posted 10-01-2009 01:17 AM ET (US)
Do you have trim tabs on your boat, if not you need them. (And trim them down all the way when you start, and then start backing off once you're up.)With six adults you added maybe 1000 lbs. And your dry wieght is 3800, so loaded with fuel, gear, and 6 persons you're ~4500 lbs.
You should get up on a plane eventually with the prop you have based on current performance you have given...
You could have a rough running engine and not know it. I have the same engine and aplha drive and found this out. I had 8 people in the boat and barely planed. The next day I went through the plugs and found one that was gummed up. (Replaced it, and had the 8 people in the boat, and just fine.)
And yes we need your prop info.
Tom - 5.7L typically are rated between 4400-4800 (250 hp). Alpha 1 typically are 1.62 reductions. So prop shaft speed is 2,962 RPM.
(And I assume he does not have an EFI, because it was not stated.)
