4-stroke oils is one of the few that made the NMMA's FC-W rating, which is the 4-stroke version of TC-W3 certification. In your FICHT, use at least the XD-50 oil for minimum carbon buildup and good protection. XD-100 is the absolute best oil, but more expensive, for your motor as it is a full synthetic lubricant. |
posted 05-19-2009 09:08 AM ET (US)
I use XD-100 in my 10 year old FICHT. I've been using it since learning it was available. I've always used Evinrude oils for my engine. Prior to switching to XD-100 I was using XD-50. Some light sooting was observed on the propeller hub while using XD-50. After switching to XD-100 no soot nor oily residue is seen on the propeller.The extra expense of the XD-100 is minimal and if the only benefit is that it is not necessary to periodically decarbonize my engine it is very well worth it. I recommend you use XD-100 oil in your FICHTs. Butch |
Smithsm
posted 05-20-2009 09:03 AM ET (US)
Thanks again guys.as of right now the plan is to use XD100 because I believe it to be the best available that is approved. as a follow-up I plan to call Amsoil and talk to the technical folks and ask them why they are not approved and why they say they are and are not listed at the site below http://www.nmma.org/certification/programs/oils/registeredoil.asp?y=TCW32008 I do not have this relevant info for outboards - but I do have it for snowmobiles - in the case of snowmobiles the rebuilder and big time snowmobiler I know gets into a ton of two stroke snowmobile engines that are run hard and he claims that amsoil is the best in terms of measurable wear and carbon buildup. but my 22 is an outboard, not a snowmobile and my FICHT has specific needs that may be different. I will report back what amsoil tells me. |
Peter
posted 05-20-2009 09:25 AM ET (US)
I use XD-50 and run a can of Engine Tuner through the engines periodically (about every 50 hours). |
weekendwarrior
posted 05-20-2009 09:35 AM ET (US)
I am familiar with Amsoil from the motorcycle world, good stuff. Have you tried calling Amsoil tech support with your question? They just might be honest. Sure they want to sell oil, but I think they prefer to keep a good reputation and I wouldn't think they would give the OK unless they really think the oil is good for your situation. |
Smithsm
posted 05-20-2009 09:36 AM ET (US)
I called Amsoil techinical 715 399 8324 -this is a number for dealers. We are an amsoil automotive shop so they took my call and talked to me at lenght. the service is intended for existing dealers - of which I am one.here is what they told me and showed me what to read. 1. they know they are not listed with NMMA TC-W3 and do not go through the test for one, and only one, reason - once an oil is tested it cannot be modified or tweeked in any way and that includes changing suppliers. this is OK for the large volume guys who lock in and do not typically keep improving the product available to the consumer until they make a major change with associated marketing rollout etc. Amsoil says they constantly improve products and will not lock themselves into the constraints of this system of approval. 2. The HP Injector is a direct replacement for the XD50 evinrude product that is 100% synthetic and will burn cleaner and cooler and works very well in a FICHT. 3. The HP Injector is NOT a replacement and is NOT intended to be used for XD100 applications. 4. Amsoil makes a product known as SABER which is a 100 ratio 100% synthetic product but it also is NOT recomended as a replacement for the XD100 becuase while Saber is an excellent 100:1 ration two stroke oil it is for premix only as the XD100 oil has a significant viscosity change from other 100 oils to match it to the unique injector characteristics of the evinrude motors calling for XD100 (e-tecs?). product info - www.amsoil.com/lit/databulletins/g1986.pdf CONCLUSIONS based on a long discussion with the technical department at amsoil. 1. HP Injector is a fine 100% synthetic replacement for XD50 but should NEVER be used to replace XD100. the fact that they are both synthetic is irrelevant. they think the HP Injector is better than the XD50 which is also a quality oil. the point is they are both good and compatible. 2. There is a big difference in viscosity between XD50 and XD100 oil beyond (1) the increased synthetic of the XD100 over the XD50 and (2) design for 100:1 ratio. Amsoil outright says ONLY use the XD100 oil for an evinrude XD100 engine - not their Saber 100 two stroke product. 3. I don't know what this all means for FICHT users who use XD100. I know using an XD50 oil in an XD100 application is bad - but I dont' know about going the other way - and nor did the technical guy at amsoil who otherwise knew alot about the evinrude oils. He did say the viscosity is different for each engine for real reaspons. For what it is worth, I believe both companies are Wisconsin companies so they are probobly very familiar with each other. I hope this information is helful.
Smithsm
posted 05-20-2009 09:41 AM ET (US)
Petercan you tell me exactly how you run the engine tuner through your engine? my local dealer told me to spary it directly into the air intake. but this came from the same buy who was 100% wrong on how to index the spark plugs |
Peter
posted 05-20-2009 09:44 AM ET (US)
What your dealer said. You just spray into the six air intake evenly and alternatingly (same as if spraying fogging oil). Then shut the motor down and let it sit for a while to "cook off" the carbon. |
Peter
posted 05-20-2009 09:45 AM ET (US)
Further, you need to pull off the air box in front of the six air intakes to do it. There is an oil collection hose and an ambient air sensor connected to the air box that need to be disconnected and of course reconnected when you are done. |
hauptjm
posted 05-20-2009 09:53 AM ET (US)
Has anyone used and/or is there a benefit to using either XD50 or XD100 in old fashioned OMCs with VRO, say from the mid 90s? I've always used the TCW3 oils. Just curious! |
seahorse
posted 05-20-2009 10:24 AM ET (US)
quote: Has anyone used and/or is there a benefit to using either XD50 or XD100 in old fashioned OMCs with VRO, say from the mid 90s? I've always used the TCW3 oils. Just curious!
Many people use the two premium oils, both premixing or with "VRO" systems.
The XD-50 smokes much less than regular oils and keeps the carbon buildup to a soft coating, not hard chunks. The XD-100 is virtually no smoke at all, and keeps the combustion chambers and exhaust chambers super clean. |
deepwater
posted 05-20-2009 11:10 AM ET (US)
Great info on the Amsoil,,i have been using it in all my trucks and cars for several years,,thanks for the info |
Smithsm
posted 05-20-2009 11:35 AM ET (US)
quote: -------------------------------------------------------------------------------- Has anyone used and/or is there a benefit to using either XD50 or XD100 in old fashioned OMCs with VRO, say from the mid 90s? I've always used the TCW3 oils. Just curious! --------------------------------------------------------------------------------As a slight expansion on the comments from the technical guy at Amsoil for XD50 vs. XD100 in different outboards: 1. the older carb outboards, and the FICTH outboards were designed for a 50:1 oil and in the case of FICHT it had a specific viscosity for the FFI system. using a 50:1 pure synthetic oil is a great idea in my mind. amsoil makes a good one in HP Injector. 2. I believe XD50 is a partial synthetic - a "blend" not 100% synthetic. many auto oils also are blends to reduce cost. http://www.evinrude.com/en-US/Accessories/Product.htm?product=XD50&category=Oil IMHO not the best idea - a pure synthetic is better (and this has been demonstrated in tests using aircraft oil analysis services to measure very small levels of engine metals in the oil.)
3. XD100 appears to be pure synthetic and absolutely requires evinrude to reprogram the engine to use it appropriately and has a different viscosity than the XD50 (the viscosity would not matter for pre mix but apparently does matter for direct injection) http://www.evinrude.com/en-US/Accessories/Product.htm?product=XD100&category=Oil 4. From my related 2 cycle experience (not outboard) - pure synthetic will burn cleaner with less smoke - so using the XD100 in an XD50 application would be expected to have less smoke. I believe the smoke is unburnt hydrocarbons in particulate sizes seen by the human eye. synthetic oil has much more uniform structure and so it should produce much fewer large size particulates in the form of smoke - but particulate sizes in exhaust are not the only relevant indicator of an oils performance 5. My intuition tells me that using an oil intended for a different ratio is not optimal and smoke is not necessarily the best way to evaluate this as a pure synthetic will almost surely always smoke less - but simply moving to a pure synthetic of different viscosity is not necessarily the right thing to do - especially if you are not premixing. the evinrude engineers changed viscosity for a reason and if the different viscocity were "discovered" to be better for everyone then I expect they would have changed it accross the board. I plan to use either XD50 or amsoil HP Injector for my engine that was designed for 50:1 oil with these oils viscosity. the HP Injector will smoke less because it is a pure synthetic.
DutchMN
posted 06-02-2009 09:21 PM ET (US)
Guys:This is a great thread, very informative. I just bought a Crestliner 2050 with a 1999 Evinrude 150 hp Ficht. I knew about the issues but decided to go ahead because it was a super deal (if I have to re-power, it wouldn't be the worst thing in the world). I watched it start and run for a minute or two on two different occasions. The motor seems to be running all right. I'm not sure if the powerhead was ever serviced or replaced (it has the manila card outlinging the "important upgrade" PN 5001213). Obviously, I want to do what I can to keep it running for as long as possible. After reading the whole thread, I think I agree with the last post... I will use the HP Injector or Evinrude XD50. Does anyone have any preference on the engine cleaner or will any off-the-shelf do? Any other helpful tips on the fogging procedure? It doesn't sound too difficult. |
newt
posted 06-03-2009 09:41 AM ET (US)
Seahorse, Can XD-50 oil be mixed with XD-30 or would the remote oil tanks need to be emptied first? |
Jeff
posted 06-03-2009 10:03 AM ET (US)
I always have burned XD50 in my 1985 235 Evinrude VRO as well as my 1974 Evinrude 85hp starflite. Virtually no smoke. |
L H G
posted 06-03-2009 11:54 PM ET (US)
Are you guys saying I can use XD100 in my conventional Mercury 2-strokes, carb or EFI, and get no idle and start-up smoke at all, just like an Optimax or 4-stroke? That would be amazing. |
seahorse
posted 06-04-2009 12:57 AM ET (US)
XD-100 has hardly any smoke at all at 50:1, but it will puff a pale blue in a heavy concentration such as in a flooded engine. |
seahorse
posted 06-04-2009 01:03 AM ET (US)
quote: Can XD-50 oil be mixed with XD-30 or would the remote oil tanks need to be emptied first?
It will mix fine, but to get the maximum benefit, run the oil tank low before adding the xd-50. Just for routine maintenance, it would be a good idea first to check the bottom of the oil tank for water, slime, debris, etc. by using a turkey baster with a 6" piece of fuel line at the end. |
andygere
posted 06-04-2009 02:03 AM ET (US)
quote: Are you guys saying I can use XD100 in my conventional Mercury 2-strokes, carb or EFI, and get no idle and start-up smoke at all
Larry, it's true, however your outboards will slowly begin turning white... Sorry, I couldn't resist! |
L H G
posted 06-04-2009 02:11 AM ET (US)
I will give it a try in my in-line sixes, pre-mixing 50 to 1, and let you know. A while ago, I tried Pennzoil 100% synthetic, and it smoked worse than the regular stuff.Andy, in FL, I have recently seen several boats with white painted triple Verados. Blasphemy! I have seen black painted Yamahas, but as of yet, no black painted E-tecs. White E-tecs are scarce enough! |
Jeff
posted 06-04-2009 09:00 AM ET (US)
Larry,I am not sure the cost benift of running XD 100 would be there. If I were you I would try XD 50 first and see how much less smoke you get. |
Smithsm
posted 06-04-2009 10:13 AM ET (US)
LHGI believe your older style outboard will not give the complete combustion that is part of the reason these newer models smoke less I believe the older outboards don't just dump unburnt fuel out due to valve/reed timing - I believe the older outboard also can't burn all the fuel as well and I believe partially burnt fuel increases smoke and reduces fuel efficiencey |
Jeff
posted 06-04-2009 10:23 AM ET (US)
Smithsm,As I stated above, I use XD50 in my 1974 Evinrude 85hp V4 as well as my 1985 235hp Evinrude V6. The reduction of smoke is very noticeable running XD50 over other oils. Many times I have been out with others here on this board and they often remark at the lack of blue smoke from the motors. |
seahorse
posted 06-04-2009 10:24 AM ET (US)
quote: I have seen black painted Yamahas, but as of yet, no black painted E-tecs.
There are special edition dark colored E-TECs, graphite colored, for the special edition Ranger bass boats.
Genmar has a bunch of those in stock right now. Hope they make it. |
Smithsm
posted 06-04-2009 10:30 AM ET (US)
Just to clarify my combined comments - I think there are two different points being "mixed".1. Synthetic oil or paritally synthetic oil should reduce smoke compared to non synthetic due in part to more consistent molecule size (and perhaps improved additive formulation?)- all other things the same (like in the same engine). seperately 2. Older style outboard do not offer as complete a combustion as DI outboards which is why the newer outboards have higher fuel efficiency and better environmental ratings - so using even pure synthetic may reduce smoke compared to non synthetic oil - but the old style engine will probobly not be as smoke free as a new DI engine. |
Smithsm
posted 06-04-2009 10:33 AM ET (US)
this is news to me.... I dont' know if it is totally legit or not. [Link and cut-and-paste deleted, for two reasons: first, this was already recently posted by this author in another discussion; second, repeatedly linking to information tends to enhance the visibility of the information. Since the authenticity of this information is seriously in doubt, I do not see any reason to participate in the enhancement of its visibility--jimh.] |
andygere
posted 06-04-2009 03:40 PM ET (US)
The use of XD-100 in a carburated 2-stroke is getting my interest. The only real complaint I have (other than the black paint job) with my trusty old 1989 Mercury 15 is the smoke and smell when trolling slowly with a tailwind. Since oil consumption in this motor is so low, the incremental cost of using the more expensive XD-100 is minor and may be really worthwhile. And for just a few dollars, I can buy a rattle can of BRP white paint and have it matching my E-TEC in not time at all. Perhaps that would be blasphemy, but on a much smaller scale... |
John from Madison CT
posted 06-07-2009 12:01 PM ET (US)
I've switched back and forth between regular and synthetic oils for years. No problems to my engines. |
Smithsm
posted 06-17-2009 09:21 AM ET (US)
my local Evinrude dealer's son runs a big FICTH on his bass boat. the Evinrude rep told the dealer that his best bet is to use the CD100 oil rather than the XD50 and don't worry about the viscosity difference - to ignore the adjustment issue for the FICHT that they make on the E-Tec.I just got off the phone with Evinrude to confirm this advice. Evinrude said two important things I want to pass on. 1. XD100 is the best oil for a FICHT BUT....... 2. He said it is critical to do a full and complete, almost excessive decarb job before switching. He said the XD100 would break up the carbon left by the XD50 but not in small pieces. He said it breaks up the carbon in LARGE pieces that can cause problems. My conclusion - switch to pure synthetic XD100 (or amsoil HP Injecter) AFTER doing a super complete decarb job. |
sandhammaren05
posted 01-31-2010 11:20 AM ET (US)
On the question of using XD-100 in older outboards. A friend races the early 1990s era V-6 @9000 RPM with oil injection disconnected, uses XD-100. This does not mean it's ok to use it at low RPM, see this discussion:http://www.sea-doo.net/techarticles/oil/oil.htm The point is that 33% higher combustion temperature is required to get rid of the ash in XD-100, so there could be a problem with older motors at least at low to moderate RPM. I've run XD-100 in our 1983 Johnson 35 @ 6100 RPM @ 37.5/1 mix. With one heat range cooler plug (L2-G) the plug runs slightly wet and dark and the motor spits/misses in a strange way if I come off the throttle suddenly. With the standard heat range plug (L77J4/L3-G) then the plug is dry and chocolate brown. The latter is not necessarily a good sign if you're running full spark advance with pump 93 octane gas! I'd appreciate hearing from anyone with experience running XD-100 in the older motors. In any case, the engineer who build OMC motors through about 2000 recommends running double oil mixture in any motor turning high RPM (over 6000, let's say), and recommends sticking to TCW-3 Evinrude, Mercury, or Yamaha oil. I asked about Shell, popular in Germany, but he couldn't confirm that it's a good chlise. I used to use Castrol, Evinrude /Johnson and Mercury oil at 25/1 in our 1975-1985 era racing motors at 6500-7000 RPM. Anyone know how Castrol is today? Also, anyone know who made Evinrude/Johnson oil in ca. 1980? |
cooper1958nc
posted 02-05-2010 08:37 AM ET (US)
Manufacturers' claims notwithstanding no one has produced convincing evidence of significant differences among automotive or aeronautical oils in actual service or controlled tests. I am skeptical of all oil claims (I include the above author claiming a 20 degree temperature reduction with this or that brand for that reason. I suspect the Evinrude special oil thing is marketing bait to sell premium price oil. Unfortunately, there are few legitimate, disinterested, knowledgeable sources of information. |
srec1
posted 02-05-2010 10:22 PM ET (US)
I have a 1994 Evinrude ocean pro 150. I ran xd 100 last season after running one bottle in the previous season and noticed a significant reduction in smoke over the xd 50. This engine has 1700 hrs on it and has always been a real mosquito repeller. After last season and about 150 hrs, I removed the plugs to replace them as I always do at the end of the season. They were completely clean! No carbon on them whatsoever. They looked like I just put them in. I did not replace them as I usually do. Usually the plugs are completely fouled at that point in the season. I inspected the tops of the pistons through the spark plug hole and they were completely clean as though I had just done a decarb procedure. |
budana
posted 02-09-2010 10:31 PM ET (US)
so let get this straight i can run xd 100 in my '95 175 hp rude and it will smoke lessand my plugs wont be all fouled up. i needed to read /hear of this 5 yrs ago.thanks. |
srec1
posted 02-10-2010 10:52 AM ET (US)
budana, It will smoke less but it does not go away completely. You have to remember that with our carbed 2 strokes we are not burning all of the air fuel mixture like those new fangled 2 strokes do. But most of the blue haze is gone You will also notice that the residue surrounding the exhaust ports will be more of an oily nature rather than the black carbon that you are used to seeing. I forgot to mention that it also cleaned all the carbon off the prop and hub area. It is like I was running a heavy concentration sea foam all season. |
