| Author | Topic: 18 Outrage and Yamaha F115 |
| FISHNFF |
Yahoo! I found my new Baby! 1988 18 Outrage with bow, side, and stern rails. Time to retire my 1998 Alert/Montauk with Merc 90 4-stroke. Now my question. A little slow to plane. Get it going and hit 31knots and was bouncing off the rev limiter at 6100RPM! Now the question. What prop should I be running? The batteries and going into the console this week, and so are a set of Lencos. I read a 17" works well, but there was somef throttle left before hitting 6100.
BTW, we trolled a few hours for 2 halibut, 10 & 15 lbs.
| Phil T |
What is the mounting position of the engine on the transom? How many empty mounting holes are there above the top set of bolts?. Tony (aka elaelap) had the same engine and model and hit ~40 mph with a kicker and baitwell etc. I am thinking a 19k in a Yamaha propeller. Here is a long and technical thread from Tony on his prop selection/evaluation with comments from Tom Clark and other propeller veterans. http://continuouswave.com/ubb/Forum4/HTML/004093.html P.S. The search tool (under "New Topic" is FABULOUS! |
| FISHNFF |
Thanks much. just what I was looking for. FISHNFF |
| FISHNFF |
Sorry. Second hole up. One empty mounting hole above. Was considering moving it up one hole. The motor has a Doel-Fin, but I'm gonna remove it and try running. Then trim tabs. Then move batteries. Then...? When propping my Merc 90 4S on my 17 Alert/Montauk, I literally tried 7 different props. Don't want to do that again! FISHNFF |
| littleblue |
Nice! I would remove the doel-fins and put on the prop that Tony had and give it a whirl. You may not need the trim tabs. Then you can start working on rod holders, live bait tank, electronics, moving the batteries :) If you're not already, you should come to the nor cal rendezvous in a few weeks! Look in the "Rendezvous" section for details. It's on Sat, May 22. Maybe the fishermen can fish after the cruise and lunch. See ya out there. |
| FISHNFF |
Rod holders were the first change. 4 Lininger chrome/white and 4 Oerki Ss/chrome brass on the rails plus the 4 gunnel mounts. Have my Kodiak Pro Flow 17 from my other Whaler. Splashed the boat at Oyster for 2 halibut (10&15) for a couple hours with my kids. They love the forward shelter! FISHNFF |
| FISHNFF |
Oops. Perko, not Oerki! |
| elaelap |
Something weird goin' on here, FISHNFF. My motor came from the dealer with a 19" Yamaha black stainless steel prop, which I used for the first year. I reached 40 mph without trouble with that prop, but was only turning about 53-5400 wide open. Because I was told by folks I trust that Yamaha four stroke motors like to be run up toward the high end at WOT (6000 rpm for that sweet F115), I decided to go down a couple of inches. Tom Clark facilitated a trade, and I ended up with another Yamaha black stainless steel prop, this time a 17-incher (in fact, I don't even think they make a 16" black SS prop, or didn't back then). Top speed didn't change -- if I remember I was still up around forty statute miles per hour wide open -- but my turns increased to about 58-5900, and perhaps the boat was a little quicker on plane. My point: you should be getting at least into the high 30s with just about whatever prop you have on that rig, and if you're not, something's wrong. I'm going to use the search engine here and get some more reliable stats, BTW...at my age, better not trust my tired memory, but I'm pretty sure the info given above is close to correct. Tony |
| elaelap |
I don't know whether this will help, but here's a link to some data from my F115's computer chip given to me after the first year's 300 hour 'tune-up.' I had not yet changed the 19" prop. http://continuouswave.com/ubb/Forum1/HTML/009269.html As you can see, I spent two-thirds of my time trolling with that motor, and only a tiny amount at WOT, so I don't know how significant these data are. I'll dig around for something more relevant after a while. Tony |
| elaelap |
By the way, I did have my two batteries up under the console, and maybe a total of 100 lbs of salmon balls and downrigger weights in the bow locker and on the starboard side of my forward cooler seat. And right after I bought my boat and had it rigged with the new motor, Joe Kriz took a ride with me at a NorCal rendezvous and convinced me to raise the motor another hole, which improved the top end speed and eliminated the rooster tail I was dragging around behind my boat at high speeds. Just something to think about. Tony |
| FISHNFF |
Thanks for responding Tony. I followed your posts a lot. You basically sold me on the F115 for the 18 Outrage. OK. The prop is a Yamaha black SS stamped 16K. My one time running this impressions. I have my props off my Merc 90 4S to try out next when I get a new aft washer.
| Perry |
If that is how you plan on loading your boat maybe you should keep the current prop. If it was slow to plane with the 16 pitch prop then it is probably only going to become more sluggish with a 17 or 19 pitch prop. |
| FISHNFF |
As for accelleration, I think moving the batteries forward will help. No, I know so. I just put on a pair of Lenco 12x12 Edgemounts tonight. That will help tremendously. I've spent countless hours perfecting (for me) my 17 Alert/Montauk with a Merc 90 4S. I hope to carry over some knowledge from that, but this a different type of horse. Thanks all, especially Tony. FISHNFF |
| littleblue |
Does sound a bit weird to be so "torquey" but at the same time be slow to plane...based on the revs you were able to get, you are under propped. My 18' had twin 70hp Yamaha's which according to my performance numbers performed very similar to a single 115. I was only able to reach 52-5300 rpm when lightly loaded (5500 max). With two other guys, my Kodiak PF-17 filled (good choice in bait tank by the way haha), rods, fish, etc, I could only get upper 4000's. Still, I never really considered the boat to be "slow" to plane. Maybe 4-5 seconds w/ lots of weight on her. I guess we should know what "slow' means. 4 seconds? 7 seconds? I'm interested in your trim tabs/bait tank pick up. Please post some pictures when you get the chance. I will most likely be adding some tabs onto my 22 in the near future. I suppose you recommend the Lencos? |
| FISHNFF |
OK. Looked at the exhaust ports. They had some drill marks. I think if they were stock, the entire prop would be cast. Aftermarket? That may explain the high RPM. Since blade was not designed for vents, maybe it's causing it to lose it's bite? Any coments in a stiletto 4blade 16"? And that pump mount looks good. Just dropped the boat off to mechanic. Owner walks up and comments how trick it looks. Calls a couple other guys over. "who's idea was that?" FISHNFF |
| elaelap |
Here's another link, this time to my computer data report when I hit 700 hours, less than two years after buying (actually trading for) that F115: http://continuouswave.com/ubb/Forum4/HTML/004064.html Looks like I didn't go down in prop pitch 'til the end (when I sold the boat the motor had ~760 hours), and I only went down one inch. So much for my remembrance of things past...five years past, anyway. Hope some of this helps, FISHNFF. I bored folks silly with reports about that boat/motor combination -- oftentimes responding to "underpowered" criticism from those who had never experienced the rig -- and a local search will dredge up many threads (maybe too many) about my experiences with Cetaceous and her F115. Would I do it again? In an instant, for my kind of use. Perfect match. Tony |
| FISHNFF |
OK. I just ordered a Stiletto Bay Pro I in a 16" pitch. Trim tabs are mounted, and all wiring and battery repositioning will be done next week. Will report back with results. FISHNFF |
| FISHNFF |
Here is the link to the trim tab and pump pictures. http://smg.photobucket.com/albums/v214/FISHNFF/1989%2018%20Outrage%20trim%20tabs/ |
| littleblue |
Looks pretty cool. Wheres the pics of the rest of the boat?! |
| Tom W Clark |
The Yamaha K-series Painted Stainless Steel propeller model is available in a 16" pitch in addition to the 17" and the 19". It does not have vent holes but vent holes can easily be drilled in any prop. Most propeller models that do come with 1/4" vent holes have them drilled after the prop is cast. Propellers with vents like Mercury's PVS have the (much larger) vent holes cast into them. I would not expect a Yamaha Painted Stainless Steel propeller to need vent holes in this application. An Outrage 18 with a stern weight bias may benefit from a good stern lifting propeller. The Yamaha Painted Stainless Steel propeller model is a good stern lifter with its semi-cleaver design. I would have suggested you move the batteries forward and try a 17" Yamaha Painted Stainless Steel propeller but as you have the Stiletto Bay Pro coming, try it out and let us know how it does. |
| JohnJ |
I'm running a 17" Yami prop. Single battery in the console. The boat jumps right up on plane if I goose it. My top end it around 37mph at 5800rpms. 16" is just too small and doesn't have enough bite to get you on plane quickly. |
| FISHNFF |
OK. After all the wiring and battery moving and electrical mounting, I got the boat out today. Blew a steady 15-20 no matter where we went, and cold! 2'-3' whitecaps. Test The Lenco's were mounted and functional, but switch panel was not mounted, so hard to adjust. Ran in the most protected area (not by much) and was able to get the boat up to 34 knots at 5900 RPMs. Not the greatest test day, but for just a seat-of-your-pants feeling, the boat ran great. Planing was quick and smooth. It took some trimming to get the last few knots and few hundred RPM's on the top end. Next, the motor gets raised up another notch, from the second to the third. I may keep the Doel Fin. On my Montauk, it seems to keep the prop from blowing out. FISHNFF |
| littleblue |
We were out today for the Rendezvous, you should have joined us. I think you are wasting efficiency by having a doel-fin and trim tabs. Typically doel-fin's are cheap fixes when you don't want to spend the money for the tabs, I would get rid of it as it doesn't really serve much purpose. I would think that if you are running a stainless steel cupped prop and you are still losing bite, you should go back down one hole. |
| FISHNFF |
Yeah. I read about the rendezvous. Just had a few hours to soak some bait with my boys today. Blowing! Guys have a good time. I've run all my whalers with and without Doelfins. This one had it on when I bought it last month. On my 17, I have it up on the 3rd hole, and when on plane, the fin is clear of the water. Only in the water working at slower speeds. The boat would occasionally cavitate trimmed up and turning. With the fin, no problems. I'll try working with this boat, piece by piece. I've gathered tons of info from this site, especially Tony. Hoping for nicer weather. Rain in the weeks forcast agaIn.
| FISHNFF |
Had a couple hours to run the boat after getting motors tuned up. Ran the 17" Ballistic with 2 aboard, full fuel tank, 9.9 4S kicker. I'm a happy Whaler guy! I also dropped of my old 1998 Alert/Montauk at the dealer, and have had multiple offers by mid afternoon. Sad to see it go, but this Outrage is nice! This same prop on the 17 and Merc 90 did the same speed at a few hundred less revs, but higher gear ratio. These Ballistic props are nice!
