Topic: Influence of Water Current on Engine Speed.
posted 09-17-2009 09:37 AM ET (US)
Assume a boat with a particular propeller and motor can reach an engine speed of 5,500-RPM in calm water with no current. If all other conditions remain unchanged, what would be the engine speed if the boat were operated in water in which there was a 2-MPH favorable current? And, conversely, what would be the engine speed in a 2-MPH adverse current? Assume the boat's course and the current are either in the same or opposite directions.
posted 09-17-2009 10:05 AM ET (US)
The engine speed would remain the same in all three conditions. However, boat speed over the ground would be approximately two MPH faster or slower with a two MPH current in your example.Butch |
Tom W Clark
posted 09-17-2009 10:23 AM ET (US)
The apparent wind will be different going up-stream vs. down-stream and that will influence the resistance of the air the boat is moving through and will affect the engine speed because the motor will be loaded differently depending on whether the boat is going with the wind or against it (or more likely against wind speed X MPH vs. against the wind X MPH plus 4 MPH.)But I am sure the difference would be so small as to unmeasurable with a conventional tachometer. |
conch
posted 09-17-2009 10:31 AM ET (US)
I have observed losing a few rpm running twin inboard engines with 1.5 reduction when climbing the backs of steep waves or running with/against the gulf stream.I didn't track vessel speed though. Chuck |
elaelap
posted 09-17-2009 11:52 AM ET (US)
This topic poses a question which resembles the beginning chapter of a popular treatise on the relativity theorem: it all depends upon an observer's point of view. Setting aside Tom's comment regarding the increase/decrease in apparent wind and its concomitant resistance, to the eyes and mind of the boat's operator and relative to the surface of the water, current will have no effect at all--the boat will seem to be moving over the water at its usual speed and its motor will be making its normal turns. To an observer on shore, however, the boat will appear to be going more slowly uphill and more swiftly down-current. This is sort of analogous to the different results which will be obtained by the boat's speedometer and its GPS, the first showing the boat's speed relative to the surface of the water and the latter showing the boat's speed over ground.The above comments are obvious to any experienced sailor, and have to do with a boat/motor moving at a sustained speed. What hasn't been discussed yet is the possible effect of current on acceleration. I would think that, as an airplane takes off more easily into the wind than downwind, a boat would accelerate up onto plane more easily and swiftly up-current than down. Tony |
jimp
posted 09-17-2009 12:48 PM ET (US)
Tony - Nope. Read your first para. The airplane on the runway is not in the same medium (surrounding environment in which something functions and thrives. Or, an intervening substance through which something else is transmitted or carried on.). The airplane is on the ground, not in the air. But airplanes "cheat", their wheels are on the ground while their wings are in the air. The boat is already in the water and dead in the water (not moving), so it makes no difference which way it goes, the acceleration will be the same - relative to the water. Similar to watching an airplane right after it has taken off. If take-off speed is 150 knots and it's taking off into a 75-knot wind, it can take-off while rolling at 75-knots into the wind because the wind is going over the wings at 150-knots. When the airplane gets airborne, it is traveling at 150-knots thru the air, but only at 75-knots over the ground. JimP |
newt
posted 09-17-2009 01:28 PM ET (US)
Tom nailed it. Ditto what he said. |
number9
posted 09-17-2009 02:13 PM ET (US)
Engine speed is the question.Running with the favorable current would produce an effective 2-MPH headwind giving increased wind resistance at the bow, slightly increase loading on the engine and possibly a small drop in RPM. Running against the adverse current the lesser effect of a 2-MPH tailwind at the stern is less likely to change or decrease loading on the engine or change in RPM. |
posted 09-17-2009 03:10 PM ET (US)
Regarding the apparent wind, you may assume the wind conditions are calm. When the boat moves, it creates an apparent wind.In the water with no current, if the boat moves forward at a speed s , it creates an apparent headwind of speed s . In the water with favorable current, the boat goes faster, so the apparent wind is of speed s + 2. In the water with adverse current, the boat goes slower, so the apparent wind is of speed s -2. If we consider the boat speed to be in the range of 40-MPH, then the apparent wind is in the range of 40 plus or minus 2 MPH. The apparent wind on the boat will affect the resistance of the boat to move, so it will affect the engine speed. We would then expect the engine speed to slightly lower in a favorable current because the apparent wind is higher, and slightly higher in an adverse current, because the apparent wind is lower. Did I get that right? |
jimp
posted 09-17-2009 03:24 PM ET (US)
So, when the boat is sitting DIW (dead in the water, even though she is moving over the bottom at 2 mph)), the relative wind is 2 mph (you feel it on your face), the apparent wind is 2 mph (you feel it on your face), and the true wind is 0 (because there is no wind except that created by the boat moving over the bottom). |
elaelap
posted 09-17-2009 03:29 PM ET (US)
Sure seems to me that a boat would get up onto plane more swiftly going against a 2 mph current than running with it. The minute power is applied from a dead stop going upstream the boat would have an apparent 2 mph speed boost, and vice versa, right jimp?Tony |
K Albus
posted 09-17-2009 03:41 PM ET (US)
Tony, you're wrong. It is the boat's speed relative to the water that gets the boat on plane. With the boat dead in the water, the boat's speed relative to the water is 0 mph. Regardless of which direction the boat takes off in, it will need to reach the same speed relative to the water in order to get up on plane. |
jimp
posted 09-17-2009 03:46 PM ET (US)
Tony - Nope. To the boat in the water - there is NO current. The boat is sitting there dead in the water. Nothing is moving between the boat and the water. BUT relative to the land (the bottom) both the water and the boat are moving (but the boat is still not moving in the water). So when you apply power to the engine, the boat is starting from sitting DIW in a body of water that it had no relative motion against. Looking at it from the beach is different. When the boat starts up stream against the current, she appears to get on a plane quickly - relative to the observer on the beach, she appears to cover a short distance of advance. When the boat starts down stream with the current, she appears to get on a plane slower - relative to the observer on the beach, she appears to cover a longer distance. But the time to plane and the distance to plane are both the same relative to the water and the boat. Not to the observer on the beach. It's all relative motion. A vector diagram using a universal plotting sheet would illustrate it nicely. JimP |
jimp
posted 09-17-2009 03:50 PM ET (US)
Tony - One more way to visualize. Pretend you're in the Gulf Stream, well offshore, out of sight of land. Now run your boat in all directions and see how long it takes to plane. With no other factors, it should take the same in all directions. Even though the Gulf Stream is moving at 1-2 knots. Relative motion can be a nasty thing. JimP |
K Albus
posted 09-17-2009 03:58 PM ET (US)
With regard to engine speed, I'm with Tom - I don't think there would be an accurately measurable difference in a typical pleasure boat. |
JMARTIN
posted 09-17-2009 04:44 PM ET (US)
I boat where there is quite of bit of current and the direction of the current changes in relationship to the boat a lot. I do not notice any change in engine speed, rpm, but it is amazing to see the difference in GPS speed and fuel economy when I go from bucking the current to going with the current. I do notice a change in rpm when hitting a tide rip, but it is momentary and the rpm will go back to where it was on exiting the rip.Being the jackass that I am at times, I will notice when my buddy is running the boat against the current and have him note the speed, 24 mph, and the mpg of 2.2. Then when we turn the corner around an island and I know that the current will change, I will take the wheel and show him how much better I am at running the boat because now it is going 27 mph and the fuel economy is 2.5 mpg. John |
elaelap
posted 09-17-2009 05:55 PM ET (US)
Hmmmm...Attempting one of those Einsteinian thought experiments (like trying to visualize what would happen in a weightless vacuum to a guy moving "downward" in an elevator), let's look at it this way: I'm tied to a dock facing upstream on a swiftly-moving river. Let's say the current is running against me at 10 knots. I start my motor, throw it into gear, and with a small forward touch on the controls I'm swiftly up on plane (my little 15 ft Whaler planes at 12 or 13 knots). On the other hand, facing down-current, still tied to the same dock on the same river with the same current flowing swiftly past my boat, seems to me that I'd first have to catch up to the current and then "pass" it at 12 or 13 knots to achieve plane. Mebbe not, but still... Tony |
elaelap
posted 09-17-2009 06:09 PM ET (US)
Thinking about what I just wrote, maybe jimp is correct. My example--with my boat tied to a dock--is analogous to his explanation about an airplane on the tarmac. If my boat were drifting with the current instead of tied up facing it, two knots of current or ten knots or whatever, facing upstream, when I applied power it would be like my boat was in stasis relative to the surface of the water, whichever way it was pointing, and it would need the same amount of power to get up onto plane up-current or down...I guess ;-)Tony P.S. Great thread, especially for those of us challenged by the physical universe! |
jimp
posted 09-17-2009 06:29 PM ET (US)
Tony - Facing upstream, your 15-ftr is going thru the water at 10-knots while still tied up (or the water is already going by the boat at 10-knots). Remember relative motion - this example only concerns your boat and the water she sits in. You have to advance the throttle to 10-knots to get a strain off your mooring lines - and you haven't moved, but the water has still moved by your boat at the rate of 10-knots. It's easy to advvance the throttle as the mooring lines are doing the first "10-knots of work". While facing downstream & still moored, you are "backing" into the current at 10-knots just sitting there. To get the boat going forward at 12-13 -knots thru the water you first have to overcomg going backwards at 10-knots. By the time your going 12-13 knots thru the water you'll be going 23-knots OVER THE BOTTOM. Maybe ground speed over the bottom (lets say you're using GPS) is confusing you compared to speed thru the water (your boat speedometer hooked to your pitot tube). Years ago I took a 180-ft Coast Guard buoy tender up the Umpqua River to Reedsport, Oregon against a 6-knot current coming down river due to heavy rains (all of the buoys were pulled underwater by the current and you could see the whirlpools/disturbances on the surface from the buoys just under the surface). When we got to the shipyard in Reedsport we slowed to 6-knots THRU THE WATER and stayed directly off the dock - not moving relative to the shipyard. To the people on the dock we weren't moving, yet the ship was making turns for 6-knots and going thru the water at 6-knots. JimP JimP |
elaelap
posted 09-17-2009 06:53 PM ET (US)
Even more to think about, jimp, and I think I've got it now. Thx, teach...Tony |
jimp
posted 09-17-2009 06:57 PM ET (US)
It's a tough concept. Years ago I had a CG Captain give me pretty much the same scenario but he wanted to know why the boat wasn't doing 23-knots to start with! JimP |
number9
posted 09-17-2009 07:14 PM ET (US)
This was a good/(bad?) mind teaser thrown at us. According to the Beaufort Wind Scale a 1-3 mph wind will produce ripples and could even affect the rpm deviation from 5,500 in both directions. Really the question is does increased apparent wind speed of two mph on the bow cause increased engine load and decrease of two mph lessen the load. +/- 4. Most of us would probably agree it is increased and decreased slightly, but is not discernible. I would like to hear Jim's explanation of how the results would differ in the same situation but when the boat is backing rather than going forward.
posted 09-17-2009 07:17 PM ET (US)
Good grief.This is how we make something easy become something difficult. Some of y'all have added issues not present in the initial post. Wind? Apparent wind? Acceleration? Where did these factors come from? Should we not add gravity to the issue? If we have current we could be going up or down in altitude in a river or a stream, or not. Too funny. Butch |
high sierra
posted 09-17-2009 10:55 PM ET (US)
Tony is right!!!!! |
posted 09-17-2009 11:47 PM ET (US)
To sum up, if I may, the effect of the current on engine speed will be zero, except via the mechanism of a very slight change in the apparent wind on the boat, which, somewhat opposite to the initial intuition, actually works in a manner opposite to the current. |
posted 09-18-2009 09:17 AM ET (US)
The corollary question, what is the influence of wind on engine speed, has already been considered in this discussion, but I think it bears examination separately.Wind appears to have a direct affect on engine speed. If the boat moves against the wind, the wind loading on the boat creates a force opposing the movement of the boat. This has the effect of increasing the load on the engine, which will reduce the engine speed. Thus a boat moving against the wind will find its engine speed reduces compared to a no-wind situation. If the boat moves with the wind, the wind assists the boat in moving, and the load on the engine decreases. Thus a boat moving with the wind will find its engine speed increases compared to the no-wind situation. The force of the wind is proportional to the velocity of the wind and the area of the boat on which the wind acts. It is also influenced by the shape of the area. You can describe the wind force as F = C x A x ρ x V2 where F = force C = a constant related to the shape of the boat A = frontal area of boat facing the wind ρ = density of air V = velocity of the wind The important factor is the velocity of the wind, whose influence is exponential. This means that as the wind speed increases, it effect grows more significant. At low speeds, such as the 2-MPH apparent wind we considered in the discussion of the current, the influence is much smaller. If the wind increases to 20-MPH, a tenfold increase in speed, the force that results will be one-hundred times greater! If the wind increases to 40-MPH, the force that results will be 400 times greater. The influence from the wind will be much more noticeable on engine speed when comparing engine speed on runs against the wind and runs with the wind. It is also important to note that the influence from wind is proportional to the frontal area. An increase in frontal area, such as occurs when a boat has put up its weather canvas, including a windshield, will increase the influence of the wind. I raised this topic for a particular purpose: to analyze the influence of wind and current on the engine speed at wide open throttle. As many know, I like to collect data about propeller performance. It is not always possible to test propellers in water which has no current or no wind. In testing propellers, an important parameter is the speed the engine can reach at wide open throttle with a particular propeller. I was curious how wind and current would affect engine speed. Based on this discussion, it seems that engine speed at wide open throttle should not be influence very much--if at all--by effects from current. However, engine speed is likely to be influenced by effects from wind. Tests made in water with current but calm winds may not need any allowance or correction for the maximum engine speed reached. Knowing this may allow some useful data to be collected. Of course, the best test method is to make runs in opposite directions, and average the results. |
posted 09-18-2009 07:20 PM ET (US)
We can use the formula above for the effect of wind on the boat to deduce how much the influence of wind might be at 2-MPH. The procedure is as follows:We operate a boat in conditions where a wind of known strength exists, and with a wind strength which we anticipate will affect the engine speed. For example, we operate the boat with a 15-MPH wind. We make runs both upwind and downwind. Let us assume a boat speed of 35-MPH is obtained. In the upwind case we have an apparent wind of 50-MPH. As we don't have actual data for a test like this, we can assume the variation in engine speed might be 600-RPM. If the engine speed is affected by 600-RPM when the apparent wind is a headwind 50-MPH, we can make a proportional analysis for the 2-MPH case. The RPM change at 2-MPH would be about 10-RPM. |
number9
posted 09-18-2009 08:25 PM ET (US)
[Not sure what the intent of this very short article was, but perhaps pointed out a typo. If so, thank you. While I was correcting that one, also fixed seven others--jimh] |
dfmcintyre
posted 09-18-2009 10:53 PM ET (US)
What if the wind, instead of going straight up the river or down the river, is going directly across the river? |
posted 09-19-2009 10:38 AM ET (US)
A cross wind could affect the calculation even more than a head or tail wind. Because a cross wind sets the course to the side it is necessary to "crab" in order to make a straight course. In a strong cross wind it would be necessary to crab the course by several degrees to maintain a steady course over the ground. The amount of the boats free board would be a factor as well as planing(sp?) attitude. IOW the more hull side exposed to the wind the greater the effect. The deeper the hull in the water the less the effect.If the pilot chose to allow the set and to maintain a constant compass course the distance traveled would be greater than if a straight course over the ground was maintained??? A few weeks ago I removed some paint from the skeg of my engine by maintaining a steady course directly toward a distant water tower in a wide body of water. Without realizing it the very strong incoming tide was setting me aside very quickly. Thank goodness for a working low water depth alarm. I am sometimes amazed at the stupid amateur mistakes I can make even after a lot of years of boating. Fatigue may be the most common factor. Butch |
posted 09-19-2009 11:17 AM ET (US)
I think the effects of the wind, current, and tide on the boat movement are widely known.This article tries to examine the effect of the current on the maximum speed the engine can reach. The effect of the wind on the engine speed was included as it became the means by which the water current influenced the engine speed. |
