| Author | Topic: Calculating Engine Mounting Height Based On Set Back Distance |
| contender |
Is there a formula to figure out how high to set your outboard engine on an engine [set back] bracket. Example: Say your outboard sits one inch above the transom with no bracket. With a four inch bracket set back, how much higher do you raise the outboard? Half-inch, one inch? |
| ratherwhalering |
I recall the rule of thumb is 1-inch of height adjustment for every 12-inches of set-back, however I have observed that 1-inch height adjustment for +/- 6-inches of set back. This may be due to the lighter hull weight of Boston Whaler boats? |
| pcrussell50 |
This is an interesting topic, rich with complex physics for those inclined to discuss. But what the fastboaters do, and they are really into that stuff is to use a water pressure gauge and raise the motor until pressure juuust begns to drop off or become unstable. But to answer your question about rules of thumb, I've heard 10:1 thrown about as well. I consider this sufficiently close to 12:1 to be insignificant. Back to just a tidbit of theory, I bet the shape and pressure distribution on the planing surface has quite an influence on how high up you can place your motor. One more thing, as long as you're not running with the anti-cav plate submerged, expect your speed increases from raising your motor to be very much in the realm of "second-order" effects. IOW, 1, maybe 2 mph. -Peter |
| L H G |
This information from the Mercury Outboard Rigging manual should give you what you need: http://www.marinepartsman.com/installing-an-outboard-on-your-boat.html |
| pcrussell50 |
Relying on the Mercury guide will of course, provide an approximate solution, versus an exact solution using a water pressure gauge. But even the exact solution will only get. a mile an hour or so. So if the approximate solution gives say, half a mile per hour improvement, who cares? I forgot to mention that the "high-budget" fastboaters, can adjust engine height while under way, (while referencing their water pressure gauge), so they can always have optimum height no matter their speed and loading situation. -Peter |
| Tom W Clark |
There's a lot more to setting the motor height than a simple rule of thumb, but it's a good start. I tend to agree with Mercury's one inch up for every twelve inches back, but that is a ceteris paribus statement and it is conservative. Change the propeller and all bets are off. It also assumes the motor was at its optimal elevation when bolted directly to the transom. On a classic Whaler with the motor set to low, the net gain in elevation could be quite a bit more. The guidance of water pressure is a poor one on a boat like a Whaler. Performance will be lost long before water pressure is lost, so it's not a real concern. As in all things relating to outboard performance, experimentation is the key to optimization and an adjustable jack-plate does make that much easier. Peter's estimates of speed gain are very low. The difference between a 16-7" Whaler's speed with its motor set way too low on the transom with a mediocre propeller...and set at the optimal height on a jack plate with a really good prop could be as much as 5 or 6 MPH. |
| L H G |
Tom - Did you notice that all of Mercury's Mid-size engines, 75-125's, including the Big Foots, and longer than the standard 20", and are actually 21-11/16". This would apply to all 90 Mercs mounted on Montauks and 170's, 2-stroke, Optimax or 4-stroke. Hence they can and should be mounted even higher. |
| pcrussell50 |
I never said anything about changing props: My estimates for speed improvement from engine height are based on the following conditions: 1) same prop as before raising the motor If those conditions two conditions are satisfied, and you then install a 6" setback, and raise the motor half an inch, I would be stunned if that was worth 6 mph of top speed. As for the water pressure method, well? BW hulls are not padded v-hulls, where the water pressure method IS used to set engine height. I alluded to as much when I said that I suspected the pressure distribution on the planing surface had a significant influence. In deference to Tom, who should know, I guess the water pressure method is not applicable to BW hulls. -Peter |
| Tom W Clark |
Larry -- You are perpetuating another myth: that "shaft length" is the distance from the top of the motor bracket to the cavitation plate. "Shaft length" is simply the approximate transom height a given motor is designed to fit on. It is NOT the distance measured from the mounting bracket to the cavitation plate (AV plate). 20" shaft length motors will measure from 19" to 22-1/2" depending on brand and horsepower rating. |
| Tohsgib |
I have a 6" setback and am up 4.5" so you do the math. There is no rule of thumb and it really depends on the engine and prop. With an armstrong bracket the rule applies and hence why a 3' bracket allows you to run a 5" shorter shaft. Jackplates, different story. |
| Sal DiMercurio |
I'm with Nick on this one, as I'm running my 200 Evinrude 4.5" higher than my transom with only a 3" setback, [Bob's Machine Shop manual lift ]. If the 1" lift rule to 12" set back holds true, than my engine should be mounted 5 ft above the transom, not 5 inches. Also a good s/s performance prop, is going to allow your engine to be raised far more than a stock aluminum $100 prop. |
| pcrussell50 |
Hmmm... 1" up for every 12" back... You say that if you follow that rule, your motor would be five FEET up. Checking our 3rd grade arthmetic, then your setback is.... ... 60 FEET Color me skeptical. -Peter |
| contender |
Tohsgib; What size/brand engine?, Which whaler? Which bracket are you using? Thanks and thanks for all the answers from everyone... |
| Sal DiMercurio |
Oops, my engine should only be up approx 1/4" with my 2.5" setback according to Merc. Being my engine is very close to 5" above my transom, & only 2.5" back, than I need to extend my setback to very near 5 ft "BACK".....RIGHT ? You get the drift. Obviously the 1" lift to 12" setback doesn't hold true in all cases. Different hulls, & different props, "ALL" act differently to engine heights, & setbacks. Sal |
| Sal DiMercurio |
Skeptical, you need to check "your" 3rd grade math. That's 60" not feet. 60" = 5ft. Color me off white. |
| pcrussell50 |
Sal said: quote: And if the 1" lift to 12" setback holds true, you would only mount your engine 5 FEET above the transom if you could set it back 60 FEET from the transom. um... I think... what am I missing here? -Peter |
| Sal DiMercurio |
Pete, did you even read my second post ? In my 1st post I said up, instead of back. I corrected that in my 2nd post. Again, according to Mercury, my engine should be 58.5 inches farther back, in order for it to be 5" higher than my transom, with their recomendation of 1" up per 12" back. I don't think so. Your an airline pilot & you make a mistake of 60 ft instead of 60 inches ????? Pete, it's all in fun, just a little pun intended. Sal |
| pcrussell50 |
I missed the subtlety in your retraction, and continued on as if you hadn't. No worries, mate. -Peter |
I know folks love to redirect people away from CONTINUOUSWAVE, but you can find the same information originally from Mercury about engine mounting height right here:
| Tohsgib |
I ran this setup on 4 different boats, 17' Montauk with 70hp Suzuki 4S, 15' Sport with 70hp OMC 2S, 13' sport with a 40hp Evinrude 2S, 19' Revenge with a 175 OMC 2S and a 115 Suzuki 4S. |
| number9 |
[After failing to create a BLOCKQUOTE presentation by use of the QUOTE Tags, finally asked,] What am I doing wrong? |
| Tom W Clark |
You are not following simple instructions: |
| Tom W Clark |
While the thirdrd Grade Math Bee rages on and the subtleties of UBB Code remain elusive, let's get back to the subject at hand: Mounting height of motor relative to setback. The other important part of the equation that has not yet been discussed is speed. As boat speed increases, the increase in motor mounting height decreases. This may help explain why the 1:12 ratio is recommended by Mercury; it comes from early years of jack plates when they were more commonly used on high performance bats capable of reaching speeds well in excess of 50 MPH. It is important to understand what it trying to be achieved here. It is the height of the motor relative to the surface of the water that it runs through that is being adjusted with a jack plate. We talk about height relative to the keel because that is what is easily measurable, but is NOT the actual goal, just a rough gauge or reference point. A boat hull displaces water, even a high speed boat that planes along the surface of the water. Once a hull passes over a spot on the water, a "hole" is left behind that rapidly fills in after the hull has moved on. From the perspective of somebody riding in the boat looking over the transom, it appears the water is coming out from under the hull leaving a trough in its wake that fills in. As the water comes out from under the hull, its surface rises up the further behind the hull it is. The angle of the water's rise is dependent on boat speed. The faster the boat goes, the flatter this angle. The slower the boat goes, that sharper this angle. It seems reasonable to expect that a boat that goes 75 MPH will need to have its motor set back further to put the gearcase in precisely the right position relative to the surface of the water it passes through than a typical Boston Whaler which might cruise at 25 MPH. At the slower speed the angle of the water rising up from behind the hull is much greater so the motor can be set much higher relative to it total set back. |
| pcrussell50 |
Touche quote: -Peter |
| ratherwhalering |
Oh goodie, fluid dynamics! |
| contender |
Tom I understand what you stated and I understand what you are saying, I have looked over the transom and seen the water angle you are talking about. But what difference would it make then if the engine is on the transom, 4 inches back or 10 inches back if the jack plate is hydraulic and can be adjusted by the driver? Would not then the engine be able(by adjustment of the cylinder) to ride in the correct "groove" for the optimol performance. Higher speed you would raise the engine and slow speed the engine will be lowered. Thanks |
| number9 |
That's the advantage of a powered/hydraulic jack plate. Similar to the difference between manual tilt and PT/T. Depending upon desired performance and the range of the jack plate vertical movement should be the deciding factor for it'd installation height in most cases. |
| pcrussell50 |
In answer your very good and perceptive question, Richard, (I know you posed it to Tom): The consensus in the fastboat community seems to be that by having the weight of the engine further back, you can have more more hull "flying", or out of the water, while using less nose-up trim. An extreme example of this is those unlimited hydroplanes, where the sponsons are way forward, relative to the prop. A second order effect, that may be more "old wives tale" than anything else is the possibility that the prop is running in "cleaner" water when it's further back. Most of the "old salts" dismiss that one as overrated, however. -Peter |
| Sal DiMercurio |
I don't think the hyraulic jack plates would be benificial on Whalers. Bass boats yes. When you find the sweet spot [ manual lift,..... engine height ] for your Whaler, your going to be pretty darn close to maximum performance. Granted, Bass boats ride on a pad, so raising or lowering the engine while under way, will benifit that type of hull, but do little for a Whaler type of hull, once you have found the optimum height with the manual lift jack plate. The right prop is the one that is going to dictate your performance, & enhance the way your boat rides. Just my $.02 worth. Sal |
| Tom W Clark |
I'm not sure I understand Rick's question. For any given boat with a given motor at a given set back with a given prop at a given speed with a given operator's goals, there is going to be an optimal motor height. How you get the motor to that height is another discussion. An electro/hydraulic jack plate adjusts the motor height with a switch and can be done while underway. A manual jack plate adjusts the motor height with wrenches. That doesn't have anything to do with what the best height is. Remember, you need to find the best motor height for a given set back. You do not adjust the set back to match a given motor height. |
| contender |
Tom: My question would be does it matter then to have a bracket or not, other then just for the movement of the engine going up and down for performance does it help in any other way?, What about set back? Is it better just to be on the transom then or set it back 4 inches or 10 inches does it matter in the set back? Thanks |
| pcrussell50 |
My take on what Richard was trying to ask is, "as long as the nosecone is at the proper height with respect to the surface of the water, what does it matter how far set back it is?" Correct me Richard if this is not what you meant to ask. But even if it's not what you meant, then consider it my question. The fastboat guys gave me the answer I posted a posts up. I always like to run things through more than one filter. -Peter |
| contender |
Yes, Thanks Pete, this is what I trying to state, Thanks again |
| number9 |
[Again entered into this discussion but did not properly use the QUOTE tags. Your constant attempt to use the QUOTE tags notwithstanding, please stop trying to change the topic of this discussion to something about the reference material on this website. If you feel there is something inappropriate about the reference material on this website, please contact the webmaster--me--via email and I would be glad to discuss that topic with you.--jimh] |
| Tom W Clark |
Rick -- So your question really is: All other things held constant (ceteris paribus), what does set back do for you? Peter hits on some of them: allowing the prop to operate in smoother "cleaner" water, changing the center of gravity of the boat, but moving the motor back and up also raises the center of thrust relative to the hull. That can affect how a boat accelerates onto plane making the bow raise less. It can also mean a boat may draw less water and be operable in shallower water. It also means there may be more room in the splashwell. In extreme cases of a lot of set back, some guys are using their splashwells for additional storage, placing cooers back there. Because the power head is further away from the passengers, perceived motor noise may be reduced. I think that in the case of a classic 16'-7" Whaler with only 4" or 6" of set back, these benefits will be small or insignificant. By far the most common reason owners of small Whalers use jack plates is simply to accommodate a modern motor on a transom that may have once had non-BIA standard bolts holes drilled in it. I still maintain that in such cases it is less expensive, and less work to simply fill the two lower bolt holes and mount the new motor two holes up on the transom allowing the lower bolts to clear the splashwell. |
| number9 |
test [QUOTE]the QUOTE tags[QUOTE] |
| number9 |
Duh, sorry about that. quote: |
| contender |
Thanks Tom: I already purchased the 4 inch set back/bracket from CMC. And instead of filling the holes in on the transom I drilled 2 new ones in the bracket. This will still give me plenty of movement both ways, and if it does not work or I do no like it I can remove it and just bolt the engine back to the transom. I just wanted to try something new for me and the cost of the manual jackplate bracket was not that bad (I think around $170). I understand now what you are saying about the cleaner water and Pete made some good points as well. I'm still redoing the boat and I'm waiting for something from the welder (I'm kinda stuck right not and can do no more work until I get the parts form him) But so far I'm really happy how the boat is shaping up. The whaler look's really good right now and hope to post pictures when done. Thanks again for the insight to you and Peter and the rest... |
